12-06-2010 11:42 AM - edited 03-16-2019 02:17 AM
On other discussions has appeared a case of Yellowcode alarm on CCM cluster, and related to a gateway generating multiple calls. I have that issue, and solved it using max-conn to limit the quantity of connections to the CCMs, but I found that the dial-peer matching the issue is announcing that the max-conn is exceeded, but with no call present using it.
A sample:
R3825ToescaP2#sh voice call stat
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x596184 2C1C 0x70BCE668 0/3/0:15.7 0/1:4 6015 g711ulaw 200/611
0x59618B 2C1E 0x70BCE668 0/3/0:15.8 0/1:2 6519 g729r8 200/650
0x596198 2C22 0x70BCE668 0/3/0:15.15 0/2:1 6090 g711ulaw 200/611
0x5961A2 2C27 0x70BCE668 0/3/0:15.12 0/1:5 6134 None 200/612
0x5961A6 2C29 0x70BCE668 0/3/0:15.11 0/1:1 6034 None 200/611
0x5961A8 2C2A 0x70BCE668 0/3/0:15.24 0/1:3 6173 None 200/612
6 active calls found
*Dec 6 18:47:50.100: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 610
So no active call is matching DP 610, but the warning for maximum number of connections is present.
This is the config:
dial-peer voice 610 voip
tone ringback alert-no-PI
preference 1
max-conn 60
destination-pattern 60[012346789].
progress_ind setup enable 1
voice-class codec 10
voice-class h323 1
session target ipv4:172.30.1.2
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 611 voip
preference 2
max-conn 60
session target ipv4:172.30.3.2
no vad
Any idea of what could be happening on this situation?
TIA
Andres Pasten
Adexus S.A.
12-06-2010 12:04 PM
"normal" kind of IOS bug, update image and hope it won;t happen again.
12-06-2010 01:15 PM
ok, it have c3825-spservicesk9-mz.124-9.T7.bin, it's the last of that version, so I´ll try with c3825-spservicesk9-mz.124-15.T14.bin, and let you know...
TIA
Andres Pasten
Adexus S.A.
12-15-2010 01:29 PM
I´ve made the upgrade of the IOS, but the messages announcing the max-conn exceeded are still present. The CPU is controlled anyway.
Dec 15 18:17:33.758: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 619
Dec 15 18:17:33.790: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 619
Dec 15 18:17:33.790: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 611
The E1 controllers are ok.
It seems that the upgrade of IOS solved the issue about teh CPU, but I'm worried about the origin of this multiple connections that are present on this gateway.
Any idea?
Andres Pasten Calzada
ADEXUS S.A.
