09-15-2016 10:20 AM - edited 03-17-2019 08:06 AM
I believe Missed call notification to email feature available in version 11. i read in google search that it required separate domain if we are using regular domain for voicemail to email.
please help.
09-15-2016 12:02 PM
Hi Firasat,
This feature is available in CUC 11.x as per the admin guide
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/administration/guide/b_cucsag/b_cucsag_chapter_01011.html
However, I do not see any specifications for domain requirements.
Manish
09-15-2016 02:11 PM
I concur with my colleagues here, I recently implemented this feature at a customer and it works as advertised without any dependencies on domains.
09-21-2016 03:38 PM
i am trying to configure based on provided solution but it is giving me same error as i mentioned above.
http://www.ciscounitytools.com/Training/Connection/CUC11_0.html
Problem is, as i am using example.com domain for voicemail to email i can not use same domain for missed call to email. please see attached and advise.
i am not using unified messaging.
09-15-2016 12:10 PM
You can see the procedure here, but you can use the same as you use for UM
https://youtu.be/Fvpjv82AI6E
