Missing TFTP Server IP Address on IP Phone
Richard Dumag
I was doing a firmware upgrade on several test phones when I discovered one of the phones that did not upgrade does not have a TFTP Server 1 IP address.
I tried to assign it on the phone itself but I'm unable to.  When I click edit it says "the key is not active".
I've tried resetting the phone several times but to no avail.  I'm about to remove/re-add the phone from CM but thought I'd ask you experts first if there's a fix other than removing/re-adding the phone in CM.
Thank you!
7941
DHCP Server10.88.24.12
BOOTP ServerNo
MAC Address001BD584A3C4
Host NameSEP001BD584A3C4
Domain Nameinsurance.ca.gov
IP Address10.88.6.101
Subnet Mask255.255.255.128
TFTP Server 1
Default Router 110.88.6.1
Default Router 2
Default Router 3
Default Router 4
Default Router 5
DNS Server 110.88.24.12
DNS Server 210.88.24.13
DNS Server 310.88.24.11
Are TFTP options configured on your DHCP server?
Use option 150 and 66.
Regards.
Yes, DHCP is setup with couple of TFTP servers.
I just discovered that this phone is not in the voice vlan.  I went ahead and changed the vlan settings and voila!!
Thanks for the response!
Good thing you found it before having a user complain of a really bad quality call because of no QOS lol
