Both these fields are used to enable SNR(single number reach) feature; by enabling this feature you can receive calls on deskphone and mobile phone(remote destination) as well so you don't miss any incoming call & you can toggle calls between Deskphone and remote destination., these are not meant for MVA.
Mobile Phone
Check the check box if you want calls that the desk phone answers to be sent to your mobile phone as the remote destination.
Checking this check box ensures that, if Send Call to Mobile Phone is specified (by using the Mobility softkey for remote destination pickup), the call gets extended to this remote destination.
Note This check box does not apply to dual-mode phones that are running SIP, such as DoCoMo N902iL and DoCoMo N906i, nor to dual-mode phones that are running SCCP, such as Nokia S60.
Enable Mobile Connect
Check the check box to allow an incoming call to ring your desk phone and remote destination at the same time.
Suresh
Learn, share, save
