Bookmark
Subscribe
1524
analog phone not registering on VG224
RFC_2549
I have a problem with a VG224 because on the CUCM I added an analog phone to it in a door but it doesn't record it.
Initially the phone (with drectory number 100 for example) was attached to another VG224, so I copied the phone and the line on the new port of the new VG224, I reset the phone and the line but the phone appears (from CUCM) still be registered on the old VG224. What can I do? doing a sh run on the two VG224 configurations do not coincide with those of the CUCM, should they not update automatically when I change something on the CUCM?
Thank you
George Sotiropoulos
Please can you post part of the VG configuration?
George
Hope the above helps,
gsotirop
yes, the interested port is 2/13
Ystcapp supplementary-services
 port 2/12
fallback-dn 1347
so there aren't directory number specified for port 1/13
voice-port 2/13
timing hookflash-in 110 80
this is the conf of the voice port interested
Thank you!
Please also post the dial peer (stcapp) configuration.
Its likely the dial peer is still configured on the old VG224.
