04-26-2015 04:15 AM - edited 03-17-2019 02:48 AM
I have been facing issue with J4W registration and display error "no connection to server". Following is the version detail:-
Version CUCM and IM&P---> (10.5.2)
On-Premises login
During analysis, i found 2 things in logs:-
1). Unable to download jabber-config.xml file (Download of TFTP File failed for server ) //// all the other xml files are succesfully downloaded which may indicate that there is an absence of jabber-config.xml file.
2). While signing into presence "OnLoginError: (data=0) LERR_JABBER_UNREACHABLE <16>: "
[rc\cert\common\BaseCertVerifier.cpp(250)] [csf.cert.] [cert::BaseCertVerifier::checkIdentity] - About to verify the Subject Alt Name.
[ls\src\cert\common\CertVerifier.cpp(154)] [csf.cert] [cert::CertVerifier::checkIdentifier] - Verifying identity '162.20.10.30'
[rc\cert\utils\AltNameParserImpl.cpp(349)] [csf.cert.utils] [cert::AltNameParserImpl::verify] - Looking for match with 162.20.10.30
[rc\cert\utils\AltNameParserImpl.cpp(400)] [csf.cert.utils] [cert::AltNameParserImpl::verify] - No Match Found
I tried to change the IP address to FQDN under System---> Server, but after that the connection is lost between CUCM and IM&P.
Attached is the log file and snapshot of IM&P.
- See more at: https://supportforums.cisco.com/discussion/12490406/jabber-windows-registration-issue#sthash.E2wXb4iJ.dpuf
04-26-2015 04:13 PM
To see if your Jabber file is available, check:
http://<ip address of CUCM TFTP server>:6970/jabber-config.xml
if you made changes to the jabber-config file, stop and start the TFTP service on the relevant server.
04-26-2015 10:16 PM
Hi Dennis,
I did checked to see manually "jabber-config.xml" but the page remain blank. And, no changes made to jabber-config.xml file
04-27-2015 03:42 PM
upload a new jabber-config.xml file if it is blank
05-04-2015 06:00 AM
Nishant,
Sorry for the late reply. You may well have resolved this by now, if you have can I suggest that you update the post with the resolution so others may benefit.
Looking at the logs, I can see that Jabber is trying to login to the IMP server below, but its returning server unreachable error.
Signing into Presence Server. Server: 162.20.10.30, login mode: ON_PREM, result: 0
[IMPStackCap::Login::OnLoginError] - ****************************************************************
[IMPStackCap::Login::OnLoginError] - OnLoginError: (data=0) LERR_JABBER_UNREACHABLE <16>:
We will need to look at the IMP logs to know what is going on. Let me know if you still need help with this.
