More than 1000 users - Distributed call processing model - BE6k bundles
Hi all!
I made distributed call processing model with BE6k bundles.
5 sites = 750+450+2x180+90 =1650 users.
399 VM = 180+108+2x43+25.
Will it fit at all?
P.S. 5 CUCM and 5 CUC clusters being on UCSs clusters BE6K-STBDL-PLS-K9= with VCenter +vSphere Ent plus.
KR
Andriy
15 Replies 15
If you want to control the GW via SIP you build SIP trunk under trunks in CUCM, if you want to control it via H323 or MGCP you build it under Gateways.  SCCP would onyl be used to control analog gateways/ports.
HTH,
Chris
