03-18-2009 12:27 PM - edited 03-15-2019 04:56 PM
Hello, I have a 2851 with a EVM-HD-8FXS/DID card configured as a MGCP gateway in a CCM 5.1 cluster environment. All ports appear as registered except the first one which appears as rejected. The config is the same than the others ports. I have reloaded the gateway the problem has not been solved. I'm going to reload the CCM (but I have to do it out of hours) to see if it solves the problem. Any idea?
Best regards.
03-18-2009 01:49 PM
I don't think rebooting CCM will resolve the issue. Try to reset the faulty port using "shutdown" and "no shutdown" command under the voice-port. If it doesn't help, unplug the faulty FXS cable and plug it back again.
Make sure you have "service MGCPAPP" configured under dial-peer
ccm-manager mgcp
ccm-manager config server
ccm-manager config
mgcp
mgcp call-agent
mgcp dtmf-relay voip codec all mode out-of-band
Try to reset the mgcp by using "no mgcp" and then "mgcp":
router(config)#no mgcp
router(config)#mgcp
MK
03-18-2009 02:53 PM
Thank you for your response. I have tried to reset the port without success. I cannot unplug the cable because I am not phisically in the office where the gateway is installed. The config of MGCP in the gateway is correct (there are seven ports working and one not working in a EVM card). I have try to reset MGCP in the gateway ("no mgcp" and "mgcp"), and I have obtained the same result. Now in RTMT I can see the status reason: DatabaseConfigurationError (before that it showed CallManagerReset).
voice-port 2/0/0
cptone ES
voice-port 2/0/1
cptone ES
voice-port 2/0/2
cptone ES
voice-port 2/0/3
cptone ES
voice-port 2/0/4
cptone ES
voice-port 2/0/5
cptone ES
voice-port 2/0/6
cptone ES
voice-port 2/0/7
cptone ES
ccm-manager redundant-host 10.1.80.5
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.50.80.6
ccm-manager config
mgcp
mgcp call-agent 10.50.80.6 2427 service-type mgcp version 0.
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 999200 pots
service mgcpapp
port 2/0/0
dial-peer voice 999201 pots
service mgcpapp
port 2/0/1
dial-peer voice 999202 pots
service mgcpapp
port 2/0/2
dial-peer voice 999203 pots
service mgcpapp
port 2/0/3
dial-peer voice 999204 pots
service mgcpapp
port 2/0/4
dial-peer voice 999205 pots
service mgcpapp
port 2/0/5
dial-peer voice 999206 pots
service mgcpapp
port 2/0/6
dial-peer voice 999207 pots
service mgcpapp
port 2/0/7
2/0/0 does not work, 2/0/1-7 work perfectly.
03-18-2009 06:20 PM
post this:
debug mgcp packet
voice-p 2/0/0
shut
no shut
-nick
03-19-2009 06:08 AM
I have done what you say. This is the result:
Mar 19 13:05:17.972: %LINK-3-UPDOWN: Interface Foreign Exchange Station 2/0/0, changed state to Administrative Shutdown
Mar 19 13:05:20.544: MGCP Packet sent to 10.50.80.6:2427--->
NTFY 364027802 *@GW2851Sevilla MGCP 0.1
X: 0
O:
Mar 19 13:05:20.548: MGCP Packet received from 10.50.80.6:2427--->
200 364027802
Mar 19 13:05:21.696: %LINK-3-UPDOWN: Interface Foreign Exchange Station 2/0/0, changed state to up
(10.112.0.1)
Mar 19 13:05:35.544: MGCP Packet sent to 10.50.80.6:2427--->
NTFY 364027803 *@GW2851Sevilla MGCP 0.1
X: 0
O:
Mar 19 13:05:35.548: MGCP Packet received from 10.50.80.6:2427--->
200 364027803
Regards.
03-19-2009 12:08 PM
Try this for a failed call - this is normal operation. Not very interesting :(
