ā06-14-2016 04:11 AM - edited ā03-17-2019 07:14 AM
Hi ,
I have setup Intradoman and interdomain federation with Lync which seems to be fine.However I have an operational issue with Jabber that I wanted to see if it was standard or something was wrong.
Scenario.
1.Open Jabber
2.In search field type in a few letters of name.
3.A list of users appear ( all lync users appear offline).
4.Click on add contact next to Lync user.
5.Lync user appears as contact and status now available.
6.Search again and user displays in list and with status.
The issue is that you need to add the user in Jabber as a contact before you can see there status.Is that normal?
Mark
IMP 10.5(2)SU2, CCM 10.5(2)SU3, Jabber 11.6
ā06-14-2016 04:34 AM
ā06-22-2016 03:16 AM
If anyone is interested this is documented under CSCun08138
It's as designed which isn't ideal , if anyone has come up with a workaround would be interested to hear
