Max e164-pattern-map Patterns Supported
Cory M.
Frequent Visitor
Frequent Visitor
Is there a max number of patterns supported on a single e164-pattern-map configuration within the IOS?
I know 5000 entries are allowed to be referenced in a txt document to reference on a txt file in flash, but would like to know what the limit is if defined in the configuraton itself.
Running a ASR1001X on Version 16.6.2.
I just asked the TME supporting CUBE. The answer is 1000 e164 entries are supported in the configuration or 5000 in the text file.
5 Replies 5
Is that 1000 patterns in each Pattern-map or 1000 e164 patterns in total in all my Pattern-Maps?
Example: 1000 total
voice class e164-pattern-map 100
e164 XXXXXXXXXX$   (500 of these)
voice class e164-pattern-map 200
Example: 2000 total
e164 XXXXXXXXXX$   (1000 of these)
The limit is per e164-pattern-map.
I have a text file in production with over 13,000 entries. The text file is not stored in the flash though; referencing from a server location.
