MGCP/SRST help
ciscouser55
I understand that I need to do the following for mgcp
mgcp
mgcp call-agent ........ service......version 0.1
ccm-manager mgcp
If I want CCM to download everything else I need the following ?
ccm-manager config server x.x.x.x - ip address of ccm
ccm-manager config
If I have FXS port on the GW as well do I need the following
Add the MGCP applicationciation to the Dial Peers for the ports or can I just configure them in CCM ?
Is this correct ?
SRST
I have a bundled SRST from Cisco, how do I know the S/W level of it - sh ver? what do I look for ?
Also If I have SRST with the router do I just need to add the following
ccm-manager fallback-mgcp
application
global
service alternative default - for h323 only
Rajesh Revuru
Level 4
Level 4
type in "sh call-manager all" and it will display SRST version at the top.
You would have to define ephone-dn and ephone as minimum to enable SRST after you type ccm-manager fallback-mgcp
Do you mean max-phone, max-dn etc?
