Low Virtual Memory
tamimicisco
Hey,
I am facing problem with  "Available virtual memory below configured threshold . Configured low threshold is 30 %
tomcat#1"
in CUCM 10.5 .I restarted the Cisco Tomcat service but still showing up  the same error in RTMT.Is it a BUG ?
Tamimi
6 Replies 6
Mohammed Khan
Hi Tamimi,
Do you see the same result after Cisco Tomcat Service. Are you look at same error for old timestamp ?
Check the output from CUCM CLI.
show process load memory
HTH,
Mohammed Noor
Hey Mohammed,
thank you for your reply
admin:show process load memory
top - 14:31:41 up 65 days, 50 min,  1 user,  load average: 0.45, 0.29, 0.22
Tasks: 238 total,   1 running, 234 sleeping,   3 stopped,   0 zombie
Cpu(s):  7.6%us,  4.7%sy,  0.0%ni, 87.5%id,  0.1%wa,  0.0%hi,  0.1%si,  0.0%st
Mem:   3925708k total,  3817580k used,   108128k free,    35812k buffers
Swap:  2064280k total,  1171188k used,   893092k free,   708212k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
29702 UCMADMIN  30  10 1194m  95m  13m S 23.3  2.5   0:04.22 java
 7170 ccmservi  20   0  346m  32m  15m S  7.8  0.8   1404:06 RisDC
 6015 certbase  20   0  158m 6116 5512 S  1.9  0.2  31:19.99 tvs
 6953 certbase  20   0  695m  60m 3828 S  1.9  1.6 118:42.58 certSync
 7564 ccmbase   20   0  437m 152m  27m S  1.9  4.0   1753:33 ccm
 7680 ccmservi  20   0  707m  99m 3992 S  1.9  2.6 200:22.85 rtmtreporter
 9679 ccmservi  20   0 98280  644  572 S  1.9  0.0   3:05.99 sshd
21050 ccmservi  20   0  145m  57m   9m S  1.9  1.5   1:55.59 CTIManager
32510 UCMADMIN  30  10 15032 1312  896 R  1.9  0.0   0:00.01 top
    1 root      20   0 19364 1432 1128 S  0.0  0.0  10:23.19 init
Hi Tamimi,
From the output i dont see tomcat using memory but i see "java" process is using "1194m"  which is not  normal. Can you take a cluster reboot in a MW or kill java process alone see if this VM Alert continous.
HTH,
Mohammed Noor
Hi Mohammed,
I already tried kill the process and restart the CUCM but no luck,However in RTMT its showing tomcat#1 not java please check the attachment
Tamimi
attach the output of the following
Outputs from CLI: 'show status', 'show process using-most cpu,’ show process using-most memory', 'show process load' ,'utils diagnose test'
HTH,
Mohammed Noor
How did you fix this problem? I have the same issue after CM 10.5 upgrade restarting the Tomcat didn't fix it before I reboot the cluster want to check with you first.
Thanks.
