IP Telephony and Phones
watch here Journey banner_1
Labels
This is a LDAP enabled system and I have checked the LDAP and it appears to be  syncing correctly.I have to use the locally defined administrator account to login.This was working, however, I am currently unable to login to my Inbox or the Cisco Unit...
Running CUCM 10.5 Looking to delete phones as we are charged for them however, would like the calls to continue going to voicemail even though phone is deleted. Thought calls would continue to flow as long as the directory number was in the system. A...
hello all, when i connect web page using ip phone 7965, the web page font have problem like this "[][]This[]is tes[]t web[]".how can i do for this problem? I don't know if it will help, but here's my configuration. ephone-template 3url-button 1 http:...
asdg by Level 1
  • 394 Views
  • 0 replies
Hi I'm new for cucm.Just got my be6k running and configure internal calls with users and phones. I can dial manually other phones but not through the coparate directory. The names are populated in the coparate directory but grayed out also it shows o...
zumriatha by Level 1
  • 632 Views
  • 1 replies
Hi there, Can someone please suggest what is the partnumber for the renewing the license "CUWL-PRO-K9", since this is EoL. Do i need to buy the replacement product itself, or do i have an option to upgrade/migrate. If so what is the partnumber Thanks...
sameeh.pp by Level 1
  • 522 Views
  • 2 replies
Hello All, I'm trying to register my Cisco cube router 3825 with the service provider. My cube is sending the register message with "expires: 0" even after receiving 200 OK. Are the below messages fine? As per the provider, the format is fine for th...
mailgunj by Level 1
  • 4646 Views
  • 11 replies
