Cisco Router 28XX working as a CME ,licenses migration
sabir.bedi1
Team ,
Customer has a CME working on 28xx router .They want to move to CUCM now
Please clarify if licenses can be migrated ?
I have licenses snapshot as per below ,Also please clarify if 28XX uses any licenses for getting phones registered in CME mode (i.e user based)or it comes with device and dies with device
Index 1 Feature: ipbasek9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: securityk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: uck9
Index 4 Feature: datak9
Index 5 Feature: NtwkEssSuitek9
Index 6 Feature: CollabProSuitek9
Index 7 Feature: LI
Index 8 Feature: ios-ips-update
Index 9 Feature: SNASw
Index 10 Feature: hseck9
Index 11 Feature: cme-srst
License Type: RightToUse
License Count: 265/0 (In-use/Violation)
License Priority: Low
Index 12 Feature: mgmt-plug-and-play
Index 13 Feature: mgmt-lifecycle
Index 14 Feature: mgmt-assurance
Index 15 Feature: mgmt-onplus
Index 16 Feature: mgmt-compliance
Suresh Hudda
Edit...earlier it was possible to convert cme license to DLU, but in for latest cucm version not sure.
https://supportforums.cisco.com/discussion/12499661/can-we-upgrade-cme-license-cucm-license
Suresh
Hi Suresh ,
can you explain why they cant be migrated
for 29xx they can be migrated using the upgrade part codes worth 50$ each
But i need justification for licenses of 28xx ,i have given snapshot also above for licenses presently in cme
Jaime Valencia
You want to reach out to your SE and see if he can assist with this.
If you're a partner, you can try pre-sales and they'll let you know if there's a PN for such migration.
java
if this helps, please rate
