Jabber softphone is compatible for Windows 2016 server
vaisak
Hi Team,
I am unable to use jabber softphone in Windows 2016 server ,let me jabber is compatible for windows 2016 server.
If it is , please provide the link to download.
Ritesh Desai
@vaisak
Hi, I did not understood your sentence, can you re-clarify which Jabber phone you are using,
These are jabber different types of phones Cisco has;
1. Jabber for windows
2. Jabber Guest
3. Jabber for MAC
4. Jabber for IOS
5. Jabber for Android
Once you confirm which Jabber you are working and basis I can say whether its compatible or not?
BTW, I haven't seen any administrator OR user install Jabber on Windows Server OS.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Jaime Valencia
Jabber documentation already contains the HW and OS requirements, have you reviewed the documentation?
java
if this helps, please rate
