Mobility Feature & Transfer Call
Gordon Ross
Level 9
Level 9
I'm playing around with the mobility feature of CUCM (I'm on 8.6.2)
I can use the *81 & *83 codes to hold and resume a call. But how does the transfer *84 work ? I can't find any docs on how a user uses the mobility feature; Only docs on how a sysadmin sets it up in CCMAdmin !
Ta,
GTG
Please rate all helpful posts.
yahsiel2004
Level 7
Level 7
Did you configure the Service Parameters?
Midcall Enterprise Feature Access Support Using  DTMF—You can configure DTMF feature codes as service parameters:  enterprise hold (default equals *81), enterprise exclusive hold (default  equals *82), resume (default equals *83), transfer (default equal *84),  and conference (default equals *85).
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsmobmgr.html
You should be able to just dial *84 and type the number you want to transfer the call to.
Yosh
HTH Regards, Yosh
Yes...
As I said, *81 (Hold) and *83 (Resume) work. I can't get *84 (Transfer) to work.
GTG
What happens when you dial *84? Do you get a second dial tone or a fast busy etc
Yosh
HTH Regards, Yosh
