06-22-2011 01:19 AM - edited 03-16-2019 05:34 AM
Hello All,
Can anyone tell me if Multicast MoH is supported over a SIP Trunk from CUCM 7.1 --> 2911 gateway (Cube IOS 15.0) --> ISP SIP proxy.
At the moment we can get unicast MoH via the SIP Trunk.
If we set the SIP Trunk to look at a Multicast MoH source we just get tone on hold.
(Note we have multicast MoH working to other h323 and mgcp gateways on our network)
I have run a ‘debug ccm music-on-hold’ and can’t see the gateway try to join the multicast stream?
Looking around forums I see some people say it’s supported and some say not.
Any help would be more than welcome.
Cheers
06-22-2011 10:00 AM
Adam,
At this time SIP MMOH is not supported on CUCM 7.1.3 and I can't find any docs saying that its supported on 8.X either. I think I remember hearing that it was going to be supported on CUCM 8.5, but just can't find it at this time.
Ryan
06-22-2011 06:15 PM
I have it working on 8.0(2) and 8.5(1) clusters. Do you have the "ccm-manager music-on-hold bind Loopback0" command on the router? You still need this with SIP trunks to support it.
06-22-2011 06:25 PM
Hi Jonathan,
Are you talking in the context of of the Gateway playing MMoH locally from flash or recieving the stream from CUCM ?
If its from CUCM what version of IOS are you running on your router.
Cheers
Adam
06-22-2011 06:35 PM
From CUCM.
15.1(2)T and 15.1(4)M for CUCM 8.0(2) and 8.5(1) respectively.
I am almost positive that I have a 7.1(3) customer running 12.4(24)T where this works with SIP dial-peers; however, I don't have remote access to that environment so I can't speak definitively.
You may want to run a 'debug ccsip messages' and see if CUCM sends a multicast address in the SDP when going on hold. The SDP portion of the re-INVITE should look something like this. Notice the multicast address.
Content-Type: application/sdp
Content-Length: 167
v=0
o=CiscoSystemsCCM-SIP 2000 4 IN IP4 10.101.12.3
s=SIP Call
c=IN IP4 239.101.12.5
t=0 0
m=audio 16384 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
a=recvonly
Also don't forget to see the router actually running multicast routing!
06-22-2011 07:58 PM
Hi Jonathan,
I don't see CUCM send the multicast address, is there something I've missed in CUCM config ?
v=0
o=CiscoSystemsSIP-GW-UserAgent 5724 9261 IN IP4 192.168.248.6
s=SIP Call
c=IN IP4 192.168.248.6
t=0 0
m=audio 16948 RTP/AVP 8 101
a=sendrecv
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20 v=0
Cheers
Adam
06-22-2011 08:01 PM
Well as long as the SIP Trunk has a multicast-enable MOH resource assigned to it I would think that you're good to go.
The only other thought I have at 10PM is to ensure you are not calling a Remote Destination number when doing this testing. At least in 8.0 I am seeing that CUCM always chooses unicast MOH if the off-net number is matched in the remote destination table. I haven't decided if this is a bug or some obscure [read: dumb] WAD behavior.
06-22-2011 09:54 PM
Hi Jonathan,
Yep our SIP Trunk is only for off net.
Your help is appreciate.
Cheers
Adam
06-23-2011 01:01 AM
