12-15-2010 11:39 AM - edited 03-16-2019 02:27 AM
I was doing a firmware upgrade on several test phones when I discovered one of the phones that did not upgrade does not have a TFTP Server 1 IP address.
I tried to assign it on the phone itself but I'm unable to. When I click edit it says "the key is not active".
I've tried resetting the phone several times but to no avail. I'm about to remove/re-add the phone from CM but thought I'd ask you experts first if there's a fix other than removing/re-adding the phone in CM.
Thank you!
7941
DHCP Server | 10.88.24.12 | |
BOOTP Server | No | |
MAC Address | 001BD584A3C4 | |
Host Name | SEP001BD584A3C4 | |
Domain Name | insurance.ca.gov | |
IP Address | 10.88.6.101 | |
Subnet Mask | 255.255.255.128 | |
TFTP Server 1 | ||
Default Router 1 | 10.88.6.1 | |
Default Router 2 | ||
Default Router 3 | ||
Default Router 4 | ||
Default Router 5 | ||
DNS Server 1 | 10.88.24.12 | |
DNS Server 2 | 10.88.24.13 | |
DNS Server 3 | 10.88.24.11 |
12-15-2010 11:53 AM
Are TFTP options configured on your DHCP server?
Use option 150 and 66.
Regards.
12-15-2010 01:01 PM
Yes, DHCP is setup with couple of TFTP servers.
I just discovered that this phone is not in the voice vlan. I went ahead and changed the vlan settings and voila!!
Thanks for the response!
12-15-2010 01:11 PM
Good thing you found it before having a user complain of a really bad quality call because of no QOS lol
