02-20-2019 12:17 PM
I have a Cisco phone 8832 CUCM version 11.0.1.24900-2 the load file is sip8832.12-1-1-23 and the phone is not registering with Call Manager.
What else do i need to do?
02-20-2019 12:27 PM
Hi!
Can you confirm that you configure the endpoint at the CUCM as 8832 (confirm that this type exists on CUCM available devices)?
George
02-20-2019 12:32 PM
Yes i have confirmed that the 8832 is available.
02-20-2019 10:14 PM
02-21-2019 09:55 AM
1) Check if IP Phone is Getting Power SUpply YES
2) Check if IP Phone is getting IP and it is in correct VLAN. Correct VLAN but is not getting the IP address
3) Check if IP Phone is getting Option 150 i,e TFTP Address YES
4) Check if IP Phone is able to contact CUCM on TFTP Port and get the configuration file. NO
5) Check if IP Phone MAC and Model is configured properly in CUCM YES
02-21-2019 11:11 AM
Does the CUCM provides the DHCP service?
Can you assisgn statically an IP address to the phone to check if the problem gets resolved?
It looks like the phone does not receive an IP Address, consequently it cannot communicate with the CUCM to register.
George
02-22-2019 09:21 AM
Yes CUCM provides the DHCP
I did assign the static IP address to a phone and still nothing.
01-29-2020 10:41 AM
Same issue here. It keeps cycling through "Verify Your Network Connectivity" and "Network Unavailable."
