01-23-2012 09:15 PM - edited 03-16-2019 09:10 AM
IP phones registered to CME are assigned 1XX ephon-dn's. There are four 3 digit PSTN numbers that start with 1 (1XX).
Users call PSTN with 9 prefix (91XX) and after translation 91XX transformed to 1XX and internal number is called instead of
PSTN number. Is there any workaround for this issue except changing internal numbers?
01-24-2012 02:25 AM
Can you post the config of the CME
Show runn
Rehards
Alex
01-24-2012 08:18 AM
Hi Alex,
Here is the part of the config regarding the issue, ephone-dn's 101-104 and dial-peer 11 overlap.
voice translation-rule 1
rule 1 /.../ /3129556/
voice translation-rule 10
rule 1 /^92/ /2/
rule 2 /^93/ /3/
rule 10 /^98/ /8/
rule 11 /^91/ /1/
voice translation-profile SIP_OUT
translate calling 1
translate called 10
dial-peer voice 10 voip
translation-profile outgoing SIP_OUT
destination-pattern 9[2-3]......
session protocol sipv2
session target ipv4:10.1.1.10
session transport udp
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 11 voip
destination-pattern 910.
dtmf-relay rtp-nte
codec g711alaw
no vad
ephone-dn 101 dual-line
number 101 no-reg both
ephone-dn 102 dual-line
number 102 no-reg both
ephone-dn 104 dual-line
number 104 no-reg both
01-24-2012 08:42 AM
Is your PSTN connection a SIP trunk?
Can you post your configuration for telephony-service?
Chris
01-24-2012 09:09 AM
Since it is overlapping dial-peer 11 and ephone-dn, you might have to configure 'dial-peer hunt' with the longest match.
Try with following global command:
dial-peer hunt 2
dial-peer 11 voice voip
preference 1
