List of Downloaded Files
mrmhar1408
Level 4
Level 4
Hi Guys,
I am looking to list all the upgrade files downloaded to the call manager or to the unity connection
Anyone has an idea how to list them ?
2 Accepted Solutions
Hi.
You always need to upload it again via ftp or sftp.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi ,
After u download the files from Cisco site, u can verify the MD5 checksum before uploading to Call Manager and compare.
As said by Carlo, u need to use sftp software to upload the files in call manager cluster.
at the end, you Restart the tftp service .
regds,
aman
9 Replies 9
Aman Soi
You can use the command file list tftp * from CLI of CUCM.
regds,
aman
Hi.
Also show version active through CLI should show all installed software.
Carlo
mrmhar1408
Level 4
Level 4
Thanks Guys for the response, but i downloaded the files using FTP not TFTP and there is no file list FTP
i need that because sometimes i get error in installation and i need to re-install the same file without download it again.
file list activelog installed_options here are the istalled files
Carlo
Great Carlo. I could see the downloaded file
the question now, How i can re-install the software using the downloaded file ?
Hi.
Unfortunately this is not an option :(
What you can do is download files from cucm and use them again via FTP/SFTP.
To get files use
file get activelog installed_options/fileyouneed
Carlo
dear,
i don't want to get it, I need to start install the file in case i get error in the installation and i want to try again
Hi.
Carlo
Hi ,
regds,
aman
