missing sip re-invite messages when placing on hold
Hello everyone,
I'm a bit new to SIP signaling so this might be something obvious but i'm running into a situation which according to most documentation out there should not happen.
I'm working on setting up a CUBE with an ITSP and it looks like everything is working but when i was trying call features i noticed that when placing an external caller on hold from an IP phone there were no sip messages generated at all in the debugs. I read a few documents and most say that you should see a SIP re-invite message when placing someone on hold but i get nothing and the caller simply hears dead air.
here's a call setup with the caller being placed on hold 2-3 times before i hung up:
https://lh3.googleusercontent.com/-96l1vjSzB9U/Vk9aLFvHq3I/AAAAAAAABCg/HC--0sQcFmc/s863-Ic42/Untitled.png
mid-call signaling pasthru is configured on the CUBE but it seems to make no difference wheater i disable or enable that command.
aditional information that might be relevant, i was calling from a CIPC configured with SCCP on our call manager and i guess the dead air is normal as the phone is configured to use MoH but the max hops on the CUCM is set to 1 (we re-generate it locally on sites with h323 gateways).
If MTP is involved, CUCM keeps the media leg between MTP and CUBE from beginning to end; when necessary, (ie when there is media break in the even of putting a call on hold) it just updates another leg of MTP between MTP and the IP Phone.
This is why you dont see a re-INVITE. If there is no MTP involved, then you will definitely see a re-INVITE
Please rate all useful posts
7 Replies 7
Nadeem Ahmed
Can you please just confirm the exact call-flow and do you have any traces or debugs collected. Please post show tech from CUBE.
Call-flow example
IP Phone-----SCCP/SIP-----CUCM-----SIP------VGW(CUBE)-----SIP---ITSP
Br,
nadeem
PS:Please rate all useful post.
Br, Nadeem Please rate all useful post.
hey, here's a show tech. what debug would you like? i assume ccsip messages?
------------------ show version ------------------
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Sun 27-Sep-15 06:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
IACHZURVGW01 uptime is 9 hours, 6 minutes
System returned to ROM by reload at 09:00:33 UTC Fri Nov 20 2015
System restarted at 09:02:28 UTC Fri Nov 20 2015
System image file is "flash:c2900-universalk9-mz.SPA.154-3.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ194171VP
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO2911/K9          FCZ194171VP
Technology Package License Information for Module:'c2900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
uc            uck9                 Permanent      uck9
data          None                 None           None
NtwkEss       None                 None           None
CollabPro     None                 None           None
------------------ show running-config ------------------
Building configuration...
Current configuration : 11576 bytes
! Last configuration change at 17:02:05 UTC Fri Nov 20 2015 by hunor_szombatfalvi
! NVRAM config last updated at 17:02:06 UTC Fri Nov 20 2015 by hunor_szombatfalvi
version 15.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname IACHZURVGW01
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.154-3.M4.bin
boot-end-marker
logging buffered 65536
enable secret 5 <removed>
aaa new-model
aaa group server tacacs+ EPMACS
 server name ACS_EU
 server name ACS_NA
aaa authentication login default group EPMACS group tacacs+ local
aaa authorization config-commands
aaa authorization exec default group EPMACS group tacacs+ local
aaa authorization commands 0 default group EPMACS group tacacs+ local
aaa authorization commands 1 default group EPMACS group tacacs+ local
aaa authorization commands 15 default group EPMACS group tacacs+ local
aaa accounting exec default start-stop group EPMACS group tacacs+
aaa accounting commands 1 default start-stop group EPMACS group tacacs+
aaa accounting commands 15 default start-stop group EPMACS group tacacs+
aaa session-id common
no ip dhcp conflict logging
ip dhcp excluded-address 10.75.32.129 10.75.32.140
ip dhcp pool VOIP_Zurich
 network 10.75.32.128 255.255.255.192
 dns-server 129.130.102.100 129.130.102.101
 default-router 10.75.32.129
 option 150 ip 10.96.108.12 10.96.109.11
ip multicast-routing
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog always
voice call carrier capacity active
voice rtp send-recv
voice service voip
 no ip address trusted authenticate
 allow-connections sip to sip
 no supplementary-service sip handle-replaces
 redirect ip2ip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 sip
  session transport tcp
  min-se 1100 session-expires 1100
  registrar server expires max 600 min 60
  asserted-id pai
  no anat
  early-offer forced
  no silent-discard untrusted
  history-info
  midcall-signaling passthru
  sip-profiles inbound
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
 codec preference 4 ilbc
voice class sip-profiles 11
 request INVITE sip-header SIP-Req-URI modify "sip:564044320(.*)@" "sip:88602243@"
 request INVITE sip-header From modify "sip:(.*);phone-context=international@" "sip:+\1@"
 request INVITE sip-header From modify "sip:(.*);phone-context=national@" "sip:+41\1@"
 request INVITE sip-header To modify "sip:564044320@" "sip:88602243@"
 request INVITE sip-header Contact modify "sip:(.*);phone-context=international@" "sip:+\1@"
 request INVITE sip-header Contact modify "sip:(.*);phone-context=national@" "sip:+41\1@"
 request INVITE sip-header P-Asserted-Identity modify "sip:(.*);phone-context=international@" "sip:+\1@"
 request INVITE sip-header P-Asserted-Identity modify "sip:(.*);phone-context=national@" "sip:+41\1@"
 request CANCEL sip-header SIP-Req-URI modify "sip:564044320(.*)@" "sip:88602243@"
 request CANCEL sip-header From modify "sip:(.*);phone-context=international@" "sip:+\1@"
 request CANCEL sip-header From modify "sip:(.*);phone-context=national@" "sip:+41\1@"
 request CANCEL sip-header To modify "sip:564044320@" "sip:88602243@"
voice class sip-profiles 10
 request INVITE sip-header SIP-Req-URI modify "sip:000(.*)@" "sip:\1;phone-context=international@"
 request INVITE sip-header SIP-Req-URI modify "sip:00041(.*)@" "sip:\1;phone-context=national@"
 request INVITE sip-header SIP-Req-URI modify "sip:00(.*)@" "sip:\1;phone-context=national@"
 request INVITE sip-header From modify "sip:88602243@" "sip:564044320@"
 request INVITE sip-header To modify "sip:000(.*)@" "sip:\1;phone-context=international@"
 request INVITE sip-header To modify "sip:00041(.*)@" "sip:\1;phone-context=national@"
 request INVITE sip-header To modify "sip:00(.*)@" "sip:\1;phone-context=national@"
 request INVITE sip-header Contact modify "sip:88602243@" "sip:564044320@"
 request INVITE sip-header P-Asserted-Identity modify "sip:88602243@" "sip:564044320@"
 request CANCEL sip-header SIP-Req-URI modify "sip:000(.*)@" "sip:\1;phone-context=international@"
 request CANCEL sip-header SIP-Req-URI modify "sip:00041(.*)@" "sip:\1;phone-context=national@"
 request CANCEL sip-header SIP-Req-URI modify "sip:00(.*)@" "sip:\1;phone-context=national@"
 request CANCEL sip-header From modify "sip:88602243@" "sip:564044320@"
 request CANCEL sip-header To modify "sip:000(.*)@" "sip:\1;phone-context=international@"
 request CANCEL sip-header To modify "sip:00041(.*)@" "sip:\1;phone-context=national@"
 request CANCEL sip-header To modify "sip:00(.*)@" "sip:\1;phone-context=national@"
voice iec syslog
voice register global
 mode srst
 timeouts interdigit 3
 system message Operating in Fallback mode
 max-dn 200
 max-pool 1
 ip qos dscp af31 signal
voice register pool  1
 busy-trigger-per-button 1
 id network 10.75.32.128 mask 255.255.255.192
license udi pid CISCO2911/K9 sn FCZ194171VP
hw-module pvdm 0/0
username netadmin secret 5 <removed>
redundancy
class-map match-any VOIP-SIG
 match protocol skinny
 match protocol h323
 match protocol sip
class-map match-all VOIP-RTP
 match protocol rtp
policy-map VOIP
 class VOIP-RTP
  priority percent 70
 class VOIP-SIG
  bandwidth 100
interface Loopback0
 ip address 10.75.32.241 255.255.255.240
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description primary
 backup interface GigabitEthernet0/1
 ip address 10.75.32.130 255.255.255.192
 ip pim sparse-mode
 duplex auto
 speed auto
 service-policy output VOIP
 description back up
 ip pim sparse-mode
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address 192.168.10.2 255.255.255.0
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.75.32.129
ip route 192.168.10.0 255.255.255.0 192.168.10.1
ip route 193.246.242.0 255.255.255.0 192.168.10.1
ip route 193.246.244.0 255.255.255.0 192.168.10.1
ip tacacs source-interface Loopback0
ip ssh version 2
logging source-interface Loopback0
logging host 10.69.97.7
logging host 10.69.97.169
snmp-server community <removed> RO 51
snmp-server community <removed> RW 51
snmp-server contact EPMEISNetworkTeam@emerson.com
tacacs server ACS_EU
 address ipv4 10.69.97.6
 key 7 <removed>
 single-connection
tacacs server ACS_NA
 address ipv4 10.223.51.12
 key 7 <removed>
 single-connection
access-list 51 permit 10.69.97.2
access-list 51 permit 10.69.131.3
access-list 51 remark *** SNMP_Control_ACL ***
access-list 51 permit 10.69.0.0 0.0.252.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local Loopback0
sccp ccm 10.96.109.11 identifier 1 priority 1 version 7.0
sccp ccm 10.96.108.13 identifier 2 priority 2 version 7.0
sccp ccm 10.72.83.129 identifier 3 priority 3 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate ccm 3 priority 3
 associate profile 1 register IACHZURSIPMTP
 associate profile 2 register IACHZURXCODE01
 associate profile 3 register IACHZURCONF01
ccm-manager music-on-hold bind Loopback0
dspfarm profile 2 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec ilbc
 codec g729r8
 codec g729br8
 maximum sessions 5
 associate application SCCP
dspfarm profile 3 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec ilbc
 maximum sessions 1
dspfarm profile 1 mtp
 codec g711alaw
 maximum sessions software 150
dial-peer voice 20 voip
 description to CUCM03
 destination-pattern 88602T
 session protocol sipv2
 session target ipv4:10.96.109.11
 incoming called-number 0T
 voice-class codec 1
 voice-class sip bind control source-interface Loopback0
 voice-class sip bind media source-interface Loopback0
 dtmf-relay rtp-nte
 fax rate disable
dial-peer voice 21 voip
 description to CUCM04
 preference 2
 session target ipv4:10.96.108.13
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate disable
dial-peer voice 10 voip
 description to SIP Provider
 destination-pattern .T
 no modem passthrough
 session target ipv4:193.246.242.84
 session transport udp
 incoming called-number [1-9]T
 voice-class sip localhost dns:sbc01.ch
 voice-class sip profiles 10
 voice-class sip profiles 11 inbound
 voice-class sip options-keepalive up-interval 30 down-interval 60
 voice-class sip bind control source-interface GigabitEthernet0/2
 voice-class sip bind media source-interface GigabitEthernet0/2
 dtmf-relay rtp-nte
 codec g711alaw
 fax rate 14400
 no vad
gateway
 timer receive-rtp 1200
sip-ua
 no remote-party-id
 set pstn-cause 31 sip-status 503
 retry invite 3
 retry bye 3
 retry cancel 3
 connection-reuse
gatekeeper
 shutdown
banner exec ^C
      |          |        Emerson
    |||||      |||||      Hostname: $(hostname)
    CISCO --- SYSTEMS     AUTHORIZED ACCESS ONLY!!
^C
banner login ^C
                                        W A R N I N G
                             THIS IS A PRIVATE COMPUTER SYSTEM.
                         UNAUTHORISED ACCESS IS STRICTLY PROHIBITED
This computer system including all related equipment, network devices (specifically
including Internet access), are provided only for authorized use. All computer systems
may be monitored for all lawful purposes, including to ensure that their use is
authorized, for management of the system, to facilitate protection against unauthorized
access, and to verify security procedures, survivability and operational security.
Monitoring includes active attacks by authorized personnel and their entities to test or
verify the security of the system. During monitoring, information may be examined,
recorded, copied and used for authorized purposes. All information including personal
information, placed on or sent over this system may be monitored. Uses of this system,
authorized or unauthorized, constitutes consent to monitoring of this system. Unauthorized
use may subject you to criminal prosecution. Evidence of any such unauthorized use
collected during monitoring may be used for administrative, criminal or other adverse action.
^C
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
scheduler allocate 20000 1000
ntp server 10.16.64.124
ntp server 10.20.64.124
end
------------------ show redundancy history ------------------
00:00:12 client added: Redundancy Mode RF(29) seq=60
00:00:12 client added: CHKPT RF(25) seq=68
00:00:12 client added: SNMP RF Client(34) seq=238
00:00:12 client added: History RF Client(35) seq=248
00:00:12 client added: CRYPTO RSA(130) seq=364
00:00:12 client added: PKI RF Client(131) seq=365
00:00:13 *my state = INITIALIZATION(2) peer state = DISABLED(1)
00:00:13 RF_PROG_INITIALIZATION(100) First Slave(0) op=0 rc=11
00:00:13 RF_PROG_INITIALIZATION(100) Slave(3) op=0 rc=23
00:00:13 RF_PROG_INITIALIZATION(100) Redundancy Mode RF(29) op=0 rc=11
00:00:13 RF_PROG_INITIALIZATION(100) CHKPT RF(25) op=0 rc=11
00:00:13 RF_PROG_INITIALIZATION(100) SNMP RF Client(34) op=0 rc=11
00:00:13 RF_PROG_INITIALIZATION(100) History RF Client(35) op=0 rc=11
00:00:13 RF_PROG_INITIALIZATION(100) CRYPTO RSA(130) op=0 rc=11
00:00:13 RF_PROG_INITIALIZATION(100) PKI RF Client(131) op=0 rc=11
00:00:13 RF_EVENT_SLAVE_PROG_DONE(522) Slave(3) op=0 rc=11
00:00:13 RF_PROG_INITIALIZATION(100) Last Slave(65000) op=0 rc=11
00:00:13 *my state = NEGOTIATION(3) peer state = DISABLED(1)
00:00:30 client added: LLDP(208) seq=211
00:00:30 client added: TPM RF client(402) seq=157
00:00:30 client added: VOIP RF CLIENT(1345) seq=129
00:00:30 client added: EEM Server RF CLIENT(250) seq=272
00:00:30 client added: EEM POLICY-DIR RF CLIENT(252) seq=274
00:00:30 client added: mDNS(24115) seq=486
00:00:30 client added: FH_RF_Event_Detector_stub(50) seq=285
00:00:37 System initialization complete
00:00:37 RF_STATUS_PEER_COMM(401) op=0 rc=0
00:00:37 RF_STATUS_PEER_PRESENCE(400) op=0 rc=0
00:00:37 RF_EVENT_GO_ACTIVE(512) op=0 rc=0
00:00:37 *my state = ACTIVE-FAST(9) peer state = DISABLED(1)
00:00:37 RF_PROG_ACTIVE_FAST(200) First Slave(0) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) Slave(3) op=0 rc=23
00:00:37 RF_PROG_ACTIVE_FAST(200) Redundancy Mode RF(29) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) CHKPT RF(25) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) VOIP RF CLIENT(1345) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) TPM RF client(402) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) LLDP(208) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) SNMP RF Client(34) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) History RF Client(35) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) EEM Server RF CLIENT(250) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) EEM POLICY-DIR RF CLIENT(252) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) CRYPTO RSA(130) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) PKI RF Client(131) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) mDNS(24115) op=0 rc=11
00:00:37 RF_EVENT_SLAVE_PROG_DONE(522) Slave(3) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_FAST(200) Last Slave(65000) op=0 rc=11
00:00:37 *my state = ACTIVE-DRAIN(10) peer state = DISABLED(1)
00:00:37 RF_PROG_ACTIVE_DRAIN(201) First Slave(0) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) Slave(3) op=0 rc=23
00:00:37 RF_PROG_ACTIVE_DRAIN(201) Redundancy Mode RF(29) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) CHKPT RF(25) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) VOIP RF CLIENT(1345) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) TPM RF client(402) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) LLDP(208) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) SNMP RF Client(34) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) History RF Client(35) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) EEM Server RF CLIENT(250) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) EEM POLICY-DIR RF CLIENT(252) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) CRYPTO RSA(130) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) PKI RF Client(131) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) mDNS(24115) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_DRAIN(201) Last Slave(65000) op=0 rc=11
00:00:37 *my state = ACTIVE_PRECONFIG(11) peer state = DISABLED(1)
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) First Slave(0) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) Slave(3) op=0 rc=23
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) Redundancy Mode RF(29) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) CHKPT RF(25) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) VOIP RF CLIENT(1345) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) TPM RF client(402) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) LLDP(208) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) SNMP RF Client(34) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) History RF Client(35) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) EEM Server RF CLIENT(250) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) EEM POLICY-DIR RF CLIENT(252) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) CRYPTO RSA(130) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) PKI RF Client(131) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) mDNS(24115) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_PRECONFIG(202) Last Slave(65000) op=0 rc=11
00:00:37 *my state = ACTIVE_POSTCONFIG(12) peer state = DISABLED(1)
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) First Slave(0) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(3) op=0 rc=23
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) Redundancy Mode RF(29) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) CHKPT RF(25) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) VOIP RF CLIENT(1345) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) TPM RF client(402) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) LLDP(208) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP RF Client(34) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) History RF Client(35) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) EEM Server RF CLIENT(250) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) EEM POLICY-DIR RF CLIENT(252) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) CRYPTO RSA(130) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) PKI RF Client(131) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) mDNS(24115) op=0 rc=11
00:00:37 RF_PROG_ACTIVE_POSTCONFIG(203) Last Slave(65000) op=0 rc=11
00:00:37 *my state = ACTIVE(13) peer state = DISABLED(1)
00:00:37 RF_PROG_ACTIVE(204) First Slave(0) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) Slave(3) op=0 rc=23
00:00:37 RF_PROG_ACTIVE(204) Redundancy Mode RF(29) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) CHKPT RF(25) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) VOIP RF CLIENT(1345) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) TPM RF client(402) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) LLDP(208) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) SNMP RF Client(34) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) History RF Client(35) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) EEM Server RF CLIENT(250) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) EEM POLICY-DIR RF CLIENT(252) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) CRYPTO RSA(130) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) PKI RF Client(131) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) mDNS(24115) op=0 rc=11
00:00:37 RF_PROG_ACTIVE(204) Last Slave(65000) op=0 rc=11
------------------ show redundancy states ------------------
       my state = 13 -ACTIVE
     peer state = 1  -DISABLED
           Mode = Simplex
        Unit ID = 0
     Maintenance Mode = Disabled
    Manual Swact = disabled (system is simplex (no peer unit))
 Communications = Down      Reason: Simplex mode
   client count = 13
 client_notification_TMR = 120000 milliseconds
          keep_alive TMR = 4000 milliseconds
        keep_alive count = 0
    keep_alive threshold = 7
           RF debug mask = 0x0
------------------ show redundancy switchover history ------------------
------------------ show stacks ------------------
Minimum process stacks:
 Free/Size   Name
 5224/6000   CDP BLOB
 8196/9000   EM ED GOLD
10400/12000  PnP Agent Discovery
 2448/6000   Call Home DSFileUp
10928/12000  MRIB IPv4 Init Process
11172/12000  MRIB IPv6 Init Process
 3636/6000   EEM Shell Director
92916/100000  stile_activate_process
 5152/6000   VPM_CABLE_STAT_POLL_BACKGROUND
 5192/6000   SPAN Subsystem
58948/60000  script background loader
 4960/6000   FLEX DSPRM boot download main
58692/60000  EEM Auto Registration Proc
 5080/6000   Auto Upgrade Startup Process
 4652/6000   DIB error message
 2220/3000   LIM WAVL
 5144/6000   SASL MAIN
 2220/3000   allegro libretto init
 4952/6000   LICENSE AGENT DEFAULT
15140/24000  Init
 8224/9000   cdp init process
 4992/6000   RADIUS INITCONFIG
 3000/6000   sp2600_dnld_fmw_record
 5220/6000   platform_reclaim_mem
 5228/6000   IP SLAs Deferred Schedule Processor
 1608/3000   Rom Random Update Process
 5116/6000   URPF stats
47872/60000  AFW_application_process
 8444/12000  FTP Read Process
 4528/12000  SSH Process
Interrupt level stacks:
Level    Called Unused/Size  Name
  1    10426843  14492/18000  Network Interrupt
  3       37748  17392/18000  Mgmt Interrupt
  4        6936  17528/18000  Console UART
  7     8201376  17548/18000  NMI Interrupt Handler
------------------ show interfaces ------------------
Embedded-Service-Engine0/0 is administratively down, line protocol is down
  Hardware is Embedded Service Engine, address is 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Input queue: 0/64/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 5897.bd17.c340 (bia 5897.bd17.c340)
  Description: primary
  Internet address is 10.75.32.130/26
  Backup interface GigabitEthernet0/1, failure delay 0 sec, secondary disable delay 0 sec,
  kickin load not set, kickout load not set
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  5 minute input rate 2000 bits/sec, 2 packets/sec
  5 minute output rate 4000 bits/sec, 2 packets/sec
     55091 packets input, 10077000 bytes, 0 no buffer
     Received 653 broadcasts (0 IP multicasts)
     0 watchdog, 545 multicast, 0 pause input
     85420 packets output, 15947937 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is standby mode, line protocol is down
  Hardware is CN Gigabit Ethernet, address is 5897.bd17.c341 (bia 5897.bd17.c341)
  Description: back up
  Last input never, output 09:06:06, output hang never
     0 watchdog, 0 multicast, 0 pause input
     10 packets output, 954 bytes, 0 underruns
GigabitEthernet0/2 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 5897.bd17.c342 (bia 5897.bd17.c342)
  Internet address is 192.168.10.2/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Full Duplex, 100Mbps, media type is RJ45
  Last input 00:00:05, output 00:00:05, output hang never
     40955 packets input, 9556873 bytes, 0 no buffer
     Received 607 broadcasts (0 IP multicasts)
     0 watchdog, 607 multicast, 0 pause input
     16395 packets output, 3590475 bytes, 0 underruns
Loopback0 is up, line protocol is up
  Hardware is Loopback
  Internet address is 10.75.32.241/28
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Last input 05:59:17, output never, output hang never
  Output queue: 0/0 (size/max)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
------------------ show interfaces history ------------------
------------------ show controllers ------------------
Embedded engine is not enabled
Interface GigabitEthernet0/0
 = Hardware =
Hardware is PLATFORM SGMII INTERFACE
HWIDB: 3DE12DC4, INSTANCE: 3DE13A80, FASTSEND: 300BD320, MCI_INDEX: 0
Route Cache Flag: 11
= Media  RJ45 =
Media Change Count: 1
PORT IPD Registers:
        BP_PAGE_CNT: 0x0000000000000001, BP_CNTS_PRX: 0x0000000000000000
GMX Registers:
        RXX_INT_REG: 0x0000000000000000, RXX_INT_EN : 0x0000000000000000
        PRTX_CFG   : 0x000000000000300F, RXX_FRM_CTL: 0x0000000000000077
        RXX_FRM_CHK: 0x00000000000003BA, RXX_FRM_MIN: 0x0000000000000000
        RXX_FRM_MAX: 0x0000000000000000, RXX_JABBER : 0x0000000000002580
        RXX_DECISIO: 0x0000000000000018, RXX_FRM_CTL: 0x0000000000000077
        RXX_FRM_CHK: 0x00000000000003BA, RXX_JABBER : 0x0000000000002580
        RXX_DECISIO: 0x0000000000000018, RXX_UDD_SKI: 0x0000000000000000
        RXX_STATS_C: 0x0000000000000000, RXX_IFG    : 0x0000000000000008
        RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x00000000000116CA
        RXX_STAT_CT: 0x0000000000000000, RXX_STATS_D: 0x0000000000000002
        RXX_STAT_DR: 0x0000000000000000, RXX_STATS_B: 0x0000000000000000
        SMACX      : 0x00005897BD17C340
        TXX_SGMII_C: 0x0000000000000001, TXX_CTL    : 0x0000000000000003
        RX_PRTS    : 0x0000000000000004, RX_BP_DROP : 0x0000000000000002
        RX_BP_ON   : 0x0000000000000040, RX_BP_OFF  : 0x0000000000000010
        TXX_PAU_PKT: 0x0000000000000060, TXX_MIN_PKT: 0x000000000000003B
        TXX_PAU_PKI: 0x0000000000000010, TXX_SOFTPAU: 0x0000000000000000
        TXX_PAU_TGO: 0x0000000000000000, TXX_PAU_ZRO: 0x0000000000000001
        INF_MODE   : 0x0000000000000022, TX_PRTS    : 0x0000000000000004
        TX_IFG     : 0x0000000000000048, TX_JAM     : 0x00000000000000EE
        TX_COL_ATMP: 0x0000000000000010, TX_PAU_DMAC: 0x00000180C2000001
        TX_PAU_TYPE: 0x0000000000008808, TX_OVR_BP  : 0x0000000000000F0F
        TX_BP      : 0x0000000000000000, TX_CORRUPT : 0x000000000000000F
        RX_PRT_INFO: 0x0000000000000000, GMX_STAT_BP: 0x0000000000000000
        TX_INT_REG : 0x0000000000000000, TX_INT_EN  : 0x0000000000000000
        ADR_CAM0   : 0x0000000000000058
        ADR_CAM1   : 0x0000000000000097
        ADR_CAM2   : 0x00000000000000BD
        ADR_CAM3   : 0x0000000000000017
        ADR_CAM4   : 0x00000000000000C3
        ADR_CAM5   : 0x0000000000000040
        ADR_CTL    : 0x000000000000000D, CAM_EN     : 0x00000000000000FF
        TXX_STAT0  : 0x0000000000000000, TXX_STAT1  : 0x0000000000000000
        TXX_STAT2  : 0x0000000000F8B5A5, TXX_STAT3  : 0x0000000000014DBE
        TXX_STAT4  : 0x00003BD300000000, TXX_STAT5  : 0x0000CE5500002F47
        TXX_STAT6  : 0x00000A53000009FC, TXX_STAT7  : 0x0000000000000000
        TXX_STAT8  : 0x00000B390000000D, TXX_STAT9  : 0x0000000000000000
PCS Registers:
        MRX_CTL_REG: 0x0000000000001140, MRX_STS_REG: 0x000000000000017C
        RXX_STA_REG: 0x00000000000008C7, RXX_SYN_REG: 0x0000000000000003
        TXX_STA_REG: 0x0000000000000064, SGMX_AN_ADV: 0x0000000000001801
        SGMX_AN_ADV: 0x000000000000D801, MISC_CTL   : 0x0000000000000000
        ANX_ADV_REG: 0x0000000000000060, ANX_LP_ABIL: 0x000000000000D000
        ANX_RESULTS: 0x0000000000000017, ANX_EXT_ST : 0x000000000000C000
        LNX_TMR_CNT: 0x0000000000000396, TX_RXX_PLRT: 0x0000000000000000
        INT_REG    : 0x0000000000000000, INT_EN_REG : 0x0000000000000000
        LOG_ANL_REG: 0x0000000000000000, ANX_ADV_REG: 0x0000000000000060
        ANX_LP_ABIL: 0x000000000000D000, ANX_RSL_REG: 0x0000000000000017
        ANX_EXT_ST : 0x000000000000C000, LNX_TMR_CNT: 0x0000000000000396
        MISCX_CTL: 0x0000000000001001
==============PIP Statistics================
        PIP_RX_NO_ERR = 0, PIP_PARTIAL_ERR = 0
        PIP_JABBER_ERR = 0, PIP_OVER_FCS_ERR = 0
        PIP_OVER_ERR = 0, PIP_ALIGN_ERR = 0
        PIP_UNDER_FCS_ERR = 0, PIP_GMX_FCS_ERR = 0
        PIP_UNDER_ERR = 0, PIP_EXTEND_ERR = 0
        PIP_LENGTH_ERR = 0, PIP_DAT_ERR = 0
        PIP_SKIP_ERR = 0, PIP_NIBBLE_ERR = 0
        PIP_UNKNOWN_ERR_14 = 0, PIP_UNKNOWN_ERR_15 = 0
        PIP_PIP_FCS = 0, PIP_PIP_SKIP_ERR = 0
        PIP_PIP_L2_MAL_HDR = 0
        pip_rx_no_particle = 0, pip_undef_err = 0
        pip_rx_no_buf_start = 0
PHY REGISTERS:
        Display for CRC check for page:6
        PACKET_GENERATION reg_addr: 16: 0x0010
        CRC COUNTERS reg_addr: 17: 0xFF00
        page number:0
        Copper Contrl @ reg_addr: 0: 0x1140
        Copper Status @ reg_addr: 1: 0x7969
        PHY Idf1 @ reg_addr: 2: 0x0141
        PHY Idf2 @ reg_addr: 3: 0x0C97
        Autoneg Adv @ reg_addr: 4: 0x0DE1
        Autoneg Lnk Ptr abty @ reg_addr: 5: 0xC1E1
        Autoneg Exp @ reg_addr: 6: 0x000F
        Autoneg Nx Pg Tx @ reg_addr: 7: 0x2801
        Autoneg Lk Prt Nx Pg @ reg_addr: 8: 0x4B94
        1000B-T Ctr @ reg_addr: 9: 0x0E00
        1000B-T St @ reg_addr: 10: 0x7800
        Copper Ext St @ reg_addr: 15: 0x3000
        Copper Specific Ctl1 @ reg_addr: 16: 0x6060
        Copper Specific St1 @ reg_addr: 17: 0xAC08
        Copper Interrupt En @ reg_addr: 18: 0x0000
        Copper Specific St2 @ reg_addr: 19: 0x1C40
        Copper Rcv Er Ctr @ reg_addr: 21: 0x0000
        Copper Specific Ctl2 @  reg_addr: 26: 0x8040
        page number:1
        Fiber Contrl @ reg_addr: 0: 0x1140
        Fiber Status @ reg_addr: 1: 0x7949
        Autoneg Adv @ reg_addr: 4: 0x0060
        Autoneg Lnk Ptr abty @ reg_addr: 5: 0x0000
        Autoneg Exp @ reg_addr: 6: 0x0004
        Autoneg Nx Pg Tx @ reg_addr: 7: 0x2001
        Autoneg Lk Prt Nx Pg @ reg_addr: 8: 0x0000
        Fiber Ext St @ reg_addr: 15: 0x3000
        Fiber Specific Ctl1 @ reg_addr: 16: 0x0000
        Fiber Specific St1 @ reg_addr: 17: 0x0018
        Fiber Interrupt En @ reg_addr: 18: 0x0000
        Fiber Specific St2 @ reg_addr: 19: 0x0000
        Fiber Rcv Er Ctr @ reg_addr: 21: 0x0000
        Fiber Specific Ctl2 @  reg_addr: 26: 0x8085
        page number:2
        MAC Contrl @ reg_addr: 0: 0x1040
        MAC Specific Ctl1 @ reg_addr: 16: 0x0288
        MAC Specific St1 @ reg_addr: 17: 0x0440
        MAC Interrupt En @ reg_addr: 18: 0x0000
        MAC Specific St2 @ reg_addr: 19: 0x0000
        MAC Specific Ctl2 @  reg_addr: 26: 0x0005
TX_COUNT: 0, TX_LIMITED: 1, TX_HEAD: 446, TX_TAIL: 446
TX_MIN_SIZE: 32, TX_MAX_SIZE: 512, TX_CURRENT_SIZE: 240
RX STARVES: 0
Software MAC Address Filter (hash:length/addr/mask/hits)
  0x000:  0  ffff.ffff.ffff  0000.0000.0000       108
  0x053:  0  0100.5e00.000d  0000.0000.0000         0
  0x076:  0  0100.5e00.0128  0000.0000.0000         0
  0x0C0:  0  0180.c200.0002  0000.0000.0000         0
  0x0C0:  1  0100.0ccc.cccc  0000.0000.0000       545
  0x0C5:  0  0180.c200.0007  0000.0000.0000         0
  0x0CC:  0  0180.c200.000e  0000.0000.0000         0
  0x0FD:  0  5897.bd17.c340  0000.0000.0000         0
  0x100:  0  0100.5e7f.ffff  0000.007f.ffff         0
  Software filtered frames: 16353
  Unicast overflow mode: 0
  Multicast overflow mode: 1
  Promiscuous mode: 0
  Total Number of CAM entries: 1
Port Stopped: N
Internal Loopback Set: N
Interface GigabitEthernet0/1
 = Hardware =
HWIDB: 3DE22114, INSTANCE: 3DE22E80, FASTSEND: 300BD320, MCI_INDEX: 0
= Media  RJ45 =
PORT IPD Registers:
GMX Registers:
        PRTX_CFG   : 0x000000000000300E, RXX_FRM_CTL: 0x0000000000000077
        RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x0000000000000007
        RXX_STAT_CT: 0x0000000000000000, RXX_STATS_D: 0x0000000000000000
        SMACX      : 0x00005897BD17C341
        ADR_CAM5   : 0x0000000000000041
        TXX_STAT2  : 0x00000000000003E2, TXX_STAT3  : 0x000000000000000A
        TXX_STAT4  : 0x0000000600000000, TXX_STAT5  : 0x0000000000000003
        TXX_STAT6  : 0x0000000000000001, TXX_STAT7  : 0x0000000000000000
        TXX_STAT8  : 0x0000000500000005, TXX_STAT9  : 0x0000000000000000
PCS Registers:
        MRX_CTL_REG: 0x0000000000001140, MRX_STS_REG: 0x0000000000000168
        SGMX_AN_ADV: 0x0000000000004801, MISC_CTL   : 0x0000000000000000
        ANX_ADV_REG: 0x0000000000000060, ANX_LP_ABIL: 0x0000000000004000
        ANX_RESULTS: 0x0000000000000015, ANX_EXT_ST : 0x000000000000C000
        ANX_LP_ABIL: 0x0000000000004000, ANX_RSL_REG: 0x0000000000000015
PHY REGISTERS:
        CRC COUNTERS reg_addr: 17: 0x1200
        page number:0
        Copper Contrl @ reg_addr: 0: 0x1940
        Copper Status @ reg_addr: 1: 0x7949
        Autoneg Exp @ reg_addr: 6: 0x0006
        1000B-T St @ reg_addr: 10: 0x4000
        Copper Specific St1 @ reg_addr: 17: 0x8000
        page number:1
        Fiber Contrl @ reg_addr: 0: 0x1940
        Fiber Specific St1 @ reg_addr: 17: 0x0010
        page number:2
        MAC Contrl @ reg_addr: 0: 0x1840
TX_COUNT: 0, TX_LIMITED: 1, TX_HEAD: 10, TX_TAIL: 10
RX STARVES: 0
  0x000:  0  ffff.ffff.ffff  0000.0000.0000         0
  0x0C0:  0  0100.0ccc.cccc  0000.0000.0000         0
  0x0C0:  1  0180.c200.0002  0000.0000.0000         0
  0x0FC:  0  5897.bd17.c341  0000.0000.0000         0
  Software filtered frames: 7
  Promiscuous mode: 0
Port Stopped: Y
Interface GigabitEthernet0/2
 = Hardware =
HWIDB: 21B5FEEC, INSTANCE: 21B60C00, FASTSEND: 300BD320, MCI_INDEX: 0
= Media  RJ45 =
PORT IPD Registers:
GMX Registers:
        PRTX_CFG   : 0x0000000000003005, RXX_FRM_CTL: 0x0000000000000077
        RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x0000000000008F54
        SMACX      : 0x00005897BD17C342
        ADR_CAM5   : 0x0000000000000042
        TXX_STAT2  : 0x000000000037CB19, TXX_STAT3  : 0x000000000000400B
        TXX_STAT4  : 0x00000D9F00000000, TXX_STAT5  : 0x000026CB0000003B
        TXX_STAT6  : 0x0000003F00000AFB, TXX_STAT7  : 0x000000000000002C
        TXX_STAT8  : 0x000002A100000005, TXX_STAT9  : 0x0000000000000000
PCS Registers:
        SGMX_AN_ADV: 0x000000000000D401, MISC_CTL   : 0x0000000000000000
        ANX_RESULTS: 0x000000000000000F, ANX_EXT_ST : 0x000000000000C000
        ANX_LP_ABIL: 0x000000000000D000, ANX_RSL_REG: 0x000000000000000F
        MISCX_CTL: 0x0000000000001005
PHY REGISTERS:
        page number:0
        Autoneg Lnk Ptr abty @ reg_addr: 5: 0x41E1
        Autoneg Exp @ reg_addr: 6: 0x0007
        Copper Specific St1 @ reg_addr: 17: 0x6C08
        page number:1
        page number:2
TX_COUNT: 0, TX_LIMITED: 0, TX_HEAD: 11, TX_TAIL: 11
TX_MIN_SIZE: 32, TX_MAX_SIZE: 512, TX_CURRENT_SIZE: 128
RX STARVES: 0
  0x0C0:  1  0100.0ccc.cccc  0000.0000.0000       608
  0x0FF:  0  5897.bd17.c342  0000.0000.0000         0
  Software filtered frames: 0
  Promiscuous mode: 0
Port Stopped: N
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
*388 vty 0     hunor_szom idle                 00:00:00 10.96.128.159
  Interface    User               Mode         Idle     Peer Address
------------------ show file systems ------------------
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   archive:
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     rw   null:
             -             -   network     rw   tftp:
*    261197824      44847104      disk     rw   flash0: flash:#
             -             -      disk     rw   flash1:
        262136        241340     nvram     rw   nvram:
             -             -    opaque     wo   syslog:
             -             -    opaque     rw   xmodem:
             -             -    opaque     rw   ymodem:
             -             -   network     rw   rcp:
             -             -   network     rw   pram:
             -             -   network     rw   http:
             -             -   network     rw   ftp:
             -             -   network     rw   scp:
             -             -    opaque     ro   tar:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
------------------ show file descriptors ------------------
File Descriptors:
   FD  Position  Open  PID  Path
  No open file descriptors
------------------ show flash0: all ------------------
-#- --length-- -----date/time------ path
1    104193476 Oct 8 2015 21:19:34 +00:00 c2900-universalk9-mz.SPA.154-3.M3.bin
2         3066 Oct 8 2015 21:31:14 +00:00 cpconfig-29xx.cfg
3    104247932 Nov 20 2015 07:20:34 +00:00 c2900-universalk9-mz.SPA.154-3.M4.bin
4            0 Oct 8 2015 21:31:32 +00:00 ccpexp
5            0 Oct 8 2015 21:31:32 +00:00 ccpexp/external
6            0 Oct 8 2015 21:31:32 +00:00 ccpexp/external/development-bundle
7            0 Oct 8 2015 21:31:32 +00:00 ccpexp/external/development-bundle/themes
8            0 Oct 8 2015 21:31:32 +00:00 ccpexp/external/development-bundle/themes/flick
9            0 Oct 8 2015 21:31:32 +00:00 ccpexp/external/development-bundle/themes/flick/images
10        1738 Oct 8 2015 21:31:36 +00:00 ccpexp/external/development-bundle/themes/flick/images/animated-overlay.gif
11         180 Oct 8 2015 21:31:38 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_flat_0_aaaaaa_40x100.png
12         180 Oct 8 2015 21:31:38 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_flat_0_eeeeee_40x100.png
13         178 Oct 8 2015 21:31:38 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_flat_55_ffffff_40x100.png
14         178 Oct 8 2015 21:31:38 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_flat_75_ffffff_40x100.png
15         105 Oct 8 2015 21:31:40 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_glass_65_ffffff_1x400.png
16          90 Oct 8 2015 21:31:40 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_highlight-soft_100_f6f6f6_1x100.png
17         118 Oct 8 2015 21:31:40 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_highlight-soft_25_0073ea_1x100.png
18         136 Oct 8 2015 21:31:40 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-bg_highlight-soft_50_dddddd_1x100.png
19        4369 Oct 8 2015 21:31:40 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_0073ea_256x240.png
20        4369 Oct 8 2015 21:31:42 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_454545_256x240.png
21        4369 Oct 8 2015 21:31:42 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_666666_256x240.png
22        4369 Oct 8 2015 21:31:42 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_ff0084_256x240.png
23        4369 Oct 8 2015 21:31:42 +00:00 ccpexp/external/development-bundle/themes/flick/images/ui-icons_ffffff_256x240.png
24       27419 Oct 8 2015 21:31:44 +00:00 ccpexp/external/development-bundle/themes/flick/jquery-ui-1.10.3.custom.css1
25       26635 Oct 8 2015 21:31:44 +00:00 ccpexp/external/development-bundle/themes/flick/jquery-ui-1.8.17.custom.css1
26       27419 Oct 8 2015 21:31:44 +00:00 ccpexp/external/development-bundle/themes/flick/jquery-ui.css
27         840 Oct 8 2015 21:31:44 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.accordion.css
28         292 Oct 8 2015 21:31:46 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.all.css
29         771 Oct 8 2015 21:31:46 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.base.css
30        2541 Oct 8 2015 21:31:46 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.button.css
31        1468 Oct 8 2015 21:31:46 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.core.css
32        1304 Oct 8 2015 21:31:46 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.dialog.css
33        1454 Oct 8 2015 21:31:48 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.menu.css
34         618 Oct 8 2015 21:31:48 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.progressbar.css
35        1207 Oct 8 2015 21:31:48 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.resizable.css
36        1314 Oct 8 2015 21:31:48 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.slider.css
37        1322 Oct 8 2015 21:31:48 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.tabs.css
38       17106 Oct 8 2015 21:31:50 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.theme.css
39         375 Oct 8 2015 21:31:50 +00:00 ccpexp/external/development-bundle/themes/flick/jquery.ui.tooltip.css
40           0 Oct 8 2015 21:31:32 +00:00 ccpexp/external/js
41       93868 Oct 8 2015 21:31:54 +00:00 ccpexp/external/js/jquery-1.7.1.min.js
42           0 Oct 8 2015 21:31:54 +00:00 ccpexp/external/js/jquery-ui-1.10.3.custom.min.js
43       46982 Oct 8 2015 21:31:54 +00:00 ccpexp/external/js/jquery-ui-1.10.4.custom.min.js
44     1144429 Oct 8 2015 21:31:52 +00:00 ccpexp/external/jQueryFramework.js
45       17769 Oct 8 2015 21:31:52 +00:00 ccpexp/external/jquery.i18n.properties-1.0.9.js
46       21601 Oct 8 2015 21:31:54 +00:00 ccpexp/external/jquery.validate.min.js
47         929 Oct 8 2015 21:31:54 +00:00 ccpexp/external/readme.txt
48       45489 Oct 8 2015 21:31:56 +00:00 ccpexp/external/underscore.js
49           0 Oct 8 2015 21:31:34 +00:00 ccpexp/html
50           0 Oct 8 2015 21:31:34 +00:00 ccpexp/html/bundles
51       51143 Oct 8 2015 21:31:56 +00:00 ccpexp/html/bundles/CCPExpNG.properties
52        3372 Oct 8 2015 21:31:56 +00:00 ccpexp/html/bundles/ValidationMessages.properties
53           0 Oct 8 2015 21:31:34 +00:00 ccpexp/html/fonts
54       62856 Oct 8 2015 21:32:00 +00:00 ccpexp/html/fonts/FontAwesome.otf
55       38205 Oct 8 2015 21:32:00 +00:00 ccpexp/html/fonts/fontawesome-webfont.eot
56      202148 Oct 8 2015 21:32:02 +00:00 ccpexp/html/fonts/fontawesome-webfont.svg
57       80652 Oct 8 2015 21:32:02 +00:00 ccpexp/html/fonts/fontawesome-webfont.ttf
58       44432 Oct 8 2015 21:32:02 +00:00 ccpexp/html/fonts/fontawesome-webfont.woff
59           0 Oct 8 2015 21:31:34 +00:00 ccpexp/html/images
60        3406 Oct 8 2015 21:32:04 +00:00 ccpexp/html/images/Activate.png
61        1282 Oct 8 2015 21:32:04 +00:00 ccpexp/html/images/Collapse.png
62        1473 Oct 8 2015 21:32:04 +00:00 ccpexp/html/images/Excel.png
63        3419 Oct 8 2015 21:32:06 +00:00 ccpexp/html/images/Help_uishell_16.png
64        1405 Oct 8 2015 21:32:06 +00:00 ccpexp/html/images/IPS_drilldown.png
65        3040 Oct 8 2015 21:32:06 +00:00 ccpexp/html/images/NoSIM.png
66        3233 Oct 8 2015 21:32:06 +00:00 ccpexp/html/images/NoSignal.png
67         371 Oct 8 2015 21:32:08 +00:00 ccpexp/html/images/NotActivate.png
68        3219 Oct 8 2015 21:32:08 +00:00 ccpexp/html/images/SIM.png
69        3421 Oct 8 2015 21:32:08 +00:00 ccpexp/html/images/Sent-Mail.png
70         261 Oct 8 2015 21:32:08 +00:00 ccpexp/html/images/Signal1.png
71         294 Oct 8 2015 21:32:08 +00:00 ccpexp/html/images/Signal2.png
72         319 Oct 8 2015 21:32:10 +00:00 ccpexp/html/images/Signal3.png
73         324 Oct 8 2015 21:32:10 +00:00 ccpexp/html/images/Signal4.png
74         324 Oct 8 2015 21:32:10 +00:00 ccpexp/html/images/Signal5.png
75      211889 Oct 8 2015 21:32:10 +00:00 ccpexp/html/images/UtmSpriteImage.png
76       33259 Oct 8 2015 21:32:12 +00:00 ccpexp/html/images/allImagesby40.png
77       22196 Oct 8 2015 21:32:12 +00:00 ccpexp/html/images/allimagesby80.jpg
78         181 Oct 8 2015 21:32:12 +00:00 ccpexp/html/images/application.png
79      114483 Oct 8 2015 21:32:14 +00:00 ccpexp/html/images/banner.jpg
80       56706 Oct 8 2015 21:32:14 +00:00 ccpexp/html/images/banner6.jpg
81       33012 Oct 8 2015 21:32:14 +00:00 ccpexp/html/images/bars.jpg
82        2816 Oct 8 2015 21:32:14 +00:00 ccpexp/html/images/blankSpace.png
83       83587 Oct 8 2015 21:32:16 +00:00 ccpexp/html/images/caaDeviceList.png
84        1315 Oct 8 2015 21:32:16 +00:00 ccpexp/html/images/ccpeQR.png
85       16786 Oct 8 2015 21:32:16 +00:00 ccpexp/html/images/ceserver.png
86       12575 Oct 8 2015 21:32:16 +00:00 ccpexp/html/images/content-security.jpg
87        1330 Oct 8 2015 21:32:16 +00:00 ccpexp/html/images/cpu_utilization.png
88        1270 Oct 8 2015 21:32:18 +00:00 ccpexp/html/images/cws.png
89        1102 Oct 8 2015 21:32:18 +00:00 ccpexp/html/images/device-details.png
90        1269 Oct 8 2015 21:32:18 +00:00 ccpexp/html/images/device_details.png
91        1268 Oct 8 2015 21:32:18 +00:00 ccpexp/html/images/disable.png
92         992 Oct 8 2015 21:32:20 +00:00 ccpexp/html/images/down.png
93        1972 Oct 8 2015 21:32:20 +00:00 ccpexp/html/images/dragArrow.png
94        1271 Oct 8 2015 21:32:20 +00:00 ccpexp/html/images/enable.png
95        1287 Oct 8 2015 21:32:20 +00:00 ccpexp/html/images/expand.png
96        1435 Oct 8 2015 21:32:20 +00:00 ccpexp/html/images/firewall.png
97        1597 Oct 8 2015 21:32:22 +00:00 ccpexp/html/images/flash-memory.png
98        1174 Oct 8 2015 21:32:22 +00:00 ccpexp/html/images/flash_memory.png
99        6877 Oct 8 2015 21:32:22 +00:00 ccpexp/html/images/header_icon_sprite.png
100       1816 Oct 8 2015 21:32:22 +00:00 ccpexp/html/images/information.png
101        941 Oct 8 2015 21:32:24 +00:00 ccpexp/html/images/interfacePort.png
102       1191 Oct 8 2015 21:32:24 +00:00 ccpexp/html/images/interfaces.png
103      22992 Oct 8 2015 21:32:24 +00:00 ccpexp/html/images/ips-enable.jpg
104      39606 Oct 8 2015 21:32:24 +00:00 ccpexp/html/images/ips-in-enable.png
105      17467 Oct 8 2015 21:32:24 +00:00 ccpexp/html/images/ips.jpg
106        209 Oct 8 2015 21:32:26 +00:00 ccpexp/html/images/key_minus.png
107        238 Oct 8 2015 21:32:26 +00:00 ccpexp/html/images/key_plus.png
108      18760 Oct 8 2015 21:32:26 +00:00 ccpexp/html/images/logo.png
109       1374 Oct 8 2015 21:32:26 +00:00 ccpexp/html/images/maximize.png
110       1293 Oct 8 2015 21:32:28 +00:00 ccpexp/html/images/network.png
111      10130 Oct 8 2015 21:32:28 +00:00 ccpexp/html/images/papergrid.jpg
112       1374 Oct 8 2015 21:32:28 +00:00 ccpexp/html/images/policy.png
113       1234 Oct 8 2015 21:32:28 +00:00 ccpexp/html/images/port.png
114       1591 Oct 8 2015 21:32:30 +00:00 ccpexp/html/images/processor-memory.png
115       1458 Oct 8 2015 21:32:30 +00:00 ccpexp/html/images/processor_memory.png
116       1236 Oct 8 2015 21:32:30 +00:00 ccpexp/html/images/reload.png
117       2087 Oct 8 2015 21:32:30 +00:00 ccpexp/html/images/right-check-icon.png
118       2975 Oct 8 2015 21:32:32 +00:00 ccpexp/html/images/right_arrow.png
119       4059 Oct 8 2015 21:32:32 +00:00 ccpexp/html/images/router.png
120       1405 Oct 8 2015 21:32:32 +00:00 ccpexp/html/images/search-icon.png
121       1178 Oct 8 2015 21:32:32 +00:00 ccpexp/html/images/settings.png
122       3339 Oct 8 2015 21:32:34 +00:00 ccpexp/html/images/sortable.png
123       5363 Oct 8 2015 21:32:34 +00:00 ccpexp/html/images/split-icon40.png
124       5945 Oct 8 2015 21:32:34 +00:00 ccpexp/html/images/startup.gif
125      29881 Oct 8 2015 21:32:34 +00:00 ccpexp/html/images/startupImage.png
126       1161 Oct 8 2015 21:32:36 +00:00 ccpexp/html/images/temperature.png
127      13338 Oct 8 2015 21:32:36 +00:00 ccpexp/html/images/tileImages.png
128       1247 Oct 8 2015 21:32:36 +00:00 ccpexp/html/images/top_10_applications.png
129       1381 Oct 8 2015 21:32:36 +00:00 ccpexp/html/images/top_10_threats.png
130       1590 Oct 8 2015 21:32:38 +00:00 ccpexp/html/images/top_10_users.png
131      16843 Oct 8 2015 21:32:38 +00:00 ccpexp/html/images/towerDown.png
132      16843 Oct 8 2015 21:32:38 +00:00 ccpexp/html/images/towerUp.png
133        330 Oct 8 2015 21:32:38 +00:00 ccpexp/html/images/user.png
134      17840 Oct 8 2015 21:32:40 +00:00 ccpexp/html/images/utm_40.png
135       3428 Oct 8 2015 21:32:40 +00:00 ccpexp/html/images/utm_80.jpg
136      12683 Oct 8 2015 21:32:40 +00:00 ccpexp/html/images/vpn.jpg
137       1488 Oct 8 2015 21:32:40 +00:00 ccpexp/html/images/vpn.png
138       1630 Oct 8 2015 21:32:42 +00:00 ccpexp/html/images/vpnAdd.png
139       1377 Oct 8 2015 21:32:42 +00:00 ccpexp/html/images/zone.png
140       4613 Oct 8 2015 21:31:56 +00:00 ccpexp/html/basicwizard.html
141     167875 Oct 8 2015 21:31:58 +00:00 ccpexp/html/ccpExpress.css1
142       8453 Oct 8 2015 21:31:58 +00:00 ccpexp/html/ccpExpress.html
143       3418 Oct 8 2015 21:31:58 +00:00 ccpexp/html/ceServer.html
144       6431 Oct 8 2015 21:31:58 +00:00 ccpexp/html/configureDHCP.html
145       9194 Oct 8 2015 21:32:00 +00:00 ccpexp/html/dhcpDns.html
146      17768 Oct 8 2015 21:32:00 +00:00 ccpexp/html/font-awesome.min.css1
147       6331 Oct 8 2015 21:32:02 +00:00 ccpexp/html/frames.html
148       1542 Oct 8 2015 21:32:04 +00:00 ccpexp/html/framesEndUser.html
149      41180 Oct 8 2015 21:32:04 +00:00 ccpexp/html/iAndC.html
150       6001 Oct 8 2015 21:32:42 +00:00 ccpexp/html/jquery.steps.css
151        703 Oct 8 2015 21:32:42 +00:00 ccpexp/html/jsNotEnabled.html
152       3670 Oct 8 2015 21:32:44 +00:00 ccpexp/html/navigationTemplate.html
153      12835 Oct 8 2015 21:32:44 +00:00 ccpexp/html/nv.d3.css
154      23346 Oct 8 2015 21:32:44 +00:00 ccpexp/html/overview.html
155       5634 Oct 8 2015 21:32:44 +00:00 ccpexp/html/phonehome.html
156       1948 Oct 8 2015 21:32:44 +00:00 ccpexp/html/pingAndTrace.html
157      10298 Oct 8 2015 21:32:46 +00:00 ccpexp/html/staticRouting.html
158       1754 Oct 8 2015 21:32:46 +00:00 ccpexp/html/transportCLI.html
159      23602 Oct 8 2015 21:32:46 +00:00 ccpexp/html/user.html
160      68649 Oct 8 2015 21:32:46 +00:00 ccpexp/html/utm.html
161       1970 Oct 8 2015 21:32:48 +00:00 ccpexp/html/wireless.html
162      99397 Oct 8 2015 21:32:48 +00:00 ccpexp/html/wizard.html
163          0 Oct 8 2015 21:31:34 +00:00 ccpexp/js
164          0 Oct 8 2015 21:31:34 +00:00 ccpexp/js/l10n
165          0 Oct 8 2015 21:31:34 +00:00 ccpexp/js/unittest
166        358 Oct 8 2015 21:32:48 +00:00 ccpexp/js/CachedCommands.JSON
167      92452 Oct 8 2015 21:32:50 +00:00 ccpexp/js/HWDictionary.xml
168       1873 Oct 8 2015 21:32:50 +00:00 ccpexp/js/analytics.js
169    1755076 Oct 8 2015 21:32:52 +00:00 ccpexp/js/ccpExpressFeatures.js
170      19236 Oct 8 2015 21:32:52 +00:00 ccpexp/js/ccpExpressValidation.js
171       6216 Oct 8 2015 21:32:54 +00:00 ccpexp/js/cliWorker.js
172       1157 Oct 8 2015 21:32:54 +00:00 ccpexp/js/connectionWorker.js
173      32144 Oct 8 2015 21:32:54 +00:00 ccpexp/js/deviceCommunicator.js
174      25304 Oct 8 2015 21:32:54 +00:00 ccpexp/js/frames.js
175      47569 Oct 8 2015 21:32:56 +00:00 ccpexp/js/performChecks.js
176       5521 Oct 8 2015 21:32:56 +00:00 ccpexp/js/routerDashboardWorker.js
177       5729 Oct 8 2015 21:32:56 +00:00 ccpexp/js/securityDashboardWorker.js
178      17547 Oct 8 2015 21:32:56 +00:00 ccpexp/js/wizard.js
179          0 Oct 8 2015 21:31:36 +00:00 ccpexp/odm
180        506 Oct 8 2015 21:32:58 +00:00 ccpexp/odm/overviewshCpuUtil.odm
181        630 Oct 8 2015 21:32:58 +00:00 ccpexp/odm/overviewshFileSystem.odm
182        813 Oct 8 2015 21:32:58 +00:00 ccpexp/odm/overviewshProcMemory.odm
183        818 Oct 8 2015 21:32:58 +00:00 ccpexp/odm/overviewshVer.odm
184        614 Oct 8 2015 21:32:58 +00:00 ccpexp/odm/wirelessshCdpNeighborDetail.odm
185          0 Oct 8 2015 21:31:36 +00:00 ccpexp/templates
186         85 Oct 8 2015 21:33:14 +00:00 ccpexp/templates/ATMDescription.txt
187         73 Oct 8 2015 21:33:14 +00:00 ccpexp/templates/ChatScript_EVDO.txt
188         72 Oct 8 2015 21:33:14 +00:00 ccpexp/templates/ChatScript_HSPA.txt
189         78 Oct 8 2015 21:33:14 +00:00 ccpexp/templates/ChatScript_HSPA7.txt
190         66 Oct 8 2015 21:33:16 +00:00 ccpexp/templates/ChatScript_LTE.txt
191         76 Oct 8 2015 21:33:16 +00:00 ccpexp/templates/CreateACLforNAT.txt
192       1042 Oct 8 2015 21:33:16 +00:00 ccpexp/templates/CreateATMBackupWanInterface.txt
193       1295 Oct 8 2015 21:33:16 +00:00 ccpexp/templates/CreateATMBackupWanInterfacewithPPPoE.txt
194        174 Oct 8 2015 21:33:18 +00:00 ccpexp/templates/CreateATMPrimaryWanInterface.txt
195        265 Oct 8 2015 21:33:18 +00:00 ccpexp/templates/CreateATMPrimaryWanInterfacewithPPPoE.txt
196       1468 Oct 8 2015 21:33:18 +00:00 ccpexp/templates/CreateBackUpCellular_DiPer_EVDO.txt
197       1431 Oct 8 2015 21:33:18 +00:00 ccpexp/templates/CreateBackUpCellular_DiPer_HSPA.txt
198       1465 Oct 8 2015 21:33:20 +00:00 ccpexp/templates/CreateBackUpCellular_DiPer_HSPA7.txt
199       1314 Oct 8 2015 21:33:20 +00:00 ccpexp/templates/CreateBackUpCellular_NonDiPer_EVDO.txt
200       1284 Oct 8 2015 21:33:20 +00:00 ccpexp/templates/CreateBackUpCellular_NonDiPer_HSPA.txt
201       1284 Oct 8 2015 21:33:20 +00:00 ccpexp/templates/CreateBackUpCellular_NonDiPer_HSPA7.txt
202        999 Oct 8 2015 21:33:20 +00:00 ccpexp/templates/CreateBackWanIntwithPPPoENoDialer.txt
203        907 Oct 8 2015 21:33:22 +00:00 ccpexp/templates/CreateBackupWanInterface.txt
204       1164 Oct 8 2015 21:33:22 +00:00 ccpexp/templates/CreateBackupWanInterfacewithPPPoE.txt
205         42 Oct 8 2015 21:33:22 +00:00 ccpexp/templates/CreateNatObjectGroup.txt
206        158 Oct 8 2015 21:33:24 +00:00 ccpexp/templates/CreatePrimWanIntwithPPPoENoDialer.txt
207        648 Oct 8 2015 21:33:24 +00:00 ccpexp/templates/CreatePrimaryCellular_DiPer_EVDO.txt
208        662 Oct 8 2015 21:33:24 +00:00 ccpexp/templates/CreatePrimaryCellular_DiPer_HSPA.txt
209        699 Oct 8 2015 21:33:24 +00:00 ccpexp/templates/CreatePrimaryCellular_DiPer_HSPA7.txt
210        552 Oct 8 2015 21:33:26 +00:00 ccpexp/templates/CreatePrimaryCellular_NonDiPer_EVDO.txt
211        517 Oct 8 2015 21:33:26 +00:00 ccpexp/templates/CreatePrimaryCellular_NonDiPer_HSPA.txt
212        517 Oct 8 2015 21:33:26 +00:00 ccpexp/templates/CreatePrimaryCellular_NonDiPer_HSPA7.txt
213        174 Oct 8 2015 21:33:26 +00:00 ccpexp/templates/CreatePrimaryWanInterface.txt
214        201 Oct 8 2015 21:33:26 +00:00 ccpexp/templates/CreatePrimaryWanInterfacewithPPPoE.txt
215        106 Oct 8 2015 21:33:28 +00:00 ccpexp/templates/DefaultCws.txt
216         68 Oct 8 2015 21:33:28 +00:00 ccpexp/templates/DefaultInterface.txt
217        696 Oct 8 2015 21:33:28 +00:00 ccpexp/templates/DefaultIps.txt
218        410 Oct 8 2015 21:33:28 +00:00 ccpexp/templates/DefaultZone.txt
219        110 Oct 8 2015 21:33:30 +00:00 ccpexp/templates/EncapsulationPPP.txt
220         96 Oct 8 2015 21:33:30 +00:00 ccpexp/templates/FirewallPolicyCreate.txt
221        271 Oct 8 2015 21:33:30 +00:00 ccpexp/templates/FirewallPolicyDeleteAll.txt
222        390 Oct 8 2015 21:33:32 +00:00 ccpexp/templates/FirewallPolicyDisable.txt
223        233 Oct 8 2015 21:33:32 +00:00 ccpexp/templates/FirewallPolicyEnable.txt
224        172 Oct 8 2015 21:33:32 +00:00 ccpexp/templates/FirewallVPNPolicyCreate.txt
225         39 Oct 8 2015 21:33:32 +00:00 ccpexp/templates/IPSAdd.txt
226        229 Oct 8 2015 21:33:34 +00:00 ccpexp/templates/IPSCompileSignatures.txt
227         42 Oct 8 2015 21:33:34 +00:00 ccpexp/templates/IPSDelete.txt
228         65 Oct 8 2015 21:33:34 +00:00 ccpexp/templates/MMDsl.txt
229         19 Oct 8 2015 21:33:34 +00:00 ccpexp/templates/NofilePrivilege.txt
230       1638 Oct 8 2015 21:33:36 +00:00 ccpexp/templates/ScannerPayloadTemplate.txt
231         56 Oct 8 2015 21:33:36 +00:00 ccpexp/templates/ZoneMgmtAdd.txt
232         59 Oct 8 2015 21:33:36 +00:00 ccpexp/templates/ZoneMgmtDelete.txt
233         45 Oct 8 2015 21:33:36 +00:00 ccpexp/templates/addDNS.txt
234         66 Oct 8 2015 21:33:36 +00:00 ccpexp/templates/addNewDHCP.txt
235         74 Oct 8 2015 21:33:38 +00:00 ccpexp/templates/addNewDHCP_DNS.txt
236         94 Oct 8 2015 21:33:38 +00:00 ccpexp/templates/associateVlan.txt
237         61 Oct 8 2015 21:33:38 +00:00 ccpexp/templates/authRoulToLAN.txt
238        114 Oct 8 2015 21:33:38 +00:00 ccpexp/templates/authorizationPolicy.txt
239         10 Oct 8 2015 21:33:40 +00:00 ccpexp/templates/cdpRun.txt
240        146 Oct 8 2015 21:33:40 +00:00 ccpexp/templates/chap.txt
241         87 Oct 8 2015 21:33:40 +00:00 ccpexp/templates/classMapApp.txt
242         79 Oct 8 2015 21:33:40 +00:00 ccpexp/templates/classMapCategory.txt
243         88 Oct 8 2015 21:33:42 +00:00 ccpexp/templates/classMapParameterMap.txt
244         85 Oct 8 2015 21:33:42 +00:00 ccpexp/templates/classMapPolicy.txt
245        103 Oct 8 2015 21:33:42 +00:00 ccpexp/templates/classMapURL.txt
246         88 Oct 8 2015 21:33:42 +00:00 ccpexp/templates/classMapUserGroup.txt
247        364 Oct 8 2015 21:33:42 +00:00 ccpexp/templates/cnsFormCreate.txt
248        461 Oct 8 2015 21:33:44 +00:00 ccpexp/templates/cnsFormCreateWithIp.txt
249        255 Oct 8 2015 21:33:44 +00:00 ccpexp/templates/cnsFormCreateWithoutIp.txt
250        478 Oct 8 2015 21:33:44 +00:00 ccpexp/templates/cnsFormDelete.txt
251        361 Oct 8 2015 21:33:44 +00:00 ccpexp/templates/cnsFormImage.txt
252        590 Oct 8 2015 21:33:46 +00:00 ccpexp/templates/cnsFormImageDelete.txt
253        478 Oct 8 2015 21:33:46 +00:00 ccpexp/templates/cnsFormIpDelete.txt
254        412 Oct 8 2015 21:33:46 +00:00 ccpexp/templates/cnsFormWithoutIpDelete.txt
255        110 Oct 8 2015 21:33:46 +00:00 ccpexp/templates/configAuthServer.txt
256        161 Oct 8 2015 21:33:48 +00:00 ccpexp/templates/configLDAPIPv4.txt
257        138 Oct 8 2015 21:33:48 +00:00 ccpexp/templates/configNTLMService.txt
258        159 Oct 8 2015 21:33:48 +00:00 ccpexp/templates/configNetFlow.txt
259         46 Oct 8 2015 21:33:48 +00:00 ccpexp/templates/configWebAuthService.txt
260         31 Oct 8 2015 21:33:50 +00:00 ccpexp/templates/contentScan.txt
261        113 Oct 8 2015 21:33:50 +00:00 ccpexp/templates/createATMInterface.txt
262        148 Oct 8 2015 21:33:50 +00:00 ccpexp/templates/createATMInterfacePppoe.txt
263        135 Oct 8 2015 21:33:50 +00:00 ccpexp/templates/createATMInterfaceWithDHCP.txt
264        158 Oct 8 2015 21:33:52 +00:00 ccpexp/templates/createATMInterfaceWithDHCPHostname.txt
265        137 Oct 8 2015 21:33:52 +00:00 ccpexp/templates/createATMInterfaceWithIpv6Autoconfig.txt
266        102 Oct 8 2015 21:33:52 +00:00 ccpexp/templates/createATMInterfaceWithIpv6DhcpClient.txt
267        203 Oct 8 2015 21:33:52 +00:00 ccpexp/templates/createATMInterfaceWithIpv6PrefixFPro.txt
268        165 Oct 8 2015 21:33:54 +00:00 ccpexp/templates/createATMInterfaceWithIpv6StaticIP.txt
269        137 Oct 8 2015 21:33:54 +00:00 ccpexp/templates/createATMInterfaceWithStaticIP.txt
270        417 Oct 8 2015 21:33:54 +00:00 ccpexp/templates/createDialer.txt
271        102 Oct 8 2015 21:33:54 +00:00 ccpexp/templates/createEigrp.txt
272         80 Oct 8 2015 21:33:56 +00:00 ccpexp/templates/createInterface.txt
273        137 Oct 8 2015 21:33:56 +00:00 ccpexp/templates/createLoopback.txt
274        198 Oct 8 2015 21:33:56 +00:00 ccpexp/templates/createNat.txt
275         50 Oct 8 2015 21:33:58 +00:00 ccpexp/templates/createNatOutside.txt
276        131 Oct 8 2015 21:33:58 +00:00 ccpexp/templates/createVLAN.txt
277         57 Oct 8 2015 21:33:58 +00:00 ccpexp/templates/cwsWhiteListing.txt
278         66 Oct 8 2015 21:33:58 +00:00 ccpexp/templates/deConfigAuthRoulToLAN.txt
279        116 Oct 8 2015 21:34:00 +00:00 ccpexp/templates/deConfigAuthServer.txt
280        148 Oct 8 2015 21:34:00 +00:00 ccpexp/templates/deConfigNTLMAuthService.txt
281        174 Oct 8 2015 21:34:00 +00:00 ccpexp/templates/deConfigNetFlow.txt
282         47 Oct 8 2015 21:34:00 +00:00 ccpexp/templates/deConfigWebAuthService.txt
283         67 Oct 8 2015 21:34:02 +00:00 ccpexp/templates/deconfigLDAP.txt
284        108 Oct 8 2015 21:34:02 +00:00 ccpexp/templates/defaultRoute.txt
285         49 Oct 8 2015 21:34:02 +00:00 ccpexp/templates/deleteAclClassMap.txt
286        600 Oct 8 2015 21:34:02 +00:00 ccpexp/templates/deleteBackupInterfaceConfigs.txt
287        745 Oct 8 2015 21:34:04 +00:00 ccpexp/templates/deleteBackupInterfaceConfigsPPPOE.txt
288         44 Oct 8 2015 21:34:04 +00:00 ccpexp/templates/deleteClassMapApp.txt
289         40 Oct 8 2015 21:34:04 +00:00 ccpexp/templates/deleteClassMapUrl.txt
290         34 Oct 8 2015 21:34:04 +00:00 ccpexp/templates/deleteContentScan.txt
291         19 Oct 8 2015 21:34:06 +00:00 ccpexp/templates/deleteCwsWhiteListing.txt
292         25 Oct 8 2015 21:34:06 +00:00 ccpexp/templates/deleteDNS.txt
293         52 Oct 8 2015 21:34:06 +00:00 ccpexp/templates/deleteDescription.txt
294         49 Oct 8 2015 21:34:06 +00:00 ccpexp/templates/deleteDialerList.txt
295         84 Oct 8 2015 21:34:08 +00:00 ccpexp/templates/deleteDomainNameDNS.txt
296         30 Oct 8 2015 21:34:08 +00:00 ccpexp/templates/deleteEigrp.txt
297         80 Oct 8 2015 21:34:08 +00:00 ccpexp/templates/deleteEnableNbarProtocolDiscovery.txt
298        102 Oct 8 2015 21:34:08 +00:00 ccpexp/templates/deleteExternalDNS.txt
299         32 Oct 8 2015 21:34:10 +00:00 ccpexp/templates/deleteGroup.txt
300        100 Oct 8 2015 21:34:10 +00:00 ccpexp/templates/deleteInterface.txt
301         40 Oct 8 2015 21:34:10 +00:00 ccpexp/templates/deleteIpAccessList.txt
302         63 Oct 8 2015 21:34:10 +00:00 ccpexp/templates/deleteLocalDNS.txt
303        163 Oct 8 2015 21:34:12 +00:00 ccpexp/templates/deleteNat.txt
304         56 Oct 8 2015 21:34:12 +00:00 ccpexp/templates/deleteNatOutside.txt
305         36 Oct 8 2015 21:34:12 +00:00 ccpexp/templates/deleteObjectGroupNetwork.txt
306         38 Oct 8 2015 21:34:12 +00:00 ccpexp/templates/deleteObjectService.txt
307         44 Oct 8 2015 21:34:14 +00:00 ccpexp/templates/deleteParameterMap.txt
308         47 Oct 8 2015 21:34:14 +00:00 ccpexp/templates/deletePolicyClassMap.txt
309         40 Oct 8 2015 21:34:14 +00:00 ccpexp/templates/deletePolicyMap.txt
310         73 Oct 8 2015 21:34:14 +00:00 ccpexp/templates/deletePolicyMapClass.txt
311        199 Oct 8 2015 21:34:16 +00:00 ccpexp/templates/deletePrimaryIfRoutesAndAcl.txt
312        347 Oct 8 2015 21:34:16 +00:00 ccpexp/templates/deletePrimaryPPPOE.txt
313        164 Oct 8 2015 21:34:16 +00:00 ccpexp/templates/deletePrimaryRoutes.txt
314        120 Oct 8 2015 21:34:16 +00:00 ccpexp/templates/deleteRedundantRoute.txt
315         32 Oct 8 2015 21:34:18 +00:00 ccpexp/templates/deleteScanSafe.txt
316         60 Oct 8 2015 21:34:18 +00:00 ccpexp/templates/deleteScriptFromLine.txt
317         46 Oct 8 2015 21:34:18 +00:00 ccpexp/templates/deleteUserClassMap.txt
318         85 Oct 8 2015 21:34:20 +00:00 ccpexp/templates/deleteVlan.txt
319        154 Oct 8 2015 21:34:20 +00:00 ccpexp/templates/deleteVpnIkev1.txt
320        104 Oct 8 2015 21:34:20 +00:00 ccpexp/templates/deleteVpnIkev1InterfaceTunnel.txt
321        208 Oct 8 2015 21:34:20 +00:00 ccpexp/templates/deleteVpnIkev2.txt
322        185 Oct 8 2015 21:34:22 +00:00 ccpexp/templates/deleteVpnIkev2InterfaceTunnel.txt
323         63 Oct 8 2015 21:34:22 +00:00 ccpexp/templates/deleteVpnObjectGroup.txt
324         45 Oct 8 2015 21:34:22 +00:00 ccpexp/templates/deleteVpnWhiteListing.txt
325         76 Oct 8 2015 21:34:22 +00:00 ccpexp/templates/deleteZonePair.txt
326         44 Oct 8 2015 21:34:24 +00:00 ccpexp/templates/dest-net-ipv6Interface.txt
327         47 Oct 8 2015 21:34:24 +00:00 ccpexp/templates/dest-net-ipv6InterfaceDelete.txt
328         44 Oct 8 2015 21:34:24 +00:00 ccpexp/templates/dest-net-ipv6Ip.txt
329         37 Oct 8 2015 21:34:24 +00:00 ccpexp/templates/dest-net-ipv6IpDelete.txt
330         33 Oct 8 2015 21:34:26 +00:00 ccpexp/templates/dest-netInterfaceCreate.txt
331         36 Oct 8 2015 21:34:26 +00:00 ccpexp/templates/dest-netInterfaceDelete.txt
332         29 Oct 8 2015 21:34:26 +00:00 ccpexp/templates/dest-netIpCreate.txt
333         29 Oct 8 2015 21:34:26 +00:00 ccpexp/templates/dest-netIpDelete.txt
334         27 Oct 8 2015 21:34:28 +00:00 ccpexp/templates/dest-netIpDhcpCreate.txt
335         30 Oct 8 2015 21:34:28 +00:00 ccpexp/templates/dest-netIpDhcpDelete.txt
336         93 Oct 8 2015 21:34:28 +00:00 ccpexp/templates/deteteATMInterface.txt
337        134 Oct 8 2015 21:34:28 +00:00 ccpexp/templates/deteteDialer.txt
338        119 Oct 8 2015 21:34:30 +00:00 ccpexp/templates/dialerDHCP.txt
339        130 Oct 8 2015 21:34:30 +00:00 ccpexp/templates/dialerDHCPHostname.txt
340        103 Oct 8 2015 21:34:30 +00:00 ccpexp/templates/dialerIPNego.txt
341        117 Oct 8 2015 21:34:30 +00:00 ccpexp/templates/dialerIpv6Autoconfig.txt
342         82 Oct 8 2015 21:34:32 +00:00 ccpexp/templates/dialerIpv6DhcpClient.txt
343        156 Oct 8 2015 21:34:32 +00:00 ccpexp/templates/dialerIpv6PrefixFromProvider.txt
344        135 Oct 8 2015 21:34:32 +00:00 ccpexp/templates/dialerIpv6StaticIP.txt
345        109 Oct 8 2015 21:34:32 +00:00 ccpexp/templates/dialerStaticIP.txt
346         72 Oct 8 2015 21:34:34 +00:00 ccpexp/templates/disableNativeVlanOnInterface.txt
347         59 Oct 8 2015 21:34:34 +00:00 ccpexp/templates/disableTrunkOnInterface.txt
348         75 Oct 8 2015 21:34:34 +00:00 ccpexp/templates/disassociateVlan.txt
349        202 Oct 8 2015 21:34:34 +00:00 ccpexp/templates/domainNameDNS.txt
350        260 Oct 8 2015 21:34:36 +00:00 ccpexp/templates/enableAAAConfig.txt
351         23 Oct 8 2015 21:34:36 +00:00 ccpexp/templates/enableIpv6UnicastRouting.txt
352         73 Oct 8 2015 21:34:36 +00:00 ccpexp/templates/enableLicense.txt
353         84 Oct 8 2015 21:34:38 +00:00 ccpexp/templates/enableNativeVlanOnInterface.txt
354         74 Oct 8 2015 21:34:38 +00:00 ccpexp/templates/enableNbarProtocolDiscovery.txt
355         68 Oct 8 2015 21:34:38 +00:00 ccpexp/templates/enableTrunkOnInterface.txt
356         73 Oct 8 2015 21:34:38 +00:00 ccpexp/templates/encryptLicenseCWS.txt
357         84 Oct 8 2015 21:34:38 +00:00 ccpexp/templates/externalDNS.txt
358         19 Oct 8 2015 21:34:40 +00:00 ccpexp/templates/filePrivilege.txt
359         88 Oct 8 2015 21:34:40 +00:00 ccpexp/templates/group.txt
360         69 Oct 8 2015 21:34:40 +00:00 ccpexp/templates/hostnameDomainname.txt
361         39 Oct 8 2015 21:34:40 +00:00 ccpexp/templates/import.txt
362         63 Oct 8 2015 21:34:42 +00:00 ccpexp/templates/interfaceDescription.txt
363         61 Oct 8 2015 21:34:42 +00:00 ccpexp/templates/interfaceMediaType.txt
364         51 Oct 8 2015 21:34:42 +00:00 ccpexp/templates/interfaceNoShut.txt
365        114 Oct 8 2015 21:34:42 +00:00 ccpexp/templates/interfacePppoe.txt
366         45 Oct 8 2015 21:34:44 +00:00 ccpexp/templates/interfaceShut.txt
367         86 Oct 8 2015 21:34:44 +00:00 ccpexp/templates/interfaceWithDHCP.txt
368        109 Oct 8 2015 21:34:44 +00:00 ccpexp/templates/interfaceWithDHCPHostname.txt
369         92 Oct 8 2015 21:34:44 +00:00 ccpexp/templates/interfaceWithIPNego.txt
370        114 Oct 8 2015 21:34:46 +00:00 ccpexp/templates/interfaceWithIpv6Autoconfig.txt
371        123 Oct 8 2015 21:34:46 +00:00 ccpexp/templates/interfaceWithIpv6DhcpClient.txt
372        153 Oct 8 2015 21:34:46 +00:00 ccpexp/templates/interfaceWithIpv6PrefixFromProvider.txt
373        132 Oct 8 2015 21:34:46 +00:00 ccpexp/templates/interfaceWithIpv6StaticIP.txt
374         88 Oct 8 2015 21:34:48 +00:00 ccpexp/templates/interfaceWithStaticIP.txt
375         29 Oct 8 2015 21:34:48 +00:00 ccpexp/templates/ipv4DHCPDelete.txt
376         42 Oct 8 2015 21:34:48 +00:00 ccpexp/templates/ipv4DHCPDelete_DNS.txt
377        193 Oct 8 2015 21:34:48 +00:00 ccpexp/templates/licenseCWS.txt
378         49 Oct 8 2015 21:34:50 +00:00 ccpexp/templates/localDNS.txt
379        132 Oct 8 2015 21:34:50 +00:00 ccpexp/templates/loopbackIpv6StaticIP.txt
380         90 Oct 8 2015 21:34:50 +00:00 ccpexp/templates/loopbackStaticIP.txt
381     106537 Oct 8 2015 21:34:50 +00:00 ccpexp/templates/masking_rule.xml
382         48 Oct 8 2015 21:34:52 +00:00 ccpexp/templates/natInside.txt
383        155 Oct 8 2015 21:34:52 +00:00 ccpexp/templates/networkPortAccessList.txt
384         13 Oct 8 2015 21:34:52 +00:00 ccpexp/templates/noCdpRun.txt
385         47 Oct 8 2015 21:34:52 +00:00 ccpexp/templates/noDefaultRoute.txt
386         50 Oct 8 2015 21:34:54 +00:00 ccpexp/templates/noDslGroup0.txt
387         11 Oct 8 2015 21:34:54 +00:00 ccpexp/templates/noIpSla.txt
388         51 Oct 8 2015 21:34:54 +00:00 ccpexp/templates/noNatInside.txt
389         42 Oct 8 2015 21:34:54 +00:00 ccpexp/templates/noimport.txt
390         61 Oct 8 2015 21:34:56 +00:00 ccpexp/templates/objectGroupNetwork.txt
391        111 Oct 8 2015 21:34:56 +00:00 ccpexp/templates/objectGroupPort.txt
392        137 Oct 8 2015 21:34:56 +00:00 ccpexp/templates/pap.txt
393        220 Oct 8 2015 21:34:56 +00:00 ccpexp/templates/papchap.txt
394         76 Oct 8 2015 21:34:58 +00:00 ccpexp/templates/parameterMapURL.txt
395        276 Oct 8 2015 21:34:58 +00:00 ccpexp/templates/parserCLIAaaCommands.txt
396        305 Oct 8 2015 21:34:58 +00:00 ccpexp/templates/parserCLICellularCommands.txt
397        201 Oct 8 2015 21:34:58 +00:00 ccpexp/templates/parserCLIDeleteAaaCommand.txt
398         29 Oct 8 2015 21:35:00 +00:00 ccpexp/templates/parserCLIDeleteView.txt
399         55 Oct 8 2015 21:35:00 +00:00 ccpexp/templates/parserCLIInterface.txt
400        667 Oct 8 2015 21:35:00 +00:00 ccpexp/templates/parserCLIView.txt
401        242 Oct 8 2015 21:35:00 +00:00 ccpexp/templates/parserCLIWlanCommand.txt
402         26 Oct 8 2015 21:35:02 +00:00 ccpexp/templates/parserUserDeleteCmd.txt
403        110 Oct 8 2015 21:35:02 +00:00 ccpexp/templates/policyMap.txt
404         96 Oct 8 2015 21:35:02 +00:00 ccpexp/templates/removeAccessList23.txt
405       1160 Oct 8 2015 21:35:02 +00:00 ccpexp/templates/sampleSwitchConfiguration.txt
406        104 Oct 8 2015 21:35:02 +00:00 ccpexp/templates/scanSafeNameOrIPv4.txt
407        108 Oct 8 2015 21:35:04 +00:00 ccpexp/templates/secondaryIPv4OrName.txt
408        102 Oct 8 2015 21:35:04 +00:00 ccpexp/templates/setDefaultRoute.txt
409         63 Oct 8 2015 21:35:04 +00:00 ccpexp/templates/setMTUSize.txt
410         52 Oct 8 2015 21:35:04 +00:00 ccpexp/templates/shdslATM.txt
411         50 Oct 8 2015 21:35:06 +00:00 ccpexp/templates/shdslAUTO.txt
412         64 Oct 8 2015 21:35:06 +00:00 ccpexp/templates/shdslEFM.txt
413         50 Oct 8 2015 21:35:06 +00:00 ccpexp/templates/shdslEFMATM.txt
414         93 Oct 8 2015 21:35:06 +00:00 ccpexp/templates/shdslMMEFMATM.txt
415         73 Oct 8 2015 21:35:08 +00:00 ccpexp/templates/shutdownDmvpn.txt
416        446 Oct 8 2015 21:35:08 +00:00 ccpexp/templates/tunnelConfiguration.txt
417         21 Oct 8 2015 21:35:08 +00:00 ccpexp/templates/userFormDelete.txt
418         61 Oct 8 2015 21:35:08 +00:00 ccpexp/templates/userPasswordCreate.txt
419         59 Oct 8 2015 21:35:10 +00:00 ccpexp/templates/userSecretCreate.txt
420         48 Oct 8 2015 21:35:10 +00:00 ccpexp/templates/userToGroup.txt
421        570 Oct 8 2015 21:35:10 +00:00 ccpexp/templates/vpnIKEv1.txt
422        782 Oct 8 2015 21:35:10 +00:00 ccpexp/templates/vpnIKEv2.txt
423        323 Oct 8 2015 21:35:12 +00:00 ccpexp/templates/vpnIkev1InterfaceTunnel.txt
424        300 Oct 8 2015 21:35:12 +00:00 ccpexp/templates/vpnIkev2InterfaceTunnel.txt
425         85 Oct 8 2015 21:35:12 +00:00 ccpexp/templates/vpnWhiteListing.txt
426         20 Oct 8 2015 21:35:12 +00:00 ccpexp/templates/wanMode.txt
427        117 Oct 8 2015 21:35:12 +00:00 ccpexp/templates/zonePair.txt
428          0 Oct 8 2015 21:31:36 +00:00 ccpexp/templates2
429        907 Oct 8 2015 21:33:00 +00:00 ccpexp/templates2/CellularNanoDialer.txt
430        687 Oct 8 2015 21:33:00 +00:00 ccpexp/templates2/CellularNanoSim0.txt
431       8400 Oct 8 2015 21:33:00 +00:00 ccpexp/templates2/EMScriptCellular.txt
432       1683 Oct 8 2015 21:33:00 +00:00 ccpexp/templates2/EMScriptSingleSIM.txt
433      11980 Oct 8 2015 21:33:02 +00:00 ccpexp/templates2/EMScriptTemplate.txt
434      72061 Oct 8 2015 21:33:02 +00:00 ccpexp/templates2/Quick_Setup.txt
435         51 Oct 8 2015 21:33:02 +00:00 ccpexp/templates2/addNAT.txt
436         61 Oct 8 2015 21:33:02 +00:00 ccpexp/templates2/addNATInterface.txt
437         95 Oct 8 2015 21:33:04 +00:00 ccpexp/templates2/addNATwithPort.txt
438         85 Oct 8 2015 21:33:04 +00:00 ccpexp/templates2/addPort.txt
439         61 Oct 8 2015 21:33:04 +00:00 ccpexp/templates2/assignProfile.txt
440         41 Oct 8 2015 21:33:04 +00:00 ccpexp/templates2/cntrlrOperatingMode.txt
441         58 Oct 8 2015 21:33:06 +00:00 ccpexp/templates2/createClockRate.txt
442        214 Oct 8 2015 21:33:06 +00:00 ccpexp/templates2/createDialerEthernet.txt
443        230 Oct 8 2015 21:33:06 +00:00 ccpexp/templates2/createSerialPPP.txt
444        109 Oct 8 2015 21:33:06 +00:00 ccpexp/templates2/createSubEthernet.txt
445         60 Oct 8 2015 21:33:08 +00:00 ccpexp/templates2/createSubEthernetWithoutPPPoE.txt
446        151 Oct 8 2015 21:33:08 +00:00 ccpexp/templates2/deleteATMInterfacePppoe.txt
447         41 Oct 8 2015 21:33:08 +00:00 ccpexp/templates2/deleteDHCPDefaultRoute.txt
448        105 Oct 8 2015 21:33:08 +00:00 ccpexp/templates2/deleteEthernetInterfacePppoe.txt
449         72 Oct 8 2015 21:33:10 +00:00 ccpexp/templates2/deleteNATInterface.txt
450         98 Oct 8 2015 21:33:10 +00:00 ccpexp/templates2/deleteNATIntwithPort.txt
451         62 Oct 8 2015 21:33:10 +00:00 ccpexp/templates2/deleteNATVal.txt
452         88 Oct 8 2015 21:33:10 +00:00 ccpexp/templates2/deleteOldNAT.txt
453         85 Oct 8 2015 21:33:12 +00:00 ccpexp/templates2/deleteSerialPPP.txt
454         61 Oct 8 2015 21:33:12 +00:00 ccpexp/templates2/interfaceWithDHCPPool.txt
455         57 Oct 8 2015 21:33:12 +00:00 ccpexp/templates2/setPrimarySimSlot.txt
456        255 Oct 8 2015 21:33:12 +00:00 ccpexp/templates2/vpnIkev1Modified.txt
457     132462 Oct 8 2015 21:31:36 +00:00 ccpexp/CCPExpress_3.1_Open_Source_Documentation.html
458         72 Oct 8 2015 21:35:14 +00:00 ccpexp/version.txt
459       2885 Oct 8 2015 21:35:14 +00:00 home.shtml
460     496555 Nov 20 2015 09:24:08 +00:00 802.ulaw.wav
44847104 bytes available (216350720 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Manufacturer Name
   Model Number           UGB30STX0256Z6-FAA-2
   Serial Number          UNIGEN4     00824047
   Firmware Revision      100511g
   Number of Heads        16
   Number of Cylinders    998
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          510976
ATA PARTITION 1 INFO
   Start Sector           32
   Number of Sectors      510944
   Size in Bytes          261603328
   File System Type       FAT16
   Number of FAT Sectors  250
   Sectors Per Cluster    8
   Number of Clusters     63769
   Number of Data Sectors 510152
   Base FAT Sector        259
   Base Root Sector       759
   Base Data Sector       791
ATA MONLIB INFO
   Image Monlib size      128064
   Disk Monlib Size       128064
   Disk Space Available   132096
   Name                   piptom-atafslib-m
   Start sector           2
   End sector             252
   Updated By             C2900-UNIVERSALK9-M15.4(3)M3
   Version                2
------------------ dir nvram: ------------------
Directory of nvram:/
  242  -rw-       11655                    <no date>  startup-config
  243  ----        1921                    <no date>  private-config
  244  -rw-       11655                    <no date>  underlying-config
    1  -rw-        2945                    <no date>  cwmp_inventory
    4  ----         438                    <no date>  persistent-data
    5  -rw-          17                    <no date>  ecfm_ieee_mib
    6  -rw-         559                    <no date>  IOS-Self-Sig#1.cer
    7  -rw-           0                    <no date>  ifIndex-table
262136 bytes total (241340 bytes free)
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   3D5688A0   278812412    93433112   185379300    43652212   151438616
      I/O    D800000    41943040    18566272    23376768    23324176    23226364
------------------ show process memory ------------------
Processor Pool Total:  278812412 Used:   93425804 Free:  185386608
      I/O Pool Total:   41943040 Used:   18566144 Free:   23376896
 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  230137852  151093976   70363944        931      29072 *Init*
   0   0      12764    1879360      12764        747        747 *Sched*
   0   0   56779620   44491052   15596692         42         41 *Dead*
   0   0          0          0     460556          0          0 *MallocLite*
   1   0    1109820          0    1117084          0          0 Chunk Manager
   2   0        240        240       4264          0          0 Load Meter
   3 388    5845264    5750880     106588        277        277 SSH Process
   4   0      65588          0      90852          0          0 EDDRI_MAIN
   5   0          0          0       7264          0          0 RO Notify Timers
   6   0       3408        240      10432          0          0 Check heaps
   7   0   36832884   37001368     204256         49          0 Pool Manager
   8   0          0          0       7264          0          0 DiscardQ Backgro
   9   0        240        240       7264          0          0 Timers
  10   0          0          0       4264          0          0 WATCH_AFS
  11   0          0          0       7264          0          0 License Client N
  12   0          0          0       7264          0          0 Image License br
  13   0 4172647592 4172648404       7328          0          0 Licensing Auto U
  14   0          0          0       4264          0          0 RMI RM Notify Wa
  15   0        240        240       7264          0          0 Environmental mo
  16   0          0          0       7264          0          0 IPC Event Notifi
  17   0          0          0       7264          0          0 IPC Dynamic Cach
  18   0          0          0       7264          0          0 IPC Session Serv
  19   0          0          0       7264          0          0 IPC Zone Manager
  20   0          0          0       7264          0          0 IPC Periodic Tim
  21   0          0          0       7264          0          0 IPC Deferred Por
  22   0          0          0       7264          0          0 IPC Process leve
  23   0       2104          0       9368          0          0 IPC Seat Manager
  24   0          0          0       7264          0          0 IPC Check Queue
  25   0          0          0       7264          0          0 IPC Seat RX Cont
  26   0          0          0       7264          0          0 IPC Seat TX Cont
  27   0          0          0       7264          0          0 IPC Keep Alive M
  28   0          0          0       7264          0          0 IPC Loadometer
  29   0          0          0      25264          0          0 Crash writer
  30   0        380          0       7644          0          0 Exception contro
  31   0      35572          0       9056        196        196 TACACS+
  32   0          0          0       7264          0          0 IFS Agent Manage
  33   0      17736        976      24024         97         97 ARP Input
  34   0      11756       6824       7264         12         12 ARP Background
  35   0        240        240       7264          0          0 ATM Idle Timer
  36   0          0          0       7264          0          0 ATM ASYNC PROC
  37   0          0          0       7264          0          0 CEF MIB API
  38   0          0          0       7264          0          0 AAA_SERVER_DEADT
  39   0          0          0      13264          0          0 Policy Manager
  40   0        240        240       7264          0          0 DDR Timers
  41   0       5288         80      12472         30         30 Entity MIB API
  42   0        996        996       7264          0          0 PrstVbl
  43   0        240        240       7264          0          0 Serial Backgroun
  44   0          0          0      13264          0          0 License IPC stat
  45   0          0          0      13264          0          0 License IPC serv
  46   0       8460       8536       7264          2          2 SMART
  47   0     272704       1664     278096          0          0 RF SCTPthread
  48   0       1688          0       8952          0          0 CHKPT RG SCTPthr
  49   0          0          0       7264          0          0 ARP Snoop
  50   0        240        240       7264          0          0 GraphIt
  51   0        240        240      13264          0          0 Dialer event
  52   0          0          0       7264          0          0 SERIAL A'detect
  53   0        240        240      13264          0          0 XML Proxy Client
  54   0     123884     146612       7804          0          0 crypto sw pk pro
  55   0          0          0       7264          0          0 Critical Bkgnd
  56   0      61996       1796      21544       6573       6573 Net Background
  57   0        760        760      13264          0          0 IDB Work
  58   0        240        240      13264       1006       1006 Logger
  59   0     218748      59988      53024        733        733 TTY Background
  60   0      10052          0      17244          0          0 Skinny MOH Event
  61   0       1044          0      14308          0          0 CTS CORE
  62   0       1044       3980      14068          0          0 SXP CORE
  63   0      22196      16164      22976          0          0 RF Slave Main Th
  64   0      66532          0      73796          0          0 IF-MGR control p
  65   0          0          0       7264          0          0 IF-MGR event pro
  66   0          0          0       4264          0          0 Inode Table Dest
  67   0          0          0       7264          0          0 cpf_msg_holdq_pr
  68   0          0          0       7264          0          0 cpf_msg_rcvq_pro
  69   0          0          0       7264          0          0 cpf_process_tpQ
  70   0          0          0       7264          0          0 CHKPT Test clien
  71   0          0          0       7264          0          0 CHKPT Test clien
  72   0          0          0       7264          0          0 CHKPT Test clien
  73   0          0          0       7264          0          0 CHKPT Test clien
  74   0          0          0       7264          0          0 CHKPT Test clien
  75   0          0          0       7264          0          0 CHKPT Test clien
  76   0          0          0       7264          0          0 CHKPT Test clien
  77   0          0          0       7264          0          0 CHKPT Test clien
  78   0          0          0       7264          0          0 CHKPT Test clien
  79   0          0          0       7264          0          0 CHKPT Test clien
  80   0          0          0       7264          0          0 CHKPT Test clien
  81   0          0          0      13264          0          0 Crypto PKI-HA
  82   0        240        240       7264          0          0 TDM Management
  83   0      17732       9292      10716          0          0 RF Master Main T
  84   0       1688          0       8952          0          0 RF Master Status
  85   0          0          0       7264          0          0 Net Input
  86   0        240        240       7264          0          0 Compute load avg
  87   0     959140    1928332       7264          0          0 Per-minute Jobs
  88   0        548        456      10356          0          0 Per-Second Jobs
  89   0          0          0       7264          0          0 AggMgr Process
  90   0          0          0       7264          0          0 Token Daemon
  91   0          0          0       7264          0          0 Transport Port A
  92   0          0          0       7264          0          0 HC Counter Timer
  93   0        240        240       7264          0          0 SM Monitor
  94   0        240        240       7264          0          0 Bryce I2C CMD Qu
  95   0        240        240      13264          0          0 SM Installer
  96   0          0          0       4264          0          0 dev_device_inser
  97   0          0          0       4264          0          0 dev_device_remov
  98   0          0          0      13264          0          0 sal_dpc_process
  99   0          0          0       7264          0          0 ARL Table Manage
 100   0        240        240       7264          0          0 ESWPPM
 101   0        240        240       7264          0          0 Eswilp Storm Con
 102   0        240        240       7264          0          0 ESWILPPM
 103   0        240        240       4264          0          0 Eswilp Storm Con
 104   0       4968        240      11992          0          0 DXMRVL
 105   0          0          0       7264          0          0 esw_mrvl mat que
 106   0        240        240       7264          0          0 ehwic_eswge Proc
 107   0          0          0       7264          0          0 RF_INTERDEV_DELA
 108   0          0          0      25264          0          0 RF_INTERDEV_SCTP
 109   0      11960       5208      17184          0          0 EEM ED Identity
 110   0      48684    1818284      53544          0          0 EEM ED ND
 111   0          0          0       7264          0          0 VIDEO DSPRM MAIN
 112   0     160460        240     167484          0          0 VNM DSPRM MAIN
 113   0       7848        240       7264          2          2 FLEX DNLD MAIN
 114   0        240        240       7264          0          0 UCSE Monitor
 115   0        240        240       7264          0          0 Ether-Switch RBC
 116   0          0          0      13128          0          0 Skinny Socket Se
 117   0          0          0       7264          0          0 IGMP Snooping Pr
 118   0          0          0       7264          0          0 IGMP Snooping Re
 119   0        240        240       7264          0          0 Call Management
 120   0     212672        316     194356          0          0 USB Startup
 121   0          0          0      25264          0          0 CF_INTERDEV_SCTP
 122   0        240        240       7264          0          0 BPSM stat Proces
 123   0        240          0       4504          0          0 Async write proc
 124   0        240          0       4504          0          0 Async write proc
 125   0        240          0       4504          0          0 Async write proc
 126   0        240          0       4504          0          0 Async write proc
 127   0          0          0       4264          0          0 DFS flush period
 128   0     366936     212080     148328          0          0 mDNS
 130   0       1992          0       9256          0          0 FHRP Main thread
 131   0       1908          0       9172          0          0 VRRP Main thread
 132   0      54508        416      61356          0          0 VRRS Main thread
 133   0        240        240       7264          0          0 IP NAT HA BGND P
 134   0        240        240      13264          0          0 Auth Manager
 135   0          0          0       7264          0          0 AUTH POLICY Fram
 136   0        284        284       7264          0          0 Dot1x Mgr Proces
 137   0          0          0       7264          0          0 802.1x Webauth F
 138   0          0          0       7264          0          0 EAP Framework
 139   0        240        240       7264          0          0 CMD HANDLER
 140   0       1152        240       8176          0          0 DTP Protocol
 141   0          0          0       7264          0          0 SFF8472
 142   0        240        240       7264          0          0 PI MATM Aging Pr
 143   0        240        240       7264          0          0 EtherChnl
 144   0       3208        240      10232          0          0 call_home_les_oi
 145   0       3168          0      28432          0          0 SMI Director DB
 146   0          0          0       7264          0          0 SMI CDP Update H
 147   0        704          0      25968          0          0 SMI Backup Proce
 148   0        240        240      13264          0          0 RG Faults Timer
 149   0        240        240      13264          0          0 RG Protocol Time
 150   0       4968        240      17992          0          0 RG Transport Tim
 151   0          0          0       7264          0          0 RG VP
 152   0        240        240       7264          0          0 RG AR
 153   0          0          0       7264          0          0 DHCP Snooping
 154   0        240        240      10264          0          0 IP Host Track Pr
 155   0      16832        240      23856          0          0 AAA Server
 156   0          0          0       7264          0          0 AAA ACCT Proc
 157   0      49420          0      56684          0          0 ACCT Periodic Pr
 158   0          0          0       7264          0          0 AAA System Acct
 159   0    5238704    2957348     499456       2387       2387 CDP Protocol
 161   0      58468          0       9104          0          0 Call Home Timer
 162   0        240        240       7264          0          0 AAA Dictionary R
 163   0        240        240      13264          0          0 Ethernet LMI
 164   0        240        240      10264          0          0 Ethernet OAM Pro
 165   0        240          0      13504          0          0 CEF switching ba
 166   0        224          0       4488          0          0 ADJ NSF process
 167   0       1892          0       9156          0          0 TRACK Main threa
 168   0       1864          0       9128          0          0 TRACK Client thr
 169   0        240        240      13264          0          0 ATM OAM Input
 170   0        240        240      13264          0          0 ATM OAM TIMER
 171   0        240        240       7264          0          0 IPAM/ODAP Events
 172   0      49392          0      62656          0          0 IPAM Manager
 173   0        240        240      13264          0          0 IPAM Events
 174   0       2572        212      15376          0          0 IP ARP Adjacency
 175   0      49384          0      56648          0          0 IP ARP Retry Age
 176   0     103264      54088      22192      24875      24869 IP Input
 177   0          0          0       7264          0          0 ICMP event handl
 178   0        240        240       7264          0          0 PIM register asy
 179   0        240        240       7264          0          0 NAT64 Bgnd Proce
 180   0       6708        240       7264        111        111 MOP Protocols
 181   0        240        240       7264          0          0 PPP SIP
 182   0        240        240       7264          0          0 PPP Bind
 183   0        240        240      13264          0          0 PPP IP Route
 184   0          0          0      10264          0          0 HQF TARGET DYNAM
 186   0          0          0       7264          0          0 RIB LM VALIDATE
 187   0          0          0      13264          0          0 SSS Manager
 188   0          0          0      13264          0          0 SSS Policy Manag
 189   0          0          0       7264          0          0 SSS Feature Mana
 190   0          0          0       7264          0          0 SSS Feature Time
 191   0        480        240      13504          0          0 Spanning Tree
 192   0        240        240      13264          0          0 SSM connection m
 193   0          0          0      13264          0          0 WAAS Process
 194   0          0          0       7264          0          0 X.25 Encaps Mana
 195   0          0          0       7264          0          0 IPv6 ping proces
 196   0       1840        240      26864          0          0 Ethernet CFM
 197   0        240        240      13264          0          0 Ethernet Timer C
 198   0        240        240      13264          0          0 Ethernet Msec Ti
 199   0        240        240      25264          0          0 Ethernet CFM PAL
 200   0          0          0       7264          0          0 FRR Background P
 201   0      24396      20372      17372          0          0 CEF background p
 202   0        224          0      13488          0          0 fib_fib_bfd_sb e
 203   0        240        372      13264          0          0 Flow Exporter Ti
 204   0        240        240      13264          0          0 Flow Exporter Pa
 205   0        224          0      10488          0          0 Tunnel FIB
 206   0          0          0       7264          0          0 HQF Output Shape
 207   0          0          0       7264          0          0 HQF Input Shaper
 208   0        240        240       7264          0          0 IPMUXv4
 209   0        240        240       7264          0          0 IPMUXv6
 210   0          0          0       7264          0          0 IPC UDP Input
 211   0      16636       3504      22528          0          0 CEF: IPv4 proces
 212   0        224          0      13488          0          0 ADJ background
 213   0        948       1176      13496          0          0 Collection proce
 214   0          0          0       7264          0          0 Socket Timers
 215   0          0          0       7264          0          0 Critical Auth
 216   0        480        240       7504          0          0 Dot1x Supplicant
 217   0        480        240       7504          0          0 Dot1x Supplicant
 218   0        480        240       7504          0          0 Dot1x Supplicant
 219   0        796        160       8060          0          0 L2MM
 220   0          0          0       7264          0          0 MRD
 221   0          0          0       7264          0          0 IGMPSN
 222   0        240        240       4264          0          0 L2X Switching Ev
 223   0          0          0       7264          0          0 MAB Framework
 224   0        240        240      13264          0          0 RG Media Timer
 225   0          0          0      13264          0          0 RG If-Mgr Timer
 226   0          0          0      13264          0          0 Routing Topology
 227   0      47072          0      60124          0          0 IP RIB Update
 228   0       6184       9436      12076          0          0 IP Background
 229   0      82764        960      92068          0          0 IP Connected Rou
 230   0          0          0       7264          0          0 IP Traceroute
 231   0        368          0       7632          0          0 Service Routing
 232   0      34792       5088      36968          0          0 SR CapMan Proces
 233   0          0          0       7264          0          0 SNMP Timers
 234   0      85324        240      26520          0          0 SCTP Main Proces
 235   0          0      92200      13264       7764       7764 TCP Timer
 236   0     256412          0      15156          0          0 TCP Protocols
 237   0        944          0      26208          0          0 HTTP CORE
 238   0          0          0       7264          0          0 IUA Main Process
 239   0        240        240       7264          0          0 RUDPV1 Main Proc
 240   0          0          0       7264          0          0 bsm_timers
 241   0          0          0       7264          0          0 bsm_xmt_proc
 242   0        240        240       7264          0          0 PPP Compress Inp
 243   0        240        240       7264          0          0 PPP Compress Res
 244   0        944          0      62208          0          0 COPS
 245   0        240        240       7264          0          0 Dialer Forwarder
 246   0        444        220      13488          1          1 ADJ resolve proc
 248   0        240        240      13264          0          0 Tunnel
 249   0        308        376      13488          0          0 MFIB Master back
 250   0        996        240      11020          0          0 MVPN Mgr Process
 251   0        480        240      10504          0          0 Multicast Offloa
 252   0          0          0       7264          0          0 RARP Input
 253   0        240       1500      10264          0          0 static
 254   0        240        240      10264          0          0 App Route Proces
 255   0          0          0      10264          0          0 IPv6 RIB Cleanup
 256   0          0          0      10264          0          0 IPv6 RIB Event H
 257   0          0          0      10264          0          0 IP IRDP
 258   0          0          0       7264          0          0 LAPB Process
 259   0          0          0       7264          0          0 PAD InCall
 260   0        240        240      13264          0          0 X.25 Background
 261   0     278672     278672      10264          0          0 QoS stats proces
 262   0          0          0      13264          0          0 VPDN call manage
 263   0      10616          0      17812          2          2 SSH Event handle
 264   0          0          0      10264          0          0 IPv6 Static Hand
 265   0          0          0      10264          0          0 Ethernet Datapla
 266   0          0          0      10264          0          0 Ethernet PM Proc
 267   0        240        240      10264          0          0 Ethernet PM Soft
 268   0          0          0      13264          0          0 Ethernet PM Moni
 269   0        240        240       7264          0          0 RLM groups Proce
 270   0        240        240       7264          0          0 PPP NBF
 271   0       1044        240      26068          0          0 Border Element p
 272   0       1196        240      26220          0          0 gk process
 273   0       1048        240       8072          0          0 CRM_CALL_UPDATE_
 275   0        240        240       7264          0          0 AAA Cached Serve
 276   0        240        240       7264          0          0 ENABLE AAA
 277   0          0          0       7264          0          0 EM Background Pr
 278   0          0          0       7264          0          0 IDMGR CORE
 279   0          0          0      13264          0          0 Opaque Database
 280   0          0          0       7264          0          0 Key chain liveke
 281   0        240        240       7264          0          0 LINE AAA
 282   0        240        240      13264          0          0 LOCAL AAA
 283   0     487548     431236      21012        354        353 TPLUS
 284   0     285728     284184       8808         33         33 NIST rng proc
 285   0       1044        240      14068          0          0 LDAP process
 286   0      51488        104      58584          0          0 MMA DB TIMER
 287   0      25672        240      50696          0          0 STUN_APP
 288   0        944          0      26208          0          0 STUN_TEST
 289   0        240        240       7264          0          0 VSP_MGR
 290   0        240        240       4264          0          0 RSCMSM VOLUME MO
 291   0        240        240       7264          0          0 CSDB Timer proce
 292   0          0          0       7264          0          0 crypto engine pr
 293   0          0          0      13264          0          0 RSA background p
 294   0     285436     238740      60036          1          1 Crypto CA
 295   0        240        240      13264          0          0 Crypto PKI-CRL
 296   0          0          0      13264          0          0 Crypto PKI-Rev-P
 297   0        944          0      14208          0          0 PKI OCSP
 298   0          0          0      13264          0          0 PKI Revocation
 299   0          0          0      13264          0          0 encrypt proc
 300   0       5564        104      12828          0          0 MMA DP TIMER
 301   0       5368          0      12632          0          0 PERFMON ASYNC TI
 302   0     207180        240       9092          0          0 FLEX DSPRM MAIN
 303   0          0          0       7264          0          0 FLEX DSP KEEPALI
 304   0      28252          0      41516          0          0 CCVPM_HTSP
 305   0        240        240       7264          0          0 VPM_MWI_BACKGROU
 307   0        932          0       8196          0          0 VPM_CONN_CHK_BAC
 308   0        436          0       7700          0          0 CCVPM_R2
 309   0       1308          0       8572          0          0 IP TRUST Registe
 310   0          0          0       7264          0          0 EPHONE MWI Refre
 311   0          0          0       7264          0          0 FB/KS Log HouseK
 312   0        240        240       7264          0          0 EPHONE MWI BG Pr
 313   0       8244          0      15508          0          0 Skinny HW confer
 314   0          0          0      13264          0          0 CCSIP_EVENT_TRAC
 315   0      10932        240      35956          0          0 CTI Front End Pr
 316   0        240        240       7264          0          0 CTI Call Control
 317   0        240        240       7264          0          0 CTI Line Monitor
 318   0          0          0       7264          0          0 CME CTI Device M
 319   0        480        480      13264          0          0 VOICE REG BG Pro
 320   0        240        240      13264          0          0 CME Extension Mo
 321   0          0          0       7264          0          0 Presence Process
 322   0          0          0       7264          0          0 DS0 PCM Capture
 323   0       7608        240      20632          0          0 Sip MPA
 325   0        944          0      62208          0          0 http client proc
 327   0     266424          0     276688          0          0 QOS_MODULE_MAIN
 328   0        284          0      25548          0          0 RPMS_PROC_MAIN
 329   0          0          0      25264          0          0 VoIP AAA
 330   0      25684        240      32708          0          0 Dialog Manager
 331   0     201748          0     215012          0          0 VOIP_FMD_MAIN
 332   0          0          0      10264          0          0 Licensing MIB pr
 333   0        240        240       7264          0          0 Control-plane ho
 334   0          0          0       7264          0          0 PM Callback
 335   0        240        240       7264          0          0 dhcp snooping sw
 337   0       6340      23736       7264          0          0 AAA SEND STOP EV
 338   0          0          0      13264          0          0 Test AAA Client
 339   0       2532          0       9796          0          0 dcm_cli_engine
 340   0       5592        292      12668          0          0 dcm_cli_provider
 341   0      20380       5760      22032          0          0 DCM Core Thread
 342   0      11644       5008      16900          0          0 EEM ED Routing
 343   0     287068       4988     292344       2982       2950 EEM ED Syslog
 344   0     212004       4988     217280          0          0 EEM ED Generic
 345   0      11620       4988      16896          0          0 EEM ED NHRP
 346   0      11628       4988      16904          0          0 EEM ED Track
 347   0      13440       4988      18716          0          0 EEM ED Resource
 348   0       4968        240      11992          0          0 RMON Recycle Pro
 349   0        240        240       7264          0          0 RMON Deferred Se
 350   0          0          0       7264          0          0 Syslog Traps
 351   0          0          0       7264          0          0 WAN Optimization
 353   0       9352       1552      14904          2          2 VLAN Manager
 354   0      29204        772      54384          0          0 LICENSE AGENT
 355   0       2512        524      15252          0          0 RBM CORE
 356   0       3104        480       9888          0          0 CTS credentials
 357   0    1384932      20552    1371644          0          0 EEM Server
 358   0     145184     104008     133004          0          0 Call Home proces
 359   0      10056        260       9012          0          0 Call Home DS
 360   0       1704          0       8968          0          0 Call Home DSfile
 361   0       9764       1896      14932          0          0 DCM snmp dp Thre
 362   0       3560        264      10456          0          0 snmp dcm ma shim
 363   0      10184      14716      14172          0          0 Bulkstat-Client
 364   0       3780        264      10696          0          0 dcm_expression_p
 365   0      13052       1208      22108          0          0 EEM Policy Direc
 366   0      75656      14144      60588          4          4 DHCPD Receive
 367   0      11516       4988      16792          0          0 EEM ED CLI
 368   0      11516       4988      16792          0          0 EEM ED Counter
 369   0      12000       4988      17276          0          0 EEM ED Interface
 370   0      11516       4988      16792          0          0 EEM ED IOSWD
 371   0      11516       4988      16792          0          0 EEM ED None
 372   0      11516       4988      16792          0          0 EEM ED OIR
 373   0      12300       4988      17120          0          0 EEM ED RF
 374   0      11516       4988      16792          0          0 EEM ED SNMP
 375   0      11516       4988      16792          0          0 EEM ED SNMP Obje
 376   0      11620       4988      16896          0          0 EEM ED SNMP Noti
 377   0      11684       4988      16960          0          0 EEM ED Timer
 378   0      11516       4988      16792          0          0 EEM ED Test
 379   0      11516       4988      16792          0          0 EEM ED Config
 380   0      11516       4988      16792          0          0 EEM ED Env
 381   0      16816       4988      22092          0          0 EEM ED DS
 382   0      16816       4988      22092          0          0 EEM ED CRASH
 383   0        240        240       7264          0          0 TRP_PSEUDOTIMER
 384   0      16672       4988      21948          0          0 EEM ED Nf
 385   0      15392      13348      15308        158        158 Syslog
 386   0        544        240       7568          0          0 Resource Monitor
 387   0      11616       4988      16892          0          0 EEM ED RPC
 388   0      11516       4988      16792          0          0 EEM ED Ipsla
 389   0          0          0       7264          0          0 IP SLAs Ethernet
 390   0          0          0       7264          0          0 trunk conditioni
 391   0       4660          0      11924          0          0 trunk conditioni
 392   0          0          0       7264          0          0 VDC process
 393   0        240          0      25504          0          0 tHUB
 394   0   17786592   17786504      13352          0          0 mdns Timer Proce
 395   0       1728        240      14752          0          0 MRIB Process
 396   0       7632        776      14408          0          0 EEM Helper Threa
 397   0        240        240       7264          0          0 Resource Availab
 398   0       3644        240      16668          0          0 TRPAPP
 399   0    1405684       3852     219084          0          0 CC-API_VCM
 400   0     129004     410980     176384          5          5 VOIP_RTCP
 401   0        240        240      13264          0          0 confmsp
 402   0     237772        532      43656          0          0 Session Applicat
 403   0     503288     330048     185316         69         69 DSMP
 404   0      71336        240      96360          0          0 VTSP
 405   0      41192          0      66456          0          0 TSP
 406   0     412644        240     437668          0          0 swmtp_msp
 407   0       2600        240      15624          0          0 RECMSPAPP
 408   0        828          0      14092          0          0 lib_off_app
 409   0          0          0       7264          0          0 Media Record
 410   0        240        240       7264          0          0 Voice Player
 411   0          0          0       7264          0          0 Resource Measure
 412   0        240        240      13264          0          0 vxcmsp
 413   0        240        240       7264          0          0 Synthetic Video
 414   0     229772        240     242796          0          0 VOICE_HA_ACTIVE
 415   0        240        240      13264          0          0 VOICE_HA_STANDBY
 416   0      39320        240      52344          0          0 Voip HA Session
 417   0    1405476        240    1466500          0          0 CCH323_CT
 418   0          0          0       7264          0          0 CCH323_DNS
 419   0  102376520  100052264    2751504       1086       1086 CCSIP_SPI_CONTRO
 420   0          0          0      13264          0          0 CCSIP_DNS
 421   0    3522588    2248704     183844       2862       2862 CCSIP_UDP_SOCKET
 422   0    6126508    6416468     348432       5021       5016 CCSIP_TCP_SOCKET
 423   0    3079952    1706032     606436          0          0 RTPSPI
 424   0   18566236   12059012    6513292          0          0 STILE PERIODIC T
 425   0          0          0      13312          0          0 CFT Timer Proces
 426   0      10132        240      20156       1093       1093 IGMP Input
 427   0    5812996    5608188     208604       1115       1115 PIM Process
 428   0          0          0      10264          0          0 Mwheel Process
 429   0          0          0       7264          0          0 mcast_rw_process
 430   0     188644       1564     200344          0          0 MRIB Trans
 431   0      46836        352      12692          0          0 MFIB_init
 432   0      29440        696      39008          0          0 MFIB_cable
 433   0        240        240      10264          0          0 MFIB_mrib_write
 434   0     184284       1048     198664          3          0 MFIB_mrib_read
 435   0        240        240      10264          0          0 MFIB_rate
 436   0       1312        292      14284          0          0 IP SNMP
 437   0          0          0      13264          0          0 PDU DISPATCHER
 438   0        996        996      13264          0          0 SNMP ENGINE
 439   0       1260        240      14304          0          0 IP SNMPV6
 440   0          0          0      13264          0          0 SNMP ConfCopyPro
 441   0        240        240      13264          0          0 SNMP Traps
 442   0    2703440    1702700     790096       7405       7402 SCCP Application
 443   0      76640      45308      36992       2020       2020 NTP
 444   0          0          0       7128          1          1 DHCPD Timer
 445   0        224          0       7352          0          0 DHCPD Database
 446   0      34392          0      42588          4          4 MLD
 447   0          0          0       7196          0          0 NBAR LLT timer s
                                111914332 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 0%/0%; one minute: 2%; five minutes: 1%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           4          59         67  0.00%  0.00%  0.00%   0 Chunk Manager
   2           8        6557          1  0.00%  0.01%  0.00%   0 Load Meter
   3        1892         196       9653  0.00%  1.05%  0.27% 388 SSH Process
   4           0           1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
   6       35532        5531       6424  0.00%  0.09%  0.10%   0 Check heaps
   7           0         552          0  0.00%  0.00%  0.00%   0 Pool Manager
   8           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   9           0           2          0  0.00%  0.00%  0.00%   0 Timers
  10           0         373          0  0.00%  0.00%  0.00%   0 WATCH_AFS
  11           0           3          0  0.00%  0.00%  0.00%   0 License Client N
  12           0           1          0  0.00%  0.00%  0.00%   0 Image License br
  13       62992         617     102094  0.00%  0.24%  0.18%   0 Licensing Auto U
  14           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  15       30552       32716        933  0.00%  0.09%  0.06%   0 Environmental mo
  16          12        6547          1  0.00%  0.00%  0.00%   0 IPC Event Notifi
  17           4         547          7  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  18           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  19           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  20           0       32004          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  21           0       32004          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  22           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  24           0        1875          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  25           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  26           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  27           0        3281          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  28           8        6558          1  0.00%  0.00%  0.00%   0 IPC Loadometer
  29           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  30           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  31           0         345          0  0.00%  0.00%  0.00%   0 TACACS+
  32           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  33          12          98        122  0.00%  0.00%  0.00%   0 ARP Input
  34          16       34063          0  0.00%  0.00%  0.00%   0 ARP Background
  35           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  36           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  37           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  38           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  39           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  40           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  41           0           3          0  0.00%  0.00%  0.00%   0 Entity MIB API
  42        2144          29      73931  0.00%  0.00%  0.00%   0 PrstVbl
  43           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  44           0           1          0  0.00%  0.00%  0.00%   0 License IPC stat
  45           0           1          0  0.00%  0.00%  0.00%   0 License IPC serv
  46        3464        1390       2492  0.00%  0.00%  0.00%   0 SMART
  47           0           1          0  0.00%  0.00%  0.00%   0 RF SCTPthread
  48           0           1          0  0.00%  0.00%  0.00%   0 CHKPT RG SCTPthr
  49           0           1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  50           0       32780          0  0.00%  0.00%  0.00%   0 GraphIt
  51           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  52           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  53           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  54         688          84       8190  0.00%  0.00%  0.00%   0 crypto sw pk pro
  55           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  56          28        4245          6  0.00%  0.00%  0.00%   0 Net Background
  57           0           2          0  0.00%  0.00%  0.00%   0 IDB Work
  58           8         644         12  0.00%  0.00%  0.00%   0 Logger
  59         212       32916          6  0.00%  0.00%  0.00%   0 TTY Background
  60           0           1          0  0.00%  0.00%  0.00%   0 Skinny MOH Event
  61           0           2          0  0.00%  0.00%  0.00%   0 CTS CORE
  62           0          24          0  0.00%  0.00%  0.00%   0 SXP CORE
  63           8          12        666  0.00%  0.00%  0.00%   0 RF Slave Main Th
  64           0           4          0  0.00%  0.00%  0.00%   0 IF-MGR control p
  65           0          11          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  66           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  67           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  68           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
  69           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
  70           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  71           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  72           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  73           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  74           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  75           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  76           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  77           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  78           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  79           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  80           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  81           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-HA
  82           0         289          0  0.00%  0.00%  0.00%   0 TDM Management
  83           0          12          0  0.00%  0.00%  0.00%   0 RF Master Main T
  84           0           7          0  0.00%  0.00%  0.00%   0 RF Master Status
  85           0           1          0  0.00%  0.00%  0.00%   0 Net Input
  86           0        6558          0  0.00%  0.00%  0.00%   0 Compute load avg
  87        6552        1114       5881  0.00%  0.01%  0.00%   0 Per-minute Jobs
  88          80       32789          2  0.00%  0.02%  0.02%   0 Per-Second Jobs
  89           0           1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  90           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  91           0          18          0  0.00%  0.00%  0.00%   0 Transport Port A
  92          20        6547          3  0.00%  0.00%  0.00%   0 HC Counter Timer
  93           0           2          0  0.00%  0.00%  0.00%   0 SM Monitor
  94           0           2          0  0.00%  0.00%  0.00%   0 Bryce I2C CMD Qu
  95           0           2          0  0.00%  0.00%  0.00%   0 SM Installer
  96           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  97           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  98           0           1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  99           0           1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
 100           0           2          0  0.00%  0.00%  0.00%   0 ESWPPM
 101           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
 102           0           2          0  0.00%  0.00%  0.00%   0 ESWILPPM
 103           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
 104           0           2          0  0.00%  0.00%  0.00%   0 DXMRVL
 105           0           1          0  0.00%  0.00%  0.00%   0 esw_mrvl mat que
 106           0           2          0  0.00%  0.00%  0.00%   0 ehwic_eswge Proc
 107           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_DELA
 108           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_SCTP
 109           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Identity
 110          48        1165         41  0.00%  0.00%  0.00%   0 EEM ED ND
 111           0           1          0  0.00%  0.00%  0.00%   0 VIDEO DSPRM MAIN
 112           0           2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
 113           8           7       1142  0.00%  0.00%  0.00%   0 FLEX DNLD MAIN
 114           0           2          0  0.00%  0.00%  0.00%   0 UCSE Monitor
 115           0           2          0  0.00%  0.00%  0.00%   0 Ether-Switch RBC
 116           8        6314          1  0.00%  0.00%  0.00%   0 Skinny Socket Se
 117           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
 118           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
 119           8        1092          7  0.00%  0.00%  0.00%   0 Call Management
 120           4           2       2000  0.00%  0.00%  0.00%   0 USB Startup
 121           0           1          0  0.00%  0.00%  0.00%   0 CF_INTERDEV_SCTP
 122          28       65540          0  0.07%  0.02%  0.02%   0 BPSM stat Proces
 123         180          13      13846  0.00%  0.00%  0.00%   0 Async write proc
 124           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
 125           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
 126           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
 127           4         547          7  0.00%  0.00%  0.00%   0 DFS flush period
 128          24       32722          0  0.00%  0.00%  0.00%   0 mDNS
 130          24       32721          0  0.00%  0.00%  0.00%   0 FHRP Main thread
 131           0           1          0  0.00%  0.00%  0.00%   0 VRRP Main thread
 132          40      511234          0  0.07%  0.03%  0.05%   0 VRRS Main thread
 133           0           2          0  0.00%  0.00%  0.00%   0 IP NAT HA BGND P
 134           0           2          0  0.00%  0.00%  0.00%   0 Auth Manager
 135           0           1          0  0.00%  0.00%  0.00%   0 AUTH POLICY Fram
 136           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
 137           0           1          0  0.00%  0.00%  0.00%   0 802.1x Webauth F
 138           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
 139           0           2          0  0.00%  0.00%  0.00%   0 CMD HANDLER
 140           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
 141           0           1          0  0.00%  0.00%  0.00%   0 SFF8472
 142           4       32716          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
 143           4        3273          1  0.00%  0.00%  0.00%   0 EtherChnl
 144           0           2          0  0.00%  0.00%  0.00%   0 call_home_les_oi
 145           0           1          0  0.00%  0.00%  0.00%   0 SMI Director DB
 146           0           1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
 147           0           1          0  0.00%  0.00%  0.00%   0 SMI Backup Proce
 148           0           2          0  0.00%  0.00%  0.00%   0 RG Faults Timer
 149           0           2          0  0.00%  0.00%  0.00%   0 RG Protocol Time
 150           0           2          0  0.00%  0.00%  0.00%   0 RG Transport Tim
 151           0           1          0  0.00%  0.00%  0.00%   0 RG VP
 152           0           2          0  0.00%  0.00%  0.00%   0 RG AR
 153           0         274          0  0.00%  0.00%  0.00%   0 DHCP Snooping
 154           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
 155           0          52          0  0.00%  0.00%  0.00%   0 AAA Server
 156           0         175          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
 157           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
 158           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
 159         384        5061         75  0.00%  0.00%  0.00%   0 CDP Protocol
 161           0         563          0  0.00%  0.00%  0.00%   0 Call Home Timer
 162           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
 163           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
 164           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
 165           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
 166           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
 167           0           1          0  0.00%  0.00%  0.00%   0 TRACK Main threa
 168           4           1       4000  0.00%  0.00%  0.00%   0 TRACK Client thr
 169           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
 170           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
 171           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
 172          20     1021127          0  0.00%  0.04%  0.05%   0 IPAM Manager
 173           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
 174           0           6          0  0.00%  0.00%  0.00%   0 IP ARP Adjacency
 175           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
 176        2076       20944         99  0.00%  0.02%  0.00%   0 IP Input
 177           0           3          0  0.00%  0.00%  0.00%   0 ICMP event handl
 178           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
 179           8       63976          0  0.00%  0.00%  0.00%   0 NAT64 Bgnd Proce
 180           0          57          0  0.00%  0.00%  0.00%   0 MOP Protocols
 181           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
 182           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
 183           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
 184           0           1          0  0.00%  0.00%  0.00%   0 HQF TARGET DYNAM
 186           0           2          0  0.00%  0.00%  0.00%   0 RIB LM VALIDATE
 187           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
 188           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
 189           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
 190           0      128045          0  0.00%  0.00%  0.00%   0 SSS Feature Time
 191           0           2          0  0.00%  0.00%  0.00%   0 Spanning Tree
 192           0           2          0  0.00%  0.00%  0.00%   0 SSM connection m
 193           0           1          0  0.00%  0.00%  0.00%   0 WAAS Process
 194           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
 195           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
 196           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
 197           4      194707          0  0.00%  0.00%  0.00%   0 Ethernet Timer C
 198          52     4146226          0  0.15%  0.20%  0.21%   0 Ethernet Msec Ti
 199           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM PAL
 200           0         547          0  0.00%  0.00%  0.00%   0 FRR Background P
 201           4        2687          1  0.00%  0.00%  0.00%   0 CEF background p
 202           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
 203           0           5          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
 204           0           2          0  0.00%  0.00%  0.00%   0 Flow Exporter Pa
 205           0           1          0  0.00%  0.00%  0.00%   0 Tunnel FIB
 206           0           2          0  0.00%  0.00%  0.00%   0 HQF Output Shape
 207           0           2          0  0.00%  0.00%  0.00%   0 HQF Input Shaper
 208           0           2          0  0.00%  0.00%  0.00%   0 IPMUXv4
 209           0           2          0  0.00%  0.00%  0.00%   0 IPMUXv6
 210           0           1          0  0.00%  0.00%  0.00%   0 IPC UDP Input
 211          16       16365          0  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
 212          24       32719          0  0.00%  0.00%  0.00%   0 ADJ background
 213           0           6          0  0.00%  0.00%  0.00%   0 Collection proce
 214           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
 215           0           1          0  0.00%  0.00%  0.00%   0 Critical Auth
 216           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 217           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 218           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
 219           8           2       4000  0.00%  0.00%  0.00%   0 L2MM
 220           0           1          0  0.00%  0.00%  0.00%   0 MRD
 221           0           1          0  0.00%  0.00%  0.00%   0 IGMPSN
 222           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
 223           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
 224           0           2          0  0.00%  0.00%  0.00%   0 RG Media Timer
 225           0           1          0  0.00%  0.00%  0.00%   0 RG If-Mgr Timer
 226           0           2          0  0.00%  0.00%  0.00%   0 Routing Topology
 227           0          10          0  0.00%  0.00%  0.00%   0 IP RIB Update
 228           4         552          7  0.00%  0.00%  0.00%   0 IP Background
 229           8          15        533  0.00%  0.00%  0.00%   0 IP Connected Rou
 230           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
 231           0           3          0  0.00%  0.00%  0.00%   0 Service Routing
 232           8           8       1000  0.00%  0.00%  0.00%   0 SR CapMan Proces
 233           0           2          0  0.00%  0.00%  0.00%   0 SNMP Timers
 234           0           2          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
 235           8        5819          1  0.00%  0.00%  0.00%   0 TCP Timer
 236          16          35        457  0.00%  0.00%  0.00%   0 TCP Protocols
 237           0         110          0  0.00%  0.00%  0.00%   0 HTTP CORE
 238           0           1          0  0.00%  0.00%  0.00%   0 IUA Main Process
 239          12       32716          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
 240           0           1          0  0.00%  0.00%  0.00%   0 bsm_timers
 241           8       32722          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
 242           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
 243           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
 244           0           1          0  0.00%  0.00%  0.00%   0 COPS
 245           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
 246           0           4          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
 248           0           2          0  0.00%  0.00%  0.00%   0 Tunnel
 249           0           8          0  0.00%  0.00%  0.00%   0 MFIB Master back
 250           0           4          0  0.00%  0.00%  0.00%   0 MVPN Mgr Process
 251           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
 252           0           1          0  0.00%  0.00%  0.00%   0 RARP Input
 253           0           6          0  0.00%  0.00%  0.00%   0 static
 254           0           2          0  0.00%  0.00%  0.00%   0 App Route Proces
 255           0           1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Cleanup
 256           0           3          0  0.00%  0.00%  0.00%   0 IPv6 RIB Event H
 257           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
 258           0           1          0  0.00%  0.00%  0.00%   0 LAPB Process
 259           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
 260           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
 261          16        3269          4  0.00%  0.00%  0.00%   0 QoS stats proces
 262           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
 263           0          12          0  0.00%  0.00%  0.00%   0 SSH Event handle
 264           0           1          0  0.00%  0.00%  0.00%   0 IPv6 Static Hand
 265           0           1          0  0.00%  0.00%  0.00%   0 Ethernet Datapla
 266           0           1          0  0.00%  0.00%  0.00%   0 Ethernet PM Proc
 267           0           2          0  0.00%  0.00%  0.00%   0 Ethernet PM Soft
 268           4        6905          0  0.00%  0.00%  0.00%   0 Ethernet PM Moni
 269           0           2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
 270           0           2          0  0.00%  0.00%  0.00%   0 PPP NBF
 271           0           2          0  0.00%  0.00%  0.00%   0 Border Element p
 272           0           3          0  0.00%  0.00%  0.00%   0 gk process
 273           0        1313          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
 275           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
 276           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
 277           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
 278           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
 279           0           1          0  0.00%  0.00%  0.00%   0 Opaque Database
 280           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
 281           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
 282           0           3          0  0.00%  0.00%  0.00%   0 LOCAL AAA
 283         120         796        150  0.00%  0.01%  0.00%   0 TPLUS
 284         640          21      30476  0.00%  0.00%  0.00%   0 NIST rng proc
 285           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
 286          16      511236          0  0.07%  0.03%  0.02%   0 MMA DB TIMER
 287           0           2          0  0.00%  0.00%  0.00%   0 STUN_APP
 288           0           1          0  0.00%  0.00%  0.00%   0 STUN_TEST
 289           0           2          0  0.00%  0.00%  0.00%   0 VSP_MGR
 290          12       32781          0  0.00%  0.00%  0.00%   0 RSCMSM VOLUME MO
 291           0           2          0  0.00%  0.00%  0.00%   0 CSDB Timer proce
 292           0           2          0  0.00%  0.00%  0.00%   0 crypto engine pr
 293           0           1          0  0.00%  0.00%  0.00%   0 RSA background p
 294          56          40       1400  0.00%  0.00%  0.00%   0 Crypto CA
 295           0           3          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
 296           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-Rev-P
 297           0           1          0  0.00%  0.00%  0.00%   0 PKI OCSP
 298           0           1          0  0.00%  0.00%  0.00%   0 PKI Revocation
 299           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
 300          20      511236          0  0.07%  0.03%  0.02%   0 MMA DP TIMER
 301          52      511236          0  0.00%  0.04%  0.05%   0 PERFMON ASYNC TI
 302         240       24244          9  0.00%  0.00%  0.00%   0 FLEX DSPRM MAIN
 303           4       12125          0  0.00%  0.00%  0.00%   0 FLEX DSP KEEPALI
 304           4           1       4000  0.00%  0.00%  0.00%   0 CCVPM_HTSP
 305           0           2          0  0.00%  0.00%  0.00%   0 VPM_MWI_BACKGROU
 307           0           1          0  0.00%  0.00%  0.00%   0 VPM_CONN_CHK_BAC
 308           0           1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
 309           0          16          0  0.00%  0.00%  0.00%   0 IP TRUST Registe
 310           0           1          0  0.00%  0.00%  0.00%   0 EPHONE MWI Refre
 311           0          37          0  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
 312           0           2          0  0.00%  0.00%  0.00%   0 EPHONE MWI BG Pr
 313           0           1          0  0.00%  0.00%  0.00%   0 Skinny HW confer
 314           0           1          0  0.00%  0.00%  0.00%   0 CCSIP_EVENT_TRAC
 315           0           2          0  0.00%  0.00%  0.00%   0 CTI Front End Pr
 316           0           2          0  0.00%  0.00%  0.00%   0 CTI Call Control
 317           0           2          0  0.00%  0.00%  0.00%   0 CTI Line Monitor
 318           0           1          0  0.00%  0.00%  0.00%   0 CME CTI Device M
 319           4        1094          3  0.00%  0.00%  0.00%   0 VOICE REG BG Pro
 320           0       32781          0  0.00%  0.00%  0.00%   0 CME Extension Mo
 321           0           1          0  0.00%  0.00%  0.00%   0 Presence Process
 322           0           1          0  0.00%  0.00%  0.00%   0 DS0 PCM Capture
 323           0           2          0  0.00%  0.00%  0.00%   0 Sip MPA
 325           0           1          0  0.00%  0.00%  0.00%   0 http client proc
 327           0           1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
 328           0           1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
 329           0           1          0  0.00%  0.00%  0.00%   0 VoIP AAA
 330           4           2       2000  0.00%  0.00%  0.00%   0 Dialog Manager
 331           0           1          0  0.00%  0.00%  0.00%   0 VOIP_FMD_MAIN
 332           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
 333           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
 334           0           1          0  0.00%  0.00%  0.00%   0 PM Callback
 335           4        2624          1  0.00%  0.00%  0.00%   0 dhcp snooping sw
 337           0          32          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
 338           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
 339           0           1          0  0.00%  0.00%  0.00%   0 dcm_cli_engine
 340           0           3          0  0.00%  0.00%  0.00%   0 dcm_cli_provider
 341           0           5          0  0.00%  0.00%  0.00%   0 DCM Core Thread
 342           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Routing
 343          40         670         59  0.00%  0.00%  0.00%   0 EEM ED Syslog
 344           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED Generic
 345           0           4          0  0.00%  0.00%  0.00%   0 EEM ED NHRP
 346           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Track
 347           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Resource
 348           4        3273          1  0.00%  0.00%  0.00%   0 RMON Recycle Pro
 349           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
 350           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
 351           0           1          0  0.00%  0.00%  0.00%   0 WAN Optimization
 353           0           2          0  0.00%  0.00%  0.00%   0 VLAN Manager
 354           0           1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
 355           0           3          0  0.00%  0.00%  0.00%   0 RBM CORE
 356           0           3          0  0.00%  0.00%  0.00%   0 CTS credentials
 357          20         112        178  0.00%  0.00%  0.00%   0 EEM Server
 358           8          33        242  0.00%  0.00%  0.00%   0 Call Home proces
 359           4           1       4000  0.00%  0.00%  0.00%   0 Call Home DS
 360           0           1          0  0.00%  0.00%  0.00%   0 Call Home DSfile
 361           4           6        666  0.00%  0.00%  0.00%   0 DCM snmp dp Thre
 362           0           3          0  0.00%  0.00%  0.00%   0 snmp dcm ma shim
 363          40        3276         12  0.00%  0.00%  0.00%   0 Bulkstat-Client
 364           0           3          0  0.00%  0.00%  0.00%   0 dcm_expression_p
 365           0           3          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
 366           8          39        205  0.00%  0.00%  0.00%   0 DHCPD Receive
 367           0           4          0  0.00%  0.00%  0.00%   0 EEM ED CLI
 368           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Counter
 369           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Interface
 370           0           4          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
 371           0           4          0  0.00%  0.00%  0.00%   0 EEM ED None
 372           0           4          0  0.00%  0.00%  0.00%   0 EEM ED OIR
 373           4           9        444  0.00%  0.00%  0.00%   0 EEM ED RF
 374           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
 375           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
 376           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
 377           0         568          0  0.00%  0.00%  0.00%   0 EEM ED Timer
 378           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Test
 379           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Config
 380           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Env
 381           0           4          0  0.00%  0.00%  0.00%   0 EEM ED DS
 382           0           4          0  0.00%  0.00%  0.00%   0 EEM ED CRASH
 383           0       32784          0  0.00%  0.00%  0.00%   0 TRP_PSEUDOTIMER
 384           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Nf
 385           0          20          0  0.00%  0.00%  0.00%   0 Syslog
 386           8          70        114  0.00%  0.00%  0.00%   0 Resource Monitor
 387           0           4          0  0.00%  0.00%  0.00%   0 EEM ED RPC
 388           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Ipsla
 389           0           1          0  0.00%  0.00%  0.00%   0 IP SLAs Ethernet
 390           8       32703          0  0.00%  0.00%  0.00%   0 trunk conditioni
 391           0           1          0  0.00%  0.00%  0.00%   0 trunk conditioni
 392           0        6546          0  0.00%  0.00%  0.00%   0 VDC process
 393           0           1          0  0.00%  0.00%  0.00%   0 tHUB
 394           0        2002          0  0.00%  0.00%  0.00%   0 mdns Timer Proce
 395           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
 396           0          49          0  0.00%  0.00%  0.00%   0 EEM Helper Threa
 397           0           2          0  0.00%  0.00%  0.00%   0 Resource Availab
 398           0           3          0  0.00%  0.00%  0.00%   0 TRPAPP
 399          12         447         26  0.00%  0.00%  0.00%   0 CC-API_VCM
 400          32         583         54  0.00%  0.00%  0.00%   0 VOIP_RTCP
 401           0           2          0  0.00%  0.00%  0.00%   0 confmsp
 402           4           4       1000  0.00%  0.00%  0.00%   0 Session Applicat
 403         180         114       1578  0.00%  0.00%  0.00%   0 DSMP
 404           0           2          0  0.00%  0.00%  0.00%   0 VTSP
 405           0           1          0  0.00%  0.00%  0.00%   0 TSP
 406          16         208         76  0.00%  0.00%  0.00%   0 swmtp_msp
 407           0           2          0  0.00%  0.00%  0.00%   0 RECMSPAPP
 408           0           1          0  0.00%  0.00%  0.00%   0 lib_off_app
 409           0           1          0  0.00%  0.00%  0.00%   0 Media Record
 410           0           2          0  0.00%  0.00%  0.00%   0 Voice Player
 411           0           1          0  0.00%  0.00%  0.00%   0 Resource Measure
 412           0           2          0  0.00%  0.00%  0.00%   0 vxcmsp
 413           0           2          0  0.00%  0.00%  0.00%   0 Synthetic Video
 414           0           2          0  0.00%  0.00%  0.00%   0 VOICE_HA_ACTIVE
 415           0           6          0  0.00%  0.00%  0.00%   0 VOICE_HA_STANDBY
 416           0           2          0  0.00%  0.00%  0.00%   0 Voip HA Session
 417           4           2       2000  0.00%  0.00%  0.00%   0 CCH323_CT
 418           0           1          0  0.00%  0.00%  0.00%   0 CCH323_DNS
 419        9104        8461       1075  0.00%  0.02%  0.00%   0 CCSIP_SPI_CONTRO
 420           0           1          0  0.00%  0.00%  0.00%   0 CCSIP_DNS
 421         624        5773        108  0.00%  0.00%  0.00%   0 CCSIP_UDP_SOCKET
 422        1612        3806        423  0.00%  0.00%  0.00%   0 CCSIP_TCP_SOCKET
 423         124        1182        104  0.00%  0.00%  0.00%   0 RTPSPI
 424         228       32717          6  0.00%  0.00%  0.00%   0 STILE PERIODIC T
 425           0       31998          0  0.00%  0.00%  0.00%   0 CFT Timer Proces
 426         136      327577          0  0.00%  0.01%  0.00%   0 IGMP Input
 427          44      654497          0  0.00%  0.04%  0.05%   0 PIM Process
 428          24      327583          0  0.00%  0.01%  0.00%   0 Mwheel Process
 429           0           1          0  0.00%  0.00%  0.00%   0 mcast_rw_process
 430           4         550          7  0.00%  0.00%  0.00%   0 MRIB Trans
 431           0           4          0  0.00%  0.00%  0.00%   0 MFIB_init
 432           0           5          0  0.00%  0.00%  0.00%   0 MFIB_cable
 433          52     1632966          0  0.07%  0.08%  0.07%   0 MFIB_mrib_write
 434           4           5        800  0.00%  0.00%  0.00%   0 MFIB_mrib_read
 435           0        4099          0  0.00%  0.00%  0.00%   0 MFIB_rate
 436           0           2          0  0.00%  0.00%  0.00%   0 IP SNMP
 437           0           1          0  0.00%  0.00%  0.00%   0 PDU DISPATCHER
 438          40           2      20000  0.00%  0.00%  0.00%   0 SNMP ENGINE
 439           0           2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
 440           0           1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
 441           0           2          0  0.00%  0.00%  0.00%   0 SNMP Traps
 442        4048        7960        508  0.00%  0.01%  0.00%   0 SCCP Application
 443          28       33791          0  0.00%  0.00%  0.00%   0 NTP
 444           0         275          0  0.00%  0.00%  0.00%   0 DHCPD Timer
 445           0         546          0  0.00%  0.00%  0.00%   0 DHCPD Database
 446          20      131095          0  0.00%  0.00%  0.00%   0 MLD
 447           0       31994          0  0.00%  0.00%  0.00%   0 NBAR LLT timer s
------------------ show process cpu history ------------------
IACHZURVGW01   06:09:23 PM Friday Nov 20 2015 UTC
                               11111
           8888844444111111111100000     1111111111     11111
  100
   90
   80
   70
   60
   50
   40
   30
   20
   10      *****               *****
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
      1                                     1
      043435434434444333343343334443434444441344344444444334343343
  100
   90
   80
   70
   60
   50
   40
   30
   20
   10 *    *                                *
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
      153 16117
      105414115
  100
   90
   80         *
   70         *
   60      *  *
   50  *   *  *
   40  **  *  *
   30  **  *  *
   20  **  *  *
   10 *** *****
     0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
               0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show diag ------------------
Slot 0:
        C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 3 ports
        Port adapter is analyzed
        Port adapter insertion time 09:06:34 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC1927CK47
        Hardware Revision        : 1.0
        Part Number              : 73-11833-12
        Top Assy. Part Number    : 800-30797-06
        Board Revision           : H0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2911/K9
        Version Identifier       : V07
        CLEI Code                : CMMJD00ARA
        Processor type           : C1
        Chassis Serial Number    : FCZ194171VP
        Chassis MAC Address      : 5897.bd17.c340
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 39 32 37 43 4B 34 37 40
          0x10: 06 18 41 01 00 82 49 2E 39 0C C0 46 03 20 00 78
          0x20: 4D 06 42 48 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 31 31 2F 4B 39 89 56 30 37 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 4A 44 30 30 41 52
          0x50: 41 09 C1 C2 8B 46 43 5A 31 39 34 31 37 31 56 50
          0x60: C3 06 58 97 BD 17 C3 40 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 25 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0235-07
        PCB Serial Number        : ART1912F0KJ
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V05
        Product (FRU) Number     : PWR-2911-AC
        CLEI Code                :
        Board Revision           : A0
          0x00: 04 FF 40 05 E5 DF 45 01 55 00 EB 07 88 00 00 00
          0x10: 00 C1 8B 41 52 54 31 39 31 32 46 30 4B 4A 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 35 20 CB 8B 50 57
          0x30: 52 2D 32 39 31 31 2D 41 43 C6 8A 00 00 00 00 00
          0x40: 00 00 00 00 00 F3 00 59 41 00 BE 42 00 05 F8 00
          0x50: 50 01 F4 17 2B 02 EE 1A 7A 03 E8 1B 65 04 E2 1C
          0x60: 47 05 DC 1C C9 06 D6 1D A3 07 D0 1E 54 08 CA 1E
          0x70: E6 09 C4 1F 5C 0A BE 1F BF 0B B8 20 12 0D AC 20
          0x80: 92 0F A0 20 F0 11 94 21 38 13 88 21 6B 17 70 21
          0x90: AE 1B 58 21 D3 1F 40 21 E0 23 28 21 DE 27 10 22
          0xA0: 56 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
          0xC0: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
          0xD0: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
          0xE0: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
          0xF0: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11576-03
        Board Revision           : D0
        Fab Version              : 03
        PCB Serial Number        : FOC19360ZZZ
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-16
        Version Identifier       : V01
          0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 44 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 39 33 36
          0x20: 30 5A 5A 5A 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
------------------ show platform ------------------
 CIU Interrupt info:
CIU Int  Handler    Count   Context     Level  Name
0        0x300BD194 124973  0x0         IP2    Pow Interrupt
18       0x300C4288 32769   0x2         IP3    fpga interrupt
30       0x300C29C0 0       0xE         IP2    USB 0 Over Current i
31       0x300C29C0 0       0xF         IP2    USB 1 Over Current g
32       0x303EC7B4 0       0x0         IP2    MBOX0 interrupt
33       0x303EC7B4 0       0x0         IP2    MBOX1 interrupt
34       0x304134B4 1       0x1         IP4    Aux Port interrupt
35       0x304134B4 6935    0x0         IP4    Console interrupt
40       0x300C2DDC 0       0x0         IP2    MSI 0 interrupt
41       0x300C2DDC 0       0x1         IP2    MSI 1 interrupt
42       0x300C2C34 0       0x2         IP2    IO-Controller Networ
43       0x300C2A8C 0       0x3         IP2    IO-Controller Mgmt/E
46       0x300C3554 1       0x0         IP2    NPEI RML interrupt
52       0x3042DEC0 4989    0x3D667240  IP3    CIU Timer 0 ISR
53       0x3042DEC0 9354337  0x21313100  IP2    CIU Timer 1 ISR
54       0x3042DEC0 70      0x3D6672B4  IP2    CIU Timer 2 ISR
56       0x30475FFC 1       0x0         IP2    USB 0 interrupt
IP2 Int En: 0x01604F03 C0000001
IP3 Int En: 0x00100000 00040000
IP4 Int En: 0x0000000C 00000000
Interrupt Counters:
Int Level Counter: L1 (netio) 10430117, L2 0, L3 (mgmt) 37758, L4 (console) 6936, L5 0, L6 0, l7 (4ms timer) 8204093
CIU IP level int counter: IP2 10432973, IP3 37758, IP4 6936
Debug counters/Info:
 ciu_int2_count 10432973, ciu_int3_count 37758, ciu_int4_count 6936
 unknown_ip4_int_cnt 0, unreg_int_cnt 0, wdog_int_cnt 0
 unreg_int_sum1 0x0, unreg_int_sum2 0x0
 spur_timer_int 0, unreg_msi_int_cnt 0
 rml_int 1, npei_int 0, usb1_int 1
 npei_pcie0_err 0, npei_pcie1_err 0, npei_pcie_timeout 0
 fpa_err 0, pip_err 0, ipd_err 0, mio_err 1
 l2c_err 0, l2c_int_sum 0x00000000, lmc_err 0
 l2d_faddr 0x00000000, l2t_fddr 0x00000000, lmc_faddr 0x00000000
 usb 0/1 over current 0/0
 pcie0_cfg030 0x0000583F, pcie1_cfg030 0x00000000
 pcie0_cfg065 0x00000000, pcie1_cfg065 0x00000000
 pcie0_cfg068 0x00000000, pcie1_cfg068 0x00000000
 pcie0_cfg071 0x00000000, pcie1_cfg071 0x00000000
 pcie0_cfg072 0x00000000, pcie1_cfg072 0x00000000
 pcie0_cfg073 0x00000000, pcie1_cfg073 0x00000000
 pcie0_cfg074 0x00000000, pcie1_cfg074 0x00000000
 pcie0_cfg076 0x00000001, pcie1_cfg076 0x00000000
 pcie0_dbg_info 0x00000022, pcie1_dbg_info 0x00000000
 fpa_int_sum 0x00000000, pip_err_reg 0x00000000, ipd_int_sum 0x00000000
MSI Interrupt info:
MSI 128, name: wic_mbrd_hdlc_intr, hdlr 0x306E1D34, cnt 0, ctx 0x0, slot 0, IO_Controller, NETIO, number 0
MSI 129, name: wic_mbrd_hdlc_intr, hdlr 0x306E1D34, cnt 0, ctx 0x1, slot 0, IO_Controller, NETIO, number 1
MSI 130, name: wic_mbrd_hdlc_intr, hdlr 0x306E1D34, cnt 0, ctx 0x2, slot 0, IO_Controller, NETIO, number 2
MSI 131, name: wic_mbrd_hdlc_intr, hdlr 0x306E1D34, cnt 0, ctx 0x3, slot 0, IO_Controller, NETIO, number 3
MSI 132, name: wic_mbrd_hdlc_intr, hdlr 0x306E1D34, cnt 0, ctx 0x4, slot 0, IO_Controller, NETIO, number 4
MSI 133, name: wic_mbrd_hdlc_intr, hdlr 0x306E1D34, cnt 0, ctx 0x5, slot 0, IO_Controller, NETIO, number 5
MSI 134, name: wic_mbrd_hdlc_intr, hdlr 0x306E1D34, cnt 0, ctx 0x6, slot 0, IO_Controller, NETIO, number 6
MSI 135, name: wic_mbrd_hdlc_intr, hdlr 0x306E1D34, cnt 0, ctx 0x7, slot 0, IO_Controller, NETIO, number 7
MSI 155, name: i2c intr handler, hdlr 0x3096E1F8, cnt 0, ctx 0x0, slot 0, IO_Controller, NETIO, number 27
MSI 156, name: wic_mbrd_scc_netio_, hdlr 0x306E1958, cnt 0, ctx 0x0, slot 0, IO_Controller, NETIO, number 28
MSI 192, name: wic_mbrd_hdlc_error, hdlr 0x306E19D8, cnt 0, ctx 0x0, slot 0, IO_Controller, ERR, number 0
MSI 193, name: wic_mbrd_hdlc_error, hdlr 0x306E19D8, cnt 0, ctx 0x1, slot 0, IO_Controller, ERR, number 1
MSI 194, name: wic_mbrd_hdlc_error, hdlr 0x306E19D8, cnt 0, ctx 0x2, slot 0, IO_Controller, ERR, number 2
MSI 195, name: wic_mbrd_hdlc_error, hdlr 0x306E19D8, cnt 0, ctx 0x3, slot 0, IO_Controller, ERR, number 3
MSI 196, name: wic_mbrd_hdlc_error, hdlr 0x306E19D8, cnt 0, ctx 0x4, slot 0, IO_Controller, ERR, number 4
MSI 197, name: wic_mbrd_hdlc_error, hdlr 0x306E19D8, cnt 0, ctx 0x5, slot 0, IO_Controller, ERR, number 5
MSI 198, name: wic_mbrd_hdlc_error, hdlr 0x306E19D8, cnt 0, ctx 0x6, slot 0, IO_Controller, ERR, number 6
MSI 199, name: wic_mbrd_hdlc_error, hdlr 0x306E19D8, cnt 0, ctx 0x7, slot 0, IO_Controller, ERR, number 7
MSI 212, name: Hsib Error Monitor , hdlr 0x30974188, cnt 0, ctx 0x0, slot 0, IO_Controller, ERR, number 20
MSI 220, name: wic_mbrd_scc_mgmt_i, hdlr 0x306E127C, cnt 0, ctx 0x0, slot 0, IO_Controller, MGMT, number 28
MSI 221, name: tdm_exception_handl, hdlr 0x30D969E4, cnt 0, ctx 0x108A0000, slot 0, IO_Controller, ERR, number 29
MSI 222, name: GPIO interrupt hand, hdlr 0x30963988, cnt 0, ctx 0x10900200, slot 0, IO_Controller, ERR, number 30
MSI Enable Reg 0:  0x00000000 00000000
MSI Enable Reg 1:  0x00000000 00000000
MSI Enable Reg 2:  0x00000000 180000FF
MSI Enable Reg 3:  0x00000000 701000FF
Platform DMA brief information:
DMA Channel 1:  is free.
DMA Channel 2:  is free.
DMA Channel 3:  is free.
 CISCO2911/K9 Network IO Interrupt Throttling:
 throttle count=953775, timer count=4989
 throttle counts= 953762 3 1 0 9
 active=0, configured=1
 netint usec=20000, netint mask usec=1000
 real netint usec=3999, real netint mask usec=200
CPU Registers:
  Processor Revision ID    : 0xD0708
  Configuration            : 0x8000C48B
  Status                   : 0x50009FE1
  Cause                    : 0x0
  Count                    : 0xCC5B3557
  Compare                  : 0xCC6BDB6F
  WatchLo  (0)  : 0x0
  WatchLo  (1)  : 0xEF6EFFFD97F5AFC8
  WatchHo  (0)  : 0x80000000
  WatchHo  (1)  : 0x80000000
  CacheErr (D)  : 0x26C8
  TagLo    (I)  : 0x405088040500BF80
  TagLo    (D)  : 0x0
  DataLo   (I)  : 0xFFFF9E617FFFFFFF
  DataLo   (D)  : 0x201FFFFE14280007
  TagHi    (D)  : 0x0
  DataHi   (I)  : 0x3
  DataHi   (D)  : 0xD1
  CVM Control   : 0xB00003F0
  CVM Mem Ctrl  : 0x46102
  CVM Count     : 0x119ABEFF9FEC
  MultiCore Dbg : 0x0
  CIU PP RST    : 0xE
  CIU MBOX CLRX0 : 0x0
  CIU MBOX SETX0 : 0x0
  CIU MBOX CLRX1 : 0x0
  CIU MBOX SETX1 : 0x0
  BOOT_CFG_REG 0 : 0x200B13F1EC0
  BOOT_TIM_REG 0 : 0x1000080C0869044
  BOOT_CFG_REG 1 : 0x0
  BOOT_TIM_REG 1 : 0xFFFFFFFFFFFFFFF
  BOOT_CFG_REG 2 : 0xB00F1010
  BOOT_TIM_REG 2 : 0x180005249560043
  BOOT_CFG_REG 3 : 0xB00F1020
  BOOT_TIM_REG 3 : 0x180005249560043
  BOOT_CFG_REG 4 : 0xB00F1030
  BOOT_TIM_REG 4 : 0x13FFE8208A28186
  BOOT_CFG_REG 5 : 0xB00F1040
  BOOT_TIM_REG 5 : 0x13FFE8208A28186
  BOOT_CFG_REG 6 : 0xB00F1050
  BOOT_TIM_REG 6 : 0xBFFC4000722000
  BOOT_CFG_REG 7 : 0xB00F1060
  BOOT_TIM_REG 7 : 0xBFFC4000722000
On-board SPD data :
Size of dimm                 = 512 Megabytes
Memory Type                  = 0x8
Row Addresses                = 0xD
Column Address               = 0xA
Module Rows                  = 0x60
Data Width                   = 0x48
Voltage Interface            = 0x5
Cycle Time                   = 0x30
Access Time                  = 0x45
Configuration Type           = 0x2
Refresh Rate/Type            = 0x82
Primary Width                = 0x10
Error Width                  = 0x10
Burst Lengths                = 0xC
Number of Banks              = 0x8
Cas Latency                  = 0x30
DIMM Mechanical              = 0x1
DIMM Type                    = 0x2
Module Attributes            = 0x0
General Attributes           = 0x3
Min Cycle Time, CAS of 2     = 0x3D
Access Clock Cycle, CAS of 2 = 0x45
Min Cycle Time, CAS of 1     = 0x0
Access Clock Cycle, CAS of 2 = 0x0
Row Precharge                = 0x3C
Row Active to Row Active     = 0x28
RAS CAS Delay                = 0x3C
Ras Pulse Width              = 0x2D
Rank Density                 = 0x80
COM Setup Time               = 0x20
COM Hold Time                = 0x27
Data Setup Time              = 0x10
Data Hold Time               = 0x17
Write Recovery Time          = 0x3C
Write to Read Cmd Delay      = 0x1E
Read to Precharge Delay      = 0x1E
Probe Characteristics        = 0x0
Byte Ext to tRC and tRFC     = 0x6
Min Act to Act Refresh       = 0x3C
Min Refresh to Act Refresh   = 0x7F
Max Device Cycle Time        = 0x80
Device DQS-DQ Skew for DQS   = 0x18
Read Data Hold Skew Factor   = 0x22
PLL Relock Time              = 0x0
Vendor Id                    = 0000000000000000
Module Part Number           =
Module Revision Code         = 0000
        SPD contents (hex):
         0x00: 80 08 08 0D 0A 60 48 00 05 30 45 02 82 10 10 00
         0x10: 0C 08 30 01 02 00 03 3D 45 00 00 3C 28 3C 2D 80
         0x20: 20 27 10 17 3C 1E 1E 00 06 3C 7F 80 18 22 00 00
         0x30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 F9
         0x40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
         0x50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
         0x60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
         0x70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM0 SPD data :
Memory Slot Empty
FPA Buffer pools information:
        FPA INT SUM: 0x0000000000000000, ENB: 0x000000000FFFFFFF
        FPA CTL STATUS: 0x0000000000004000
        FPA QUE(n) AVAILABLE:
        QUE(0): 0x00000000000003E9, QUE(1): 0x0000000000000FF9
        QUE(2): 0x000000000000001D, QUE(3): 0x0000000000000600
        QUE(4): 0x0000000000000000, QUE(5): 0x0000000000000000
        QUE(6): 0x0000000000000000, QUE(7): 0x0000000000000000
        FPA WART CTL: 0x0000000000000000, STATUS: 0x0000000000000000
        FPA QUE(n) PAGE INDEX:
        QUE(0): 0x000000000000001E, QUE(1): 0x000000000000007F
        QUE(2): 0x0000000000000000, QUE(3): 0x000000000000002F
        FPA QUE EXE: 0x0000000000000000, ACT: 0x0000000000000000
Cavium IPD Registers:
        IPD_1ST_MBUF_SKP:0x0000000000000000, IPD_NOT_1ST_MBUF:0x0000000000000000
        IPD_PKT_MBUF_SZE:0x00000000000000C0, IPD_CTL_STATUS  :0x0000000000000209
        IPD_WQE_FPA_QUE :0x0000000000000001, IPD_SUB_BP_CNT  :0x0000000001FFFFFF
        IPD_BP_PRT_REDE :0x000000000000000F, IPD_RED_PT_EN2  :0x0000000000000000
        IPD_RED_QUE(0)_PARAM :0x0001FF0100000000
        IPD_RED_QUE(1)_PARAM :0x0001FF0100000000
        IPD_RED_QUE(2)_PARAM :0x0001FF0100000000
        IPD_RED_QUE(3)_PARAM :0x0001FF0100000000
        IPD_RED_QUE(4)_PARAM :0x0001FF0100000000
        IPD_RED_QUE(5)_PARAM :0x0001FF0100000000
        IPD_RED_QUE(6)_PARAM :0x0001FF0100000000
        IPD_RED_QUE(7)_PARAM :0x0001FF0100000000
        IPD_QOS(0)_RED_MARKS :0x0000010000000000
        IPD_QOS(1)_RED_MARKS :0x0000010000000000
        IPD_QOS(2)_RED_MARKS :0x0000010000000000
        IPD_QOS(3)_RED_MARKS :0x0000010000000000
        IPD_QOS(4)_RED_MARKS :0x0000010000000000
        IPD_QOS(5)_RED_MARKS :0x0000010000000000
        IPD_QOS(6)_RED_MARKS :0x0000010000000000
        IPD_QOS(7)_RED_MARKS :0x0000010000000000
Cavium PKO Registers:
        PKO_MEM_COUNT(0):0x0000000000014F10, PKO_MEM_COUNT(1):0x0000000000F632AD
        PKO_MEM_DEBUG(0):0x1000FFE400410102, PKO_MEM_DEBUG(1):0x000102000D9F004A
        PKO_MEM_DEBUG(10):0x0000000000000000, PKO_MEM_DEBUG(11): 0x0000000000000000
        PKO_MEM_DEBUG12: 0x1000FFE40041024E, PKO_MEM_DEBUG13: 0x00024E000D9EF24A
        PKO_MEM_DEBUG14: 0x0000000000000000, PKO_MEM_DEBUG2: 0x000102000D9F004A
        PKO_MEM_DEBUG3: 0x0000000000000000, PKO_MEM_DEBUG4: 0x0001020400000180
        PKO_MEM_DEBUG5: 0x0000000D9F014C00, PKO_MEM_DEBUG6: 0x0000000001111100
        PKO_MEM_DEBUG7: 0xF807A01B22D02C71, PKO_MEM_DEBUG8: 0x000000000000003F
        PKO_MEM_DEBUG9: 0x000103A8000103A8, PKO_MEM_PORT_PTRS: 0x1FE0000000000000
        PKO_MEM_PORT_QOS: 0x1FE0000000000000, PKO_MEM_PORT_RATE0: 0x0000000000000000
        PKO_MEM_PORT_RATE1: 0x0000000000000000, PKO_MEM_QUEUE_PTRS: 0xFFE01B22D0200000
        PKO_MEM_QUEUE_QOS: 0x1FE0000000000000, PKO_REG_BIST_RESULT: 0x0000000000000000
        PKO_REG_CMD_BUF: 0x00000000 0x0020007F, PKO_REG_CRC_ENABLE: 0x0000000000000000
        PKO_REG_DEBUG0: 0x0000000000000000, PKO_REG_DEBUG1: 0x0000000000000000
        PKO_REG_DEBUG2: 0x0000000000000000, PKO_REG_DEBUG3: 0x0000000000000000
        PKO_REG_ENGINE_INFLIGHT: 0x0000004400004444, PKO_REG_ENGINE_THRESH: 0x0000000000000000
        PKO_REG_ERROR: 0x0000000000000000, PKO_REG_FLAGS: 0x0000000000000007
        PKO_REG_GMX_PORT_MODE: 0x0000000000000002, PKO_REG_INT_MASK: 0x0000000000000000
        PKO_REG_QUEUE_MODE: 0x0000000000000000, PKO_REG_QUEUE_PTRS1: 0x0000000000000000
        PKO_REG_READ_IDX: 0x0000000000000000
Watchodg information :
L1 watchdog is ON
  Address = 0x8001070000000500; Value = 0x4617A646182
    Mode = 2
    Length = 17944 (1999 millisec)
L2 watchdog is ON - watchdog 0 is used
  wdog_timer_limit address 0x10900494, value 0x1312D00
UART Information:
AUX (Uart 0)  Port Registers:
 SR: 0x6  IER: 0xD   IIR: 0xC1  LCR: 0x7
MCR: 0x3  LSR: 0x60  MSR: 0x0   FCR: 0xC1
TFL: 0x0  RFL: 0x0
Parity Error = 0, Framing Error = 0, Receive Error = 0
Outcount = 0, TotalOut = 39, Incount = 0, Total In = 0
Overrun = 0, Overflow = 0
Brk Character: Received 0, Brk Processed 0
Console (Uart 1) Port Registers:
TFL: 0x0  RFL: 0x0
Outcount = 0, TotalOut = 439404, Incount = 0, Total In = 0
TLB entries :
Entries used: 40
SN  Size  paddr                                   vaddr                 perm
0   16MB  0x00000004_10000000:0x00000004_11FFFFFF 0x30000000:0x31FFFFFF 3,O,V
1   16MB  0x00000004_12000000:0x00000004_13FFFFFF 0x32000000:0x33FFFFFF 3,O,V
2   16MB  0x00000004_14000000:0x00000004_15FFFFFF 0x34000000:0x35FFFFFF 3,O,V
3   4MB   0x00000004_16000000:0x00000004_167FFFFF 0x36000000:0x367FFFFF 3,O,V
4   4MB   0x00000004_16800000:0x00000004_16FFFFFF 0x36800000:0x36FFFFFF 3,O,V
5   1MB   0x00000004_17000000:0x00000004_171FFFFF 0x37000000:0x371FFFFF 3,O,V
6   64KB  0x00000004_17200000:0x00000004_1721FFFF 0x37200000:0x3721FFFF 3,O,V
7   64KB  0x00000004_17220000:0x00000004_1723FFFF 0x37220000:0x3723FFFF 3,O,V
8   4KB   0x00000004_17240000:0x00000004_17241FFF 0x37240000:0x37241FFF 3,O,V
9   4KB   0x00000004_17242000:0x00000004_17243FFF 0x37242000:0x37243FFF 3,W,V
10  4KB   0x00000004_17244000:0x00000004_17245FFF 0x37244000:0x37245FFF 3,W,V
11  4KB   0x00000004_17246000:0x00000004_17247FFF 0x37246000:0x37247FFF 3,W,V
12  16KB  0x00000004_17248000:0x00000004_1724FFFF 0x37248000:0x3724FFFF 3,W,V
13  16KB  0x00000004_17250000:0x00000004_17257FFF 0x37250000:0x37257FFF 3,W,V
14  16KB  0x00000004_17258000:0x00000004_1725FFFF 0x37258000:0x3725FFFF 3,W,V
15  64KB  0x00000004_17260000:0x00000004_1727FFFF 0x37260000:0x3727FFFF 3,W,V
16  256KB 0x00000004_17280000:0x00000004_172FFFFF 0x37280000:0x372FFFFF 3,W,V
17  256KB 0x00000004_17300000:0x00000004_1737FFFF 0x37300000:0x3737FFFF 3,W,V
18  256KB 0x00000004_17380000:0x00000004_173FFFFF 0x37380000:0x373FFFFF 3,W,V
19  1MB   0x00000004_17400000:0x00000004_175FFFFF 0x37400000:0x375FFFFF 3,W,V
20  1MB   0x00000004_17600000:0x00000004_177FFFFF 0x37600000:0x377FFFFF 3,W,V
21  4MB   0x00000004_17800000:0x00000004_17FFFFFF 0x37800000:0x37FFFFFF 3,W,V
22  64MB  0x00000004_18000000:0x00000004_1FFFFFFF 0x38000000:0x3FFFFFFF 3,W,V
23  16MB  0x00011B00_10000000:0x00011B00_11FFFFFF 0x10000000:0x11FFFFFF 0,W,V
24  16MB  0x00011E00_12000000:0x00011E00_13FFFFFF 0x12000000:0x13FFFFFF 0,W,V
25  16MB  0x00011C00_18000000:0x00011C00_19FFFFFF 0x18000000:0x19FFFFFF 0,W,V
26  4MB   0x00000000_00000000:0x00000000_007FFFFF 0x20000000:0x207FFFFF 0,O,V
27  4MB   0x00000000_00800000:0x00000000_00FFFFFF 0x20800000:0x20FFFFFF 0,O,V
28  4MB   0x00000000_01000000:0x00000000_017FFFFF 0x21000000:0x217FFFFF 0,W,V
29  4MB   0x00000000_01800000:0x00000000_01FFFFFF 0x21800000:0x21FFFFFF 0,W,V
30  16MB  0x00000000_02000000:0x00000000_03FFFFFF 0x22000000:0x23FFFFFF 0,W,V
31  16MB  0x00000000_04000000:0x00000000_05FFFFFF 0x24000000:0x25FFFFFF 0,W,V
32  16MB  0x00000000_06000000:0x00000000_07FFFFFF 0x26000000:0x27FFFFFF 0,W,V
33  16MB  0x00000000_08000000:0x00000000_09FFFFFF 0x28000000:0x29FFFFFF 0,W,V
34  16MB  0x00000000_0A000000:0x00000000_0BFFFFFF 0x2A000000:0x2BFFFFFF 0,W,V
35  4MB   0x00000000_0C000000:0x00000000_0C7FFFFF 0x2C000000:0x2C7FFFFF 0,W,V
36  4MB   0x00000000_0C800000:0x00000000_0CFFFFFF 0x2C800000:0x2CFFFFFF 0,W,V
37  4MB   0x00000000_0D000000:0x00000000_0D7FFFFF 0x2D000000:0x2D7FFFFF 0,W,V
38  4MB   0x00000000_0D800000:0x00000000_0DFFFFFF 0x0D800000:0x0DFFFFFF 0,W,V
39  16MB  0x00000000_0E000000:0x00000000_0FFFFFFF 0x0E000000:0x0FFFFFFF 0,W,V
0 = write-thru(wt)       1 = wt, write-allocate,    2 = uncached
3 = non-coherent         4 = coherent, excl,        5 = coh excl on write
6 = coh update on write
W = ReadWrite, O = ReadOnly,         V = Valid, I = Invalid
Platform Support status of Compact Flash:
CF flash0: Compact Flash plugged in is Supported.
CF flash1: Compact Flash not plugged in.
LED STATUS:
FRONT PANEL LED CONTROL REGISTER
SYSTEM   : GREEN
ACTIVITY : GREEN
POE      : OFF
RPS      : OFF
PS       : GREEN
ISM and CFLASH LED CONTROL REGISTER
ISM      : OFF
CF0      : OFF
CF1      : OFF
DSP LED CONTROL REGISTER
PVDM0    : GREEN
PVDM1    : OFF
GE LINK LED, SPEED LED
PORT 0   : GREEN, 3 (1Gb/s)
PORT 1   : OFF, 0 (OFF)
PORT 2   : GREEN, 2 (100Mb/s)
LED CONTROL REGISTER (Value is number of 1/8 seconds
ON Time    : 3
OFF Time   : 3
PAUSE Time : 7
USB CONSOLE LED, RJ45 CONSOLE LED
USB        : OFF
RJ45       : GREEN
Platform Revisions/Versions :
FPGA       : 5.02   [Val = 0x502]
Board Rev  : 2      [Val = 0x204;  Type = 4]
Env Rev    : 4.5    [Val = 0x405, Bit 15 = 0]
PSEQ Rev   : 3.05   [Val = 0x305]
I/O Ctl Nm : GA 1.1 [Val = 0x47410101]
I/O Ctl Ver: 2      [Val = 0x20316447]
CPU information :
Company ID   = 0xD
Processor ID = 0x7
Revision     = 0x8
Company OPTs = 0x0
USB Con BL : 1.01   (Boot Loader)
USB Con FW : 2.02   (Application Firmware)
USB Con FWU: 2.02   (Application Firmware Upgrade)
IOS        :
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Sun 27-Sep-15 06:34 by prod_rel_team
ROMMON (Readonly) :
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
CPU GPIO Register information :
Data Register 0x8001070000000880 = 0x32B
Pin: Config Reg Addr    Data   TX  RX_Xor Int_en Int_type fil_cnt fil_sel
0  : 0x8001070000000800   1     0    0       0      0        0      0
1  : 0x8001070000000808   1     0    0       0      0        0      0
2  : 0x8001070000000810   0     0    1       1      0        0      0
3  : 0x8001070000000818   1     0    0       0      0        0      0
4  : 0x8001070000000820   0     0    0       0      0        0      0
5  : 0x8001070000000828   1     0    0       0      0        0      0
6  : 0x8001070000000830   0     0    0       0      0        0      0
7  : 0x8001070000000838   0     0    0       0      0        0      0
8  : 0x8001070000000840   1     0    0       0      0        0      0
9  : 0x8001070000000848   1     0    0       0      0        0      0
10 : 0x8001070000000850   0     0    0       0      0        0      0
11 : 0x8001070000000858   0     0    0       0      0        0      0
12 : 0x8001070000000860   0     1    0       0      0        0      0
13 : 0x8001070000000868   0     1    0       0      0        0      0
14 : 0x8001070000000870   0     0    1       1      1        0      0
15 : 0x8001070000000878   0     0    1       1      1        0      0
io-controller global register (addr 0x10900400):
  jtag_id                                (addr 0x10900400): 0x20316447
  revision_id                            (addr 0x10900404): 0x47410101
  diag_echo                              (addr 0x10900408): 0xFFFFFFFF
  software_memory_bist                   (addr 0x1090040C): 0x00000004
  five_mhz_prescale                      (addr 0x10900410): 0x00000072
  reset_sampled_inputs                   (addr 0x10900414): 0x00000008
  slew_rate_control_gpio1                (addr 0x10900420): 0x0000FFFF
  slew_rate_control_gpio0                (addr 0x10900424): 0xFFFFFFFF
  slew_rate_control_pvdm                 (addr 0x10900428): 0x000FFFFF
  slew_rate_control_slowgpio             (addr 0x1090042C): 0x0000003F
  slew_rate_control_wic0                 (addr 0x10900430): 0x003FFFFF
  slew_rate_control_wic1                 (addr 0x10900434): 0x003FFFFF
  slew_rate_control_wic2                 (addr 0x10900438): 0x003FFFFF
  slew_rate_control_wic3                 (addr 0x1090043C): 0x003FFFFF
  wic_spi_control0                       (addr 0x10900440): 0x2455FFFF
  wic_spi_control1                       (addr 0x10900444): 0x00000000
io-controller gpio (addr 0x10900200):
  in_out_config2                         (addr 0x10900204): 0x40154415
  in_out_config1                         (addr 0x10900208): 0x44155105
  in_out_config0                         (addr 0x1090020C): 0x14504015
  polarity_ctrl1                         (addr 0x10900210): 0x0000C0C0
  polarity_ctrl0                         (addr 0x10900214): 0xC0FFFFC0
  debounce_ctrl1                         (addr 0x10900218): 0x00000000
  debounce_ctrl0                         (addr 0x1090021C): 0x00249000
  debounce_time5                         (addr 0x10900220): 0x00000000
  debounce_time4                         (addr 0x10900224): 0x00000000
  debounce_time3                         (addr 0x10900228): 0x00000000
  debounce_time2                         (addr 0x1090022C): 0x0000C351
  debounce_time1                         (addr 0x10900230): 0x0000C351
  debounce_time0                         (addr 0x10900234): 0x00000000
  reg_input_value1                       (addr 0x10900238): 0x00003A1A
  reg_input_value0                       (addr 0x1090023C): 0x1808002C
  reg_output_value1                      (addr 0x10900240): 0x00000202
  reg_output_value0                      (addr 0x10900244): 0x00000004
  intr_type2                             (addr 0x1090024C): 0xEFFFEFFF
  intr_type1                             (addr 0x10900250): 0xEFFFFFFF
  intr_type0                             (addr 0x10900254): 0xFFFEEFFF
  latch_unlatch_intr1                    (addr 0x10900258): 0x00000000
  latch_unlatch_intr0                    (addr 0x1090025C): 0x00000000
  err_intr_status1                       (addr 0x10900260): 0x00000000
  err_intr_status0                       (addr 0x10900264): 0x00000000
  mgmt_intr_status1                      (addr 0x10900268): 0x00000000
  mgmt_intr_status0                      (addr 0x1090026C): 0x00000000
  ntwk_intr_status1                      (addr 0x10900270): 0x00000000
  ntwk_intr_status0                      (addr 0x10900274): 0x00000000
  err_intr_enable1                       (addr 0x10900278): 0x00000000
  err_intr_enable0                       (addr 0x1090027C): 0x00000040
  mgmt_intr_enable1                      (addr 0x10900280): 0x00000000
  mgmt_intr_enable0                      (addr 0x10900284): 0x00000000
  ntwk_intr_enable1                      (addr 0x10900288): 0x00000000
  ntwk_intr_enable0                      (addr 0x1090028C): 0x00000000
  intr_test1                             (addr 0x10900290): 0x00000000
  intr_test0                             (addr 0x10900294): 0x00000000
  slow_output1                           (addr 0x109002A0): 0x00000000
  slow_output0                           (addr 0x109002A4): 0x040400A0
  slow_input1                            (addr 0x109002A8): 0x00000000
  slow_input0                            (addr 0x109002AC): 0x00000718
  slow_shift_reg_config                  (addr 0x109002B0): 0x0000813E
  slow_debounce_ctrl1                    (addr 0x109002B8): 0x00000000
  slow_debounce_ctrl0                    (addr 0x109002BC): 0x00000000
  slow_debounce_time5                    (addr 0x109002C8): 0x00000000
  slow_debounce_time4                    (addr 0x109002CC): 0x00000000
  slow_debounce_time3                    (addr 0x109002D0): 0x00000000
  slow_debounce_time2                    (addr 0x109002D4): 0x00000000
  slow_debounce_time1                    (addr 0x109002D8): 0x00000000
  slow_debounce_time0                    (addr 0x109002DC): 0x00000000
  slow_func_type                         (addr 0x109002E0): 0x00000000
  slow_intr_test1                        (addr 0x109002E8): 0x00000000
  slow_intr_test0                        (addr 0x109002EC): 0x00000000
  slow_fan_tach                          (addr 0x109002F0): 0x08080808
  slow_ethernet_led_cfg                  (addr 0x109002F8): 0x00003307
  slow_ethernet_led_en                   (addr 0x109002FC): 0x00000023
  slow_intr_type3                        (addr 0x10900300): 0xFFFFFFFF
  slow_intr_type2                        (addr 0x10900304): 0xFFFFFFFF
  slow_intr_type1                        (addr 0x10900308): 0xFFFFFFFF
  slow_intr_type0                        (addr 0x1090030C): 0xFFFFFFFF
  slow_err_intr_event1                   (addr 0x10900310): 0x00000000
  slow_err_intr_event0                   (addr 0x10900314): 0x00000000
  slow_mgmt_intr_event1                  (addr 0x10900318): 0x00000000
  slow_mgmt_intr_event0                  (addr 0x1090031C): 0x00000000
  slow_ntwk_intr_event1                  (addr 0x10900320): 0x00000000
  slow_ntwk_intr_event0                  (addr 0x10900324): 0x00000000
  slow_err_intr_enable1                  (addr 0x10900328): 0x00000000
  slow_err_intr_enable0                  (addr 0x1090032C): 0x00000000
  slow_mgmt_intr_enable1                 (addr 0x10900330): 0x00000000
  slow_mgmt_intr_enable0                 (addr 0x10900334): 0x00000000
  slow_ntwk_intr_enable1                 (addr 0x10900338): 0x00000000
  slow_ntwk_intr_enable0                 (addr 0x1090033C): 0x00000000
  slow_output_polarity_ctrl1             (addr 0x10900340): 0x00000000
  slow_output_polarity_ctrl0             (addr 0x10900344): 0x00000000
  slow_input_polarity_ctrl1              (addr 0x10900348): 0x00000000
  slow_input_polarity_ctrl0              (addr 0x1090034C): 0x00000000
io-controller hdlc 0 (addr 0x10800000):
  h_status                               (addr 0x10800000): 0x00000000
  h_edtbar                               (addr 0x10800004): 0x0E91C000
  h_idtbar                               (addr 0x10800008): 0x0E91E000
  h_cer                                  (addr 0x1080000C): 0x00000000
  h_edavnr                               (addr 0x10800010): 0x00000000
  h_ebrr                                 (addr 0x10800014): 0x00000000
  h_ipqnr                                (addr 0x10800018): 0x00000000
  h_eer                                  (addr 0x1080001C): 0x00000000
  h_ier                                  (addr 0x10800020): 0x00000000
  h_ilur                                 (addr 0x10800024): 0x00000000
  ca_cr                                  (addr 0x10800028): 0x00000000
  h_ccr                                  (addr 0x1080002C): 0x00000000
  h_ctrl                                 (addr 0x10800030): 0x0000006F
  h_imfsr                                (addr 0x10800034): 0x0000FFFF
  h_ifser                                (addr 0x10800038): 0x00000000
  h_tdmcr                                (addr 0x1080003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10800100): 0x00000000
  dbg_data_lower                         (addr 0x10800104): 0x00000000
  dbg_data_upper                         (addr 0x10800108): 0x00000000
  h_frm_cnt                              (addr 0x1080010C): 0x00000000
  h_mem_pesr                             (addr 0x10800110): 0x00000000
  h_mem_pecr                             (addr 0x10800114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10800118): 0x00000007
  h_imem_buf_pear                        (addr 0x1080011C): 0x0000000F
  h_echn_am_pear                         (addr 0x10800120): 0x00000074
  h_ichn_am_pear                         (addr 0x10800124): 0x00000018
  h_parerr_inject                        (addr 0x10800128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10800200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10800204): 0x0000007F
hdlc_ca_lh (addr 0x10800400 - 0x108005FF):
       0:                   00000000 00000000          ........
       8: 00000000 00000000 00000000 00000000  ................
      24: 00000000 00000000 00000000 00000000  ................
      40: 00000000 00000000 00000000 00000000  ................
      56: 00000000 00000000 00000000 00000000  ................
      72: 00000000 00000000 00000000 00000000  ................
      88: 00000000 00000000 00000000 00000000  ................
     104: 00000000 00000000 00000000 00000000  ................
     120: 00000000 00000000 00000000 00000000  ................
     136: 00000000 00000000 00000000 00000000  ................
     152: 00000000 00000000 00000000 00000000  ................
     168: 00000000 00000000 00000000 00000000  ................
     184: 00000000 00000000 00000000 00000000  ................
     200: 00000000 00000000 00000000 00000000  ................
     216: 00000000 00000000 00000000 00000000  ................
     232: 00000000 00000000 00000000 00000000  ................
     248: 00000000 00000000 00000000 00000000  ................
     264: 00000000 00000000 00000000 00000000  ................
     280: 00000000 00000000 00000000 00000000  ................
     296: 00000000 00000000 00000000 00000000  ................
     312: 00000000 00000000 00000000 00000000  ................
     328: 00000000 00000000 00000000 00000000  ................
     344: 00000000 00000000 00000000 00000000  ................
     360: 00000000 00000000 00000000 00000000  ................
     376: 00000000 00000000 00000000 00000000  ................
     392: 00000000 00000000 00000000 00000000  ................
     408: 00000000 00000000 00000000 00000000  ................
     424: 00000000 00000000 00000000 00000000  ................
     440: 00000000 00000000 00000000 00000000  ................
     456: 00000000 00000000 00000000 00000000  ................
     472: 00000000 00000000 00000000 00000000  ................
     488: 00000000 00000000 00000000 00000000  ................
     504: 00000000 00000000                    ........
hdlc_ca_uh (addr 0x10800600 - 0x108007FF):
io-controller hdlc 1 (addr 0x10810000):
  h_status                               (addr 0x10810000): 0x00000000
  h_edtbar                               (addr 0x10810004): 0x0E920000
  h_idtbar                               (addr 0x10810008): 0x0E922000
  h_cer                                  (addr 0x1081000C): 0x00000000
  h_edavnr                               (addr 0x10810010): 0x00000000
  h_ebrr                                 (addr 0x10810014): 0x00000000
  h_ipqnr                                (addr 0x10810018): 0x00000000
  h_eer                                  (addr 0x1081001C): 0x00000000
  h_ier                                  (addr 0x10810020): 0x00000000
  h_ilur                                 (addr 0x10810024): 0x00000000
  ca_cr                                  (addr 0x10810028): 0x00000000
  h_ccr                                  (addr 0x1081002C): 0x00000000
  h_ctrl                                 (addr 0x10810030): 0x0000006F
  h_imfsr                                (addr 0x10810034): 0x0000FFFF
  h_ifser                                (addr 0x10810038): 0x00000000
  h_tdmcr                                (addr 0x1081003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10810100): 0x00000000
  dbg_data_lower                         (addr 0x10810104): 0x00000000
  dbg_data_upper                         (addr 0x10810108): 0x00000000
  h_frm_cnt                              (addr 0x1081010C): 0x00000000
  h_mem_pesr                             (addr 0x10810110): 0x00000000
  h_mem_pecr                             (addr 0x10810114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10810118): 0x00000007
  h_imem_buf_pear                        (addr 0x1081011C): 0x000000F7
  h_echn_am_pear                         (addr 0x10810120): 0x00000048
  h_ichn_am_pear                         (addr 0x10810124): 0x0000006C
  h_parerr_inject                        (addr 0x10810128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10810200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10810204): 0x0000007F
hdlc_ca_lh (addr 0x10810400 - 0x108105FF):
hdlc_ca_uh (addr 0x10810600 - 0x108107FF):
io-controller hdlc 2 (addr 0x10820000):
  h_status                               (addr 0x10820000): 0x00000000
  h_edtbar                               (addr 0x10820004): 0x0E924000
  h_idtbar                               (addr 0x10820008): 0x0E926000
  h_cer                                  (addr 0x1082000C): 0x00000000
  h_edavnr                               (addr 0x10820010): 0x00000000
  h_ebrr                                 (addr 0x10820014): 0x00000000
  h_ipqnr                                (addr 0x10820018): 0x00000000
  h_eer                                  (addr 0x1082001C): 0x00000000
  h_ier                                  (addr 0x10820020): 0x00000000
  h_ilur                                 (addr 0x10820024): 0x00000000
  ca_cr                                  (addr 0x10820028): 0x00000000
  h_ccr                                  (addr 0x1082002C): 0x00000000
  h_ctrl                                 (addr 0x10820030): 0x0000006F
  h_imfsr                                (addr 0x10820034): 0x0000FFFF
  h_ifser                                (addr 0x10820038): 0x00000000
  h_tdmcr                                (addr 0x1082003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10820100): 0x00000000
  dbg_data_lower                         (addr 0x10820104): 0x00000000
  dbg_data_upper                         (addr 0x10820108): 0x00000000
  h_frm_cnt                              (addr 0x1082010C): 0x00000000
  h_mem_pesr                             (addr 0x10820110): 0x00000000
  h_mem_pecr                             (addr 0x10820114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10820118): 0x00000007
  h_imem_buf_pear                        (addr 0x1082011C): 0x0000002F
  h_echn_am_pear                         (addr 0x10820120): 0x00000078
  h_ichn_am_pear                         (addr 0x10820124): 0x00000018
  h_parerr_inject                        (addr 0x10820128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10820200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10820204): 0x0000007F
hdlc_ca_lh (addr 0x10820400 - 0x108205FF):
hdlc_ca_uh (addr 0x10820600 - 0x108207FF):
io-controller hdlc 3 (addr 0x10830000):
  h_status                               (addr 0x10830000): 0x00000000
  h_edtbar                               (addr 0x10830004): 0x0E928000
  h_idtbar                               (addr 0x10830008): 0x0E92A000
  h_cer                                  (addr 0x1083000C): 0x00000000
  h_edavnr                               (addr 0x10830010): 0x00000000
  h_ebrr                                 (addr 0x10830014): 0x00000000
  h_ipqnr                                (addr 0x10830018): 0x00000000
  h_eer                                  (addr 0x1083001C): 0x00000000
  h_ier                                  (addr 0x10830020): 0x00000000
  h_ilur                                 (addr 0x10830024): 0x00000000
  ca_cr                                  (addr 0x10830028): 0x00000000
  h_ccr                                  (addr 0x1083002C): 0x00000000
  h_ctrl                                 (addr 0x10830030): 0x0000006F
  h_imfsr                                (addr 0x10830034): 0x0000FFFF
  h_ifser                                (addr 0x10830038): 0x00000000
  h_tdmcr                                (addr 0x1083003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10830100): 0x00000000
  dbg_data_lower                         (addr 0x10830104): 0x00000000
  dbg_data_upper                         (addr 0x10830108): 0x00000000
  h_frm_cnt                              (addr 0x1083010C): 0x00000000
  h_mem_pesr                             (addr 0x10830110): 0x00000000
  h_mem_pecr                             (addr 0x10830114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10830118): 0x00000007
  h_imem_buf_pear                        (addr 0x1083011C): 0x0000003F
  h_echn_am_pear                         (addr 0x10830120): 0x00000048
  h_ichn_am_pear                         (addr 0x10830124): 0x0000006C
  h_parerr_inject                        (addr 0x10830128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10830200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10830204): 0x0000007F
hdlc_ca_lh (addr 0x10830400 - 0x108305FF):
hdlc_ca_uh (addr 0x10830600 - 0x108307FF):
io-controller hdlc 4 (addr 0x10840000):
  h_status                               (addr 0x10840000): 0x00000000
  h_edtbar                               (addr 0x10840004): 0x0E92C000
  h_idtbar                               (addr 0x10840008): 0x0E92E000
  h_cer                                  (addr 0x1084000C): 0x00000000
  h_edavnr                               (addr 0x10840010): 0x00000000
  h_ebrr                                 (addr 0x10840014): 0x00000000
  h_ipqnr                                (addr 0x10840018): 0x00000000
  h_eer                                  (addr 0x1084001C): 0x00000000
  h_ier                                  (addr 0x10840020): 0x00000000
  h_ilur                                 (addr 0x10840024): 0x00000000
  ca_cr                                  (addr 0x10840028): 0x00000000
  h_ccr                                  (addr 0x1084002C): 0x00000000
  h_ctrl                                 (addr 0x10840030): 0x0000006F
  h_imfsr                                (addr 0x10840034): 0x0000FFFF
  h_ifser                                (addr 0x10840038): 0x00000000
  h_tdmcr                                (addr 0x1084003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10840100): 0x00000000
  dbg_data_lower                         (addr 0x10840104): 0x00000000
  dbg_data_upper                         (addr 0x10840108): 0x00000000
  h_frm_cnt                              (addr 0x1084010C): 0x00000000
  h_mem_pesr                             (addr 0x10840110): 0x00000000
  h_mem_pecr                             (addr 0x10840114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10840118): 0x00000007
  h_imem_buf_pear                        (addr 0x1084011C): 0x00000067
  h_echn_am_pear                         (addr 0x10840120): 0x00000014
  h_ichn_am_pear                         (addr 0x10840124): 0x00000038
  h_parerr_inject                        (addr 0x10840128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10840200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10840204): 0x0000007F
hdlc_ca_lh (addr 0x10840400 - 0x108405FF):
hdlc_ca_uh (addr 0x10840600 - 0x108407FF):
io-controller hdlc 5 (addr 0x10850000):
  h_status                               (addr 0x10850000): 0x00000000
  h_edtbar                               (addr 0x10850004): 0x0E930000
  h_idtbar                               (addr 0x10850008): 0x0E932000
  h_cer                                  (addr 0x1085000C): 0x00000000
  h_edavnr                               (addr 0x10850010): 0x00000000
  h_ebrr                                 (addr 0x10850014): 0x00000000
  h_ipqnr                                (addr 0x10850018): 0x00000000
  h_eer                                  (addr 0x1085001C): 0x00000000
  h_ier                                  (addr 0x10850020): 0x00000000
  h_ilur                                 (addr 0x10850024): 0x00000000
  ca_cr                                  (addr 0x10850028): 0x00000000
  h_ccr                                  (addr 0x1085002C): 0x00000000
  h_ctrl                                 (addr 0x10850030): 0x0000006F
  h_imfsr                                (addr 0x10850034): 0x0000FFFF
  h_ifser                                (addr 0x10850038): 0x00000000
  h_tdmcr                                (addr 0x1085003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10850100): 0x00000000
  dbg_data_lower                         (addr 0x10850104): 0x00000000
  dbg_data_upper                         (addr 0x10850108): 0x00000000
  h_frm_cnt                              (addr 0x1085010C): 0x00000000
  h_mem_pesr                             (addr 0x10850110): 0x00000000
  h_mem_pecr                             (addr 0x10850114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10850118): 0x00000007
  h_imem_buf_pear                        (addr 0x1085011C): 0x0000003F
  h_echn_am_pear                         (addr 0x10850120): 0x00000008
  h_ichn_am_pear                         (addr 0x10850124): 0x00000028
  h_parerr_inject                        (addr 0x10850128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10850200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10850204): 0x0000007F
hdlc_ca_lh (addr 0x10850400 - 0x108505FF):
hdlc_ca_uh (addr 0x10850600 - 0x108507FF):
io-controller hdlc 6 (addr 0x10860000):
  h_status                               (addr 0x10860000): 0x00000000
  h_edtbar                               (addr 0x10860004): 0x0E934000
  h_idtbar                               (addr 0x10860008): 0x0E936000
  h_cer                                  (addr 0x1086000C): 0x00000000
  h_edavnr                               (addr 0x10860010): 0x00000000
  h_ebrr                                 (addr 0x10860014): 0x00000000
  h_ipqnr                                (addr 0x10860018): 0x00000000
  h_eer                                  (addr 0x1086001C): 0x00000000
  h_ier                                  (addr 0x10860020): 0x00000000
  h_ilur                                 (addr 0x10860024): 0x00000000
  ca_cr                                  (addr 0x10860028): 0x00000000
  h_ccr                                  (addr 0x1086002C): 0x00000000
  h_ctrl                                 (addr 0x10860030): 0x0000006F
  h_imfsr                                (addr 0x10860034): 0x0000FFFF
  h_ifser                                (addr 0x10860038): 0x00000000
  h_tdmcr                                (addr 0x1086003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10860100): 0x00000000
  dbg_data_lower                         (addr 0x10860104): 0x00000000
  dbg_data_upper                         (addr 0x10860108): 0x00000000
  h_frm_cnt                              (addr 0x1086010C): 0x00000000
  h_mem_pesr                             (addr 0x10860110): 0x00000000
  h_mem_pecr                             (addr 0x10860114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10860118): 0x00000007
  h_imem_buf_pear                        (addr 0x1086011C): 0x00000047
  h_echn_am_pear                         (addr 0x10860120): 0x00000054
  h_ichn_am_pear                         (addr 0x10860124): 0x00000074
  h_parerr_inject                        (addr 0x10860128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10860200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10860204): 0x0000007F
hdlc_ca_lh (addr 0x10860400 - 0x108605FF):
hdlc_ca_uh (addr 0x10860600 - 0x108607FF):
io-controller hdlc 7 (addr 0x10870000):
  h_status                               (addr 0x10870000): 0x00000000
  h_edtbar                               (addr 0x10870004): 0x0E938000
  h_idtbar                               (addr 0x10870008): 0x0E93A000
  h_cer                                  (addr 0x1087000C): 0x00000000
  h_edavnr                               (addr 0x10870010): 0x00000000
  h_ebrr                                 (addr 0x10870014): 0x00000000
  h_ipqnr                                (addr 0x10870018): 0x00000000
  h_eer                                  (addr 0x1087001C): 0x00000000
  h_ier                                  (addr 0x10870020): 0x00000000
  h_ilur                                 (addr 0x10870024): 0x00000000
  ca_cr                                  (addr 0x10870028): 0x00000000
  h_ccr                                  (addr 0x1087002C): 0x00000000
  h_ctrl                                 (addr 0x10870030): 0x0000006F
  h_imfsr                                (addr 0x10870034): 0x0000FFFF
  h_ifser                                (addr 0x10870038): 0x00000000
  h_tdmcr                                (addr 0x1087003C): 0x0000001B
  dbg_buf_addr                           (addr 0x10870100): 0x00000000
  dbg_data_lower                         (addr 0x10870104): 0x00000000
  dbg_data_upper                         (addr 0x10870108): 0x00000000
  h_frm_cnt                              (addr 0x1087010C): 0x00000000
  h_mem_pesr                             (addr 0x10870110): 0x00000000
  h_mem_pecr                             (addr 0x10870114): 0x0000000F
  h_emem_buf_pear                        (addr 0x10870118): 0x00000007
  h_imem_buf_pear                        (addr 0x1087011C): 0x0000000F
  h_echn_am_pear                         (addr 0x10870120): 0x00000060
  h_ichn_am_pear                         (addr 0x10870124): 0x00000000
  h_parerr_inject                        (addr 0x10870128): 0x00000000
  h_sti_buserr_sts                       (addr 0x10870200): 0x00000000
  h_sti_buserr_ctl                       (addr 0x10870204): 0x0000007F
hdlc_ca_lh (addr 0x10870400 - 0x108705FF):
hdlc_ca_uh (addr 0x10870600 - 0x108707FF):
Device Node 0 io-controller hsib (addr 0x10FF0000):
  dn_ctrl                                (addr 0x10FF0000): 0x00000027
  dn_initiator_thlv                      (addr 0x10FF0004): 0x00080808
  dn_target_thlv                         (addr 0x10FF0008): 0x00080808
  dn_status                              (addr 0x10FF000C): 0x00000002
  dn_initiator_error                     (addr 0x10FF0010): 0x00000000
  dn_target_error                        (addr 0x10FF0014): 0x00000000
  dn_initiator_error_mask                (addr 0x10FF0018): 0x00000000
  dn_target_error_mask                   (addr 0x10FF001C): 0x00000000
  dn_node_id                             (addr 0x10FF0020): 0x00000000
  dn_target_online                       (addr 0x10FF0024): 0x000000FF
  dn_first_error_hsib_hdr                (addr 0x10FF0028): 0x00000000
  dn_first_error_address                 (addr 0x10FF002C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x10FF0030): 0x00000000
  dn_first_error_address                 (addr 0x10FF0034): 0x00000000
  dn_aux_ctrl                            (addr 0x10FF0050): 0x00000329
  dn_timeout_ctrl                        (addr 0x10FF0054): 0x00000000
  dn_timer                               (addr 0x10FF0058): 0x00086982
  hsib_no_lut_priority                   (addr 0x10FF005C): 0x00000000
LUT Entry 0  LUT (addr 0x10FF0060):
  lut_ctrl                               (addr 0x10FF0060): 0x80100040
  base_limit                             (addr 0x10FF0064): 0x107F1000
LUT Entry 1  LUT (addr 0x10FF0068):
  lut_ctrl                               (addr 0x10FF0068): 0x80100080
  base_limit                             (addr 0x10FF006C): 0x108F1080
LUT Entry 2  LUT (addr 0x10FF0070):
  lut_ctrl                               (addr 0x10FF0070): 0x80120020
  base_limit                             (addr 0x10FF0074): 0x10951090
LUT Entry 3  LUT (addr 0x10FF0078):
  lut_ctrl                               (addr 0x10FF0078): 0x80100040
  base_limit                             (addr 0x10FF007C): 0x10FE10FE
Device Node 1 io-controller hsib (addr 0x10FF1000):
  dn_ctrl                                (addr 0x10FF1000): 0x0000001B
  dn_initiator_thlv                      (addr 0x10FF1004): 0x00080404
  dn_target_thlv                         (addr 0x10FF1008): 0x0004020E
  dn_status                              (addr 0x10FF100C): 0x00000000
  dn_initiator_error                     (addr 0x10FF1010): 0x00000000
  dn_target_error                        (addr 0x10FF1014): 0x00000000
  dn_initiator_error_mask                (addr 0x10FF1018): 0x00000000
  dn_target_error_mask                   (addr 0x10FF101C): 0x00000000
  dn_node_id                             (addr 0x10FF1020): 0x00000001
  dn_target_online                       (addr 0x10FF1024): 0x000000FF
  dn_first_error_hsib_hdr                (addr 0x10FF1028): 0x00000000
  dn_first_error_address                 (addr 0x10FF102C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x10FF1030): 0x00000000
  dn_first_error_address                 (addr 0x10FF1034): 0x00000000
  dn_aux_ctrl                            (addr 0x10FF1050): 0x0000032B
  dn_timeout_ctrl                        (addr 0x10FF1054): 0x00000000
  dn_timer                               (addr 0x10FF1058): 0x000BF1ED
  hsib_no_lut_priority                   (addr 0x10FF105C): 0x00000000
LUT Entry 0  LUT (addr 0x10FF1060):
  lut_ctrl                               (addr 0x10FF1060): 0x00000000
  base_limit                             (addr 0x10FF1064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x10FF1068):
  lut_ctrl                               (addr 0x10FF1068): 0x00000000
  base_limit                             (addr 0x10FF106C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x10FF1070):
  lut_ctrl                               (addr 0x10FF1070): 0x00000000
  base_limit                             (addr 0x10FF1074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x10FF1078):
  lut_ctrl                               (addr 0x10FF1078): 0x00000000
  base_limit                             (addr 0x10FF107C): 0x0000FFFF
Device Node 2 io-controller hsib (addr 0x10FF2000):
  dn_ctrl                                (addr 0x10FF2000): 0x0000001B
  dn_initiator_thlv                      (addr 0x10FF2004): 0x00080404
  dn_target_thlv                         (addr 0x10FF2008): 0x0004020E
  dn_status                              (addr 0x10FF200C): 0x00000000
  dn_initiator_error                     (addr 0x10FF2010): 0x00000000
  dn_target_error                        (addr 0x10FF2014): 0x00000000
  dn_initiator_error_mask                (addr 0x10FF2018): 0x00000000
  dn_target_error_mask                   (addr 0x10FF201C): 0x00000000
  dn_node_id                             (addr 0x10FF2020): 0x00000002
  dn_target_online                       (addr 0x10FF2024): 0x000000FF
  dn_first_error_hsib_hdr                (addr 0x10FF2028): 0x00000000
  dn_first_error_address                 (addr 0x10FF202C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x10FF2030): 0x00000000
  dn_first_error_address                 (addr 0x10FF2034): 0x00000000
  dn_aux_ctrl                            (addr 0x10FF2050): 0x0000032B
  dn_timeout_ctrl                        (addr 0x10FF2054): 0x00000000
  dn_timer                               (addr 0x10FF2058): 0x000C0AE8
  hsib_no_lut_priority                   (addr 0x10FF205C): 0x00000000
LUT Entry 0  LUT (addr 0x10FF2060):
  lut_ctrl                               (addr 0x10FF2060): 0x00000000
  base_limit                             (addr 0x10FF2064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x10FF2068):
  lut_ctrl                               (addr 0x10FF2068): 0x00000000
  base_limit                             (addr 0x10FF206C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x10FF2070):
  lut_ctrl                               (addr 0x10FF2070): 0x00000000
  base_limit                             (addr 0x10FF2074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x10FF2078):
  lut_ctrl                               (addr 0x10FF2078): 0x00000000
  base_limit                             (addr 0x10FF207C): 0x0000FFFF
Device Node 3 io-controller hsib (addr 0x10FF3000):
  dn_ctrl                                (addr 0x10FF3000): 0x0000001B
  dn_initiator_thlv                      (addr 0x10FF3004): 0x00080404
  dn_target_thlv                         (addr 0x10FF3008): 0x0004020E
  dn_status                              (addr 0x10FF300C): 0x00000000
  dn_initiator_error                     (addr 0x10FF3010): 0x00000000
  dn_target_error                        (addr 0x10FF3014): 0x00000000
  dn_initiator_error_mask                (addr 0x10FF3018): 0x00000000
  dn_target_error_mask                   (addr 0x10FF301C): 0x00000000
  dn_node_id                             (addr 0x10FF3020): 0x00000003
  dn_target_online                       (addr 0x10FF3024): 0x000000FF
  dn_first_error_hsib_hdr                (addr 0x10FF3028): 0x00000000
  dn_first_error_address                 (addr 0x10FF302C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x10FF3030): 0x00000000
  dn_first_error_address                 (addr 0x10FF3034): 0x00000000
  dn_aux_ctrl                            (addr 0x10FF3050): 0x0000032B
  dn_timeout_ctrl                        (addr 0x10FF3054): 0x00000000
  dn_timer                               (addr 0x10FF3058): 0x000C239B
  hsib_no_lut_priority                   (addr 0x10FF305C): 0x00000000
LUT Entry 0  LUT (addr 0x10FF3060):
  lut_ctrl                               (addr 0x10FF3060): 0x00000000
  base_limit                             (addr 0x10FF3064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x10FF3068):
  lut_ctrl                               (addr 0x10FF3068): 0x00000000
  base_limit                             (addr 0x10FF306C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x10FF3070):
  lut_ctrl                               (addr 0x10FF3070): 0x00000000
  base_limit                             (addr 0x10FF3074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x10FF3078):
  lut_ctrl                               (addr 0x10FF3078): 0x00000000
  base_limit                             (addr 0x10FF307C): 0x0000FFFF
Device Node 4 io-controller hsib (addr 0x10FF4000):
  dn_ctrl                                (addr 0x10FF4000): 0x0000001B
  dn_initiator_thlv                      (addr 0x10FF4004): 0x00080404
  dn_target_thlv                         (addr 0x10FF4008): 0x0004020E
  dn_status                              (addr 0x10FF400C): 0x00000000
  dn_initiator_error                     (addr 0x10FF4010): 0x00000000
  dn_target_error                        (addr 0x10FF4014): 0x00000000
  dn_initiator_error_mask                (addr 0x10FF4018): 0x00000000
  dn_target_error_mask                   (addr 0x10FF401C): 0x00000000
  dn_node_id                             (addr 0x10FF4020): 0x00000004
  dn_target_online                       (addr 0x10FF4024): 0x000000FF
  dn_first_error_hsib_hdr                (addr 0x10FF4028): 0x00000000
  dn_first_error_address                 (addr 0x10FF402C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x10FF4030): 0x00000000
  dn_first_error_address                 (addr 0x10FF4034): 0x00000000
  dn_aux_ctrl                            (addr 0x10FF4050): 0x0000032B
  dn_timeout_ctrl                        (addr 0x10FF4054): 0x00000000
  dn_timer                               (addr 0x10FF4058): 0x000C3CFE
  hsib_no_lut_priority                   (addr 0x10FF405C): 0x00000000
LUT Entry 0  LUT (addr 0x10FF4060):
  lut_ctrl                               (addr 0x10FF4060): 0x00000000
  base_limit                             (addr 0x10FF4064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x10FF4068):
  lut_ctrl                               (addr 0x10FF4068): 0x00000000
  base_limit                             (addr 0x10FF406C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x10FF4070):
  lut_ctrl                               (addr 0x10FF4070): 0x00000000
  base_limit                             (addr 0x10FF4074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x10FF4078):
  lut_ctrl                               (addr 0x10FF4078): 0x00000000
  base_limit                             (addr 0x10FF407C): 0x0000FFFF
Device Node 5 io-controller hsib (addr 0x10FF5000):
  dn_ctrl                                (addr 0x10FF5000): 0x0000001B
  dn_initiator_thlv                      (addr 0x10FF5004): 0x00040404
  dn_target_thlv                         (addr 0x10FF5008): 0x00040404
  dn_status                              (addr 0x10FF500C): 0x00000000
  dn_initiator_error                     (addr 0x10FF5010): 0x00000000
  dn_target_error                        (addr 0x10FF5014): 0x00000000
  dn_initiator_error_mask                (addr 0x10FF5018): 0x00000000
  dn_target_error_mask                   (addr 0x10FF501C): 0x00000000
  dn_node_id                             (addr 0x10FF5020): 0x00000005
  dn_target_online                       (addr 0x10FF5024): 0x000000FF
  dn_first_error_hsib_hdr                (addr 0x10FF5028): 0x00000000
  dn_first_error_address                 (addr 0x10FF502C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x10FF5030): 0x00000000
  dn_first_error_address                 (addr 0x10FF5034): 0x00000000
  dn_aux_ctrl                            (addr 0x10FF5050): 0x0000013B
  dn_timeout_ctrl                        (addr 0x10FF5054): 0x00000000
  dn_timer                               (addr 0x10FF5058): 0x000FBCE6
  hsib_no_lut_priority                   (addr 0x10FF505C): 0x00000130
LUT Entry 0  LUT (addr 0x10FF5060):
  lut_ctrl                               (addr 0x10FF5060): 0x00000000
  base_limit                             (addr 0x10FF5064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x10FF5068):
  lut_ctrl                               (addr 0x10FF5068): 0x00000000
  base_limit                             (addr 0x10FF506C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x10FF5070):
  lut_ctrl                               (addr 0x10FF5070): 0x00000000
  base_limit                             (addr 0x10FF5074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x10FF5078):
  lut_ctrl                               (addr 0x10FF5078): 0x00000000
  base_limit                             (addr 0x10FF507C): 0x0000FFFF
Device Node 6 io-controller hsib (addr 0x10FF6000):
  dn_ctrl                                (addr 0x10FF6000): 0x0000001B
  dn_initiator_thlv                      (addr 0x10FF6004): 0x00040404
  dn_target_thlv                         (addr 0x10FF6008): 0x00040404
  dn_status                              (addr 0x10FF600C): 0x00000000
  dn_initiator_error                     (addr 0x10FF6010): 0x00000000
  dn_target_error                        (addr 0x10FF6014): 0x00000000
  dn_initiator_error_mask                (addr 0x10FF6018): 0x00000000
  dn_target_error_mask                   (addr 0x10FF601C): 0x00000000
  dn_node_id                             (addr 0x10FF6020): 0x00000006
  dn_target_online                       (addr 0x10FF6024): 0x000000FF
  dn_first_error_hsib_hdr                (addr 0x10FF6028): 0x00000000
  dn_first_error_address                 (addr 0x10FF602C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x10FF6030): 0x00000000
  dn_first_error_address                 (addr 0x10FF6034): 0x00000000
  dn_aux_ctrl                            (addr 0x10FF6050): 0x0000012B
  dn_timeout_ctrl                        (addr 0x10FF6054): 0x00000000
  dn_timer                               (addr 0x10FF6058): 0x000FD4C2
  hsib_no_lut_priority                   (addr 0x10FF605C): 0x00000120
LUT Entry 0  LUT (addr 0x10FF6060):
  lut_ctrl                               (addr 0x10FF6060): 0x00000000
  base_limit                             (addr 0x10FF6064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x10FF6068):
  lut_ctrl                               (addr 0x10FF6068): 0x00000000
  base_limit                             (addr 0x10FF606C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x10FF6070):
  lut_ctrl                               (addr 0x10FF6070): 0x00000000
  base_limit                             (addr 0x10FF6074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x10FF6078):
  lut_ctrl                               (addr 0x10FF6078): 0x00000000
  base_limit                             (addr 0x10FF607C): 0x0000FFFF
Device Node 7 io-controller hsib (addr 0x10FF7000):
  dn_ctrl                                (addr 0x10FF7000): 0x0000001B
  dn_initiator_thlv                      (addr 0x10FF7004): 0x00040404
  dn_target_thlv                         (addr 0x10FF7008): 0x00040404
  dn_status                              (addr 0x10FF700C): 0x00000000
  dn_initiator_error                     (addr 0x10FF7010): 0x00000000
  dn_target_error                        (addr 0x10FF7014): 0x00000000
  dn_initiator_error_mask                (addr 0x10FF7018): 0x00000000
  dn_target_error_mask                   (addr 0x10FF701C): 0x00000000
  dn_node_id                             (addr 0x10FF7020): 0x00000007
  dn_target_online                       (addr 0x10FF7024): 0x000000FF
  dn_first_error_hsib_hdr                (addr 0x10FF7028): 0x00000000
  dn_first_error_address                 (addr 0x10FF702C): 0x00000000
  dn_second_error_hsib_hdr               (addr 0x10FF7030): 0x00000000
  dn_first_error_address                 (addr 0x10FF7034): 0x00000000
  dn_aux_ctrl                            (addr 0x10FF7050): 0x0000012B
  dn_timeout_ctrl                        (addr 0x10FF7054): 0x00000000
  dn_timer                               (addr 0x10FF7058): 0x000FECA5
  hsib_no_lut_priority                   (addr 0x10FF705C): 0x00000120
LUT Entry 0  LUT (addr 0x10FF7060):
  lut_ctrl                               (addr 0x10FF7060): 0x00000000
  base_limit                             (addr 0x10FF7064): 0x0000FFFF
LUT Entry 1  LUT (addr 0x10FF7068):
  lut_ctrl                               (addr 0x10FF7068): 0x00000000
  base_limit                             (addr 0x10FF706C): 0x0000FFFF
LUT Entry 2  LUT (addr 0x10FF7070):
  lut_ctrl                               (addr 0x10FF7070): 0x00000000
  base_limit                             (addr 0x10FF7074): 0x0000FFFF
LUT Entry 3  LUT (addr 0x10FF7078):
  lut_ctrl                               (addr 0x10FF7078): 0x00000000
  base_limit                             (addr 0x10FF707C): 0x0000FFFF
io-controller hwic0 (addr 0x10FE0000):
    scratch_reg                          (addr 0x10FE0100): 0xA0A1A2A3
    err_reg0                             (addr 0x10FE0104): 0x00000000
    err_reg1                             (addr 0x10FE0108): 0x00000000
    extnd_reg_err_info                   (addr 0x10FE010C): 0x00000000
    cfg_reg                              (addr 0x10FE0110): 0x00072701
    oir_reg                              (addr 0x10FE0114): 0x00000000
    ram_err_injection_reg                (addr 0x10FE0118): 0x00000000
    egr_cache_debug_reg                  (addr 0x10FE011C): 0x00000107
    err_int_en_reg0                      (addr 0x10FE0120): 0x00000000
    err_int_en_reg1                      (addr 0x10FE0124): 0x00000000
io-controller hwic1 (addr 0x10FE4000):
    scratch_reg                          (addr 0x10FE4100): 0xA0A1A2A3
    err_reg0                             (addr 0x10FE4104): 0x00000000
    err_reg1                             (addr 0x10FE4108): 0x00000000
    extnd_reg_err_info                   (addr 0x10FE410C): 0x00000000
    cfg_reg                              (addr 0x10FE4110): 0x00072701
    oir_reg                              (addr 0x10FE4114): 0x00000000
    ram_err_injection_reg                (addr 0x10FE4118): 0x00000000
    egr_cache_debug_reg                  (addr 0x10FE411C): 0x00000107
    err_int_en_reg0                      (addr 0x10FE4120): 0x00000000
    err_int_en_reg1                      (addr 0x10FE4124): 0x00000000
io-controller hwic2 (addr 0x10FE8000):
    scratch_reg                          (addr 0x10FE8100): 0xA0A1A2A3
    err_reg0                             (addr 0x10FE8104): 0x00000000
    err_reg1                             (addr 0x10FE8108): 0x00000000
    extnd_reg_err_info                   (addr 0x10FE810C): 0x00000000
    cfg_reg                              (addr 0x10FE8110): 0x00072701
    oir_reg                              (addr 0x10FE8114): 0x00000000
    ram_err_injection_reg                (addr 0x10FE8118): 0x00000000
    egr_cache_debug_reg                  (addr 0x10FE811C): 0x00000107
    err_int_en_reg0                      (addr 0x10FE8120): 0x00000000
    err_int_en_reg1                      (addr 0x10FE8124): 0x00000000
io-controller hwic3 (addr 0x10FEC000):
    scratch_reg                          (addr 0x10FEC100): 0xA0A1A2A3
    err_reg0                             (addr 0x10FEC104): 0x00000000
    err_reg1                             (addr 0x10FEC108): 0x00000000
    extnd_reg_err_info                   (addr 0x10FEC10C): 0x00000000
    cfg_reg                              (addr 0x10FEC110): 0x00072701
    oir_reg                              (addr 0x10FEC114): 0x00000000
    ram_err_injection_reg                (addr 0x10FEC118): 0x00000000
    egr_cache_debug_reg                  (addr 0x10FEC11C): 0x00000107
    err_int_en_reg0                      (addr 0x10FEC120): 0x00000000
    err_int_en_reg1                      (addr 0x10FEC124): 0x00000000
io-controller interrupts (addr 0x10900000):
  cpu1_network_intr_enable               (addr 0x10900000): 0x1C020FFF
  cpu1_mgmt_intr_enable                  (addr 0x10900008): 0x00000000
  cpu1_error_intr_enable                 (addr 0x1090000C): 0x7C3F0FFF
  cpu2_network_intr_enable               (addr 0x10900010): 0x00000000
  cpu2_mgmt_intr_enable                  (addr 0x10900018): 0x00000000
  cpu2_error_intr_enable                 (addr 0x1090001C): 0x00000000
  redirect_ntwk_intr_en                  (addr 0x10900020): 0x00000000
  redirect_mgmt_intr_en                  (addr 0x10900028): 0x00000000
  redirect_err_intr_en                   (addr 0x1090002C): 0x00000000
  network interrupt status               (addr 0x10900030): 0x00000000
  mgmt interrupt status                  (addr 0x10900038): 0x00000000
  error interrupt status                 (addr 0x1090003C): 0x00000000
  msi_intr_relax_order                   (addr 0x10900040): 0x00000000
  hsib_error_intr_enable                 (addr 0x10900048): 0x0000FC0F
  hsib_error_intr_status                 (addr 0x1090004C): 0x00000000
  hisb_en_error_pcie0low                 (addr 0x10900050): 0x001FFFFE
  hisb_en_error_pcie0high                (addr 0x10900054): 0x00FFFFFF
  hisb_en_error_pcie1low                 (addr 0x10900058): 0x001FFFFE
  hisb_en_error_pcie1high                (addr 0x1090005C): 0x00FFFFFF
  hisb_en_error_pcie2low                 (addr 0x10900060): 0x00000000
  hisb_en_error_pcie2high                (addr 0x10900064): 0x00000000
  hisb_en_error_pcie3low                 (addr 0x10900068): 0x00000000
  hisb_en_error_pcie3high                (addr 0x1090006C): 0x00000000
  hisb_en_error_pcie4low                 (addr 0x10900070): 0x00000000
  hisb_en_error_pcie4high                (addr 0x10900074): 0x00000000
  hsib_en_error_glb_reg_low              (addr 0x10900078): 0x001FFFFE
  hsib_en_error_glb_reg_high             (addr 0x1090007C): 0x00FFFFFF
  hsib_en_error_hwic_low                 (addr 0x10900080): 0x001FFFFE
  hsib_en_error_hwic_high                (addr 0x10900084): 0x00FFFFFF
  hsib_en_error_wan_low                  (addr 0x10900088): 0x001FFFFE
  hsib_en_error_wan_high                 (addr 0x1090008C): 0x00FFFFFF
  hsib_error_event_pcie0low              (addr 0x10900090): 0x00000000
  hsib_error_event_pcie0high             (addr 0x10900094): 0x00000000
  hsib_error_event_pcie1low              (addr 0x10900098): 0x00000000
  hsib_error_event_pcie1high             (addr 0x1090009C): 0x00000000
  hsib_error_event_pcie2low              (addr 0x109000A0): 0x00000000
  hsib_error_event_pcie2high             (addr 0x109000A4): 0x00000000
  hsib_error_event_pcie3low              (addr 0x109000A8): 0x00000000
  hsib_error_event_pcie3high             (addr 0x109000AC): 0x00000000
  hsib_error_event_pcie4low              (addr 0x109000B0): 0x00000000
  hsib_error_event_pcie4high             (addr 0x109000B4): 0x00000000
  hsib_error_event_glb_reg_low           (addr 0x109000B8): 0x00000000
  hsib_error_event_glb_reg_high          (addr 0x109000BC): 0x00000000
  hsib_error_event_hwic_low              (addr 0x109000C0): 0x00000000
  hsib_error_event_hwic_high             (addr 0x109000C4): 0x00000000
  hsib_error_event_wan_low               (addr 0x109000C8): 0x00000000
  hsib_error_event_wan_high              (addr 0x109000CC): 0x00000000
  i2c_master_intr_en                     (addr 0x109000D0): 0x00000000
  i2c_master_intr_status                 (addr 0x109000D4): 0x00000000
  pcie_err_intr_en                       (addr 0x109000D8): 0x00000000
  pcie_err_event                         (addr 0x109000DC): 0x00007800
  interrupt_delay_gpio 0                 (addr 0x109000E0): 0x00000000
  interrupt_dleay_gpio 1                 (addr 0x109000E4): 0x00000000
  interrupt_delay_gpio 2                 (addr 0x109000E8): 0x00000000
  interrupt_delay_gpio 3                 (addr 0x109000EC): 0x00000000
  interrupt_delay_hdlc 0                 (addr 0x109000F0): 0x00000000
  interrupt_delay_hdlc 1                 (addr 0x109000F4): 0x00000000
  interrupt_delay_hdlc 2                 (addr 0x109000F8): 0x00000000
  interrupt_delay_hdlc 3                 (addr 0x109000FC): 0x00000000
  interrupt_delay_hdlc 4                 (addr 0x10900100): 0x00000000
  interrupt_delay_hdlc 5                 (addr 0x10900104): 0x00000000
  interrupt_delay_hdlc 6                 (addr 0x10900108): 0x00000000
  interrupt_delay_hdlc 7                 (addr 0x1090010C): 0x00000000
  interrupt_delay_hwic 0                 (addr 0x10900110): 0x00000000
  interrupt_delay_hwic 1                 (addr 0x10900114): 0x00000000
  interrupt_delay_hwic 2                 (addr 0x10900118): 0x00000000
  interrupt_delay_hwic 3                 (addr 0x1090011C): 0x00000000
  interrupt_delay_scc                    (addr 0x10900120): 0x00000000
  interrupt_delay_packet_pump            (addr 0x10900124): 0x00000000
  cpu1_cap_ntwk_pcie_msi0                (addr 0x10900140): 0x015B5400
  cpu1_cap_ntwk_pcie_msi1                (addr 0x10900144): 0x0000BCB0
  cpu1_cap_ntwk_pcie_msi2                (addr 0x10900148): 0x00000080
  cpu1_cap_ntwk_pcie_msi3                (addr 0x1090014C): 0xE3FDF000
  cpu1_cap_ntwk_pcie_msi4                (addr 0x10900150): 0x00000000
  cpu1_cap_mgmt_pcie_msi0                (addr 0x10900154): 0x010A6800
  cpu1_cap_mgmt_pcie_msi1                (addr 0x10900158): 0x00000000
  cpu1_cap_mgmt_pcie_msi2                (addr 0x1090015C): 0x00000000
  cpu1_cap_mgmt_pcie_msi3                (addr 0x10900160): 0xFFFFFFFF
  cpu1_cap_mgmt_pcie_msi4                (addr 0x10900164): 0x00000000
  cpu1_cap_error_pcie_msi0               (addr 0x10900168): 0x015B7C00
  cpu1_cap_error_pcie_msi1               (addr 0x1090016C): 0x0000BCB0
  cpu1_cap_error_pcie_msi2               (addr 0x10900170): 0x000000C0
  cpu1_cap_error_pcie_msi3               (addr 0x10900174): 0x83C0F000
  cpu1_cap_error_pcie_msi4               (addr 0x10900178): 0x00000000
  cpu2_cap_ntwk_pcie_msi0                (addr 0x1090017C): 0x010A9000
  cpu2_cap_ntwk_pcie_msi1                (addr 0x10900180): 0x00000000
  cpu2_cap_ntwk_pcie_msi2                (addr 0x10900184): 0x00000000
  cpu2_cap_ntwk_pcie_msi3                (addr 0x10900188): 0xFFFFFFFF
  cpu2_cap_ntwk_pcie_msi4                (addr 0x1090018C): 0x00000000
  cpu2_cap_mgmt_pcie_msi0                (addr 0x10900190): 0x010AA400
  cpu2_cap_mgmt_pcie_msi1                (addr 0x10900194): 0x00000000
  cpu2_cap_mgmt_pcie_msi2                (addr 0x10900198): 0x00000000
  cpu2_cap_mgmt_pcie_msi3                (addr 0x1090019C): 0xFFFFFFFF
  cpu2_cap_mgmt_pcie_msi4                (addr 0x109001A0): 0x00000000
  cpu2_cap_error_pcie_msi0               (addr 0x109001A4): 0x010AB800
  cpu2_cap_error_pcie_msi1               (addr 0x109001A8): 0x00000000
  cpu2_cap_error_pcie_msi2               (addr 0x109001AC): 0x00000000
  cpu2_cap_error_pcie_msi3               (addr 0x109001B0): 0xFFFFFFFF
  cpu2_cap_error_pcie_msi4               (addr 0x109001B4): 0x00000000
io-controller packet pump (addr 0x10880000):
  ppsr0                                  (addr 0x10880000): 0x00000000
  ppsr1                                  (addr 0x10880004): 0x00000000
  ppcr0                                  (addr 0x10880008): 0x0B000000
  ppcr1                                  (addr 0x1088000C): 0x00000000
  ppcr2                                  (addr 0x10880010): 0x00000000
  ppcr3                                  (addr 0x10880014): 0x00000000
  ppcr4                                  (addr 0x10880018): 0x00000000
  d_mer                                  (addr 0x1088001C): 0x00000000
  chcpicr0                               (addr 0x10880020): 0x00000000
  chcpicr1                               (addr 0x10880024): 0x00000000
  rrcr                                   (addr 0x10880028): 0x00000000
  rrar                                   (addr 0x1088002C): 0x00000000
  d_btvr                                 (addr 0x10880030): 0x00001000
  d_tf_mr                                (addr 0x10880034): 0x00000000
  d_wsr                                  (addr 0x10880038): 0x00000000
  d_idqsr                                (addr 0x1088003C): 0x00000000
  d_cdmdbslr1                            (addr 0x10880044): 0x00001000
  d_cdmdbslr2                            (addr 0x10880048): 0x00001000
  d_cdmdbslr3                            (addr 0x1088004C): 0x00002000
  ewqvr[0]                               (addr 0x10880050): 0x00010101
  ewqvr[1]                               (addr 0x10880054): 0x00010101
  ewqvr[2]                               (addr 0x10880058): 0x00010101
  ewqvr[3]                               (addr 0x1088005C): 0x00010101
  iwqvr[0]                               (addr 0x10880060): 0x00000101
  iwqvr[1]                               (addr 0x10880064): 0x00000101
  iwqvr[2]                               (addr 0x10880068): 0x00000101
  iwqvr[3]                               (addr 0x1088006C): 0x00000101
  eddtvr                                 (addr 0x10880070): 0x00009C40
  d_irpr                                 (addr 0x10880100): 0x00000000
  d_iipr                                 (addr 0x10880104): 0x00000000
  ppr[0].d_erpr[0]                       (addr 0x10880108): 0x00000000
  ppr[0].d_erpr[1]                       (addr 0x1088010C): 0x00000000
  ppr[0].d_erpr[2]                       (addr 0x10880110): 0x00000000
  ppr[0].d_erpr[3]                       (addr 0x10880114): 0x00000000
  ppr[0].d_eipr[0]                       (addr 0x10880118): 0x00000000
  ppr[0].d_eipr[1]                       (addr 0x1088011C): 0x00000000
  ppr[0].d_eipr[2]                       (addr 0x10880120): 0x00000000
  ppr[0].d_eipr[3]                       (addr 0x10880124): 0x00000000
  ppr[0].d_eipr[4]                       (addr 0x10880128): 0x00000000
  ppr[0].d_eipr[5]                       (addr 0x1088012C): 0x00000000
  ppr[0].d_eipr[6]                       (addr 0x10880130): 0x00000000
  ppr[0].d_eipr[7]                       (addr 0x10880134): 0x00000000
  ppr[0].d_eipr[8]                       (addr 0x10880138): 0x00000000
  ppr[0].d_eipr[9]                       (addr 0x1088013C): 0x00000000
  ppr[0].d_eipr[10]                      (addr 0x10880140): 0x00000000
  ppr[0].d_eipr[11]                      (addr 0x10880144): 0x00000000
  ppr[0].d_eipr[12]                      (addr 0x10880148): 0x00000000
  ppr[0].d_eipr[13]                      (addr 0x1088014C): 0x00000000
  ppr[0].d_eipr[14]                      (addr 0x10880150): 0x00000000
  ppr[0].d_eipr[15]                      (addr 0x10880154): 0x00000000
  ppr[1].d_erpr[0]                       (addr 0x10880158): 0x00000000
  ppr[1].d_erpr[1]                       (addr 0x1088015C): 0x00000000
  ppr[1].d_erpr[2]                       (addr 0x10880160): 0x00000000
  ppr[1].d_erpr[3]                       (addr 0x10880164): 0x00000000
  ppr[1].d_eipr[0]                       (addr 0x10880168): 0x00000000
  ppr[1].d_eipr[1]                       (addr 0x1088016C): 0x00000000
  ppr[1].d_eipr[2]                       (addr 0x10880170): 0x00000000
  ppr[1].d_eipr[3]                       (addr 0x10880174): 0x00000000
  ppr[1].d_eipr[4]                       (addr 0x10880178): 0x00000000
  ppr[1].d_eipr[5]                       (addr 0x1088017C): 0x00000000
  ppr[1].d_eipr[6]                       (addr 0x10880180): 0x00000000
  ppr[1].d_eipr[7]                       (addr 0x10880184): 0x00000000
  ppr[1].d_eipr[8]                       (addr 0x10880188): 0x00000000
  ppr[1].d_eipr[9]                       (addr 0x1088018C): 0x00000000
  ppr[1].d_eipr[10]                      (addr 0x10880190): 0x00000000
  ppr[1].d_eipr[11]                      (addr 0x10880194): 0x00000000
  ppr[1].d_eipr[12]                      (addr 0x10880198): 0x00000000
  ppr[1].d_eipr[13]                      (addr 0x1088019C): 0x00000000
  ppr[1].d_eipr[14]                      (addr 0x108801A0): 0x00000000
  ppr[1].d_eipr[15]                      (addr 0x108801A4): 0x00000000
  ppr[2].d_erpr[0]                       (addr 0x108801A8): 0x00000000
  ppr[2].d_erpr[1]                       (addr 0x108801AC): 0x00000000
  ppr[2].d_erpr[2]                       (addr 0x108801B0): 0x00000000
  ppr[2].d_erpr[3]                       (addr 0x108801B4): 0x00000000
  ppr[2].d_eipr[0]                       (addr 0x108801B8): 0x00000000
  ppr[2].d_eipr[1]                       (addr 0x108801BC): 0x00000000
  ppr[2].d_eipr[2]                       (addr 0x108801C0): 0x00000000
  ppr[2].d_eipr[3]                       (addr 0x108801C4): 0x00000000
  ppr[2].d_eipr[4]                       (addr 0x108801C8): 0x00000000
  ppr[2].d_eipr[5]                       (addr 0x108801CC): 0x00000000
  ppr[2].d_eipr[6]                       (addr 0x108801D0): 0x00000000
  ppr[2].d_eipr[7]                       (addr 0x108801D4): 0x00000000
  ppr[2].d_eipr[8]                       (addr 0x108801D8): 0x00000000
  ppr[2].d_eipr[9]                       (addr 0x108801DC): 0x00000000
  ppr[2].d_eipr[10]                      (addr 0x108801E0): 0x00000000
  ppr[2].d_eipr[11]                      (addr 0x108801E4): 0x00000000
  ppr[2].d_eipr[12]                      (addr 0x108801E8): 0x00000000
  ppr[2].d_eipr[13]                      (addr 0x108801EC): 0x00000000
  ppr[2].d_eipr[14]                      (addr 0x108801F0): 0x00000000
  ppr[2].d_eipr[15]                      (addr 0x108801F4): 0x00000000
  ppr[3].d_erpr[0]                       (addr 0x108801F8): 0x00000000
  ppr[3].d_erpr[1]                       (addr 0x108801FC): 0x00000000
  ppr[3].d_erpr[2]                       (addr 0x10880200): 0x00000000
  ppr[3].d_erpr[3]                       (addr 0x10880204): 0x00000000
  ppr[3].d_eipr[0]                       (addr 0x10880208): 0x00000000
  ppr[3].d_eipr[1]                       (addr 0x1088020C): 0x00000000
  ppr[3].d_eipr[2]                       (addr 0x10880210): 0x00000000
  ppr[3].d_eipr[3]                       (addr 0x10880214): 0x00000000
  ppr[3].d_eipr[4]                       (addr 0x10880218): 0x00000000
  ppr[3].d_eipr[5]                       (addr 0x1088021C): 0x00000000
  ppr[3].d_eipr[6]                       (addr 0x10880220): 0x00000000
  ppr[3].d_eipr[7]                       (addr 0x10880224): 0x00000000
  ppr[3].d_eipr[8]                       (addr 0x10880228): 0x00000000
  ppr[3].d_eipr[9]                       (addr 0x1088022C): 0x00000000
  ppr[3].d_eipr[10]                      (addr 0x10880230): 0x00000000
  ppr[3].d_eipr[11]                      (addr 0x10880234): 0x00000000
  ppr[3].d_eipr[12]                      (addr 0x10880238): 0x00000000
  ppr[3].d_eipr[13]                      (addr 0x1088023C): 0x00000000
  ppr[3].d_eipr[14]                      (addr 0x10880240): 0x00000000
  ppr[3].d_eipr[15]                      (addr 0x10880244): 0x00000000
  ppr[4].d_erpr[0]                       (addr 0x10880248): 0x00000000
  ppr[4].d_erpr[1]                       (addr 0x1088024C): 0x00000000
  ppr[4].d_erpr[2]                       (addr 0x10880250): 0x00000000
  ppr[4].d_erpr[3]                       (addr 0x10880254): 0x00000000
  ppr[4].d_eipr[0]                       (addr 0x10880258): 0x00000000
  ppr[4].d_eipr[1]                       (addr 0x1088025C): 0x00000000
  ppr[4].d_eipr[2]                       (addr 0x10880260): 0x00000000
  ppr[4].d_eipr[3]                       (addr 0x10880264): 0x00000000
  ppr[4].d_eipr[4]                       (addr 0x10880268): 0x00000000
  ppr[4].d_eipr[5]                       (addr 0x1088026C): 0x00000000
  ppr[4].d_eipr[6]                       (addr 0x10880270): 0x00000000
  ppr[4].d_eipr[7]                       (addr 0x10880274): 0x00000000
  ppr[4].d_eipr[8]                       (addr 0x10880278): 0x00000000
  ppr[4].d_eipr[9]                       (addr 0x1088027C): 0x00000000
  ppr[4].d_eipr[10]                      (addr 0x10880280): 0x00000000
  ppr[4].d_eipr[11]                      (addr 0x10880284): 0x00000000
  ppr[4].d_eipr[12]                      (addr 0x10880288): 0x00000000
  ppr[4].d_eipr[13]                      (addr 0x1088028C): 0x00000000
  ppr[4].d_eipr[14]                      (addr 0x10880290): 0x00000000
  ppr[4].d_eipr[15]                      (addr 0x10880294): 0x00000000
  ppr[5].d_erpr[0]                       (addr 0x10880298): 0x00000000
  ppr[5].d_erpr[1]                       (addr 0x1088029C): 0x00000000
  ppr[5].d_erpr[2]                       (addr 0x108802A0): 0x00000000
  ppr[5].d_erpr[3]                       (addr 0x108802A4): 0x00000000
  ppr[5].d_eipr[0]                       (addr 0x108802A8): 0x00000000
  ppr[5].d_eipr[1]                       (addr 0x108802AC): 0x00000000
  ppr[5].d_eipr[2]                       (addr 0x108802B0): 0x00000000
  ppr[5].d_eipr[3]                       (addr 0x108802B4): 0x00000000
  ppr[5].d_eipr[4]                       (addr 0x108802B8): 0x00000000
  ppr[5].d_eipr[5]                       (addr 0x108802BC): 0x00000000
  ppr[5].d_eipr[6]                       (addr 0x108802C0): 0x00000000
  ppr[5].d_eipr[7]                       (addr 0x108802C4): 0x00000000
  ppr[5].d_eipr[8]                       (addr 0x108802C8): 0x00000000
  ppr[5].d_eipr[9]                       (addr 0x108802CC): 0x00000000
  ppr[5].d_eipr[10]                      (addr 0x108802D0): 0x00000000
  ppr[5].d_eipr[11]                      (addr 0x108802D4): 0x00000000
  ppr[5].d_eipr[12]                      (addr 0x108802D8): 0x00000000
  ppr[5].d_eipr[13]                      (addr 0x108802DC): 0x00000000
  ppr[5].d_eipr[14]                      (addr 0x108802E0): 0x00000000
  ppr[5].d_eipr[15]                      (addr 0x108802E4): 0x00000000
  peisr                                  (addr 0x10880300): 0x00000000
  peier                                  (addr 0x10880304): 0x00000000
  peir                                   (addr 0x10880308): 0x00000000
  ppsbesr                                (addr 0x10880800): 0x00000000
  ppsbecr                                (addr 0x10880804): 0x00000000
  pvdm_pld[0].reset                      (addr 0x10881400): 0x0000FFFF
  pvdm_pld[0].board_level                (addr 0x10881404): 0x0000FFFF
  pvdm_pld[0].interrupt                  (addr 0x10881408): 0x0000FFFF
  pvdm_pld[0].mask                       (addr 0x1088140C): 0x0000FFFF
  pvdm_pld[0].hrrq_mask                  (addr 0x10881410): 0x0000FFFF
  pvdm_pld[0].htrq_mask                  (addr 0x10881414): 0x0000FFFF
  pvdm_pld[0].hrrq_reg                   (addr 0x10881418): 0x0000FFFF
  pvdm_pld[0].htrq_reg                   (addr 0x1088141C): 0x0000FFFF
  pvdm_pld[0].preset                     (addr 0x10881420): 0x0000FFFF
  pvdm_pld[1].reset                      (addr 0x10881440): 0x0000FFFF
  pvdm_pld[1].board_level                (addr 0x10881444): 0x0000FFFF
  pvdm_pld[1].interrupt                  (addr 0x10881448): 0x0000FFFF
  pvdm_pld[1].mask                       (addr 0x1088144C): 0x0000FFFF
  pvdm_pld[1].hrrq_mask                  (addr 0x10881450): 0x0000FFFF
  pvdm_pld[1].htrq_mask                  (addr 0x10881454): 0x0000FFFF
  pvdm_pld[1].hrrq_reg                   (addr 0x10881458): 0x0000FFFF
  pvdm_pld[1].htrq_reg                   (addr 0x1088145C): 0x0000FFFF
  pvdm_pld[1].preset                     (addr 0x10881460): 0x0000FFFF
  pvdm_pld[2].reset                      (addr 0x10881480): 0x0000FFFF
  pvdm_pld[2].board_level                (addr 0x10881484): 0x0000FFFF
  pvdm_pld[2].interrupt                  (addr 0x10881488): 0x0000FFFF
  pvdm_pld[2].mask                       (addr 0x1088148C): 0x0000FFFF
  pvdm_pld[2].hrrq_mask                  (addr 0x10881490): 0x0000FFFF
  pvdm_pld[2].htrq_mask                  (addr 0x10881494): 0x0000FFFF
  pvdm_pld[2].hrrq_reg                   (addr 0x10881498): 0x0000FFFF
  pvdm_pld[2].htrq_reg                   (addr 0x1088149C): 0x0000FFFF
  pvdm_pld[2].preset                     (addr 0x108814A0): 0x0000FFFF
  pvdm_pld[3].reset                      (addr 0x108814C0): 0x0000FFFF
  pvdm_pld[3].board_level                (addr 0x108814C4): 0x0000FFFF
  pvdm_pld[3].interrupt                  (addr 0x108814C8): 0x0000FFFF
  pvdm_pld[3].mask                       (addr 0x108814CC): 0x0000FFFF
  pvdm_pld[3].hrrq_mask                  (addr 0x108814D0): 0x0000FFFF
  pvdm_pld[3].htrq_mask                  (addr 0x108814D4): 0x0000FFFF
  pvdm_pld[3].hrrq_reg                   (addr 0x108814D8): 0x0000FFFF
  pvdm_pld[3].htrq_reg                   (addr 0x108814DC): 0x0000FFFF
  pvdm_pld[3].preset                     (addr 0x108814E0): 0x0000FFFF
io-controller reset controller (addr 0x10900480):
  dn_reset                               (addr 0x10900480): 0x00000000
  function_block_reset                   (addr 0x10900484): 0x00000000
  host_cpu_reset                         (addr 0x10900488): 0x00000000
  ioctrl_warm_reset                      (addr 0x1090048C): 0x00000000
  host_system_reset                      (addr 0x10900490): 0x00000000
WatchDog 0
  wdog_timer_limit                       (addr 0x10900494): 0x01312D00
  wdog_timer_service                     (addr 0x10900498): 0x00000004
  wdog_timer_enable                      (addr 0x1090049C): 0x00000002
  wdog_timer_trigger_level               (addr 0x109004A0): 0x00000000
WatchDog 1
  wdog_timer_limit                       (addr 0x109004A4): 0x00FFFFFF
  wdog_timer_service                     (addr 0x109004A8): 0x00000000
  wdog_timer_enable                      (addr 0x109004AC): 0x00000000
  wdog_timer_trigger_level               (addr 0x109004B0): 0x00000000
  reset_status                           (addr 0x109004B4): 0x00000100
io-controller scc (addr 0x10890000):
  STI_errintr_status                     (addr 0x10890004): 0x00000000
  STI_errintr_enable                     (addr 0x10890008): 0x7FFFFFFF
  SCC_ctrl_regs                          (addr 0x10891004):     0x0000
  mgmt_intr_status                       (addr 0x10891010):     0x0010
  netio_intr_status                      (addr 0x10891012):     0x0000
  timer_0_7_status                       (addr 0x10891014):     0x0000
  timer_16_19_status                     (addr 0x10891016):     0x0000
  mgmt_intr_enable                       (addr 0x10891020):     0x0002
  netio_intr_enable                      (addr 0x10891022):     0x0000
  timer_0_7_enable                       (addr 0x10891024):     0x0000
  timer_16_19_enable                     (addr 0x10891026):     0x0000
  timer_0_1_program                      (addr 0x10891030):     0x0000
  timer_2_3_program                      (addr 0x10891032):     0x0000
  timer_4_5_program                      (addr 0x10891034):     0x0000
  timer_6_7_program                      (addr 0x10891036):     0x0000
  timer_16_program                       (addr 0x10891040):     0x0000
  timer_17_program                       (addr 0x10891042):     0x0000
  timer_18_program                       (addr 0x10891044):     0x0000
  timer_19_program                       (addr 0x10891046):     0x0000
  scc_regs[0].ch_mode_cfg                (addr 0x10891100): 0x10019030
  scc_regs[0].ch_flag_cfg                (addr 0x10891104):     0x0000
  scc_regs[0].ch_flwctrl_cfg             (addr 0x10891108):     0x0000
  scc_regs[0].ch_intr_status             (addr 0x1089110A):     0x0000
  scc_regs[0].ch_intr_enable             (addr 0x1089110C):     0x0000
  scc_regs[0].ch_cmd_stat                (addr 0x1089110E):     0x0028
  scc_regs[1].ch_mode_cfg                (addr 0x10891110): 0x10019030
  scc_regs[1].ch_flag_cfg                (addr 0x10891114):     0x0000
  scc_regs[1].ch_flwctrl_cfg             (addr 0x10891118):     0x0000
  scc_regs[1].ch_intr_status             (addr 0x1089111A):     0x0000
  scc_regs[1].ch_intr_enable             (addr 0x1089111C):     0x0000
  scc_regs[1].ch_cmd_stat                (addr 0x1089111E):     0x0028
  scc_regs[2].ch_mode_cfg                (addr 0x10891120): 0x10019030
  scc_regs[2].ch_flag_cfg                (addr 0x10891124):     0x0000
  scc_regs[2].ch_flwctrl_cfg             (addr 0x10891128):     0x0000
  scc_regs[2].ch_intr_status             (addr 0x1089112A):     0x0000
  scc_regs[2].ch_intr_enable             (addr 0x1089112C):     0x0000
  scc_regs[2].ch_cmd_stat                (addr 0x1089112E):     0x0028
  scc_regs[3].ch_mode_cfg                (addr 0x10891130): 0x10019030
  scc_regs[3].ch_flag_cfg                (addr 0x10891134):     0x0000
  scc_regs[3].ch_flwctrl_cfg             (addr 0x10891138):     0x0000
  scc_regs[3].ch_intr_status             (addr 0x1089113A):     0x0000
  scc_regs[3].ch_intr_enable             (addr 0x1089113C):     0x0000
  scc_regs[3].ch_cmd_stat                (addr 0x1089113E):     0x0028
  scc_regs[4].ch_mode_cfg                (addr 0x10891140): 0x10019030
  scc_regs[4].ch_flag_cfg                (addr 0x10891144):     0x0000
  scc_regs[4].ch_flwctrl_cfg             (addr 0x10891148):     0x0000
  scc_regs[4].ch_intr_status             (addr 0x1089114A):     0x0000
  scc_regs[4].ch_intr_enable             (addr 0x1089114C):     0x0000
  scc_regs[4].ch_cmd_stat                (addr 0x1089114E):     0x0028
  scc_regs[5].ch_mode_cfg                (addr 0x10891150): 0x10019030
  scc_regs[5].ch_flag_cfg                (addr 0x10891154):     0x0000
  scc_regs[5].ch_flwctrl_cfg             (addr 0x10891158):     0x0000
  scc_regs[5].ch_intr_status             (addr 0x1089115A):     0x0000
  scc_regs[5].ch_intr_enable             (addr 0x1089115C):     0x0000
  scc_regs[5].ch_cmd_stat                (addr 0x1089115E):     0x0028
  scc_regs[6].ch_mode_cfg                (addr 0x10891160): 0x10019030
  scc_regs[6].ch_flag_cfg                (addr 0x10891164):     0x0000
  scc_regs[6].ch_flwctrl_cfg             (addr 0x10891168):     0x0000
  scc_regs[6].ch_intr_status             (addr 0x1089116A):     0x0000
  scc_regs[6].ch_intr_enable             (addr 0x1089116C):     0x0000
  scc_regs[6].ch_cmd_stat                (addr 0x1089116E):     0x0028
  scc_regs[7].ch_mode_cfg                (addr 0x10891170): 0x10019030
  scc_regs[7].ch_flag_cfg                (addr 0x10891174):     0x0000
  scc_regs[7].ch_flwctrl_cfg             (addr 0x10891178):     0x0000
  scc_regs[7].ch_intr_status             (addr 0x1089117A):     0x0000
  scc_regs[7].ch_intr_enable             (addr 0x1089117C):     0x0000
  scc_regs[7].ch_cmd_stat                (addr 0x1089117E):     0x0028
  rx_dma_regs[0].ring_start_ptr          (addr 0x10892000): 0x00000000
  rx_dma_regs[0].ring_mask_index         (addr 0x10892004): 0x00000000
  rx_dma_regs[0].dma_internal_desc_stat  (addr 0x10892008): 0x00000000
  rx_dma_regs[0].dma_internal_buff_addr  (addr 0x1089200C): 0x00000000
  rx_dma_regs[0].dma_internal_context    (addr 0x10892010): 0x00000000
  rx_dma_regs[0].dma_internal_fifo_data  (addr 0x10892014): 0x00000000
  rx_dma_regs[1].ring_start_ptr          (addr 0x10892020): 0x00000000
  rx_dma_regs[1].ring_mask_index         (addr 0x10892024): 0x00000000
  rx_dma_regs[1].dma_internal_desc_stat  (addr 0x10892028): 0x00000000
  rx_dma_regs[1].dma_internal_buff_addr  (addr 0x1089202C): 0x00000000
  rx_dma_regs[1].dma_internal_context    (addr 0x10892030): 0x00000000
  rx_dma_regs[1].dma_internal_fifo_data  (addr 0x10892034): 0x00000000
  rx_dma_regs[2].ring_start_ptr          (addr 0x10892040): 0x00000000
  rx_dma_regs[2].ring_mask_index         (addr 0x10892044): 0x00000000
  rx_dma_regs[2].dma_internal_desc_stat  (addr 0x10892048): 0x00000000
  rx_dma_regs[2].dma_internal_buff_addr  (addr 0x1089204C): 0x00000000
  rx_dma_regs[2].dma_internal_context    (addr 0x10892050): 0x00000000
  rx_dma_regs[2].dma_internal_fifo_data  (addr 0x10892054): 0x00000000
  rx_dma_regs[3].ring_start_ptr          (addr 0x10892060): 0x00000000
  rx_dma_regs[3].ring_mask_index         (addr 0x10892064): 0x00000000
  rx_dma_regs[3].dma_internal_desc_stat  (addr 0x10892068): 0x00000000
  rx_dma_regs[3].dma_internal_buff_addr  (addr 0x1089206C): 0x00000000
  rx_dma_regs[3].dma_internal_context    (addr 0x10892070): 0x00000000
  rx_dma_regs[3].dma_internal_fifo_data  (addr 0x10892074): 0x00000000
  rx_dma_regs[4].ring_start_ptr          (addr 0x10892080): 0x00000000
  rx_dma_regs[4].ring_mask_index         (addr 0x10892084): 0x00000000
  rx_dma_regs[4].dma_internal_desc_stat  (addr 0x10892088): 0x00000000
  rx_dma_regs[4].dma_internal_buff_addr  (addr 0x1089208C): 0x00000000
  rx_dma_regs[4].dma_internal_context    (addr 0x10892090): 0x00000000
  rx_dma_regs[4].dma_internal_fifo_data  (addr 0x10892094): 0x00000000
  rx_dma_regs[5].ring_start_ptr          (addr 0x108920A0): 0x00000000
  rx_dma_regs[5].ring_mask_index         (addr 0x108920A4): 0x00000000
  rx_dma_regs[5].dma_internal_desc_stat  (addr 0x108920A8): 0x00000000
  rx_dma_regs[5].dma_internal_buff_addr  (addr 0x108920AC): 0x00000000
  rx_dma_regs[5].dma_internal_context    (addr 0x108920B0): 0x00000000
  rx_dma_regs[5].dma_internal_fifo_data  (addr 0x108920B4): 0x00000000
  rx_dma_regs[6].ring_start_ptr          (addr 0x108920C0): 0x00000000
  rx_dma_regs[6].ring_mask_index         (addr 0x108920C4): 0x00000000
  rx_dma_regs[6].dma_internal_desc_stat  (addr 0x108920C8): 0x00000000
  rx_dma_regs[6].dma_internal_buff_addr  (addr 0x108920CC): 0x00000000
  rx_dma_regs[6].dma_internal_context    (addr 0x108920D0): 0x00000000
  rx_dma_regs[6].dma_internal_fifo_data  (addr 0x108920D4): 0x00000000
  rx_dma_regs[7].ring_start_ptr          (addr 0x108920E0): 0x00000000
  rx_dma_regs[7].ring_mask_index         (addr 0x108920E4): 0x00000000
  rx_dma_regs[7].dma_internal_desc_stat  (addr 0x108920E8): 0x00000000
  rx_dma_regs[7].dma_internal_buff_addr  (addr 0x108920EC): 0x00000000
  rx_dma_regs[7].dma_internal_context    (addr 0x108920F0): 0x00000000
  rx_dma_regs[7].dma_internal_fifo_data  (addr 0x108920F4): 0x00000000
  tx_dma_regs[0].ring_start_ptr          (addr 0x10892200): 0x00000000
  tx_dma_regs[0].ring_mask_index         (addr 0x10892204): 0x00000000
  tx_dma_regs[0].dma_internal_desc_stat  (addr 0x10892208): 0x00000000
  tx_dma_regs[0].dma_internal_buff_addr  (addr 0x1089220C): 0x00000000
  tx_dma_regs[0].dma_internal_context    (addr 0x10892210): 0x00000000
  tx_dma_regs[0].dma_internal_fifo_data  (addr 0x10892214): 0x00000000
  tx_dma_regs[1].ring_start_ptr          (addr 0x10892220): 0x00000000
  tx_dma_regs[1].ring_mask_index         (addr 0x10892224): 0x00000000
  tx_dma_regs[1].dma_internal_desc_stat  (addr 0x10892228): 0x00000000
  tx_dma_regs[1].dma_internal_buff_addr  (addr 0x1089222C): 0x00000000
  tx_dma_regs[1].dma_internal_context    (addr 0x10892230): 0x00000000
  tx_dma_regs[1].dma_internal_fifo_data  (addr 0x10892234): 0x00000000
  tx_dma_regs[2].ring_start_ptr          (addr 0x10892240): 0x00000000
  tx_dma_regs[2].ring_mask_index         (addr 0x10892244): 0x00000000
  tx_dma_regs[2].dma_internal_desc_stat  (addr 0x10892248): 0x00000000
  tx_dma_regs[2].dma_internal_buff_addr  (addr 0x1089224C): 0x00000000
  tx_dma_regs[2].dma_internal_context    (addr 0x10892250): 0x00000000
  tx_dma_regs[2].dma_internal_fifo_data  (addr 0x10892254): 0x00000000
  tx_dma_regs[3].ring_start_ptr          (addr 0x10892260): 0x00000000
  tx_dma_regs[3].ring_mask_index         (addr 0x10892264): 0x00000000
  tx_dma_regs[3].dma_internal_desc_stat  (addr 0x10892268): 0x00000000
  tx_dma_regs[3].dma_internal_buff_addr  (addr 0x1089226C): 0x00000000
  tx_dma_regs[3].dma_internal_context    (addr 0x10892270): 0x00000000
  tx_dma_regs[3].dma_internal_fifo_data  (addr 0x10892274): 0x00000000
  tx_dma_regs[4].ring_start_ptr          (addr 0x10892280): 0x00000000
  tx_dma_regs[4].ring_mask_index         (addr 0x10892284): 0x00000000
  tx_dma_regs[4].dma_internal_desc_stat  (addr 0x10892288): 0x00000000
  tx_dma_regs[4].dma_internal_buff_addr  (addr 0x1089228C): 0x00000000
  tx_dma_regs[4].dma_internal_context    (addr 0x10892290): 0x00000000
  tx_dma_regs[4].dma_internal_fifo_data  (addr 0x10892294): 0x00000000
  tx_dma_regs[5].ring_start_ptr          (addr 0x108922A0): 0x00000000
  tx_dma_regs[5].ring_mask_index         (addr 0x108922A4): 0x00000000
  tx_dma_regs[5].dma_internal_desc_stat  (addr 0x108922A8): 0x00000000
  tx_dma_regs[5].dma_internal_buff_addr  (addr 0x108922AC): 0x00000000
  tx_dma_regs[5].dma_internal_context    (addr 0x108922B0): 0x00000000
  tx_dma_regs[5].dma_internal_fifo_data  (addr 0x108922B4): 0x00000000
  tx_dma_regs[6].ring_start_ptr          (addr 0x108922C0): 0x00000000
  tx_dma_regs[6].ring_mask_index         (addr 0x108922C4): 0x00000000
  tx_dma_regs[6].dma_internal_desc_stat  (addr 0x108922C8): 0x00000000
  tx_dma_regs[6].dma_internal_buff_addr  (addr 0x108922CC): 0x00000000
  tx_dma_regs[6].dma_internal_context    (addr 0x108922D0): 0x00000000
  tx_dma_regs[6].dma_internal_fifo_data  (addr 0x108922D4): 0x00000000
  tx_dma_regs[7].ring_start_ptr          (addr 0x108922E0): 0x00000000
  tx_dma_regs[7].ring_mask_index         (addr 0x108922E4): 0x00000000
  tx_dma_regs[7].dma_internal_desc_stat  (addr 0x108922E8): 0x00000000
  tx_dma_regs[7].dma_internal_buff_addr  (addr 0x108922EC): 0x00000000
  tx_dma_regs[7].dma_internal_context    (addr 0x108922F0): 0x00000000
  tx_dma_regs[7].dma_internal_fifo_data  (addr 0x108922F4): 0x00000000
  txbsc_regs[0].context_cfg_pad_char     (addr 0x10892400): 0x00000000
  txbsc_regs[1].context_cfg_pad_char     (addr 0x10892410): 0x00000000
  txbsc_regs[2].context_cfg_pad_char     (addr 0x10892420): 0x00000000
  txbsc_regs[3].context_cfg_pad_char     (addr 0x10892430): 0x00000000
  txbsc_regs[4].context_cfg_pad_char     (addr 0x10892440): 0x00000000
  txbsc_regs[5].context_cfg_pad_char     (addr 0x10892450): 0x00000000
  txbsc_regs[6].context_cfg_pad_char     (addr 0x10892460): 0x00000000
  txbsc_regs[7].context_cfg_pad_char     (addr 0x10892470): 0x00000000
  txppp_regs[0].accm_map                 (addr 0x10892600): 0x00000000
  txppp_regs[0].special_char             (addr 0x10892604): 0x00000000
  txppp_regs[0].context                  (addr 0x1089260C): 0x00000000
  txppp_regs[1].accm_map                 (addr 0x10892610): 0x00000000
  txppp_regs[1].special_char             (addr 0x10892614): 0x00000000
  txppp_regs[1].context                  (addr 0x1089261C): 0x00000000
  txppp_regs[2].accm_map                 (addr 0x10892620): 0x00000000
  txppp_regs[2].special_char             (addr 0x10892624): 0x00000000
  txppp_regs[2].context                  (addr 0x1089262C): 0x00000000
  txppp_regs[3].accm_map                 (addr 0x10892630): 0x00000000
  txppp_regs[3].special_char             (addr 0x10892634): 0x00000000
  txppp_regs[3].context                  (addr 0x1089263C): 0x00000000
  txppp_regs[4].accm_map                 (addr 0x10892640): 0x00000000
  txppp_regs[4].special_char             (addr 0x10892644): 0x00000000
  txppp_regs[4].context                  (addr 0x1089264C): 0x00000000
  txppp_regs[5].accm_map                 (addr 0x10892650): 0x00000000
  txppp_regs[5].special_char             (addr 0x10892654): 0x00000000
  txppp_regs[5].context                  (addr 0x1089265C): 0x00000000
  txppp_regs[6].accm_map                 (addr 0x10892660): 0x00000000
  txppp_regs[6].special_char             (addr 0x10892664): 0x00000000
  txppp_regs[6].context                  (addr 0x1089266C): 0x00000000
  txppp_regs[7].accm_map                 (addr 0x10892670): 0x00000000
  txppp_regs[7].special_char             (addr 0x10892674): 0x00000000
  txppp_regs[7].context                  (addr 0x1089267C): 0x00000000
  rxppp_regs[0].accm_map                 (addr 0x10892800): 0x00000000
  rxppp_regs[0].special_char             (addr 0x10892804): 0x00000000
  rxppp_regs[0].context                  (addr 0x1089280C): 0x00000000
  rxppp_regs[1].accm_map                 (addr 0x10892810): 0x00000000
  rxppp_regs[1].special_char             (addr 0x10892814): 0x00000000
  rxppp_regs[1].context                  (addr 0x1089281C): 0x00000000
  rxppp_regs[2].accm_map                 (addr 0x10892820): 0x00000000
  rxppp_regs[2].special_char             (addr 0x10892824): 0x00000000
  rxppp_regs[2].context                  (addr 0x1089282C): 0x00000000
  rxppp_regs[3].accm_map                 (addr 0x10892830): 0x00000000
  rxppp_regs[3].special_char             (addr 0x10892834): 0x00000000
  rxppp_regs[3].context                  (addr 0x1089283C): 0x00000000
  rxppp_regs[4].accm_map                 (addr 0x10892840): 0x00000000
  rxppp_regs[4].special_char             (addr 0x10892844): 0x00000000
  rxppp_regs[4].context                  (addr 0x1089284C): 0x00000000
  rxppp_regs[5].accm_map                 (addr 0x10892850): 0x00000000
  rxppp_regs[5].special_char             (addr 0x10892854): 0x00000000
  rxppp_regs[5].context                  (addr 0x1089285C): 0x00000000
  rxppp_regs[6].accm_map                 (addr 0x10892860): 0x00000000
  rxppp_regs[6].special_char             (addr 0x10892864): 0x00000000
  rxppp_regs[6].context                  (addr 0x1089286C): 0x00000000
  rxppp_regs[7].accm_map                 (addr 0x10892870): 0x00000000
  rxppp_regs[7].special_char             (addr 0x10892874): 0x00000000
  rxppp_regs[7].context                  (addr 0x1089287C): 0x00000000
  rxbsc_regs[0].context_cfg_pad_char     (addr 0x10892A00): 0x00000000
  rxbsc_regs[1].context_cfg_pad_char     (addr 0x10892A10): 0x00000000
  rxbsc_regs[2].context_cfg_pad_char     (addr 0x10892A20): 0x00000000
  rxbsc_regs[3].context_cfg_pad_char     (addr 0x10892A30): 0x00000000
  rxbsc_regs[4].context_cfg_pad_char     (addr 0x10892A40): 0x00000000
  rxbsc_regs[5].context_cfg_pad_char     (addr 0x10892A50): 0x00000000
  rxbsc_regs[6].context_cfg_pad_char     (addr 0x10892A60): 0x00000000
  rxbsc_regs[7].context_cfg_pad_char     (addr 0x10892A70): 0x00000000
  intf_regs[0].intf_ctrl                 (addr 0x10893000):     0x0200
  intf_regs[0].modem_ctrl                (addr 0x10893002):     0xE010
  intf_regs[0].flow_ctrl                 (addr 0x10893004):     0x0000
  intf_regs[0].brg_divider               (addr 0x10893006):     0x0000
  intf_regs[0].modem_intr_status         (addr 0x10893008):     0x000F
  intf_regs[1].intf_ctrl                 (addr 0x10893010):     0x0200
  intf_regs[1].modem_ctrl                (addr 0x10893012):     0xE010
  intf_regs[1].flow_ctrl                 (addr 0x10893014):     0x0000
  intf_regs[1].brg_divider               (addr 0x10893016):     0x0000
  intf_regs[1].modem_intr_status         (addr 0x10893018):     0x000F
  intf_regs[2].intf_ctrl                 (addr 0x10893020):     0x0200
  intf_regs[2].modem_ctrl                (addr 0x10893022):     0xE010
  intf_regs[2].flow_ctrl                 (addr 0x10893024):     0x0000
  intf_regs[2].brg_divider               (addr 0x10893026):     0x0000
  intf_regs[2].modem_intr_status         (addr 0x10893028):     0x000F
  intf_regs[3].intf_ctrl                 (addr 0x10893030):     0x0200
  intf_regs[3].modem_ctrl                (addr 0x10893032):     0xE010
  intf_regs[3].flow_ctrl                 (addr 0x10893034):     0x0000
  intf_regs[3].brg_divider               (addr 0x10893036):     0x0000
  intf_regs[3].modem_intr_status         (addr 0x10893038):     0x000F
  intf_regs[4].intf_ctrl                 (addr 0x10893040):     0x0200
  intf_regs[4].modem_ctrl                (addr 0x10893042):     0xE010
  intf_regs[4].flow_ctrl                 (addr 0x10893044):     0x0000
  intf_regs[4].brg_divider               (addr 0x10893046):     0x0000
  intf_regs[4].modem_intr_status         (addr 0x10893048):     0x000F
  intf_regs[5].intf_ctrl                 (addr 0x10893050):     0x0200
  intf_regs[5].modem_ctrl                (addr 0x10893052):     0xE010
  intf_regs[5].flow_ctrl                 (addr 0x10893054):     0x0000
  intf_regs[5].brg_divider               (addr 0x10893056):     0x0000
  intf_regs[5].modem_intr_status         (addr 0x10893058):     0x000F
  intf_regs[6].intf_ctrl                 (addr 0x10893060):     0x0200
  intf_regs[6].modem_ctrl                (addr 0x10893062):     0xE010
  intf_regs[6].flow_ctrl                 (addr 0x10893064):     0x0000
  intf_regs[6].brg_divider               (addr 0x10893066):     0x0000
  intf_regs[6].modem_intr_status         (addr 0x10893068):     0x000F
  intf_regs[7].intf_ctrl                 (addr 0x10893070):     0x0200
  intf_regs[7].modem_ctrl                (addr 0x10893072):     0xE010
  intf_regs[7].flow_ctrl                 (addr 0x10893074):     0x0000
  intf_regs[7].brg_divider               (addr 0x10893076):     0x0000
  intf_regs[7].modem_intr_status         (addr 0x10893078):     0x000F
  tdm_control                            (addr 0x10893100):     0x0000
  tdm_a_8k_divider                       (addr 0x10893102):     0x0000
  tdm_b_8k_divider                       (addr 0x10893104):     0x0000
  intf_irq_status                        (addr 0x10893106):     0x0000
  freq_count_port_sel                    (addr 0x1089310A):     0x0000
  freq_count                             (addr 0x1089310C): 0x00000000
  pll_regs[0].pll_ctrl                   (addr 0x10893110):     0x0000
  pll_regs[0].pll_8kref_divider          (addr 0x10893112):     0x0000
  pll_regs[0].pll_fback_pre_divider      (addr 0x10893114):     0x0000
  pll_regs[0].pll_fback_post_divider     (addr 0x10893116):     0x0000
  pll_regs[1].pll_ctrl                   (addr 0x10893120):     0x0000
  pll_regs[1].pll_8kref_divider          (addr 0x10893122):     0x0000
  pll_regs[1].pll_fback_pre_divider      (addr 0x10893124):     0x0000
  pll_regs[1].pll_fback_post_divider     (addr 0x10893126):     0x0000
  pll_regs[2].pll_ctrl                   (addr 0x10893130):     0x0000
  pll_regs[2].pll_8kref_divider          (addr 0x10893132):     0x0000
  pll_regs[2].pll_fback_pre_divider      (addr 0x10893134):     0x0000
  pll_regs[2].pll_fback_post_divider     (addr 0x10893136):     0x0000
  pll_regs[3].pll_ctrl                   (addr 0x10893140):     0x0000
  pll_regs[3].pll_8kref_divider          (addr 0x10893142):     0x0000
  pll_regs[3].pll_fback_pre_divider      (addr 0x10893144):     0x0000
  pll_regs[3].pll_fback_post_divider     (addr 0x10893146):     0x0000
  pll_regs[4].pll_ctrl                   (addr 0x10893150):     0x0000
  pll_regs[4].pll_8kref_divider          (addr 0x10893152):     0x0000
  pll_regs[4].pll_fback_pre_divider      (addr 0x10893154):     0x0000
  pll_regs[4].pll_fback_post_divider     (addr 0x10893156):     0x0000
  pll_regs[5].pll_ctrl                   (addr 0x10893160):     0x0000
  pll_regs[5].pll_8kref_divider          (addr 0x10893162):     0x0000
  pll_regs[5].pll_fback_pre_divider      (addr 0x10893164):     0x0000
  pll_regs[5].pll_fback_post_divider     (addr 0x10893166):     0x0000
  pll_regs[6].pll_ctrl                   (addr 0x10893170):     0x0000
  pll_regs[6].pll_8kref_divider          (addr 0x10893172):     0x0000
  pll_regs[6].pll_fback_pre_divider      (addr 0x10893174):     0x0000
  pll_regs[6].pll_fback_post_divider     (addr 0x10893176):     0x0000
  pll_regs[7].pll_ctrl                   (addr 0x10893180):     0x0000
  pll_regs[7].pll_8kref_divider          (addr 0x10893182):     0x0000
  pll_regs[7].pll_fback_pre_divider      (addr 0x10893184):     0x0000
  pll_regs[7].pll_fback_post_divider     (addr 0x10893186):     0x0000
io-controller tdm (addr 0x108A0000):
io-controller tdm (csm addr 0x108A0000):
  tdmsw_enbl_7f_60                       (addr 0x108B0000): 0xC0000000
  tdmsw_enbl_5f_40                       (addr 0x108B0004): 0x05550000
  tdmsw_enbl_3f_20                       (addr 0x108B0008): 0x00000000
  tdmsw_enbl_1f_00                       (addr 0x108B000C): 0x00000000
  tdmsw_rate_7f_70                       (addr 0x108B0010): 0x55555555
  tdmsw_rate_6f_60                       (addr 0x108B0014): 0x55555555
  tdmsw_rate_5f_50                       (addr 0x108B0018): 0x55556666
  tdmsw_rate_4f_40                       (addr 0x108B001C): 0x55555555
  tdmsw_rate_3f_30                       (addr 0x108B0020): 0x55555555
  tdmsw_rate_2f_20                       (addr 0x108B0024): 0x55555555
  tdmsw_rate_1f_10                       (addr 0x108B0028): 0x55555555
  tdmsw_rate_0f_00                       (addr 0x108B002C): 0x55555555
  tdmsw_lpbk_7f_60                       (addr 0x108B0030): 0x00000000
  tdmsw_lpbk_5f_40                       (addr 0x108B0034): 0x00000000
  tdmsw_lpbk_3f_20                       (addr 0x108B0038): 0x00000000
  tdmsw_lpbk_1f_00                       (addr 0x108B003C): 0x00000000
  tdmsw_ctl                              (addr 0x108B0040): 0x00000000
  tdmsw_csm_err_adrs                     (addr 0x108B0044): 0x00000000
  tdm_mgmt_event                         (addr 0x108B0050): 0x00000002
  tdm_mgmt_enbl                          (addr 0x108B0054): 0x00000000
  tdm_err_event                          (addr 0x108B0058): 0x00000000
  tdm_err_enbl                           (addr 0x108B005C): 0x00000100
  vmcr[0]                                (addr 0x108B0060): 0x00000000
  vmcr[1]                                (addr 0x108B0064): 0x00000000
  vmcr[2]                                (addr 0x108B0068): 0x00000000
  vmcr[3]                                (addr 0x108B006C): 0x00000000
  sm_tdm_cr                              (addr 0x108B0070): 0x00000003
  pvdm_tdm_cr                            (addr 0x108B0074): 0x00000006
  ntr_cr0                                (addr 0x108B0078): 0x00000000
  ntr_cr0_aux                            (addr 0x108B007C): 0x00000000
  ntr_cr1                                (addr 0x108B0080): 0x00000000
  ntr_cr1_aux                            (addr 0x108B0084): 0x00000000
  tpllr_cr                               (addr 0x108B0088): 0x00000000
  ds0_dump_beg_adrs                      (addr 0x108B0090): 0x00000000
  ds0_dump_end_adrs                      (addr 0x108B0094): 0x00000000
  ds0_dump_ctl                           (addr 0x108B0098): 0x00000000
  tdm_sync_ctrl_int                      (addr 0x108B00A0): 0x00000000
  tdm_sync_status_int                    (addr 0x108B00A4): 0x0002D200
io-controller i2c (addr 0x10910000):
 reg + adjust (addr 0x10910000):
  i2c_control                            (addr 0x10910000): 0x00010000
  i2c_scratch                            (addr 0x10910004): 0xFACEDEAD
  i2c_status                             (addr 0x10910008): 0x00000001
  i2c_status_mask                        (addr 0x1091000C): 0x00000000
  i2c_slave_addr                         (addr 0x10910010): 0x00000000
  i2c_slave_sub_addr                     (addr 0x10910014): 0x00000000
  i2c_bitbang_driver                     (addr 0x10910018): 0x0000000F
  i2c_data_fifo_rw_ptr                   (addr 0x10911804): 0x00000000
  i2c_dma_start_addr                     (addr 0x10910020): 0x00000000
  i2c_dma_transfer_size                  (addr 0x10910024): 0x00000000
  i2c_dma_next_addr                      (addr 0x10910028): 0x00000000
  i2c_dma_remain_trans_size              (addr 0x1091002C): 0x00000000
  data_fifo_addr                         (addr 0x10911800): 0xE37A0810
 reg + adjust (addr 0x10920000):
  i2c_control                            (addr 0x10920000): 0x00010000
  i2c_scratch                            (addr 0x10920004): 0xFACEDEAD
  i2c_status                             (addr 0x10920008): 0x00000001
  i2c_status_mask                        (addr 0x1092000C): 0x00000000
  i2c_slave_addr                         (addr 0x10920010): 0x00000000
  i2c_slave_sub_addr                     (addr 0x10920014): 0x00000000
  i2c_bitbang_driver                     (addr 0x10920018): 0x0000000F
  i2c_data_fifo_rw_ptr                   (addr 0x10921804): 0x00000000
  i2c_dma_start_addr                     (addr 0x10920020): 0x00000000
  i2c_dma_transfer_size                  (addr 0x10920024): 0x00000000
  i2c_dma_next_addr                      (addr 0x10920028): 0x00000000
  i2c_dma_remain_trans_size              (addr 0x1092002C): 0x00000000
  data_fifo_addr                         (addr 0x10921800): 0x36E903A2
 reg + adjust (addr 0x10930000):
  i2c_control                            (addr 0x10930000): 0x00010000
  i2c_scratch                            (addr 0x10930004): 0xFACEDEAD
  i2c_status                             (addr 0x10930008): 0x00000001
  i2c_status_mask                        (addr 0x1093000C): 0x00000000
  i2c_slave_addr                         (addr 0x10930010): 0x00000000
  i2c_slave_sub_addr                     (addr 0x10930014): 0x00000000
  i2c_bitbang_driver                     (addr 0x10930018): 0x0000000F
  i2c_data_fifo_rw_ptr                   (addr 0x10931804): 0x00000000
  i2c_dma_start_addr                     (addr 0x10930020): 0x00000000
  i2c_dma_transfer_size                  (addr 0x10930024): 0x00000000
  i2c_dma_next_addr                      (addr 0x10930028): 0x00000000
  i2c_dma_remain_trans_size              (addr 0x1093002C): 0x00000000
  data_fifo_addr                         (addr 0x10931800): 0x15ED5A69
 reg + adjust (addr 0x10940000):
  i2c_control                            (addr 0x10940000): 0x00010000
  i2c_scratch                            (addr 0x10940004): 0xFACEDEAD
  i2c_status                             (addr 0x10940008): 0x00000001
  i2c_status_mask                        (addr 0x1094000C): 0x00000000
  i2c_slave_addr                         (addr 0x10940010): 0x00000000
  i2c_slave_sub_addr                     (addr 0x10940014): 0x00000000
  i2c_bitbang_driver                     (addr 0x10940018): 0x0000000F
  i2c_data_fifo_rw_ptr                   (addr 0x10941804): 0x00000000
  i2c_dma_start_addr                     (addr 0x10940020): 0x00000000
  i2c_dma_transfer_size                  (addr 0x10940024): 0x00000000
  i2c_dma_next_addr                      (addr 0x10940028): 0x00000000
  i2c_dma_remain_trans_size              (addr 0x1094002C): 0x00000000
  data_fifo_addr                         (addr 0x10941800): 0x134FD455
 reg + adjust (addr 0x10950000):
  i2c_control                            (addr 0x10950000): 0x00010000
  i2c_scratch                            (addr 0x10950004): 0xFACEDEAD
  i2c_status                             (addr 0x10950008): 0x00000001
  i2c_status_mask                        (addr 0x1095000C): 0x00000000
  i2c_slave_addr                         (addr 0x10950010): 0x00000000
  i2c_slave_sub_addr                     (addr 0x10950014): 0x00000000
  i2c_bitbang_driver                     (addr 0x10950018): 0x0000000F
  i2c_data_fifo_rw_ptr                   (addr 0x10951804): 0x00000000
  i2c_dma_start_addr                     (addr 0x10950020): 0x00000000
  i2c_dma_transfer_size                  (addr 0x10950024): 0x00000000
  i2c_dma_next_addr                      (addr 0x10950028): 0x00000000
  i2c_dma_remain_trans_size              (addr 0x1095002C): 0x00000000
  data_fifo_addr                         (addr 0x10951800): 0x8D87EC41
 POWER CONSTANT AND MAX_POWER DETAILS
 Motherboard power constant = 125
 Motherboard maximum power = 39.1 W
 ETHSW_SM POE power consumption = 0.0 W
 PVDM3 Max Power consumption = 6.0 W
Platform EHWIC Switch TCAM Software information:
------------------ show environment table ------------------
SYSTEM POWER SUPPLY STATUS
 Internal Power Supply  Type: AC
 Internal Power Supply  12V Output Status: Normal
 External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
 Fan 1 OK, fan level 1, Low speed setting, 4278 RPM, 43% PWM
 Fan 2 OK, fan level 1, Low speed setting, 4246 RPM, 43% PWM
 Fan 3 OK, fan level 1, Low speed setting, 4259 RPM, 43% PWM
 Fan 4 OK, fan level 1, Low speed setting, 7147 RPM, 43% PWM
SYSTEM TEMPERATURE STATUS
 Intake Left(Bezel) temperature: 20 Celsius, Normal
 Intake Left temperature: 21 Celsius, Normal
 Exhaust Right(Bezel) temperature: 25 Celsius, Normal
 Exhaust Right temperature: 24 Celsius, Normal
 CPU temperature: 52 Celsius, Normal
 Power Supply Unit temperature: 23 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
 Battery OK (checked at power up)
SYSTEM ALARMS SETTINGS
 Fan tray removal or multi fan failure results in warning
 CPU Warning Over Temperature Alarm = 100C
 CPU Critical Over Temperature Alarm = 120C
 Intake Left(Bezel) Abnormal Temperature Alarm = 45C
 Intake Left(Bezel) Over Temperature Alarm = 57C
 Intake Left Abnormal Temperature Alarm = 45C
 Intake Left Over Temperature Alarm = 57C
 Exhaust Right(Bezel) Over Temperature Alarm = 75C
 Exhaust Right Over Temperature Alarm = 75C
 Power Supply Unit Over Temperature Alarm = 70C
 Power Supply Unit Over Critical Temperature Alarm = 85C
SYSTEM VOLTAGES
 12V voltage = 12.624 V, Normal
 5V voltage = 5.139 V, Normal
 3.3V voltage = 3.318 V, Normal
 2.5V voltage = 2.490 V, Normal
 1.8V voltage = 1.819 V, Normal
 1.2V voltage = 1.199 V, Normal
 ASIC voltage = 1.044 V, Normal
 CPU Core voltage = 1.096 V, Normal
SYSTEM POWER
 Motherboard Components Power consumption = 48.9 W
 Total System Power consumption is: 48.9 W
 Environmental information last updated 00:00:16 ago
ENVIRONMENTAL STRESS EVENTS
Critical Temperature: Maxium = 0
                      Total Duration = 0
 Exceed Fan Tray Removal Time: Maximum Time= 0
                               Total Time = 0
Total MCU access error count: 0
------ ENVIRONMENTAL CONTROLLER REGISTERS ------
REG: 0x0 : 0x405
REG: 0x1 : 0xF01
REG: 0x2 : 0x0
REG: 0x3 : 0x14
REG: 0x4 : 0x15
REG: 0x5 : 0x1A
REG: 0x6 : 0x18
REG: 0x7 : 0x10B6
REG: 0x8 : 0x1096
REG: 0x9 : 0x10A3
REG: 0xA : 0x1BEB
REG: 0xB : 0x0
REG: 0xC : 0x1F
REG: 0xD : 0x34
REG: 0xE : 0x8FBD
REG: 0xF : 0x4000
REG: 0x10 : 0x19
REG: 0x11 : 0x1C
REG: 0x12 : 0x1E
REG: 0x13 : 0x21
REG: 0x14 : 0x2B
REG: 0x15 : 0x2F
REG: 0x16 : 0x39
REG: 0x17 : 0x2B
REG: 0x18 : 0x2F
REG: 0x19 : 0x39
REG: 0x1A : 0x2B
REG: 0x1B : 0x2F
REG: 0x1C : 0x39
REG: 0x1D : 0x2B
REG: 0x1E : 0x2F
REG: 0x1F : 0x39
REG: 0x20 : 0x2B
REG: 0x21 : 0x2F
REG: 0x22 : 0x39
REG: 0x23 : 0x3E8
REG: 0x24 : 0x2
REG: 0x25 : 0x258
REG: 0x26 : 0x78
REG: 0x27 : 0x39
REG: 0x28 : 0x39
REG: 0x29 : 0x4B
REG: 0x2A : 0x4B
REG: 0x2B : 0x3C
REG: 0x2C : 0x0
REG: 0x2D : 0xF
REG: 0x2E : 0x0
REG: 0x2F : 0x0
REG: 0x30 : 0x3E8
REG: 0x31 : 0x3E8
REG: 0x32 : 0xC8
REG: 0x33 : 0x32
REG: 0x34 : 0x23
REG: 0x35 : 0x26
REG: 0x36 : 0x28
REG: 0x37 : 0x2B
REG: 0x38 : 0x43
REG: 0x39 : 0x62
REG: 0x3A : 0x43
REG: 0x3B : 0x62
REG: 0x3C : 0x43
REG: 0x3D : 0x62
REG: 0x3E : 0x43
REG: 0x3F : 0x62
REG: 0x40 : 0x43
REG: 0x41 : 0x62
REG: 0x42 : 0x0
REG: 0x43 : 0x19
REG: 0x44 : 0x18
REG: 0x45 : 0x1B
REG: 0x46 : 0x19
REG: 0x47 : 0x14
REG: 0x48 : 0x3
REG: 0x49 : 0x2
REG: 0x4A : 0x0
REG: 0x4B : 0x1
 ------ CURRENT TEMPERATURE SENSOR REGISTERS ------
REG: 0x0 : 0x1A
REG: 0x1 : 0x34
REG: 0x2 : 0x0
REG: 0x3 : 0x0
REG: 0x4 : 0x4
REG: 0x5 : 0x7F
REG: 0x6 : 0xC9
REG: 0x7 : 0x78
REG: 0x8 : 0xC9
------- POWER SEQUENCER REGS -------
REG: 0x0 : 0x305
REG: 0x1 : 0x1
REG: 0x2 : 0x1
REG: 0x3 : 0x0
REG: 0x4 : 0x0
REG: 0x5 : 0x0
REG: 0x6 : 0x87EA
REG: 0x7 : 0x3384
REG: 0x8 : 0x31D
REG: 0x9 : 0x321
REG: 0xA : 0x2DD
REG: 0xB : 0x2EA
REG: 0xC : 0x2EB
REG: 0xD : 0x2E8
REG: 0xE : 0x309
REG: 0xF : 0x30A
REG: 0x10 : 0x308
REG: 0x11 : 0x314
REG: 0x12 : 0x315
REG: 0x13 : 0x312
REG: 0x14 : 0x2B1
REG: 0x15 : 0x2B5
REG: 0x16 : 0x2AE
REG: 0x17 : 0x8D
REG: 0x18 : 0xCB
REG: 0x19 : 0x56
REG: 0x1A : 0x1C7
REG: 0x1B : 0x1C9
REG: 0x1C : 0x1C5
REG: 0x1D : 0x19F
REG: 0x1E : 0x1A2
REG: 0x1F : 0x19D
REG: 0x20 : 0x18D
REG: 0x21 : 0x18F
REG: 0x22 : 0x18A
REG: 0x23 : 0x0
REG: 0x24 : 0x0
REG: 0x25 : 0x0
REG: 0x26 : 0x0
REG: 0x27 : 0x0
REG: 0x28 : 0x0
REG: 0x29 : 0x0
REG: 0x2A : 0x0
REG: 0x2B : 0x0
REG: 0x2C : 0x0
REG: 0x2D : 0x0
REG: 0x2E : 0x78
REG: 0x2F : 0x0
REG: 0x30 : 0x0
REG: 0x31 : 0x4619
REG: 0x32 : 0x905
REG: 0x33 : 0x904
REG: 0x34 : 0x903
REG: 0x35 : 0x903
REG: 0x36 : 0xC03
REG: 0x37 : 0x903
REG: 0x38 : 0xA
REG: 0x39 : 0x200
REG: 0x3A : 0x43
REG: 0x3B : 0x0
REG: 0x3C : 0x154
REG: 0x3D : 0x0
REG: 0x3E : 0x0
REG: 0x3F : 0x0
REG: 0x40 : 0x0
REG: 0x41 : 0x0
REG: 0x42 : 0x0
REG: 0x43 : 0x0
------------------ show environment rps ------------------
 RPS is not connected or powered off
------------------ service-module Embedded-Service-Engine0/0 status ------------------
Service Module is Cisco Embedded-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module heartbeat-reset is enabled
Embedded Service Engine boot state is RESET
No install/uninstall in progress
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show controllers j1 ------------------
------------------ show cdp neighbor ------------------
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
IACHZUR1SW001    Gig 0/0           160              S I   WS-C3560X Gig 0/3
ip-cote-ch-bit-r-001.opnet.ch
                 Gig 0/2           167            R B S I C887VA-K9 Fas 0
Total cdp entries displayed : 2
------------------ show cdp neighbor detail ------------------
Device ID: IACHZUR1SW001
Entry address(es):
  IP address: 10.75.32.226
Platform: cisco WS-C3560X-24,  Capabilities: Switch IGMP
Interface: GigabitEthernet0/0,  Port ID (outgoing port): GigabitEthernet0/3
Holdtime : 160 sec
Version :
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:34 by prod_rel_team
advertisement version: 2
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF000000000000405539F31700FF0000
VTP Management Domain: 'ConTech'
Native VLAN: 30
Duplex: full
Management address(es):
Device ID: ip-cote-ch-bit-r-001.opnet.ch
Entry address(es):
  IP address: 192.168.10.1
Platform: Cisco C887VA-K9,  Capabilities: Router Source-Route-Bridge Switch IGMP
Interface: GigabitEthernet0/2,  Port ID (outgoing port): FastEthernet0
Holdtime : 167 sec
Version :
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.4(3)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Sun 27-Sep-15 08:36 by prod_rel_team
Native VLAN: 1
Duplex: full
------------------ show ip nbar version ------------------
NBAR software version:  20
NBAR minimum backward compatible version:  20
Loaded Protocol Pack(s):
Name:                            Standard Protocol Pack
Version:                         1.0
Publisher:                       Cisco Systems Inc.
NBAR Engine Version:             20
State:                           Active
------------------ show raw reclaimed ------------------
RAW LEAK REPORT:
ORPHAN    :  0       raw buffers reclaimed
TSP       :  0       raw buffers reclaimed
VTSP      :  0       raw buffers reclaimed
H323      :  0       raw buffers reclaimed
SIP       :  0       raw buffers reclaimed
CCAPI     :  0       raw buffers reclaimed
VOATM     :  0       raw buffers reclaimed
XGCP      :  0       raw buffers reclaimed
CAS       :  0       raw buffers reclaimed
IVR       :  0       raw buffers reclaimed
SSAPP     :  0       raw buffers reclaimed
Last Audit Session is at 18:09:04 UTC Fri Nov 20 2015
------------------ show crypto key mypubkey rsa ------------------
% Key pair was generated at: 08:39:22 UTC Nov 12 2015
Key name: IACHZURVGW01.
Key type: RSA KEYS
 Storage Device: private-config
 Usage: General Purpose Key
 Key is not exportable.
 Key Data:
  30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00B6F7ED
  80D5CE32 0CF26F00 BD00D4A9 110545C2 4D17CD15 1C39C763 11AD6823 27945EFF
  848782F6 0564360B 6D77BBCA F44640A1 6223B834 01DBCB36 9BFB8C85 7C61FA9F
  F980C933 309ED5CA 7A514234 5E4E0A61 D5FEACEB EA052ED0 880AF9D6 64A6B6E9
  5B8BB909 C3655B84 52A2448E DC54D144 F7B35FAE E4AFC499 30D446AF F3020301 0001
% Key pair was generated at: 09:03:10 UTC Nov 20 2015
Key name: IACHZURVGW01..server
Key type: RSA KEYS
Temporary key
 Usage: Encryption Key
 Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00A4A6B5 373A6082
  BA08B5E3 5583ACE5 EB4A43EE 53BA0A7A FC3A0D58 1CCB047E BF859078 696A25A6
  0D49534C 3B6245EF E971F606 8D3EE294 87838D75 065271AE 61E926C3 2C635317
  F784B3C1 BA56E16F E4CDECB4 A9ABA67D 46F57DB6 28ECFEE1 27020301 0001
------------------ show license udi ------------------
Device#   PID                   SN              UDI
*1        CISCO2911/K9          FCZ194171VP     CISCO2911/K9:FCZ194171VP
------------------ show license udi standby ------------------
------------------ show license feature ------------------
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
ipbasek9                 no           no          no             yes      no
securityk9               yes          yes         no             no       yes
uck9                     yes          yes         no             yes      yes
datak9                   yes          yes         no             no       yes
NtwkEssSuitek9           yes          yes         no             no       yes
CollabProSuitek9         yes          yes         no             no       yes
ios-ips-update           yes          yes         yes            no       yes
SNASw                    yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
cme-srst                 yes          yes         no             yes      yes
mgmt-plug-and-play       yes          no          no             no       no
mgmt-lifecycle           yes          no          no             no       no
mgmt-assurance           yes          no          no             no       no
mgmt-onplus              yes          no          no             no       no
mgmt-compliance          yes          no          no             no       no
------------------ show license feature standby ------------------
------------------ show license file ------------------
License Store: Primary License Storage
  Store Index: 0
    License: 11 ipbasek9 1.0 LONG NORMAL STANDALONE EXCL INFINITE_KEYS INFINIT
             E_KEYS NEVER NEVER NiL SLM_CODE CL_ND_LCK NiL *18YPY9TG43LAGBY400
              NiL NiL NiL 5_MINS <UDI><PID>CISCO2911/K9</PID><SN>FCZ194171VP</
             SN></UDI> pt7EHPRgBfgnl1e5nmigfdSIGOiXseZbfSF,GwAqmifYOC7jURpB4fj
             xpoeG4z:8VtU,8bkn0IWsWx5tsTrONw3xtbsQetFR4M1s:nKcZuhkVjhreGlx7DhL
             aGBbTbHgjV3f$<WLC>AQEBIf8B//+vfMdtnsdFWtYfe+5J3m/tfD5YFqNe06xwtAs
             cojEk+TaJ3uCaR6yxkplHlH7UxKNC4Y8XCC3KoslkXR3C5ImCrm09ybN49VnMtXYx
             u0ne0cAZzbcSbzpdYXV+vxSgDn5xWuPxarI4UkmPUznDwYVyDqnSaMtwOzltnGiUd
             z5Z/0UJBILhxCb5LESSfZnpoq0=</WLC>
    Comment:
       Hash: 3wzLAG6iSo7RUVHE642eXDZdA/g=
  Store Index: 1
    License: 11 uck9 1.0 LONG NORMAL STANDALONE EXCL INFINITE_KEYS INFINITE_KE
             YS NEVER NEVER NiL SLM_CODE CL_ND_LCK NiL *18YPY9TG43LAGBY400 NiL
              NiL NiL 5_MINS <UDI><PID>CISCO2911/K9</PID><SN>FCZ194171VP</SN><
             /UDI> vKWv,m87Qb4Tr3z3AWKgLDOnkHL9f,TMGlVpYAyX:LfQN,GtZw8heljTQDE
             NtWFf3p6OR02pGjxYCvYgQDUgXd3qeMnU3IR2cZF0y:FRfvNV3GRKffybUzyo,,BR
             zxLGhGLr$<WLC>AQEBIf8B//+ghhDv+/7tVb5yT/ihdX4XA2oZuwdSTbOMCImI2oV
             pICZ59Zac+Bc0w/9EdWjj7TUcqpok3/jdF0+9rbvHltmOu0itNhvV+3szTf0pqodm
             dlv//y9q4XR0hBtyYzaJKBBLqYWls/bhq87A7TPcZc0M2ehLOoE/wcnp0bC4fA3fA
             QNajcoGA1AFMWR/2JdMNJE=</WLC>
    Comment:
       Hash: /DrtRr50Bu7IeMynfaLUgJyAq+Y=
License Store: Built-In License Storage
  Store Index: 0
    License: 12 securityk9 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDALON
             E ADD INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL NiL S
             LM_CODE DEMO NiL NiL Ni NiL NiL 5_MINS <UDI><PID>NOTLOCKED</PID><
             SN>NOTLOCKED</SN></UDI><T>RTU</T> o752vzSJKZrdH4u4ZtcK3Bw6ml3WxZh
             u1tBMjO3Ug6Lksw2do3TfGHKyFrX1R8iELHZXXc1gkMK:QJkHnk509:V92eExG7eO
             HJzc0j:KNx37fPfwHgOvy17IlfYznZRK:sLqftl5PrdD0Te8m805D8iy31$<WLC>A
             QEBIf8B///Qi+RhPeDffX673lUKCuNMEDzt9tuuVAOnJSWOWt+YibyFo2qPGfJs9t
             V4fif4QI2RqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21
             MNUjVbhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q3SF/
             5Ko8XCY=</WLC>
    Comment:
       Hash: 2SdvlCANIKgA2eCVZ0Gf288w5iE=
  Store Index: 1
    License: 12 uck9 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDALONE ADD
             INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL NiL SLM_COD
             E DEMO NiL NiL Ni NiL NiL 5_MINS <UDI><PID>NOTLOCKED</PID><SN>NOT
             LOCKED</SN></UDI><T>RTU</T> dFfKnRDXksm4rRhgQ3GC3FUPG:tQGHiPcMTHp
             kpGZpVGInY9oEh7jJyNRzFYGuUGf09ijz4CCou7aoVLyGtMKyLqEPmwOvFqlvP0da
             L7xBdpLG6aAZrO9VW8L4hzymma:Tfzhq6R4dagios1U2TvvGd9LC$<WLC>AQEBIf8
             B///7shQaLj1bjoeqpL2xv1+sbNekW4SYX8pAVrC+Qo8X52PiPBrSJxVOLzCVA5K+
             gjGRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21MNUjVb
             hoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q3SF/5Ko8XC
             Y=</WLC>
    Comment:
       Hash: WeQKMUSioEWjMkctjS0boLWpNT4=
  Store Index: 2
    License: 12 datak9 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDALONE AD
             D INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL NiL SLM_C
             ODE DEMO NiL NiL Ni NiL NiL 5_MINS <UDI><PID>NOTLOCKED</PID><SN>N
             OTLOCKED</SN></UDI><T>RTU</T> nRbEsTOOMHl:ZVeYWhLM3h9H07EgKZ3DaEy
             nEbPSxo351:UZl9AFe,LigmXV4HRsfr8WjQpcF3ERNZKED4gFeUVffxungWvFnxm1
             KVSr6PUSLZteliWF0s3CtK0rqFEMGm3gg9c:iw16ZwGrqDNVLPmTVi$<WLC>AQEBI
             f8B///rbW/aK5VZHZnU1Kp7HiDRqan+uFOVBHo5UvsbCOc8yu24gnlQ94mLbol/BZ
             FAJcKRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21MNUj
             VbhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q3SF/5Ko8
             XCY=</WLC>
    Comment:
       Hash: YYhDTITGzmA0GQrQAhU3aYslL7I=
  Store Index: 3
    License: 12 NtwkEssSuitek9 1.0 LONG TRIAL DISABLED DISABLED DISABLED STAND
             ALONE ADD INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL N
             iL SLM_CODE DEMO NiL NiL Ni NiL NiL 5_MINS <UDI><PID>NOTLOCKED</P
             ID><SN>NOTLOCKED</SN></UDI><T>RTU</T> Ti,g,tDbJ7aAnJVHBUM53eFe6eE
             3DS,YSiQaE9IyGd3SxRtSnppbLdBAXSEkCVuFLHCrfir55m:G9RN0Oq6hbvL0URS8
             cXIhK4f,41z7OlONLYVVOVT89JyUtgiu1cPK6:fh68hjaBy9vK76OYAI:3Nh3a$<W
             LC>AQEBIf8B//9lLSEA4C1Fdrg7OKynOPxSxwPavKc1Ha6vQ6rEWyFFNvW7a6Sc8N
             9tsxg2HXejCmaRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ
             8H21MNUjVbhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q
             3SF/5Ko8XCY=</WLC>
    Comment:
       Hash: 3+VxGIv76TkVHGMCRskrGmK5XZ0=
  Store Index: 4
    License: 12 CollabProSuitek9 1.0 LONG TRIAL DISABLED DISABLED DISABLED STA
             NDALONE ADD INFINITE_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL
              NiL SLM_CODE DEMO NiL NiL Ni NiL NiL 5_MINS <UDI><PID>NOTLOCKED<
             /PID><SN>NOTLOCKED</SN></UDI><T>RTU</T> xN4yaWL7hVFS578,sz1o3cp0t
             g8rHVqkwfW,Tb0qEL3FUvJfq05ilKdxDP:JBnQcVCHbtMshhGsyQQpuby9JgiLrc5
             Eb:Z7iD5vVUstzqrWdfFxcbAoaOTHuycGoAG2IWmL,L0Yn0OGmp3q4K1Ddan4yfa$
             <WLC>AQEBIf8B///EEjFxXObp2ZoE5Afu4FNz3mD9NVmqPGMu1Kiphtp82kCikxtr
             fALPVHCh2NEE5HCRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyE
             vQ8H21MNUjVbhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc
             /q3SF/5Ko8XCY=</WLC>
    Comment:
       Hash: BHmBQN9Vu7Qosp5NitbHPcFMPE4=
  Store Index: 5
    License: 12 ios-ips-update 1.0 LONG TRIAL DISABLED DISABLED DISABLED STAND
             ID><SN>NOTLOCKED</SN></UDI><T>RTU</T> tzDxtBd3ARcHcbsl:bTo3DRp7AI
             M:czMKZe5ixaNnZLScz0vElR92jlsCKNeA5B3LNx8fsnEmFa5E6QG,yxWbBVCv2CN
             LbA7LcgrNvgX2IOo3tfda:TpXJP8yqlxBv910j36DEg5L494kNHZSLiCwnkmVr$<W
             LC>AQEBIf8B//9r/97v+LovAn5aedjof/46XFQVtVTfx0qKoiXr125bCwjL6QCJXN
             e7vPq2IrMxlYaRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ
             3SF/5Ko8XCY=</WLC>
    Comment:
       Hash: 7lCXQ1d2qI0/CrSzyvzp8kEPvvs=
  Store Index: 6
    License: 12 SNASw 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDALONE ADD
             DE DEMO NiL NiL Ni NiL NiL 5_MINS <UDI><PID>NOTLOCKED</PID><SN>NO
             TLOCKED</SN></UDI><T>RTU</T> JysAmcKhWt2NX,2oSl3b3C2l1Ydf69T2sqD8
             xkFFDcVJ3wi8k7xkaeh9kGnRZpfLfHljT5ZEdba6nj50M4ET,OVvYxfh0cPyQvCFH
             fftW4bILeaugEBnzifeoZPkC1v6tQ3MrGJge2nKXjwXiCj07wlbfO$<WLC>AQEBIf
             8B//9CaOsWnM8osCmi89ExWp3/nMOV1yVPvapelNln25KHNQigAuVMpVEeKnYHZcy
             ZXq2RqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21MNUjV
             bhoN0gyIWsyiJaM8AQIkVBQFzhr10GYolVzdzfJfEPQIx6tZ++/Vtc/q3SF/5Ko8X
             CY=</WLC>
    Comment:
       Hash: NLkxiKekd6aCZxjtGzAIQnQ8tOk=
  Store Index: 7
    License: 12 cme-srst 1.0 LONG TRIAL DISABLED DISABLED DISABLED STANDALONE
             ADD 5000_KEYS INFINITE_KEYS 1 JAN 2006 1 JAN 2035 NiL NiL SLM_COD
             LOCKED</SN></UDI><T>RTU</T> WpSgU6PRGwUuaGRHMbC3fD62LMBANgpqM4aJV
             6BzgHVbJcpZ675EYeqjuZYZcv3Yf6iPSJj8CDgRlI2VnTtHEh3PDHp3AwbJhP4ntM
             IK6qxg3weqfHB2IH7tmQkUytslXrVtWGWVu1h0EFzpObhH5cY03K$<WLC>AQEBIf8
             B//9dUmqTnsssF4FqWlhJM/lLCaLk4osA9BAIom2D7SaDMjVts7DbZgMHM89/CwId
             yKmRqwInXo3s+nsLU7rOtdOxoIxYZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21MNUjVb
             Y=</WLC>
    Comment:
       Hash: PbBgLws7MEc4zo2zU6IHYCLHwtk=
------------------ show license file standby ------------------
------------------ show license detail ------------------
Index: 1        Feature: CollabProSuitek9                  Version: 1.0
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Count: Non-Counted
        License Priority: None
        Store Index: 4
        Store Name: Built-In License Storage
Index: 2        Feature: NtwkEssSuitek9                    Version: 1.0
        Store Index: 3
Index: 3        Feature: SNASw                             Version: 1.0
        Store Index: 6
Index: 4        Feature: cme-srst                          Version: 1.0
        License State: Active, In Use
            Evaluation period left: 7  weeks 6  days
            Period used: 4  days 3  hours
            Transition date: Jan 15 2016 14:30:37
        License Count: 1/0  (In-use/Violation)
        License Priority: Low
        Store Index: 7
Index: 5        Feature: datak9                            Version: 1.0
        Store Index: 2
Index: 6        Feature: ios-ips-update                    Version: 1.0
        Store Index: 5
Index: 7        Feature: ipbasek9                          Version: 1.0
        License Type: Permanent
        License Priority: Medium
        Store Index: 0
        Store Name: Primary License Storage
Index: 8        Feature: securityk9                        Version: 1.0
        Store Index: 0
Index: 9        Feature: uck9                              Version: 1.0
        Store Index: 1
Index: 10       Feature: uck9                              Version: 1.0
        License State: Inactive
        Store Index: 1
------------------ show license detail standby ------------------
% Error: No license for standby found - License feature not found
------------------ show license status ------------------
                License Type Supported
        permanent               Non-expiring node locked license
        extension               Expiring node locked license
        evaluation              Expiring non node locked license
        evalRightToUse          Right to use evaluation non node locked license
        rightToUse              Right to use non node locked license
        paid subscription       Expiring node locked subscription license
                                with valid end date
        extension subscription  Expiring node locked subscription license
        evaluation subscription Expiring node locked subscription license
                License Operation Supported
        install    Install license
        clear      Clear license
        annotate   Comment license
        save       Save license
        revoke     Revoke license
        call-home  License call-home
                Call-home Operation Supported
        show pak   Display license pak via call-home
        install    Install license via call-home
        revoke     Revoke license via call-home
        resend     Fetch license via call-home
                Device status
        Device Credential type: DEVICE
        Device Credential Verification: PASS
        Rehost Type: HARDWARE
SWIFT url status
        Swift URL set to default value : https://tools.cisco.com/SWIFT/Licensing
------------------ show license status standby ------------------
------------------ show license statistics ------------------
                Administrative statistics
        Install success count:   0
        Install failure count:   0
        Install duplicate count: 0
        Comment add count:       0
        Comment delete count:    0
        Clear count:             0
        Save count:              0
        Save cred count:         0
                Client statistics
        Request success count:   10
        Request failure count:   0
        Release count:           2
        Global Notify count:     0
------------------ show license statistics standby ------------------
------------------ show buffers ------------------
Buffer elements:
     1367 in free list
     77575 hits, 0 misses, 1242 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 68 @ 09:06:22):
     42 in free list (20 min, 150 max allowed)
     40707 hits, 6 misses, 18 trims, 18 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 57, permanent 25, peak 116 @ 05:17:19):
     45 in free list (10 min, 150 max allowed)
     30420 hits, 337 misses, 94 trims, 126 created
     115 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 51 @ 09:06:36):
     50 in free list (5 min, 150 max allowed)
     4275 hits, 0 misses, 1 trims, 1 created
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 11 @ 09:06:36):
     10 in free list (0 min, 100 max allowed)
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 09:06:56):
     1 in free list (0 min, 10 max allowed)
     0 hits, 0 misses, 3 trims, 4 created
Huge buffers, 18024 bytes (total 5, permanent 0, peak 5 @ 09:06:36):
     5 in free list (4 min, 10 max allowed)
     0 hits, 0 misses, 5 trims, 10 created
Interface buffer pools:
CF Small buffers, 104 bytes (total 101, permanent 100, peak 101 @ 09:06:49):
     101 in free list (100 min, 200 max allowed)
Onboard DSPRM Pool buffers, 264 bytes (total 300, permanent 300):
     0 in free list (0 min, 300 max allowed)
     300 hits, 0 fallbacks
     300 max cache size, 300 in cache
     12302 hits in cache, 0 misses in cache
Generic ED Pool buffers, 512 bytes (total 101, permanent 100, peak 101 @ 09:06:29):
     101 in free list (100 min, 100 max allowed)
     0 hits, 0 misses
CF Middle buffers, 600 bytes (total 101, permanent 100, peak 101 @ 09:06:49):
Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 09:06:29):
     101 in free list (132 min, 132 max allowed)
     2982 hits, 0 misses
CF Big buffers, 1536 bytes (total 26, permanent 25, peak 26 @ 09:06:49):
     26 in free list (25 min, 50 max allowed)
IPC buffers, 4096 bytes (total 2, permanent 2):
     1 in free list (1 min, 8 max allowed)
     1 hits, 0 fallbacks, 0 trims, 0 created
CF VeryBig buffers, 4520 bytes (total 3, permanent 2, peak 3 @ 09:06:49):
     3 in free list (2 min, 4 max allowed)
CF Large buffers, 5024 bytes (total 2, permanent 1, peak 2 @ 09:06:49):
     2 in free list (1 min, 2 max allowed)
IPC Medium buffers, 16384 bytes (total 2, permanent 2):
     2 in free list (1 min, 8 max allowed)
     0 hits, 0 fallbacks, 0 trims, 0 created
IPC Large buffers, 65535 bytes (total 17, permanent 16, peak 17 @ 09:06:51):
     17 in free list (16 min, 16 max allowed)
     0 hits, 0 misses, 546 trims, 547 created
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     512 max cache size, 511 in cache
     12167 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 1664 bytes (total 768, permanent 768):
     512 max cache size, 512 in cache
     0 hits in cache, 0 misses in cache
Normal buffers, 1676 bytes (total 3840, permanent 3840):
     3840 in free list (128 min, 4096 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Private particle pools:
HQF Particle buffers, 0 bytes (total 2000, permanent 2000):
     2000 in free list (500 min, 2000 max allowed)
     33734 hits, 0 misses, 0 trims, 0 created
IDS SM buffers, 240 bytes (total 128, permanent 128):
     0 in free list (0 min, 128 max allowed)
     128 hits, 0 fallbacks
     128 max cache size, 128 in cache
GigabitEthernet0/0 buffers, 1664 bytes (total 1024, permanent 1024):
     0 in free list (0 min, 1024 max allowed)
     1024 hits, 0 fallbacks
     1024 max cache size, 768 in cache
     72011 hits in cache, 0 misses in cache
GigabitEthernet0/1 buffers, 1664 bytes (total 1024, permanent 1024):
     263 hits in cache, 0 misses in cache
GigabitEthernet0/2 buffers, 1664 bytes (total 1024, permanent 1024):
     36948 hits in cache, 0 misses in cache
------------------ show buffers usage ------------------
Statistics for the Small pool
Caller pc    : 0x3197FD44 count:        2
Resource User:       Init count:        2
Caller pc    : 0x303F3C24 count:        6
Resource User:   IP Input count:        6
Input IDB    :      Gi0/0 count:        1
Number of Buffers used by packets generated by system:   44
Number of Buffers used by incoming packets:               6
Statistics for the Middle pool
Output IDB   :      Gi0/0 count:       18
Caller pc    : 0x3276E67C count:       26
Resource User: SSH Proces count:       17
Resource User: SCCP Appli count:        3
Resource User:      TPLUS count:        1
Caller pc    : 0x303F3C24 count:        1
Resource User:   IP Input count:        1
Resource User: CCSIP_TCP_ count:        5
Number of Buffers used by packets generated by system:   56
Number of Buffers used by incoming packets:               1
Statistics for the Big pool
Number of Buffers used by packets generated by system:   50
Number of Buffers used by incoming packets:               0
Statistics for the VeryBig pool
Number of Buffers used by packets generated by system:   10
Statistics for the Large pool
Statistics for the Huge pool
Statistics for the CF Small pool
Number of Buffers used by packets generated by system:  101
Statistics for the Onboard DSPRM Pool pool
Number of Buffers used by packets generated by system:  300
Statistics for the Generic ED Pool pool
Statistics for the CF Middle pool
Statistics for the Syslog ED Pool pool
Caller pc    : 0x3204DAB8 count:       32
Resource User: EEM ED Sys count:       32
Number of Buffers used by packets generated by system:  133
Statistics for the CF Big pool
Number of Buffers used by packets generated by system:   26
Statistics for the IPC pool
Caller pc    : 0x305EB320 count:        1
Resource User:       Init count:        1
Statistics for the CF VeryBig pool
Statistics for the CF Large pool
Statistics for the IPC Medium pool
Statistics for the IPC Large pool
Number of Buffers used by packets generated by system:   17
Statistics for the Header pool
Caller pc    : 0x354F7198 count:        1
Number of Buffers used by packets generated by system:  768
Statistics for the FS Header pool
Caller pc    : 0x30442AF4 count:        4
Resource User:       Init count:       19
Caller pc    : 0x354F6B64 count:        1
Caller pc    : 0x331BCCE4 count:        1
Caller pc    : 0x331BCD18 count:        1
Caller pc    : 0x305342A8 count:        1
Caller pc    : 0x31F9C6D0 count:        1
Caller pc    : 0x31F9C718 count:        1
Caller pc    : 0x31F9C73C count:        1
Caller pc    : 0x31F9C788 count:        1
Caller pc    : 0x31F9C7AC count:        1
Caller pc    : 0x321B8A7C count:        1
Caller pc    : 0x32460080 count:        1
Resource User: MFIB_mrib_ count:        3
Caller pc    : 0x3246017C count:        1
Caller pc    : 0x30F0C9B8 count:        1
Caller pc    : 0x331BFA2C count:        1
Caller pc    : 0x31F9C6F4 count:        1
Caller pc    : 0x31F9C764 count:        1
Caller pc    : 0x31F9C7D0 count:        1
Caller pc    : 0x324600FC count:        1
Number of Buffers used by packets generated by system:   38
Statistics for the SW Crypto Header pool
Caller pc    : 0x33F10110 count:        1
------------------ show inventory ------------------
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FCZ194171VP, Hw Revision: 1.0"
PID: CISCO2911/K9      , VID: V07 , SN: FCZ194171VP
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC19360ZZZ
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V05 , SN: ART1912F0KJ
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
 0x0D800000  0x0FFFFFFF    41943040  Iomem  R/W    iomem
 0x20000000  0x20FFFFFF    16777216  IText  R/O    rommon_text
 0x21000000  0x2D7FFFFF   209715200  Local  R/W    Main_memory_1
 0x30000000  0x3FFFFFFF   268435456  Local  R/W    main
 0x3000F2F8  0x3724156B   119743092  IText  R/O    main:text
 0x37250A00  0x3C83561F    90065952  IData  R/W    main:data
 0x39F57A64  0x3B6A59FF    24436636  Local  R/W    data:heap
 0x3C835620  0x3D56889F    13841024  IBss   R/W    main:bss
 0x3D5688A0  0x3FFFFFFF    44660576  Local  R/W    main:heap
 0x80000000  0x8D7FFFFF   226492416  Local  R/W    main_k0
 0xA0000000  0xAD7FFFFF   226492416  Local  R/W    main_k1
Free Region Manager:
------------------ Mempool statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   3D5688A0   278812412    93486928   185325484    43652212   151438616
      I/O    D800000    41943040    18566272    23376768    23324176    23226364
-------------- Top 100 allocator pc summary -----------
Allocator PC Summary for: Processor
Displayed first 2048 Allocator PCs only
    PC          Total   Count  Name
0x3369F704    5758384      28  STILE PERIODIC TASK
0x3016EF40    4345968     132  CCE dp subblock
0x30EDE9D4    4252828     439  Interrupt Stack
0x33B26964    3649500      51  XOS_MEM_BASE
0x30742634    2138908    1697  *Packet Header*
0x33562CA4    1794440      51  Init
0x359F6BA0    1768448     256  CCSIP_SPI_CONTROL
0x336D3280    1545876      46  CFT Data Path F
0x30742684    1514128     486  *Packet Data*
0x353EFE94    1310400     600  SSH Process
0x30031480    1136748      26  pak subblock chunk
0x31B065B0    1010640     119  SSH Process
0x300145FC     992560     124  TW Buckets
0x336D32E0     991144      28  CFT Data Path I
0x3588A840     955444       1  CCH323_CT
0x35D62E68     841564       2  CCSIP CCB Pool Chunk
0x31AE7608     829512       9  event_trace_tbs
0x33701AD4     811148     279  TCL Chunks
0x35F941A0     786344       2  CCH323_CT
0x320F55B4     752760    7515  Init
0x3158FCF8     684000    9000  *Init*
0x336785C0     671092       5  stile_activate_process
0x338BD9AC     640156       2  event
0x320F55D4     627412    7251  Init
0x320F55C8     591972    7515  Init
0x3360C424     535536      16  platform_dp Mem
0x336C9D9C     482936       1  Init
0x30039F10     477184     176  Normal
0x3158FCE8     443688      12  Redundancy Even
0x35260998     418684    2900  Init
0x3308CE98     384156       2  ccecp
0x33092A14     384156       2  ppcp
0x330C8270     384156       2  ppm
0x36FC1290     375848     200  Init
0x30068678     365332     437  Process
0x335F0A94     353908     827  Init
0x31026F98     352412       2  rg_infra
0x306E94C4     335904       8  Init
0x3058D890     327940       5  IPC Message Hea
0x3005EE1C     316776      67  List Headers
0x3635CA44     307948      23  Init
0x30039E5C     307076      21  Normal
0x332740A4     286444    1192  *Init*
0x3360C100     285088      10  platform_dp Memory Chunk
0x37226FD0     266072      11  BITLIST CHUNK
0x31E75A74     262248       2  CEF: hash table
0x31BC1968     262196       1  Init
0x3672BE90     262196       1  VOICE HA DB aux elems pool
0x303FAD84     262196       1  Init
0x336A02F4     241384     422  STILE PERIODIC TASK
0x337D19B8     240156       2  tunnel
0x30099808     232132      23  RMI RO-RU Chunk
0x336B2104     231504       1  Init
0x30063194     224668      43  Watched Queue
0x31AA7D3C     205460       1  Init
0x31AA7D28     205460       1  Init
0x30448178     199312       4  Init
0x31D2383C     197324       6  DSensor 256
0x30EDABA8     196764       3  CPU RO RU Chunk
0x325C5B68     192104       2  Simple Trace
0x35EA5E58     170356       3  DSMP
0x355CFF44     160220       2  DSPRM msg chunk
0x33701A68     155924      30  TclCreateExecEnv
0x3722E67C     151908     441  TCP Protocols
0x33E9A4C0     149608    1948  Init
0x3056BEC0     147000      70  Init
0x3530B134     146560      32  SSH Process
0x30F4B6A4     140156       2  nvram
0x315B4D30     140156       2  checkpoint
0x315DA924     140156       2  redundancy
0x31ED3B84     135360       4  OCE reinject ha
0x300998B0     133600     871  Init
0x32F957D4     132160       4  CCE dp class gr
0x30055B74     131176       2  Memory RO User
0x33193C9C     131176       2  blt array
0x30475F54     131176       2  USB Startup
0x33611A7C     131156       1  STILE PERIODIC TASK
0x36566C68     131124       1  Init
0x30734034     131124       1  *Init*
0x36265904     131120       1  SCCP Application
0x36265928     131116       1  SCCP Application
0x31FD2EA8     128016      28  EEM Server
0x31FD2B00     128016      28  EEM Server
0x31FD2AF0     128016      28  EEM Server
0x31AFDDFC     127384    1503  Parser Linkage
0x365020E0     122932       1  VOIP_FMD_MAIN
0x305E9B6C     121064     189  IPC Thread
0x31A603F0     116308       4  AAA Large Chunk
0x320E9FEC     115788    1104  Init
0x36224A84     115764       1  QOS_MODULE_MAIN
0x3014F984     114000    1500  MDB Lookup List
0x320E3DA0     113128     749  Init
0x32E3BAE4     112156       2  nhrp_error
0x300634F8     106624     443  Process Events
0x3005E428     100520      10  List Elements
0x360273B4     100052       1  ivr: CallSetup
0x31AD1980      99372      21  TTY data
0x33273664      92680      45  Reg Function 12
0x341187F4      92052       1  epm database
0x32135130      88156       2  fnf_mon
Allocator PC Summary for: I/O
    PC          Total   Count  Name
0x30039F24    8672000     140  Normal
0x30039E5C    7385728       5  IDS SM
0x30430E44     786560       1  Gather List Buffer Pool
0x30430B58     524416       1  WQE Buffer Pool
0x30430BA4     524416       1  CF DMA pool
0x30742684     466304     475  *Packet Data*
0x30430CE0      65664       1  Command Buffer Pool
0x30020238      41984       1  *Init*
0x306E957C      33792       8  HDLC32_TX
0x306E95E0      33792       8  HDLC32_RX
0x3042CA8C      24960       3  *Init*
0x30F35974       4096      32  USB Startup
0x3042CACC        384       3  *Init*
0x3042CAE8        384       3  *Init*
0x30513F54        128       1  Init
------------------ show dmvpn detail ------------------
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
        N - NATed, L - Local, X - No Socket
        T1 - Route Installed, T2 - Nexthop-override
        C - CTS Capable
        # Ent --> Number of NHRP entries with same NBMA peer
        NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
        UpDn Time --> Up or Down Time for a Tunnel
Is the MTP is checked on SIP trunk?
Br, Nadeem Please rate all useful post.
yup, it's checked
If MTP is involved, CUCM keeps the media leg between MTP and CUBE from beginning to end; when necessary, (ie when there is media break in the even of putting a call on hold) it just updates another leg of MTP between MTP and the IP Phone.
This is why you dont see a re-INVITE. If there is no MTP involved, then you will definitely see a re-INVITE
Please rate all useful posts
it looks like this is the case, thanks
Manish Gogna
I don't have access to a cucm right now but I believe there is a parameter on SIP profile which decides whether to send reinvites for these mid call features. If you check the profile settings it is probably disabled.
Manish
- Do rate helpful posts -
