09-22-2022 09:49 PM
Hi Guys!
I am new with CUCM (ver. 12.5.1.13900-152) and I am trying to configure Cisco DX650 (manager) to forward all incoming calls to CP-7821 (secretary). The issue that I am facing now is that the secretary can't transfer back the forwarded call to the manager. I've searched through the forums and saw that there is a way to configure the override from the service parameters but I can't see that option on my CUCM system. Are there any other ways to do this?
Thanks in advance!
Paul
Solved! Go to Solution.
09-22-2022 11:29 PM - edited 09-23-2022 04:22 AM
09-22-2022 10:05 PM
The option is to change a parameter as you yourself has found out. I’m not in front of a CM at the moment, so I can’t provide you with a screenshot of the parameter to change. If nobody beats me to the punch on this I’ll pass it along when I get to work later this morning.
09-22-2022 10:36 PM
Thanks and noted ^^
09-22-2022 10:42 PM - edited 09-22-2022 10:43 PM
Did some searching on Google, this is what you would need to do in CM. Enable Destination Override for Call Forwarding
09-22-2022 11:02 PM
09-22-2022 11:08 PM
This is what you're looking for.
09-22-2022 11:27 PM
I checked in both a CM 12.5 and 14, the document has the section name wrong. It is named Clusterwide Parameters (Feature - Forward), not Clusterwide Parameters (Feature - Hold Reversion). That said the values of the parameter as such is correct in the document, so if you search in Service Parameter for anything named CFA you'll find it.
It is under the Cisco CallManager part.
09-24-2022 01:08 AM
Hi Roger,
That worked out nicely! Thank you so much!
Paul
