05-23-2012 09:34 AM - edited 03-16-2019 11:18 AM
HI,
I am looking for some assistance intergrating LYNC and CUCM 8.6.2. I want to confirm my application and diretory rules specifically.
I am not sure what else I need as a rule than what I have listed below.
I have numbers in AD in Plus E.164 format, so for example, +14085551212.
My numbers in Call Manager are 4 digit example 5555
I am looking for assistance with application and Directory dial rules.
From what I understand my application rules should be :
begins with +1408555
number of digits 12
total to be removed 8
I am alos looking for assitance with Directory rules, For example extension is 5555
From what I understand my directory rules should be :
number begins with 55
number of digits 4
prefix +1408555
I also understand there should be an application dial rule to dial externally
begins with +
nuber of digits 12
total to be removed 1
Randall
05-23-2012 09:44 AM
Randall,
Are you using CUCI-Lync?
Have you read this section:
in
Chris
05-23-2012 09:48 AM
Hi Chris,
I did reference that section formmy rules.
I want to confirm a rule if someone an external number?
Randall
05-23-2012 11:01 AM
You can use dial rule for outbound dialing but you could simply build a Route Pattern that mathes /+ dialing, i.e.
/+.1[2-9]XX[2-9]XXXXXX, strip PreDot, prefix off-net access code if you are using one
Your Rule does not prefix access code, if you are using it you may want to add it.
Chris
05-23-2012 11:10 AM
So my application dial rules, taking in consiferation dialing 9 for an access code and + dial.
example for lond distance dialing with access code 9
number begins with 9
number of digits 12
total digits to be removed 1
prefix 9
this would hit a route pattern 9.1[2-9]xx[2-9]xxxxxx
Randall
05-23-2012 11:17 AM
You do not need dial rules for something that is already matched via Route pattern. Dial rules are only needed when application formatting i.e. CUCI-Lync seeing AD telephoneNumbers does not match any routes in CUCM. For example user uses click to dial for an external number which is formatted as +12125551234, but CUCM does not have any routes starting with +, you can use application dial rule that will perform the modification. If the number is already formatted as 912125551234 and you have route pattern 9.1[2-9]xx[2-9]xxxxxx the rule is then unnecessary.
HTH, please rate all useful posts!
Chris
05-23-2012 11:37 AM
Chris,
Thanks I'll try it and let you know.
It will may take til tomorrow.
Randall
