More than 5 LDAP directories
billmatthews
We're running CUCM version: 8.5.1.11900-21.  I know there's a limit of 5 "LDAP Directories".  We really only have one Active Directory environment, but I have 5 specific OUs defined.  For example:
OU=Departments,DC=mycompany,DC=com
OU=FieldSites,DC=mycompany,DC=com
And now I need to add a sixth.  Is there anyway to structure my LDAP User Search Base to include multiple OUs, without necessarily restructuring AD?
2 Accepted Solutions
Chris Deren
Simply replace the directory integration to point to higher hierarchy, i.e. DC=mycompany,DC=com
HTH,
Chris
And configure the user you're using to bind LDAP and CUCM to have READ privileges, only over the OUs you want to sync.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Chris Deren
HTH,
Chris
java
java
Great tips, thank you both
