05-31-2018 07:00 AM - edited 03-17-2019 12:56 PM
i have cluster over wan with 5 nodes.
3 in one location other 2 in different location.
some devices are register with one of 3 node and some with other one of 2 node.
ANN,CFB,MTP,MOH streaming resources are only available of nodes with which devices are registered i.e 2 server.
remaining 3 streaming resources are showing zero available streaming resources of ANN,CFB,MTP,MOH.
see pic in which it shows 2 nodes are showing CFB resources and 3 showing zero resources.
ip media streaming app is started on all nodes.all media resources are registered according to device pool.
restarted ipVMS app multiple time but no use.
call manager version 11.0.1.21900-11.
Need Help
05-31-2018 07:25 AM
Hi there
Could you try the below commands in CUCM CLI and verify.
show perf query class "Cisco SW Conference Bridge Device"
show perf query class "Cisco HW Conference Bridge Device"
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
05-31-2018 09:41 AM
06-01-2018 08:13 AM
Quick question
Can you see the resources are registered under MRG in CUCM
Hope this Helps
Cheers
Rath!
06-01-2018 05:56 PM
Yes media resources of all 5 nodes are registered with cucm.
Only issue is 2 servers media resources are providing but 3 are showing no resources at all.
See pic for reference
06-03-2018 06:55 PM
Is it possible that the Run flag in the IP Voice Media Streaming App Service service parameters have turned some of the components off? If not, what happens when you restart the IPVMSA service on the non-working nodes?
06-04-2018 02:05 AM
No Every thing in Run flag is TRUE.
also when i restarted IPVMS ,it is showing normal process as other services .
it normally starts nothing abnormal.
