Issues with Corporate Directory in Cisco IP Communicator 7.0.3
kkung
I configure already configure over 50 Cisco IP Communicator and 50 users in a CUCM 7.0.2 using BAT.
The issue is that 3 of the 50 CIPC doens´t display the corporate directory, I already try re-installing the CIPC having the same issue.
Any idea of what´s happening?
mkchandak
If this is happening only on a few specific machines, it could be a firewall on it. One thing to do would be to run problem reporting tool and check the trace files to see what is causing this to fail.
mkchandak
