04-30-2018 08:21 AM - edited 03-17-2019 12:42 PM
Hello team,
I have configured the two CUBE boxes with redundancy group to preserve the active calls, both incoming and outgoing. The configuration works with a very minimum delay in the commutation of the Active to the passive box.
The drawback that arises is that the box that switches from Active to Passive is reset every time this happens. I have varied all the parameters and I continue with the inconvenience.
This is the following message that appears before the router restarts: *Apr 19 19:46:45: %RF-5-RF_RELOAD: Self reload. Reason: Reload due to DEL/SHUT on voice-b2bha RG/INTF
04-30-2018 02:12 PM
This is working as designed. The router has to reload to renegotiate HA .
04-30-2018 02:52 PM - edited 03-30-2023 09:25 AM
Thanks for your answer, is there another way to do redundacy?
I have an E1 pri and therefore I can not allow my ISR to restart.
04-30-2018 03:29 PM
What you have configured is the standard and recommended box to box redundancy. You should consider adding a similar E1 on the other gateway and then do E1 bundling on your provider side, so you can send and receive calls when one gateway is down
05-02-2018 06:23 AM
