MGCP QSIG integration with Seimens PBX - Bad Frame
Sean McQuade
Level 5
Level 5
Hi guys,
I have CUCM 9.1.2 and a 2901 MGCP gateway with a VWIC3-1MFT-T1E1-E1 card and am trying to integrate this with a Seimens PBX.
I have been following this guide to help with the config
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/818160.pdf
Originally this guide says to leave the framing as CRC but the layer 1 of ISDN status was showing shutdown and the show controller was showing "Transmitter is sending TS16 LOMF Alarm. Receiver has loss of multi-frame in TS16". I changed the E1 controller to use NO-CRC which brought the interface up:
Seimens-QSIG#sho isdn status
Global ISDN Switchtype = primary-qsig
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-qsig
         **** Slave side configuration ****
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 12
    Total Allocated ISDN CCBs = 0
However, when I do a Q931 debug, all I see is "BAD FRAME" constantly on the screen.
Seimens-QSIG# debug isdn q931
debug isdn q931 is        ON.
Seimens-QSIG#BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME
I've truncated the output above, there are hundreds of "BAD FRAME" errors within a few seconds of turning on debug.
I did a bit of searching which suggested I should set the gateway as the network side so I entered isdn protocol-emulate network, this changed the ISDN status output, but still get the same BAD FRAME errors:
        ******* Network side configuration *******
         **** Master side configuration ****
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 26, Ces = 255, SAPI = 3, State = TEI_ASSIGNED
    Layer 3 Status:
        NLCB:Calls are Held because of T309= 90.000 seconds
    Number of L2 Discards = 0, L2 Session ID = 19
I don't really know much about the Seimens side and am working with a third party engineer for that. Is there anything else I can check on the Cisco side, or anything I should specifically ask the Seimens engineer to set / check? MGCP config below:
version 15.2
hostname Seimens-QSIG
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
network-clock-participate wic 0
ip cef
no ipv6 cef
isdn switch-type primary-qsig
voice-card 0
license udi pid CISCO2901/K9 sn FCZ1742C0HE
hw-module pvdm 0/0
username sean privilege 15 secret 4 pE.7GSI2cp0tG0yXTvyzX7lmpd5OGqGF5A.SqepvAKY
username administrator privilege 15 secret 4 GD2.qFvF/5OsxtzaP4Bq9YqD8ls3ot4ox5Y/hwuNOA6
redundancy
controller E1 0/0/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-31 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.3.240 255.255.255.0
duplex full
speed 100
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip default-gateway 192.168.3.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.3.1
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
cptone GB
ccm-manager redundant-host 192.168.60.44
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.3.126
ccm-manager config
mgcp
mgcp call-agent 192.168.3.126 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
gatekeeper
shutdown
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
Thanks for the help
Sean
2 Accepted Solutions
hi
first try to identify which side must provide the clock.
can you provide outputs from
show controllers e1
debug isdn q931 is not usefull here, instead you should enable debug isdn q921.
coaxial cables connected to balun can be crossed , did you try to change tx by rx?
regards
As you can see from the optput, there are 3845 Line code violation
Total Data (last 24 hours)
     3845 Line Code Violations, 16 Path Code Violations,
     11 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins,
     53 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 50 Unavail Secs
Please make sure the line coding is same on both Cisco and Siemens sides.
Also i would suggest to replace the cable..
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
8 Replies 8
Aman Soi
Hi Sean,
You have to be on Slave side   while Seimens to be Master/Network.
Ask the Siemens Engr. to check for Time Slots Mapping.
Lastly,take the clock from Siemens EPABX.So, on the your E1 contoller change clock source to LINE.
alos, configure network-clock-select 1 E1 0/0/0 on router
regds,
aman
Hi Aman - thanks for your help. I have made the changes on the router and rebooted it, but still get the bad frame error:
version 15.2
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
ip cef
no ipv6 cef
voice-card 0
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
framing NO-CRC4
no ip address
shutdown
duplex full
speed 100
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
no ip http server
control-plane
voice-port 0/0/0:15
cptone GB
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
gatekeeper
shutdown
line con 0
login local
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
transport input all
end
Hi Sean,
Did u try to check the pin out of cables ?
Are us using 1,2 and 4,5 pairs.?
regds,
aman
Hi Aman,
I'm not sure. The connection to the Seimens is presented as a BNC and is going to a balon like this one
I am then using a plan Cat5E cable to connect to the E1 port on the router. Do I need to use a different cable for this?
Sean
Hi Sean,
what is the make of this BALUN?
can be searched on net or vendor can confirm the pin details?
if any manual, that can also help.
regds,
aman
hi
show controllers e1
regards
Thanks guys. Unfortunately, I'm not onsite at the moment so can't check the make of the balun or reverse the coax cables. I will try this next time I am there. In the meantime, the outputs from the router are below:
debug isdn q921 is        ON.
Seimens-QSIG#
*Dec 19 11:21:04.550: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E35EF)
*Dec 19 11:21:04.558: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E37EF)
*Dec 19 11:21:04.566: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E39EF)
*Dec 19 11:21:04.574: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3BEF)
*Dec 19 11:21:04.582: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3DEF)
*Dec 19 11:21:04.590: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3FEF)
*Dec 19 11:21:04.598: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E03EF)
*Dec 19 11:21:04.606: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E05EF)
*Dec 19 11:21:04.614: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E07EF)
*Dec 19 11:21:04.622: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E09EF)
*Dec 19 11:21:04.622: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
*Dec 19 11:21:04.622: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 19 11:21:04.630: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0BEF)
*Dec 19 11:21:04.638: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0DEF)
*Dec 19 11:21:04.646: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0FEF)
*Dec 19 11:21:04.654: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E11EF)
*Dec 19 11:21:04.662: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E13EF)
*Dec 19 11:21:04.670: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E15EF)
*Dec 19 11:21:04.678: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E17EF)
*Dec 19 11:21:04.686: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E19EF)
*Dec 19 11:21:04.694: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1BEF)
*Dec 19 11:21:04.702: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1DEF)
*Dec 19 11:21:04.710: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1FEF)
*Dec 19 11:21:04.718: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E23EF)
*Dec 19 11:21:04.726: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E25EF)
*Dec 19 11:21:04.734: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E27EF)
*Dec 19 11:21:04.742: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E29EF)
*Dec 19 11:21:04.750: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2BEF)
*Dec 19 11:21:04.758: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2DEF)
*Dec 19 11:21:04.766: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2FEF)
*Dec 19 11:21:04.774: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E31EF)
*Dec 19 11:21:04.782: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E33EF)
*Dec 19 11:21:04.790: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E35EF)
*Dec 19 11:21:04.798: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E37EF)
*Dec 19 11:21:04.806: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E39EF)
*Dec 19 11:21:04.814: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3BEF)
*Dec 19 11:21:04.822: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3DEF)
*Dec 19 11:21:04.830: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3FEF)
*Dec 19 11:21:04.838: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E03EF)
*Dec 19 11:21:04.846: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E05EF)
*Dec 19 11:21:04.854: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E07EF)
*Dec 19 11:21:04.862: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E09EF)
*Dec 19 11:21:04.870: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0BEF)
*Dec 19 11:21:04.878: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0DEF)
*Dec 19 11:21:04.886: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0FEF)
*Dec 19 11:21:04.894: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E11EF)
*Dec 19 11:21:04.902: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E13EF)
*Dec 19 11:21:04.910: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E15EF)
*Dec 19 11:21:04.918: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E17EF)
*Dec 19 11:21:04.926: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E19EF)
*Dec 19 11:21:04.934: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1BEF)
*Dec 19 11:21:04.942: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1DEF)
*Dec 19 11:21:04.950: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1FEF)
*Dec 19 11:21:04.958: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E23EF)
*Dec 19 11:21:04.966: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E25EF)
*Dec 19 11:21:04.974: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E27EF)
*Dec 19 11:21:04.982: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E29EF)
*Dec 19 11:21:04.990: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2BEF)
*Dec 19 11:21:04.998: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2DEF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2FEF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E31EF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E33EF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E35EF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E37EF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E39EF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3BEF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3DEF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3FEF)
*Dec 19 11:21:05.082: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E03EF)
*Dec 19 11:21:05.086: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E05EF)
*Dec 19 11:21:05.118: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E07EF)
*Dec 19 11:21:05.118: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E09EF)
*Dec 19 11:21:05.118: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0BEF)
*Dec 19 11:21:05.118: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0DEF)
*Dec 19 11:21:05.126: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0FEF)
*Dec 19 11:21:05.134: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E11EF)
*Dec 19 11:21:05.142: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E13EF)
*Dec 19 11:21:05.150: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E15EF)
*Dec 19 11:21:05.158: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E17EF)
*Dec 19 11:21:05.166: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E19EF)
*Dec 19 11:21:05.174: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1BEF)
*Dec 19 11:21:05.182: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1DEF)
*Dec 19 11:21:05.190: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1FEF)
*Dec 19 11:21:05.198: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E23EF)
*Dec 19 11:21:05.206: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E25EF)
*Dec 19 11:21:05.214: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E27EF)
*Dec 19 11:21:05.222: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E29EF)
*Dec 19 11:21:05.230: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2BEF)
*Dec 19 11:21:05.238: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2DEF)
*Dec 19 11:21:05.246: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2FEF)
*Dec 19 11:21:05.254: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E31EF)
*Dec 19 11:21:05.262: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E33EF)
*Dec 19 11:21:05.270: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E35EF)
*Dec 19 11:21:05.278: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E37EF)
*Dec 19 11:21:05.286: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E39EF)
*Dec 19 11:21:05.294: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3BEF)
*Dec 19 11:21:05.302: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3DEF)
*Dec 19 11:21:05.310: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3FEF)
*Dec 19 11:21:05.318: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E03EF)
*Dec 19 11:21:05.326: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E05EF)
*Dec 19 11:21:05.334: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E07EF)
*Dec 19 11:21:05.342: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E09EF)
*Dec 19 11:21:05.350: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0BEF)
*Dec 19 11:21:05.358: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0DEF)
*Dec 19 11:21:05.366: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0FEF)
*Dec 19 11:21:05.374: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E11EF)
*Dec 19 11:21:05.382: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E13EF)
*Dec 19 11:21:05.390: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E15EF)
*Dec 19 11:21:05.398: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E17EF)
*Dec 19 11:21:05.406: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E19EF)
*Dec 19 11:21:05.414: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1BEF)
*Dec 19 11:21:05.422: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1DEF)
*Dec 19 11:21:05.430: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1FEF)
*Dec 19 11:21:05.438: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E23EF)
*Dec 19 11:21:05.446: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E25EF)
*Dec 19 11:21:05.454: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E27EF)
*Dec 19 11:21:05.462: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E29EF)
*Dec 19 11:21:05.470: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2BEF)
*Dec 19 11:21:05.478: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2DEF)
*Dec 19 11:21:05.486: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2FEF)
*Dec 19 11:21:05.494: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E31EF)
*Dec 19 11:21:05.502: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E33EF)
*Dec 19 11:21:05.510: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E35EF)
*Dec 19 11:21:05.518: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E37EF)
*Dec 19 11:21:05.526: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E39EF)
*Dec 19 11:21:05.534: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3BEF)
*Dec 19 11:21:05.542: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3DEF)
*Dec 19 11:21:05.550: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3FEF)
*Dec 19 11:21:05.558: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E03EF)
*Dec 19 11:21:05.566: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E05EF)
*Dec 19 11:21:05.574: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E07EF)
*Dec 19 11:21:05.582: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E09EF)
*Dec 19 11:21:05.590: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0BEF)
*Dec 19 11:21:05.598: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0DEF)
*Dec 19 11:21:05.606: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0FEF)
*Dec 19 11:21:05.614: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E11EF)
*Dec 19 11:21:05.622: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Dec 19 11:21:05.622: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E13EF)
*Dec 19 11:21:05.630: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E15EF)
*Dec 19 11:21:05.638: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E17EF)
*Dec 19 11:21:05.646: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E19EF)
*Dec 19 11:21:05.654: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1BEF)
*Dec 19 11:21:05.662: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1DEF)
*Dec 19 11:21:05.670: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E1FEF)
*Dec 19 11:21:05.678: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E23EF)
*Dec 19 11:21:05.686: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E25EF)
*Dec 19 11:21:05.694: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E27EF)
*Dec 19 11:21:05.702: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E29EF)
*Dec 19 11:21:05.710: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2BEF)
*Dec 19 11:21:05.718: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2DEF)
*Dec 19 11:21:05.726: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E2FEF)
*Dec 19 11:21:05.734: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E31EF)
*Dec 19 11:21:05.742: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E33EF)
*Dec 19 11:21:05.750: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E35EF)
*Dec 19 11:21:05.758: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E37EF)
*Dec 19 11:21:05.766: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E39EF)
*Dec 19 11:21:05.774: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3BEF)
*Dec 19 11:21:05.782: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3DEF)
*Dec 19 11:21:05.790: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E3FEF)
*Dec 19 11:21:05.798: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E03EF)
*Dec 19 11:21:05.806: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E05EF)
*Dec 19 11:21:05.814: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E07EF)
*Dec 19 11:21:05.822: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E09EF)
*Dec 19 11:21:05.830: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0BEF)
*Dec 19 11:21:05.838: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0DEF)
*Dec 19 11:21:05.846: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E0FEF)
*Dec 19 11:21:05.854: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E11EF)
*Dec 19 11:21:05.862: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E13EF)
*Dec 19 11:21:05.870: ISDN Se0/0/0:15 Q921: User RX <- BAD FRAME(0x0E15EF)
Seimens-QSIG#show controllers e1 0/0/0
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK1
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (271 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
  Data in Interval 2:
  Data in Interval 3:
  Data in Interval 4:
  Data in Interval 5:
  Data in Interval 6:
  Data in Interval 7:
  Data in Interval 8:
  Data in Interval 9:
  Data in Interval 10:
     2 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     11 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 11:
  Data in Interval 12:
  Data in Interval 13:
  Data in Interval 14:
  Data in Interval 15:
  Data in Interval 16:
  Data in Interval 17:
  Data in Interval 18:
  Data in Interval 19:
     1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     9 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 20:
  Data in Interval 21:
  Data in Interval 22:
     8 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 23:
  Data in Interval 24:
  Data in Interval 25:
  Data in Interval 26:
  Data in Interval 27:
  Data in Interval 28:
  Data in Interval 29:
  Data in Interval 30:
  Data in Interval 31:
  Data in Interval 32:
  Data in Interval 33:
  Data in Interval 34:
  Data in Interval 35:
  Data in Interval 36:
  Data in Interval 37:
  Data in Interval 38:
  Data in Interval 39:
  Data in Interval 40:
  Data in Interval 41:
  Data in Interval 42:
  Data in Interval 43:
  Data in Interval 44:
     6 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 45:
  Data in Interval 46:
  Data in Interval 47:
  Data in Interval 48:
  Data in Interval 49:
  Data in Interval 50:
  Data in Interval 51:
  Data in Interval 52:
  Data in Interval 53:
  Data in Interval 54:
     5 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 55:
     3 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 56:
  Data in Interval 57:
  Data in Interval 58:
     2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 59:
  Data in Interval 60:
  Data in Interval 61:
  Data in Interval 62:
  Data in Interval 63:
  Data in Interval 64:
  Data in Interval 65:
  Data in Interval 66:
  Data in Interval 67:
  Data in Interval 68:
  Data in Interval 69:
  Data in Interval 70:
  Data in Interval 71:
  Data in Interval 72:
  Data in Interval 73:
  Data in Interval 74:
  Data in Interval 75:
  Data in Interval 76:
  Data in Interval 77:
  Data in Interval 78:
  Data in Interval 79:
  Data in Interval 80:
     0 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins
     1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 50 Unavail Secs
  Data in Interval 81:
  Data in Interval 82:
  Data in Interval 83:
  Data in Interval 84:
  Data in Interval 85:
  Data in Interval 86:
  Data in Interval 87:
  Data in Interval 88:
  Data in Interval 89:
  Data in Interval 90:
  Data in Interval 91:
  Data in Interval 92:
  Data in Interval 93:
  Data in Interval 94:
  Data in Interval 95:
  Data in Interval 96:
Seimens-QSIG#
Br,
Nadeem
