Missing webapps folder in UCCX
bhavnakraman
Hi All,
Webapps folder is missing in this path C:\ProgramFiles\wfavvid\tomcat_appadmin\ and I am not able to login to the appadmin webpage.
Please suggest what needs to be done.
UCCX version is 7
Bhavna
I think you need to login to appadmin page
so you can let it as fresh install with the following steps
on the server through cmd prompt - type in CET - bring up the object editor - select "com.cisco.crs.cluster.config.AppadminSetupConfig - in right hand side select the row go to second tab and change the "setup state" to "FRESH_INSTALL" from drop down menu.
Login into Appadmin with the user "Administrator" "ciscocisco"
Haitham
20 Replies 20
Haitham
bhavnakraman
Hi Haitham,
Many thanks for your response.  I wouldn't be able to do a fresh install as the system is live. Is there any other way I can get around this?
Bhavna
Hi Bhavna,
No, you won't install it again
Only after this step, when you open the appadmin page
You will login with Administrator - ciscocisco and will be asked to choose the new admin user
I think it won't affect your call center operation but you can do it at lower load calls
Haitham
Thanks for your quick reply.
Also I am not able to login through the phone I suspect its because the appadmin web page is not opening. Once this process is done, can you let me know will this resolve even the issue of phone login?
are you using IPPA ?
Yes. At present, the agents are logged in through the agent desktop and answering calls. But they at times login through their phones as well, which they are now not able to do so. Also the surpervisor is not able to extract reports.
Sorry, we are not using IPPA. the users hit the services key and then login to the contact center with userid and password
The IPPA enable agent to receive calls by login to phone
Also they can see their calls in queue
IF CAD is working , then there may be an issue with the service from the cucm side
Also please check in the control center if it is in service or partial service
you can do jtapi resynch and data resynch that could help in solving some issues
Haitham
Can you please provide me with the procedure on how to do a jtapi and data resyn. In control center all the services show as started.
I can't login to the appadmin page in UCCX and also the agents can't login from their phone.
I don't have the backup for UCCX
So please do the reset password action I told you above
then you will be able to follow your troubleshooting steps
Haitham
* plz rate helpful posts
Thanks. Got the issue resolved.
Now we have another issue, when we try to login to the historical reports we get an error.
Login Error An error occurred while attempting to communicate with web server. Check your userid and password and try again.
Please suggest.
Hi Bhavna,
Did you assign reporting capabilities to this user
Check on Tools > user management
check for this user capabilities
Haitham
Yes everything was working yesterday and there are no issues with the proxy or firewall as I am able to access the appadmin page
