Line Group Issues
drbabbers
Level 3
Level 3
All,
Here is the scenario:
PSTN----->CUBE----->CUCM----->HP----->HL----->LG----->User A, B, C, D
  • 1st call comes in all OK and is delivered to User A
  • 2nd call comes in and only rings User A! (Busy Trigger is 2 - but is needed in general so can't be changed)
  • The LG is set to 'Broadcast' and ring next member if no answer
  • Users B, C, D are all logged into the Hunt Group from the Phone
  • Also the 'Log out on no answer option' is disabled on the Line Group
The traces for this are quite a challenge, so to save me some time... has anyone seen this before?
Thanks guys.
7 Replies 7
-##Use circular hunting
Thanks Muhammed. Can you please explain why this change should be made? Is this a known issue to you with Broadcast?
Also when I lab this, I can't replicate the issue... it works everytime in fact with Broadcast! :/
Aeby Vinod
Level 3
Level 3
Based on your description the behavior looks buggy, what the CUCM ver? Also does the issue seem to go away when you remove the line group members and reassign them ?
Please rate if you find this helpful.
Aeby
Aeby
Hi Aeby,
CUCM 11.5.
Funny enough if you delete the DN from the Jabber phone and then reassign, the problem goes away for a while! Then comes back..
drbabbers
Level 3
Level 3
Ok the plot thickens...
  1. This ONLY happens when there are 2 or more concurrent calls coming into the Hunt Pilot.
  2. The 1st call is answered by Agent A and the 2nd call goes straight on hold on the User A phone!
Visually it looks like Cisco Jabber is answering 2 calls at the same time! Any ideas?
that's interesting, do you by any chance have auto answer enabled on the user A phone, if not would it be possible to grab the callmanager trace for an event?
Please rate if found helpful
Aeby
Aeby
Auto Answer is disabled on the DN for the User A phone.
I am just checking the version of Cisco Jabber also to see if any known bugs.
Traces maybe tricky to obtain... Watch this space for the moment.
