Lost Extension in Unity
daleshew517
I'm trying to create a mailbox user in my Unity database and I'm getting the "user with extension already exists in the Partition" error.  I have searched users with the Primary and Alternate Extensions option checked.  I have searched the Call Handlers, Directory Handlers, and Interview Handlers as well but I'm not finding anything.  As far as I know, that only leaves  Message Waiting Indicators.  Does anyone know of a way to search or dump those or is there another area I might have missed?  I am running version 11.5.1.10000-6.
Thanks for any help offered.
Dale
davidn#
Hi Dale,
Please follow these steps to find the lost extension:
-- Search user
-- change  the “Limit search to” box to “partition”
-- Change the radio button to “Display Primary and Alternate Extensions in Selected Partition”
-- Change search criteria to “Find users where Extension contains <the alternate extension you’re looking for>”
-- Click “Find”
The result is the user id where your alternate extension is presently (mis)configured.
HTH.
David
davidn#
Hi Dale,
-- Search user
-- Click “Find”
HTH.
David
