LDAP Integration
mightyking
Level 6
Level 6
Hello Everyone,
We are planning to integrate our CUCM with the corporate AD and have some questions:
1) In our organization, the names contain some special characters such as é, ç, è etc...  Are there any specific consierations regarding those characters before the integration?
2)  What are the Fields/Atributes we need to take into consideration in AD for integration with CUCM?
3) Any recommendations for a smouth integration?
CUCM version : 10.5.2
MK
26 Replies 26
Robert Shaw
Level 3
Level 3
We have CUCM integrated with AD and have no problems with special characters in the name fields.  As long as they don't appear in the SAM account name you should be fine.
As for the field / attributes you need to consider, you may need to consider which users you want to pull in to the CUCM Directory.  For example we (like yourself I would imagine) have a number of users in our Active Directory that are system accounts and have no number assigned.  We also have some users that don't have office phone numbers that are controlled by CUCM for various reasons.
We took the decision to apply a filter that looks to the ipPhone field in AD, if the user account has something in their it is pulled through to the CUCM directory.  If not, it doesn't sync.  This is the filter we use,
(&(objectCategory=user)(objectClass=user)(ipPhone=*))
It does mean before the integration you will need to manually populate this field to get the user to sync to CUCM.  Then every new user after the initial sync will need to have the ipPhone field completed.
As for smooth integration, that depends on how you system looks now and what you want it to look like when you have completed the Sync.  If this is a green deployment then nothing to worry about.  However if this is an existing deployment with local users a lot of manual effort (BAT can come in handy) will be required to map the sync'ed user accounts to Device Profiles, if you are using Extension Mobility.
Let me know if you need anything else.
Rob
Thanks Rob,
This is very helpful.
Would you happen to have any détails about how to map the synced user account to Device Profile for EM users? This is an existing environement.
Sorry only just noticed this comment.
You would need to use BAT to join up the Device Profile and User Account.  I'll presume you haven't used BAT before so apologies if you already know the basics.
Basically BAT works with an Excel template bat.xlt which can be found by searching "bat" in the "upload / download files" menu option on the BAT Menu.  In the Excel template there is an Update Users tab.  Here you can specify the UserID that needs to be updated, enter the Default Profile and set the Primary Extension.  Use the buttons on the right hand side to convert the sheet to a CSV and upload this CSV to your Call Manager using the Upload / Download Files menu.
In the BAT menu go to Users > Update Users > Custom file and select the file you just uploaded.  Call manager will then go through your CSV and pair up the Device Profiles with the User Accounts that have been synced through LDAP.
Of course the process of getting the UserIDs and Device Profiles into the Spreadsheet is the hardest part.  How difficult this will be will depend on your Active Directory SAMAccount names vs your current username naming convention within Call Manager.
You could try exporting the information from Call Manager first before the initial LDAP sync and then tie up the old CUCM usernames with the new AD usernames.  Perform the initial LDAP Sync and then run your BAT tool.
A more detailed guide for the BAT tool can be found here.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/9_1_1/CUCM_BK_C271A69D_00_cucm-bulk-administration-guide-91.html
Rob
Thank you Rob,
In the first reply you mentioned,
and in the last reply
I am kind of confiused, Are we going to use SAMAccount names? If yes, how are we going to deal with special characters?
MK
Sorry for the confusion.  The second comment about SAMAccount names was not related to special characters.  The SAMAccount name in AD is used to migrate the user accounts across to CUCM, CUCM will use the SAMAccount name from AD as the End User userid for Extension Mobility.
I don't know how your naming convention for current userid's in CUCM compare to the SAMAccount name in your AD environment.  I was trying to explain that you when you export your list of current users from CUCM the userid's will map to a Device Profile.  You need to replace those userid's with the SAMAccount names from AD.  If they were different, that may be a challenge.
I would imagine that you are using the same userid's as the user has in AD which is easy.  Export the User List to Excel.  Delete all Local Users in CUCM.  Import all User Accounts from AD with an initial sync and map the End Users to Device Profiles using the previously exported data.
Hope this clears it up, if not please let me know.
Rob
Thanks Rob,
We are going to go through this CUCM and AD integration in couple of weeks. If you don't mind I will update this post as we go through and ask for your help if needed. Hope it's OK with you.
Many thanks,
MK
Would you happen to have a step-by-step document that you can share with me?
MK
Hi MK,
No guide unfortunately.  All the information you need will be in the CUCM Admin guide to take you through the setup of LDAP, pre-requisites etc.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmcfg/CUCM_BK_C95ABA82_00_admin-guide-100.html
Like I say the hardest part is using BAT to reassign your EM Device Profiles to the new LDAP accounts.  Have a play with BAT first on a couple of test users to see what it does and what you need to do for the rest of the users.
The first step, is setting up your LDAP sync.  If users don't have the IP Phone field completed in the Telephones tab of the user accounts in AD, you can put the filter in place that I discussed earlier and you will have control of what gets pulled across.  You can then use a couple of test users to play with and then migrate users over a batch at a time.
Feel free to update this post at anytime, I will do my best to help you, if I'm not available I'm sure you will get a response from someone on here.
Rob
Hi Robert,
Hope you're doing well.
I need your help for the issue I have with CUCM-LDAP integration.
The issue is that when I use the telephone number, I am able to sync the LDAP with CUCM but fail when using sAMAcountName. Could you please see if I am doing anything wrong? I have another post on this issue but not getting any answer. I thought you may be able to help me out.
https://supportforums.cisco.com/t5/ip-telephony/ldap-amp-cucm-integration/td-p/3376779/page/2
Please find attached the screenshots that I have uploaded for the other post.
MK
Hi there
Just curious, in the screenshot I can see the same user as Local and Inactive User. Do you want the user-id of the user in phone number  or normal user id (text)?
Reason I asked is , I just did the testing in my lab with both sAMAcountName and Telephone Number.
Worked in both cases.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Were you able to sync tajkarb using sAMAcountName attribute? For some reason, I am able to sync with TelephoneNumber but not with sAMAcountName!
 As you can see in the attached file, I have a LDAP user called tajkarb2 and I also have the same user in the CUCM but not able to sync it with sAMAcountName. As soon as, I modify the sAMAcountName to TelephoneNumber the sync works but it creats another entery in the CUCM database where the user ID is the extension. What I want is to be able to overwirte the existing user in the CUCM datebase with the information coming from LDAP.
MK
Hi there
Yes, I am able to sync using both sAMAcountName and telephoneNumber.
Why do you need the same user as Local user if you are syncing with LDAP ?
Hope this Helps
Cheers
Rath!
Oops. Got it. You have 2 users. Let me check
Hi there
Just got confused..
You have two users tajkarb & tajkarb2...Right!
tajkarb2 - is a Local User
tajkarb - is an AD user
When you set sAMAcountName you are NOT able to sync tajkarb, whereas with telephoneNumber you are.
At this time tajkarb2 is in the CUCM as a Local User
Is my understanding correct ?
One question. Was tajkarb2 was a AD user at an point of time.
Hope this Helps
Cheers
Rath!
