07-31-2013 04:09 AM - edited 03-16-2019 06:38 PM
HII all,
I Have set up mobility profiles for metting rooms, and are workign fine the problem is I do not have an option to logout of the profile once signed in I am using Cisco IP Phone 7940 series.
I must be missing a setting somewhere can somebody point me in the right direction? I am using call manager version 7
Thanks in advance.
Martin
Solved! Go to Solution.
07-31-2013 04:29 AM
go to the User Device Profile page and assign the EM phone service to the user- top right of page - drop down menu
the fact you can log in means the end user page configuration is correct so it is just the UDP missing the EM phone service
07-31-2013 04:23 AM
It sounds like you need to assign a EM service to the UDP profile as well so they can use the service to log out
07-31-2013 04:25 AM
Thank you for your reply and sorry to be thick, but I havetn been using Call manager long(couple of days) could you break that down a bit for me.
07-31-2013 04:29 AM
07-31-2013 04:34 AM
Thank you very much, you have just made my day alot easier.
Thanks.
