Modify SIP "From"header / sip profile
startx001
Little help?
How to config to modify sip "from" header on router 2900 with sip profile?
The Voice gateway is sending the “FROM” header in the follow format: 850735200@10.10.10.10 this needs to be: 850735200@test.it.com.  So the “FROM” header needs to be transformed.
Below needs to be removed from the “From header”
*Remote-Party-ID
*Cisco-GUID
VZ
Denis
try to apply the following sip profile to the outgoing dial-peer:
voice class sip-profiles 1
request ANY sip-header From modify "10.10.10.10" "test.it.com"
request ANY sip-header Remote-Party-ID remove
request ANY sip-header Cisco-Guid remove
George Sotiropoulos
You may also find some info on the following:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-border-element/118825-technote-sip-00.html
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
