06-18-2013 01:12 AM - edited 03-16-2019 05:56 PM
hi,
I have a requirement for locking IP Phone when a user leaves desk or something. though I have extension mobility implemented but it is becoming difficult everytime to put PIN/PWD, so are there any other option which can be used?
Thanks in advance.
Regards.
06-18-2013 01:15 AM
Start mentioning system type and version you're using.
06-18-2013 01:17 AM
I am using CUCM 8.5
06-18-2013 01:18 AM
There are third-party applications that yoiu can search about.
06-18-2013 01:20 AM
Hi Gautam,
You need to go for third party application .
http://www.andtek.com/communications-products-lockout.html
regds,
aman
10-21-2013 04:51 AM
Pls checkount the below link
