jabber-config.xml file location
awrabek
I configured the UC jabber service in CUCM that caused some interference with jabber-config.xml on the TFTP server.
The jabber-config.xml file has been deleted from both TFTP servers, only the service profile in CUCM has the parameter configuration.
It works fine, all options and policies are applied to the clients.
However, I cant find the jabber-config.xml file. Where is it stored if the parameters are configured only in CUCM, not in jabber-config.xml file?
There is no actual configuration file in this case. All configuration is kept and maintained in the UI in CM.
Response Signature
