Listen to conversation in a call center
Simon Robert
Hi and thanks for your help!
I would like to know if this is possible to listen to a talk between a customer and a employe directly from a phone that is own by a supervisor?
I have seen this:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/UC6-0-1/features_apps/CMmonrec.html
witch is a method to do the above , but it require a program on a PC or it record the line.
What we would like is to listen to the line that is in use by a agent inside the organisation by a phone like you would do on an analog phone went there is 2 phones and by the simple way of grabbing it you could be able to listen to the conversation.
The client is using a Cisco UC520 Phone with SPA 500 series phones.
thanks alot.
Hi Simon,
That's a feature mostly use by Call Center but CME has feature called Barge to be able to force a conference between two phone but both phones need to have a share line.
The best way is to use UCCX (Contac Center Express), it  has a feature called Silent Monitor to be able to listen calls from agents:
Silent Monitoring. CSD allows a supervisor to silently monitor agent calls. It can be configured whether the agents are aware or unaware that they are being monitored.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_9_02/design/guide/UCCX_BK_C39FDB35_00_cisco-unified-contact-center-express/UCCX_BK_C39FDB35_00_cisco-unified-contact-center-express_chapter_01.html
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Another way is to use 3rd party apps that provide Silent Monitoring, Barge and Whisper features. Check this - http://aurus5.com/phoneup/priority
So as I understand I need a 3rt party software in all case.
Correct?
I can't do it with the phone already in place.
Thanks!
Without a 3rd party app, the only option is Barge and cBarge, and that means you would need to have a shared line on your phone for everyone you want to monitor, and it won't be silent monitoring, you'll be creating a conference.
java
if this helps, please rate
