06-08-2015 12:36 AM - edited 03-17-2019 03:15 AM
Our client is using CM 10.5.1. We have two phone 7965 and 7945, which have same extension. When we call on DN, both phones rings simultaneously. But current missed call logs appears only on 7945 phone. 7965 phone shows old 5 6 days back missed call logs.
One more issue is 7965 phone expansion module is added with phone but not working, stuck on Cisco logo and buttons amber lights.
Kindly suggest.
HK
06-08-2015 02:06 AM
please chk ur phone is getting correct TFTP
06-08-2015 04:36 AM
Hi Feni,
TFTP IP is correct, both phones are registered with cucm.
HK
06-09-2015 12:09 PM
Hi Humza,
Try deleting ITL on 7965 to see if it changes anything.
What is the model number of Expansion module.
JB
06-10-2015 04:34 AM
Hi JB,
Ok i will try to delete.
Expension module model is 7916.
HK
06-10-2015 05:42 AM
Hi HK,
If you have web access enable on your IP phone, browse the phone through a web browser and find out the firmware on expansion module. Copy the same and past it Under Expansion Module Information >> Module 1 Load Name section
JB
06-15-2015 12:55 AM
Issue has been resolved, Ip phone was plugged in wireless vlan port, thats why don't getting their settings. After changing port, missed calls and expansion module both are working fine.
Humza Khan
06-15-2015 04:41 AM
Hi HK,
Great to hear the issue is resolved.keep the above setting regarding expansion module for feature, if you don't have the Module 1 Load Name section populated the firmware for expansion module will not take effect, which in turn sometime hampers the expansion module functionality.
JB
