ā11-09-2010 12:57 PM - edited ā03-16-2019 01:50 AM
We want to add a group of user from a different domain (XYZ.com) in our network to join the Cisco Call Manager. They are going to use the Cisco Phone system. The only issue that we have is the LDAP Authentication. It seems that we can only enter one LDAP Authentication for End Users. Currently it is using the ABC.com domain. We can see the users in both ABC and XYZ domain in the User Management in the CCM Admin (I guess because we can add more than 1 LDAP directory in CUCM) but it will not authenticate when the user from XYZ.com try to login to the CCM User Page.
CCM User Page is the user site access to modify their phone feature like speed dials, call forwarding, etc.
Is there any solution on the issue that we are experiencing? I have no idea on how to add another LDAP Authentication.
Thank you,
sienz
Solved! Go to Solution.
ā11-09-2010 01:37 PM
You can only add one authentication config.
Review this
In environments that employ a distributed AD topology with multiple domain controllers geographically distributed, authentication speed might be unacceptable. When the Domain Controller for the authentication agreement does not contain a user account, a search must occur for that user across other domain controllers. If this configuration applies, and login speed is unacceptable, it is possible to set the authentication configuration to use a Global Catalog Server.
An important restriction exists, however. Because a Global Catalog does not carry the Employee ID attribute, this method cannot be used if the Employee ID is used as the login. Only Domain Controllers may be used with this attribute.
To enable queries against the Global Catalog, simply configure the LDAP Server Information in the LDAP Authentication page to point to the IP address or host name of a Domain Controller that has the Global Catalog role enabled, and configure the LDAP port as 3268.
The use of Global Catalog for authentication becomes even more efficient if the users synchronized from Microsoft AD belong to multiple domains, because it allows Unified CM to authenticate users immediately without having to follow referrals. For these cases, point Unified CM to a Global Catalog server and set the LDAP User Search Base to the top of the root domain.
In the case of a Microsoft AD forest that encompasses multiple trees, some additional considerations apply. Because a single LDAP search base cannot cover multiple namespaces, Unified CM must use a different mechanism to authenticate users across these discontiguous namespaces.
As mentioned in the section on LDAP Synchronization, in order to support synchronization with an AD forest that has multiple trees, the UserPrincipalName (UPN) attribute must be used as the user ID within Unified CM. When the user ID is the UPN, the LDAP authentication configuration page within Unified CM Administration does not allow you to enter the LDAP Search Base field, but instead it displays the note, "LDAP user search base is formed using userid information."
In fact, the user search base is derived from the UPN suffix for each user, as shown in Figure 17-14. In this example, a Microsoft Active Directory forest consists of two trees, avvid.info and vse.lab. Because the same user name may appear in both trees, Unified CM has been configured to use the UPN to uniquely identify users in its database during the synchronization and authentication processes.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html#wp1045381
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Review this
java
ā01-09-2023 10:35 AM
hello,
Since we can only allow one LDAP authentication.
If we change LDAP Authentication in UCM from ABC domain to XYZ domain for testing and then change back to ABC.com
Is there anything we need to worry that willl break when we put it back to ABC.com ?
tks,
J
ā01-09-2023 11:23 AM
Youāre already asking this in another thread. Please do not create duplicates.
