locating a unity voicemail alternate extension
clsnyder10
I am trying to locate an extension which is an alternate extension in unity but do not know the primary extension to the box. Is there a way to locate the alternate without clicking on every box and then clicking on alternate extension? thanks
6 Replies 6
Chris Deren
You can run the following SQL query against the UnityDb database:
select dbo.Subscriber.Alias from dbo.Subscriber, dbo.DtmfAccessId
where DtmfAccessId = 'XXXX'and ParentObjectId = SubscriberObjectId;
where XXXX is the alternate extension. This will return the corresponding alias.
HTH,
Chris
Thanks for the info, it was very helpful.
Rob,
Again great job with research, but these ways force you to still look through the output, my query returns the alias immediately, so I guess you save couple of minutes :-)
Chris
Hey Chris,
Happy Holidays buddy! This does look like an excellent method. Anything that saves time and narrows these searches down is a great thing in my books. +5 points for this Chris.
Cheers!
Rob
Thanks to everyone that responded to the question, the info was extremely helpful.
