MGCP Controlled Gateway Call Drops
sarwarm123
I am trying to configure MGCP controlled gateway but experiencing a call drop issue. A gateway has BRI card installed, when I try to make a call it rings but as soon as I receive call it just drop. I gathered some debug logs (Debug ISDNQ931). I have replaced DSP but still no luck.
When I ring first time after restart Gateway
Oct 31 16:04:23.730: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x01
2951-rtr1#
Oct 31 16:04:32.423: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2183, '7776137568'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '306892'
                Plan:ISDN, Type:Unknown
Oct 31 16:04:32.435: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
Willenhall-2951-rtr1#
Oct 31 16:04:32.463: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8  callref = 0x81
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Oct 31 16:04:34.487: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8  callref = 0x81
Oct 31 16:04:34.511: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
       Cause i = 0x80AF - Resource unavailable, unspecified
Oct 31 16:04:34.539: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x01
Oct 31 16:04:34.551: ISDN BR0/1/0 Q931: TX -> STATUS pd = 8  callref = 0x81
       Cause i = 0x80E2 - Message not compatible with call state or not implemented
        Call State i = 0x0B
Oct 31 16:04:34.703: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
Oct 31 16:04:34.707: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
When I ring second time, it just beep and give this error message
Oct 31 16:05:40.233: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
Oct 31 16:05:44.225: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
Oct 31 16:05:48.194: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
        Cause i = 0x82E6 - Recovery on timer expiry
Oct 31 16:05:48.198: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
       Cause i = 0x80D1 - Invalid call reference value
17 Replies 17
Two more SDI log files attached
I have looked at the trace and I can see that the gateway is sending error code 510 to CUCM during the CRCX phase of the negotiation..
11/08/2012 18:09:32.286 CCM|MGCPHandler received msg from: 10.88.48.3
510 7337 fx: setting cannot be supported
|<:STANDALONECLUSTER><:10.102.243.13><:2><:10.88.48.3><:><:SIGNIFICANT><:2000>
11/08/2012 18:09:32.286 CCM|MGCPHandler received RESP header w/ transId= 7337|<:STANDALONECLUSTER><:10.102.243.13><:2><:10.88.48.3><:><:DETAILED><:2000>
11/08/2012 18:09:32.286 CCM|<:STANDALONECLUSTER><:10.102.243.13><:2><:MGCPENDPOINT><:>BRI/S0/SU1/P1/1@BellGreen-2851-rtr1.cwss.nhs.uk><:BRI><:ALL><:FFFF>
11/08/2012 18:09:32.286 CCM|MGCPHandler received RESP header w/ transId= 7337 FOUND a match with ERROR RETURN CODE|<:STANDALONECLUSTER><:10.102.243.13><:2><:10.88.48.3><:BRI><:SIGNIFICANT><:2000>
11/08/2012 18:09:32.286 CCM|MGCP Protocol Error - VERB:CRCX, transId: 7337, return_code: 510
Can you send me your sh run and also please enable the ff debug
debug mgcp packet
then do a test..pleae send the debug
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Thanks Aokanlawon, I'll be out all day today. But will upload sh run and mgcp debug output tomorrow. Thank you very much once again to being looking at this issue
