11-03-2010 05:01 AM - edited 03-16-2019 01:42 AM
I am trying to incorporate call manger v4.3(2) with Unity Express 2.2.2, but evey time I run the initial setup wizard, I receive an error of "JTAPI login failed. Unsupported version of call manager detected", how can I fix this error?
Solved! Go to Solution.
11-03-2010 06:55 AM
Hi Michael,
This document does not show support for CUE 2.2 with CUCM 4.3(2). You would need ;
Cisco Unity Express Compatibility Matrix (Check Table #2)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
Hope this helps!
Rob
11-03-2010 06:55 AM
Hi Michael,
Hope this helps!
Rob
