Showing results forĀ
Search instead forĀ
Did you mean:Ā
MGCP FXS ports requires a license in CUCM9
Muhammad Awais Khan
Hello!
I am connecting Some analoge phones to VG350 FXS ports which is  configured as a MGCP Gateway in CUCM. I beleive MGCP did not requires any license for it. Can some confirm this ? is there any Cisco doc on it ?
Thanks & Regards,
6 Replies 6
I don't have a doc confirming this but I have a VG220 running on CUCM BE6000 ver 9.0 and I did not need any aditional licenses.
The licenses is only for the users depending on what type of licensing you make use of the CUWL.
Best Regards
Sambit Khuas
Please check if this helps:
https://supportforums.cisco.com/thread/2218302
hi,
u would be requiring UCL essential license.
regds,
aman
Ok, what about if we make it H323/SIP GW. How the user licenses can be tracked ?
If you make it an H323 gateway, then I dont think you would be registering any phones to the CUCM. All you need to do is to configure dial-peers to route the calls. So I dont think you would need any licenses then.
Sam
Hi Sambit,
Technically u are correct but legally I think u would be requiring license.
even the ordering guide says Analog devices are supported with Essential USer license  and must be purchased through UCL.
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/finalcopy.pdf
regds,
aman
