Media Resources (MTP, CONF, XCODE) TCP_CONN_ERROR
stavropouloss
Hello community,
Does anyone know if it is possible to use a Tunnel interface as a source for the media resourcesregistration to UCM 7.1(5)? I know that it is not possible with vrf interfaces for example. Apparently that is the case for Tunnel interfaces but i'm not sure. Here is the config:
interface Tunnel10
bandwidth 512
ip address 192.168.10.75 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nhrp authentication arco_vpn
ip nhrp map 192.168.10.100 x.y.z.195
ip nhrp map multicast x.y.z.195
ip nhrp network-id 99
ip nhrp holdtime 300
ip nhrp nhs 192.168.10.100
ip virtual-reassembly
ip tcp adjust-mss 1360
delay 1000
qos pre-classify
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 100000
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.10.75
sccp local Tunnel10
sccp ccm 10.50.2.4 identifier 2 version 7.0
sccp ccm 10.50.2.3 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface Tunnel10
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 1 register YANBU_CONF
associate profile 2 register YANBU_XCODE
associate profile 3 register YANBU_MTP
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 4
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
XYZ#sh sccp
SCCP Admin State: UP
Gateway Local Interface: Tunnel10
        IPv4 Address: 192.168.10.75
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.50.2.4, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 2
                Trustpoint: N/A
Call Manager: 10.50.2.3, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: CONNECT_PENDING, Profile Identifier: 2
Reported Max Streams: 8, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
TCP Link Status: CONNECT_PENDING, Profile Identifier: 1
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
TLS : ENABLED
MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
TCP Link Status: CONNECT_PENDING, Profile Identifier: 3
Reported Max Streams: 4, Reported Max OOS Streams: 0
TLS : ENABLED
testeven
No, you can't use a tunnel interface to register media resources as SCCP is not aware of that type of interfce just as with the VRF.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Yes it seems that Tunnel interface cannot be used with SCCP. I'm searching for a document now to show to my client. If you have found it in the past or know that this statement exists in any document please share . Until now I've found this: http://goo.gl/d0Mqz : "Interface type that the SCCP application uses to register with Cisco CallManager. The type can be an interface address or a virtual-interface address such as Ethernet." :/
If I find something more specific I'll post it.
