Migrate CME license to new CME platform
I have a customer that currently has CME on a 3800 series router.
I am proposing two options to get them a little more current.
a)Add more memory to the router and I can upgrade them to 8.6 CME/CUE and that is it.
or
b) Replace the 3800 with a 3900, move the NME-CUE with a SM-NM-Adaptor to the new 3900-CME/SRST platform and move the configuration as well.
Question I have is, do I have to do anything license wise with CME from the 3800 to the 3900 to keep them legal?
Or is this the wrong forum?
Chris Deren
CME licenses are not transferable. Though they are not enforced at this time,
CUE on the other hand is tied to the router and depending on version would need to be rehosted.
Chris
Chris Deren
Chris
Rob Huffman
Hi Richard,
For the CUE license migration
Migrating to CSL Licenses
When you upgrade to version 7.1 or later, you must replace your pre-CSL  licenses with CSL licenses. You are required to migrate your licenses  for mailbox features and port features. If you purchased the optional  IVR features, you must also migrate your licenses for the IVR features.  The migration procedure for each of these types of licenses are  described in a separate section below.
Note If you are upgrading to the same of licensed features as before, the CSL licenses are free.
When  you obtain licenses for features for Cisco Unity Express 7.1 or later,  the licenses are available only in the increments shown below. The  following types of licenses are available:
Mailboxes (available only in increments of five)
Ports (available only in increments of two)
IVR (available only in increments of two)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/Licensing/Using_CSL.html
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
