MGCP GW port is not registering in CUCM
Humza Khan
E1---MGCP---CUCM
MGCP gateway is registered with cucm but E1 port is not showing registered.
MGCP connections are none in debug packets are sending and receive.
mgcp endpoints showing up.
Help required.
HK
Jaime Valencia
This is the Video Over IP community, might want to move this over to IP Telephony.
java
if this helps, please rate
Deepak Rawat
Can you please make sure that you are entering the correct Domain Name while adding the MGCP gateway on CUCM that you are getting in the output of show ccm-manager
Refer below to review your configuration again:
http://www.cisco.com/c/en/us/support/docs/voice/media-gateway-control-protocol-mgcp/23966-mgcp-pri-cm.html
Deepak
We need a few more things. Please post a "sh run" as well as a screenshot of the gateway page in CUCM.
A few pointers you can check in the meantime while you post the info:
1. Ensure you have "service mgcp" under the pri-group timeslots configuration. i.e:
controller T1 3/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
2. Ensure you have ccm l3 binding under the serial interface of the PRI.
nterface Serial3/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn protocol-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
3. Check the "domain name" matches on the gateway page in CUCM and the router.
4. Do a reset on the gateway page and the "no mgcp" "mgcp" on the router.
99% of the time if you follow those 4 steps above it will work, assuming the rest of the mgcp config is correct.
FG
