Issue with Voice Hunt-Groups-CME
ra_jeshkalra_2
My customer wants to form two groups.Incoming calls should ring parallely to all the members of 1st Hunt Group and should be be forwarded to the second group pilot point, where again all the members Phones should ring again.
The issue is sometimes , the call is nor forwarded to the second hunt group pilot point from the first hunt group, and produces a busy tone.
Following is my config:
voice hunt-group 1 parallel
final 601
list 387,386
timeout 20
pilot 600
voice hunt-group 2 parallel
list 393,320,334,336,337,379,306,392,318,301,308
timeout 20
pilot 602
ephone-dn  137
number 601
call-forward all 602
ephone-dn 88 dual-line
number 387
pickup-group 1
description Seet Lily
name Seet Lily
call-forward busy 398
call-forward noan 398 timeout 18
ephone-dn 89 dual-line
number 388
pickup-group 1
description Lim T. K.
name Lim T. K.
Note:The ephone-dn config of the members 393,320,334,336,337,379,306,392,318,301,308 is similar to that of 393,320,334,336,337,379,306,392,318,301,308.
Adam Thompson
Level 4
Level 4
Instead of having the final number of the first hunt group set to the extension of an ephone with that forwarded to the pilot of the second hunt pilot, have you tried something like this:
pilot 600
list 387,386
final 602
timeout 20
pilot 602
timeout 20
This should work. The only drawback is that you can not set the pilot of the first hunt-group (600) as the final number for any other hunt-group.
Adam
Please rate if helpful
DEAN LUE
Have you tried this command?
max-redirect 20
The default is max-redirect 10 under either telephony-service or call-manager-fallback.
Regards..
