MGCP fxr-package
Gordon Ross
Level 9
Level 9
What exactly does mgcp fxr-package do on an MGCP gateway?
I've seen mention that it's needed when using T.38, but we're not using T.38 for faxes.
GTG
Please rate all helpful posts.
5 Replies 5
George Thomas
Level 10
Level 10
Yes, FXR package is used for T38 fax negotitation. If you are not using T38 capabilities, its not required.
Please rate useful posts.
islam.kamal
Level 10
Level 10
The configuration for a GW that does T38 , you can use FXR as the below:-
no ccm-manager fax protocol cisco
no mgcp fax t38 inhibit
mgcp package-capability fxr-package
mgcp default-package fxr-package
mgcp fax t38 nsf 000000
no mgcp fax t38 ecm
Please find the below link:-
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080bf23f2.shtml
Thank you
please rate all useful information
Thanks, but I actually want the opposite: I do NOT want to use T.38.
GTG
This is up to you , if you need to use passthrough. This will be better as the below:-
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711ulaw
Thank you
please rate alluseful information
FYI , please also find the below:-
Configuring T 38 for MGCP gateway
mgcp fax t38 ecm
mgcp fax t38 gateway force
Configuring Fax passthrough for MGCP gateway
Configuring Fax relay for MGCP gateway
no mgcp fax t38 gateway force
Thank you
