Location Device Pool Setting or Phone Location Setting
j-lehmann
Level 4
Level 4
Hi all,
We create a device Pool Hamburg and Set the Location to a configured Location Hamburg. We add a Phone and assinge the Device Pool Hamburg to the new Phone. On the Phone itself is a default Location Setting hub None. Have we Set also here the Location Hamburg ?
Thx Joerg
2 Accepted Solutions
Chris Deren
I normally do as that is a required field, however I belive that if you leave it as hub_none it will be overwritten with the location defined on the DP, if you assigned anything else that would have been the selected location.
Chris
Ayodeji Okanlawon
No, you dont have to. When the location on the phone is Hub_None, then the location settings on the device pool takes effect..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Chris Deren
Chris
Ayodeji Okanlawon
j-lehmann
Level 4
Level 4
your are both right. In additional i foun in the forum also the information how to check the bandwith use via rtmt.
RTMT go to System --> Performance ---> Select the server---> Cisco Locations ---> Choose the locations you want ---> Bandwidth Available
Thx for help
